#include <ossimImageSource.h>
| virtual ossim_uint32 | getNumberOfInputBands () const =0 |
| virtual void | initialize ()=0 |
| virtual | ~ossimSource () |
| virtual bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const =0 |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Definition at line 23 of file ossimImageSource.h.
| ossimImageSource::ossimImageSource | ( | ossimObject * | owner = 0 | ) |
| ossimImageSource::ossimImageSource | ( | ossimObject * | owner, |
| ossim_uint32 | inputListSize, | ||
| ossim_uint32 | outputListSize, | ||
| bool | inputListIsFixedFlag = true, |
| bool | outputListIsFixedFlag = true |
Definition at line 25 of file ossimImageSource.cpp.
Definition at line 36 of file ossimImageSource.cpp.
protected |
Definition at line 370 of file ossimImageSource.cpp.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Reimplemented in ossimImageHandler, ossimMapCompositionSource, ossimImageChain, ossimImageSourceSequencer, ossimEsriShapeFileFilter, ossimMeanMedianFilter, ossimTopographicCorrectionFilter, ossimElevImageSource, ossimRLevelFilter, ossimSubImageTileSource, ossimGdalOgrVectorAnnotation, ossimAnnotationSource, ossimImageRenderer, ossimScaleFilter, ossimMemoryImageSource, ossimPolyCutter, ossimRectangleCutFilter, ossimImageCombiner, ossimFusionCombiner, ossimOrthoImageMosaic, and ossimTrimFilter.
Definition at line 160 of file ossimImageSource.cpp.
References getBoundingRect(), ossimConnectableObject::getInput(), ossimIrect::makeNan(), and PTR_CAST.
Referenced by ossimScaleFilter::allocate(), ossimWatermarkFilter::allocate(), ossimBrightnessMatch::computeInputBrightness(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), ossimElevRemapper::elevRemap(), ossimCacheTileSource::fillTile(), ossimNullPixelFlip::flipPixels(), ossimFusionCombiner::getBoundingRect(), ossimPolyCutter::getBoundingRect(), ossimMemoryImageSource::getBoundingRect(), ossimScaleFilter::getBoundingRect(), ossimAnnotationSource::getBoundingRect(), ossimSubImageTileSource::getBoundingRect(), ossimImageRenderer::getBoundingRect(), ossimRLevelFilter::getBoundingRect(), ossimTopographicCorrectionFilter::getBoundingRect(), ossimMeanMedianFilter::getBoundingRect(), ossimEsriShapeFileFilter::getBoundingRect(), ossimImageSourceSequencer::getBoundingRect(), getBoundingRect(), ossimCacheTileSource::getCacheId(), ossimIgenGenerator::getInputBoundingRect(), ossimTiledImagePatch::getTile(), ossimImageRenderer::getTileAtResLevel(), getValidImageVertices(), ossimMapCompositionSource::getViewingRect(), ossimImageToPlaneNormalFilter::initialize(), ossimIntensityAdjustmentFilter::initialize(), ossimImageSourceSequencer::initialize(), ossimWatermarkFilter::initialize(), ossimAtCorrGridRemapper::initialize(), ossimPixelFlipper::initialize(), ossimImageRenderer::initializeBoundingRects(), ossimImageCombiner::precomputeBounds(), ossimIgenGenerator::setInput(), ossimRectangleCutFilter::setRectangle(), and ossimFgdcFileWriter::writeFile().
Gets the bounding rectangle of the source.
This default implementation calls the getBoundingRect interface that returns a rectangle. Derived classes should override as needed.
| rect | Initialized with bounding rectangle by this. |
| resLevel | Reduced resolution level if applicable. |
Reimplemented in ossimImageRenderer.
Definition at line 172 of file ossimImageSource.cpp.
References getBoundingRect().
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Reimplemented in ossimImageHandler, ossimGdalTileSource, ossimImageChain, ossimKakaduJ2kReader, ossimMrSidReader, ossimImageSourceSequencer, ossimElevImageSource, ossimImageRenderer, ossimTopographicCorrectionFilter, ossimMemoryImageSource, ossimVideoImageSource, ossimScaleFilter, and ossimRLevelFilter.
Definition at line 88 of file ossimImageSource.cpp.
References getDecimationFactor(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimImageRenderer::fillTile(), ossimPolyCutter::getBoundingRect(), ossimSubImageTileSource::getBoundingRect(), ossimMapCompositionSource::getBoundingRect(), ossimRLevelFilter::getDecimationFactor(), getDecimationFactor(), ossimTopographicCorrectionFilter::getDecimationFactor(), ossimImageRenderer::getDecimationFactor(), ossimImageSourceSequencer::getDecimationFactor(), ossimImageToPlaneNormalFilter::getTile(), ossimPolyCutter::getTile(), and ossimSubImageTileSource::getTile().
Will return an array of all decimations for each resolution level.
Reimplemented in ossimMemoryImageSource, and ossimVideoImageSource.
Definition at line 99 of file ossimImageSource.cpp.
References getDecimationFactors(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimImageHistogramSource::computeNormalModeHistogram(), ossimTopographicCorrectionFilter::getDecimationFactors(), getDecimationFactors(), ossimImageRenderer::getDecimationFactors(), ossimImageSourceSequencer::getDecimationFactors(), and ossimRectangleCutFilter::initialize().
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimGpkgReader, ossimPngReader, ossimImageCacheBase, ossimKakaduJp2Reader, ossimRpfCacheTileSource, ossimLasReader, ossimImageChain, ossimH5ImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimPointCloudImageHandler, ossimMG4LidarReader, ossimJpegTileSource, ossimOpjJp2Reader, ossimHdfReader, ossimGeneralRasterTileSource, ossimUsgsDemTileSource, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimKmlSuperOverlayReader, ossimDtedTileSource, ossimGdalTileSource, ossimEsriShapeFileFilter, ossimVpfTileSource, ossimRangeDomeTileSource, ossimBitMaskTileSource, ossimImageRenderer, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimplugins::ossimRadarSat2TiffReader, ossimMemoryImageSource, ossimKakaduJpipHandler, ossimVideoImageHandler, ossimLandsatTileSource, ossimScaleFilter, ossimVideoImageSource, ossimGeoAnnotationSource, ossimEnviTileSource, ossimERSTileSource, ossimRLevelFilter, ossimPointCloudUtilityFilter, ossimSrtmTileSource, ossimQbTileFilesHandler, ossimDoqqTileSource, ossimQuickbirdTiffTileSource, ossimOrthoImageMosaic, ossimViirsHandler, ossimViirsHandler, and ossimQuickbirdNitfTileSource.
Definition at line 262 of file ossimImageSource.cpp.
References getImageGeometry(), ossimConnectableObject::getInput(), and PTR_CAST.
Referenced by ossimGpkgWriter::addLevels(), ossimImageRenderer::checkIVT(), ossimPotraceTool::convertToBitmap(), ossimRLevelFilter::getImageGeometry(), ossimGeoAnnotationSource::getImageGeometry(), ossimScaleFilter::getImageGeometry(), ossimImageRenderer::getImageGeometry(), getImageGeometry(), ossimElevRemapper::initialize(), ossimSFIMFusion::initialize(), ossimImageToPlaneNormalFilter::initialize(), ossimMapCompositionSource::inputMapProjection(), ossimImageRenderer::refreshEvent(), ossimGpkgWriter::writeEntry(), ossimGeomFileWriter::writeFile(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), ossimFgdcFileWriter::writeFile(), ossimNitfWriterBase::writeGeometry(), ossimKakaduJp2Writer::writeGeotiffBox(), ossimKakaduJp2Writer::writeGmlBox(), ossimGdalWriter::writeProjectionInfo(), and ossimWriter::writeTiffTags().
Reimplemented in ossimImageHandler, ossimHistogramRemapper, ossimNitfTileSource, ossimGdalTileSource, ossimEquationCombiner, ossimLasReader, ossimTiffTileSource, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimPngReader, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimImageChain, ossimKakaduNitfReader, ossimPixelFlipper, ossimGeneralRasterTileSource, ossimBumpShadeTileSource, ossimIndexToRgbLutFilter, ossimOpjJp2Reader, ossimImageSourceSequencer, ossimVpfTileSource, ossimPiecewiseRemapper, ossimElevImageSource, ossimImageCacheTileSource, ossimBandSelector, ossimKMeansFilter, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimRgbToIndexFilter, ossimImageHandlerMtAdaptor, ossimNBandToIndexFilter, ossimBandAverageFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimShiftFilter, ossimImageCombiner, ossimBandMergeSource, ossimLinearStretchRemapper, ossimMemoryImageSource, ossimTwoColorView, ossimLandsatTileSource, ossimCastTileSourceFilter, ossim3x3ConvolutionFilter, ossimFftFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimHsvToRgbSource, and ossimImageToPlaneNormalFilter.
Definition at line 246 of file ossimImageSource.cpp.
References ossim::defaultMax(), ossimConnectableObject::getInput(), getMaxPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimImageHistogramSource::getBinInformation(), ossimImageToPlaneNormalFilter::getMaxPixelValue(), ossimFftFilter::getMaxPixelValue(), ossim3x3ConvolutionFilter::getMaxPixelValue(), ossimCastTileSourceFilter::getMaxPixelValue(), ossimMemoryImageSource::getMaxPixelValue(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimShiftFilter::getMaxPixelValue(), ossimConvolutionFilter1D::getMaxPixelValue(), ossimBandAverageFilter::getMaxPixelValue(), ossimNBandToIndexFilter::getMaxPixelValue(), ossimRgbToIndexFilter::getMaxPixelValue(), ossimTopographicCorrectionFilter::getMaxPixelValue(), ossimBandSelector::getMaxPixelValue(), ossimPiecewiseRemapper::getMaxPixelValue(), ossimVpfTileSource::getMaxPixelValue(), ossimImageSourceSequencer::getMaxPixelValue(), ossimPixelFlipper::getMaxPixelValue(), getMaxPixelValue(), ossimImageChain::getMaxPixelValue(), ossimOgrGdalTileSource::getMaxPixelValue(), ossimEquationCombiner::getMaxPixelValue(), ossimHistogramRemapper::getMaxPixelValue(), ossimPixelFlipper::getMinPixelValue(), ossimLinearStretchRemapper::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimPixelFlipper::inRange(), and ossimHistogramRemapper::setupTable().
Reimplemented in ossimImageHandler, ossimHistogramRemapper, ossimNitfTileSource, ossimGdalTileSource, ossimEquationCombiner, ossimTiffTileSource, ossimLasReader, ossimHdf5ImageHandler, ossimPointCloudImageHandler, ossimOgrVectorTileSource, ossimImageChain, ossimOgrGdalTileSource, ossimPixelFlipper, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimVpfTileSource, ossimBumpShadeTileSource, ossimPiecewiseRemapper, ossimElevImageSource, ossimImageCacheTileSource, ossimBandSelector, ossimKMeansFilter, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimRgbToIndexFilter, ossimImageHandlerMtAdaptor, ossimNBandToIndexFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimBandAverageFilter, ossimShiftFilter, ossimImageCombiner, ossimBandMergeSource, ossimLinearStretchRemapper, ossimMemoryImageSource, ossimTwoColorView, ossimCastTileSourceFilter, ossimLandsatTileSource, ossim3x3ConvolutionFilter, ossimFftFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimHsvToRgbSource, and ossimImageToPlaneNormalFilter.
Definition at line 235 of file ossimImageSource.cpp.
References ossim::defaultMin(), ossimConnectableObject::getInput(), getMinPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimImageHistogramSource::getBinInformation(), ossimPixelFlipper::getMaxPixelValue(), ossimImageToPlaneNormalFilter::getMinPixelValue(), ossimFftFilter::getMinPixelValue(), ossim3x3ConvolutionFilter::getMinPixelValue(), ossimCastTileSourceFilter::getMinPixelValue(), ossimMemoryImageSource::getMinPixelValue(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimShiftFilter::getMinPixelValue(), ossimBandAverageFilter::getMinPixelValue(), ossimConvolutionFilter1D::getMinPixelValue(), ossimNBandToIndexFilter::getMinPixelValue(), ossimRgbToIndexFilter::getMinPixelValue(), ossimTopographicCorrectionFilter::getMinPixelValue(), ossimBandSelector::getMinPixelValue(), ossimPiecewiseRemapper::getMinPixelValue(), ossimVpfTileSource::getMinPixelValue(), ossimImageSourceSequencer::getMinPixelValue(), getMinPixelValue(), ossimPixelFlipper::getMinPixelValue(), ossimOgrGdalTileSource::getMinPixelValue(), ossimEquationCombiner::getMinPixelValue(), ossimHistogramRemapper::getMinPixelValue(), ossimBandAverageFilter::getNullPixelValue(), ossimLinearStretchRemapper::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimPixelFlipper::inRange(), ossimHistogramRemapper::setMinOutputValue(), and ossimHistogramRemapper::setupTable().
Reimplemented in ossimImageHandler, ossimNitfTileSource, ossimGdalTileSource, ossimLasReader, ossimTiffTileSource, ossimEquationCombiner, ossimH5ImageHandler, ossimPointCloudImageHandler, ossimHdf5ImageHandler, ossimImageChain, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimKakaduNitfReader, ossimGeneralRasterTileSource, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimVpfTileSource, ossimImageCacheTileSource, ossimBandSelector, ossimDtedTileSource, ossimBitMaskTileSource, ossimUsgsDemTileSource, ossimTopographicCorrectionFilter, ossimImageHandlerMtAdaptor, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimBandAverageFilter, ossimImageCombiner, ossimShiftFilter, ossimBandMergeSource, ossimMemoryImageSource, ossimTwoColorView, ossimFftFilter, ossimCastTileSourceFilter, ossimLandsatTileSource, ossim3x3ConvolutionFilter, ossimViirsHandler, and ossimViirsHandler.
Definition at line 223 of file ossimImageSource.cpp.
References ossim::defaultNull(), ossimConnectableObject::getInput(), getNullPixelValue(), getOutputScalarType(), and PTR_CAST.
Referenced by ossimPiecewiseRemapper::buildLinearNativeTable(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageDataFactory::create(), ossimCastTileSourceFilter::getNullPixelValue(), ossimFftFilter::getNullPixelValue(), ossimMemoryImageSource::getNullPixelValue(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNullPixelValue(), ossimShiftFilter::getNullPixelValue(), ossimBandAverageFilter::getNullPixelValue(), ossimNBandToIndexFilter::getNullPixelValue(), ossimRgbToIndexFilter::getNullPixelValue(), ossimTopographicCorrectionFilter::getNullPixelValue(), ossimBandSelector::getNullPixelValue(), ossimVpfTileSource::getNullPixelValue(), getNullPixelValue(), ossimImageSourceSequencer::getNullPixelValue(), ossimOgrGdalTileSource::getNullPixelValue(), ossimEquationCombiner::getNullPixelValue(), ossimLinearStretchRemapper::getTile(), ossimKMeansFilter::getTile(), ossimBandLutFilter::getTile(), ossimIndexToRgbLutFilter::getTile(), ossimNBandToIndexFilter::initialize(), and ossimPixelFlipper::inRange().
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Reimplemented in ossimImageHandler, ossimLasReader, ossimGpkgReader, ossimImageChain, ossimPointCloudImageHandler, ossimTiffTileSource, ossimKakaduJ2kReader, ossimKakaduJp2Reader, ossimMrSidReader, ossimMG4LidarReader, ossimImageSourceSequencer, ossimElevImageSource, ossimOgrGdalTileSource, ossimOgrVectorTileSource, ossimBitMaskTileSource, ossimImageRenderer, ossimCcfTileSource, ossimGdalTileSource, ossimTopographicCorrectionFilter, ossimOpjJp2Reader, ossimKakaduNitfReader, ossimVpfTileSource, ossimScaleFilter, ossimImageHandlerMtAdaptor, ossimMemoryImageSource, ossimVideoImageSource, and ossimKakaduJpipHandler.
Definition at line 109 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getNumberOfDecimationLevels(), and PTR_CAST.
Referenced by ossimBrightnessMatch::computeInputBrightness(), ossimImageRenderer::fillTile(), ossimTopographicCorrectionFilter::getNumberOfDecimationLevels(), getNumberOfDecimationLevels(), ossimImageRenderer::getNumberOfDecimationLevels(), ossimImageSourceSequencer::getNumberOfDecimationLevels(), ossimImageRenderer::getTileAtResLevel(), ossimPixelFlipper::initialize(), ossimCacheTileSource::initializeRlevelCache(), and ossimTiledImagePatch::isValidRLevel().
pure virtual |
Returns the number of bands available from the input.
Implemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimMaskFilter, ossimImageChain, ossimImageSourceSequencer, ossimImageCacheBase, ossimElevImageSource, ossimBandSelector, ossimNitfTileSource, ossimImageCacheTileSource, ossimLasReader, ossimGeoPdfReader, ossimTiffTileSource, ossimKakaduJp2Reader, ossimPointCloudImageHandler, ossimRangeDomeTileSource, ossimKakaduJ2kReader, ossimAdrgTileSource, ossimMG4LidarReader, ossimMrSidReader, ossimH5ImageHandler, ossimPngReader, ossimBitMaskTileSource, ossimDtedTileSource, ossimHdfReader, ossimCcfTileSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimOgrVectorTileSource, ossimGpkgReader, ossimGdalTileSource, ossimOpjJp2Reader, ossimJpegTileSource, ossimUsgsDemTileSource, ossimGeneralRasterTileSource, ossimKmlSuperOverlayReader, ossimImageHandlerMtAdaptor, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimVpfTileSource, ossimVideoImageHandler, ossimImageCombiner, ossimBandSeparateHandler, ossimVideoImageSource, ossimMemoryImageSource, and ossimImageSourceFilter.
Referenced by ossimInfo::getImageInfo(), ossimImageHandlerMtAdaptor::getNumberOfInputBands(), ossimBandSelector::getNumberOfInputBands(), ossimMaskFilter::getNumberOfInputBands(), getNumberOfOutputBands(), getOutputBandList(), ossimImageHandler::getProperty(), ossimImageHandler::setOutputBandList(), ossimSingleImageChain::setToThreeBands(), and ossimSingleImageChain::setToThreeBandsReverse().
Reimplemented in ossimCibCadrgTileSource, ossimLasReader, ossimRpfCacheTileSource, ossimImageCacheBase, ossimBumpShadeTileSource, ossimIndexToRgbLutFilter, ossimImageCacheTileSource, ossimNitfTileSource, ossimGeoPdfReader, ossimKakaduJp2Reader, ossimTiffTileSource, ossimKakaduJ2kReader, ossimBandSelector, ossimMG4LidarReader, ossimMrSidReader, ossimAdrgTileSource, ossimH5ImageHandler, ossimPngReader, ossimHdfReader, ossimDtedTileSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimBitMaskTileSource, ossimOgrVectorTileSource, ossimGpkgReader, ossimGdalTileSource, ossimCcfTileSource, ossimOpjJp2Reader, ossimJpegTileSource, ossimTopographicCorrectionFilter, ossimGeneralRasterTileSource, ossimKmlSuperOverlayReader, ossimUsgsDemTileSource, ossimImageHandlerMtAdaptor, ossimHsiRemapper, ossimElevImageSource, ossimVpfTileSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimKakaduJpipHandler, ossimVideoImageHandler, ATP::AtpTileSource, ossimVideoImageSource, ossimBandMergeSource, ossimMemoryImageSource, ossimAnnotationSource, ossimRgbToGreyFilter, ossimBandAverageFilter, ossimMapCompositionSource, ossimTwoColorView, ossimPointCloudUtilityFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimRgbToHsiSource, and ossimRgbToHsvSource.
Definition at line 323 of file ossimImageSource.cpp.
References getNumberOfInputBands().
Referenced by ossimLinearStretchRemapper::allocate(), ossimTableRemapper::allocate(), ossimWatermarkFilter::allocate(), ossimPiecewiseRemapper::buildLinearNativeTable(), ossimPiecewiseRemapper::buildTable(), ossimBandAverageFilter::checkWeights(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageHistogramSource::computeNormalModeHistogram(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimBandMergeSource::computeNumberOfInputBands(), ossimImageStatisticsSource::computeStatisticsTemplate(), ATP::AtpGenerator::constructChain(), ossimMultiBandHistogram::create(), ossimImageDataFactory::create(), ossimSingleImageChain::createRenderedChain(), ossimInfo::getImageInfo(), ossimBandMergeSource::getMaxPixelValue(), ossimImageCombiner::getMaxPixelValue(), ossimBandAverageFilter::getMaxPixelValue(), ossimBandMergeSource::getMinPixelValue(), ossimImageCombiner::getMinPixelValue(), ossimBandAverageFilter::getMinPixelValue(), ossimBandMergeSource::getNullPixelValue(), ossimImageCombiner::getNullPixelValue(), ossimImageSourceFilter::getNumberOfInputBands(), ossimImageSourceSequencer::getNumberOfInputBands(), ossimImageToPlaneNormalFilter::getNumberOfOutputBands(), ossimFftFilter::getNumberOfOutputBands(), ossimTwoColorView::getNumberOfOutputBands(), ossimBandAverageFilter::getNumberOfOutputBands(), ossimAnnotationSource::getNumberOfOutputBands(), ossimRgbToGreyFilter::getNumberOfOutputBands(), ossimNBandToIndexFilter::getNumberOfOutputBands(), ossimRgbToIndexFilter::getNumberOfOutputBands(), ossimImageHandlerMtAdaptor::getNumberOfOutputBands(), ossimTopographicCorrectionFilter::getNumberOfOutputBands(), ossimIndexToRgbLutFilter::getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimClosestToCenterCombiner::getTile(), ossimLinearStretchRemapper::getTile(), ossimBumpShadeTileSource::getTile(), ossimGdalDataset::init(), ossimFusionCombiner::initialize(), ossimHistoMatchRemapper::initialize(), ossimImageCombiner::initialize(), ossimLinearStretchRemapper::initialize(), ossimAnnotationSource::initialize(), ossimBandClipFilter::initialize(), ossimWatermarkFilter::initialize(), ossimTwoColorView::initialize(), ossimOverviewSequencer::initialize(), ossimEquationCombiner::initialize(), ossimChipperUtil::initializePsmChain(), ossimPiecewiseRemapper::initMinMax(), ossimPointCloudImageHandler::initTile(), ossimTiledElevationDatabase::isCompatible(), ossimNBandToIndexFilter::isSourceEnabled(), ossimTiffWriter::openTiff(), ossimPiecewiseRemapper::saveState(), ossimPdfWriter::setupInputChain(), ossimPiecewiseRemapper::setupTable(), ossimNitf20Writer::writeBlockBandSeparate(), ossimNitfWriter::writeBlockBandSeparate(), ossimNitf20Writer::writeBlockBandSequential(), ossimNitfWriter::writeBlockBandSequential(), ossimERSFileWriter::writeFile(), ossimEnviHeaderFileWriter::writeFile(), ossimJpegWriter::writeFile(), ossimWriter::writeTiffTags(), and ossimTiffWriter::writeTiffTags().
inlinevirtual |
For RTTI support.
overrides ossimImageSource get object to return the correct casted base pointer for RTTI casting
Definition at line 67 of file ossimImageSource.h.
Referenced by ossimSFIMFusion::initialize(), and ossimLocalCorrelationFusion::initialize().
inlinevirtual |
For RTTI support.
Definition at line 74 of file ossimImageSource.h.
Initializes bandList.
This implementation initializes to the zero based order of input bands. Derived classes that are band selectors should override.
| bandList | Initialized by this. |
Reimplemented in ossimGeneralRasterTileSource, ossimImageChain, ossimTiffTileSource, ossimBandSelector, and ossimImageSourceFilter.
Definition at line 306 of file ossimImageSource.cpp.
Referenced by ossimHistogramEqualization::allocate(), ossimTopographicCorrectionFilter::allocate(), ossimBandSelector::checkPassThrough(), ossimImageSourceFilter::getOutputBandList(), ossimBandSelector::getOutputBandList(), ossimTiffTileSource::getOutputBandList(), ossimImageChain::getOutputBandList(), if(), ossimImageHandler::isIdentityBandList(), ossimOverviewBuilderBase::setInputSource(), ossimImageHandler::setOutputBandList(), and ossimImageHandler::setOutputToInputBandList().
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimEquationCombiner, ossimTiffTileSource, ossimImageChain, ossimLasReader, ossimPngReader, ossimPixelFlipper, ossimNitfTileSource, ossimPointCloudImageHandler, ossimGpkgReader, ossimGdalTileSource, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimGeoPdfReader, ossimKakaduJp2Reader, ossimKmlSuperOverlayReader, ossimH5ImageHandler, ossimOpjJp2Reader, ossimBumpShadeTileSource, ossimImageSourceSequencer, ossimIndexToRgbLutFilter, ossimHdf5ImageHandler, ossimKakaduJ2kReader, ossimUsgsDemTileSource, ossimBandLutFilter, ossimJpegTileSource, ossimElevImageSource, ossimMG4LidarReader, ossimMrSidReader, ossimVpfTileSource, ossimHdfReader, ossimGeneralRasterTileSource, ossimTiledImageHandler, ossimRangeDomeTileSource, ossimImageCacheTileSource, ossimBitMaskTileSource, ossimTopographicCorrectionFilter, ossimBandSeparateHandler, ossimKMeansFilter, ossimImageHandlerMtAdaptor, ossimKakaduJpipHandler, ossimRgbToIndexFilter, ossimLinearStretchRemapper, ossimNBandToIndexFilter, ossimVideoImageHandler, ossimSlopeFilter, ossimImageCombiner, ossimVideoImageSource, ATP::AtpTileSource, ossimLandsatTileSource, ossimMemoryImageSource, ossimAnnotationSource, ossimFftFilter, ossimScalarRemapper, ossimTwoColorView, ossimTableRemapper, ossimRgbToGreyFilter, ossimMapCompositionSource, ossimPointCloudUtilityFilter, ossimFusionCombiner, ossimImageToPlaneNormalFilter, ossimCastTileSourceFilter, ossimHsiToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, and ossimHsvToRgbSource.
Definition at line 120 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, and PTR_CAST.
Referenced by ossimWatermarkFilter::allocate(), ossim3x3ConvolutionFilter::computeNullMinMax(), ossimConvolutionFilter1D::computeNullMinMax(), ossimImageStatisticsSource::computeStatistics(), ossimConvolutionSource::convolve(), ossimMultiBandHistogram::create(), ossimImageDataFactory::create(), ossimSingleImageChain::createRenderedChain(), ossimImageHistogramSource::getBinInformation(), ossimSingleImageChain::getImageHandlerScalarType(), ossimInfo::getImageInfo(), getMaxPixelValue(), ossimImageHandler::getMaxPixelValue(), getMinPixelValue(), ossimImageHandler::getMinPixelValue(), ossimMpiMasterOverviewSequencer::getNextTile(), ossim3x3ConvolutionFilter::getNullPixelValue(), ossimConvolutionFilter1D::getNullPixelValue(), getNullPixelValue(), ossimImageHandler::getNullPixelValue(), ossimCastTileSourceFilter::getOutputScalarType(), ossimImageToPlaneNormalFilter::getOutputScalarType(), ossimFusionCombiner::getOutputScalarType(), ossimRgbToGreyFilter::getOutputScalarType(), ossimTableRemapper::getOutputScalarType(), ossimAnnotationSource::getOutputScalarType(), ossimFftFilter::getOutputScalarType(), ossimMemoryImageSource::getOutputScalarType(), ossimImageCombiner::getOutputScalarType(), ossimNBandToIndexFilter::getOutputScalarType(), ossimRgbToIndexFilter::getOutputScalarType(), ossimImageHandlerMtAdaptor::getOutputScalarType(), ossimTopographicCorrectionFilter::getOutputScalarType(), ossimIndexToRgbLutFilter::getOutputScalarType(), ossimImageSourceSequencer::getOutputScalarType(), getOutputScalarType(), ossimPixelFlipper::getOutputScalarType(), ossimEquationCombiner::getOutputScalarType(), ossimImageHandler::getProperty(), ossimBumpShadeTileSource::getTile(), ossimHistoMatchRemapper::initialize(), ossimImageCombiner::initialize(), ossimTableRemapper::initialize(), ossimWatermarkFilter::initialize(), ossimTwoColorView::initialize(), ossimChipperUtil::initializeColorReliefChain(), ossimOverviewBuilderBase::initializeScanOptions(), ossimTiledElevationDatabase::isCompatible(), ossimNBandToIndexFilter::isSourceEnabled(), ossimImageHandler::loadMetaData(), main(), ossimGeoidImage::open(), ossimOverviewSequencer::resampleTile(), ossimBandSelector::setOutputBandList(), ossimMpiSlaveOverviewSequencer::slaveProcessTiles(), and ossimERSFileWriter::writeFile().
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimLasReader, ossimTiffTileSource, ossimGdalTileSource, ossimBumpShadeTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimH5ImageHandler, ossimEquationCombiner, ossimNitfTileSource, ossimHdf5ImageHandler, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimPngReader, ossimBandSelector, ossimWatermarkFilter, ossimGpkgReader, ossimImageRenderer, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimHistogramMatchFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimEnviTileSource, ossimLandsatTileSource, ossimKakaduJpipHandler, ossimSrtmTileSource, ossimCacheTileSource, ossimImageSourceFilter, ossimSFIMFusion, ossimImageGaussianFilter, ossimFftFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossimDoqqTileSource, ossim3x3ConvolutionFilter, ossimTrimFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 328 of file ossimImageSource.cpp.
References ossimProperty::clearChangeType(), ossimString::downcase(), ossimKeywordNames::ENABLED_KW, ossimSource::getProperty(), ossimProperty::setFullRefreshBit(), and ossimRefPtr< T >::valid().
Referenced by ossimImageSourceFilter::getProperty(), ossimEquationCombiner::getProperty(), and ossimBumpShadeTileSource::getProperty().
Reimplemented in ossimImageHandler, ossimCibCadrgTileSource, ossimLasReader, ossimGdalTileSource, ossimTiffTileSource, ossimBumpShadeTileSource, ossimH5ImageHandler, ossimPixelFlipper, ossimHdf5ImageHandler, ossimNitfTileSource, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimMaskFilter, ossimDtedTileSource, ossimAdrgTileSource, ossimCcfTileSource, ossimJpegTileSource, ossimWatermarkFilter, ossimPngReader, ossimBandSelector, ossimGpkgReader, ossimImageRenderer, ossimHistogramMatchFilter, ossimNBandToIndexFilter, ossimScalarRemapper, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimEnviTileSource, ossimLandsatTileSource, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimSrtmTileSource, ossimKakaduJpipHandler, ossimCacheTileSource, ossimImageSourceFilter, ossimTrimFilter, ossimSFIMFusion, ossimFftFilter, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimDoqqTileSource, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 353 of file ossimImageSource.cpp.
References ossimSource::getPropertyNames().
Referenced by ossimSFIMFusion::getPropertyNames(), ossimImageSourceFilter::getPropertyNames(), ossimMaskFilter::getPropertyNames(), ossimEquationCombiner::getPropertyNames(), ossimBumpShadeTileSource::getPropertyNames(), and ossimImageHandler::getPropertyNames().
Reimplemented in ossimImageHandlerMtAdaptor.
Definition at line 40 of file ossimImageSource.cpp.
References getTileHeight(), getTileWidth(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageHistogramSource::computeFastModeHistogram(), ossimHistogramRemapper::computeHistogram(), ossimHlzTool::computeHLZ(), ossimBrightnessMatch::computeInputBrightness(), ossimIntensityAdjustmentFilter::createAndPopulateGrid(), demo1(), demo3(), ossimTilePatch::fillPatch(), ossimCacheTileSource::fillTile(), ossimChipperUtil::getChip(), ossimImageCombiner::getNextTile(), ossimImageSourceSequencer::getNextTile(), ossimOverviewSequencer::getNextTile(), ossimFusionCombiner::getNormIntensity(), ossimFusionCombiner::getNormTile(), ossimKakaduNitfReader::getOverviewTile(), ossimKakaduJ2kReader::getOverviewTile(), ossimKakaduJp2Reader::getOverviewTile(), ossimImageHandler::getOverviewTile(), ossimHsvToRgbSource::getTile(), ossimIntensityAdjustmentFilter::getTile(), ossimCastTileSourceFilter::getTile(), ossimRgbToHsiSource::getTile(), ossimRgbToHsvSource::getTile(), ossimHsiToRgbSource::getTile(), ossimRgbToJpegYCbCrSource::getTile(), ossimImageToPlaneNormalFilter::getTile(), ossimJpegYCbCrToRgbSource::getTile(), ossimHistogramThreshholdFilter::getTile(), ossimHistogramEqualization::getTile(), ossimErosionFilter::getTile(), ossimMultiBandHistogramTileSource::getTile(), ossimDespeckleFilter::getTile(), ossimBrightnessMatch::getTile(), ossimTrimFilter::getTile(), ossimFftFilter::getTile(), ossimDilationFilter::getTile(), ossimSICDToDetectedImage::getTile(), ossimImageSharpenFilter::getTile(), ossim3x3ConvolutionFilter::getTile(), ossimHistoMatchRemapper::getTile(), ossimEdgeFilter::getTile(), ossimNullPixelFlip::getTile(), ossimRgbToGreyFilter::getTile(), ossimHistogramMatchFilter::getTile(), ossimBrightnessContrastSource::getTile(), ossimGammaRemapper::getTile(), ossimBandMergeSource::getTile(), ossimAOD::getTile(), ossimPolyCutter::getTile(), ossimSFIMFusion::getTile(), ossimBandSelector::getTile(), ossimMapCompositionSource::getTile(), ossimTwoColorView::getTile(), ossimRectangleCutFilter::getTile(), ossimLinearStretchRemapper::getTile(), ossimTableRemapper::getTile(), ossimShiftFilter::getTile(), ossimLocalCorrelationFusion::getTile(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimAnnotationSource::getTile(), ossimImageGaussianFilter::getTile(), ossimConvolutionSource::getTile(), ossimSlopeFilter::getTile(), ossimBandAverageFilter::getTile(), ossimHsiRemapper::getTile(), ossimScaleFilter::getTile(), ossimNBandToIndexFilter::getTile(), ossimValueAssignImageSourceFilter::getTile(), ossimMeanMedianFilter::getTile(), ossimRgbToIndexFilter::getTile(), ossimConvolutionFilter1D::getTile(), ossimSubImageTileSource::getTile(), ossimHistogramRemapper::getTile(), ossimTiledImagePatch::getTile(), ossimGdalTileSource::getTile(), ossimKMeansFilter::getTile(), ossimBandClipFilter::getTile(), ossimBandSeparateHandler::getTile(), ossimTopographicCorrectionFilter::getTile(), ossimRLevelFilter::getTile(), ossimWatermarkFilter::getTile(), ossimMrSidReader::getTile(), ossimMG4LidarReader::getTile(), ossimGridRemapSource::getTile(), ossimPiecewiseRemapper::getTile(), ossimTiledImageHandler::getTile(), ossimBandLutFilter::getTile(), ossimIndexToRgbLutFilter::getTile(), ossimBumpShadeTileSource::getTile(), ossimImageElevationHandler::getTile(), ossimPixelFlipper::getTile(), ossimImageChain::getTile(), ossimMaskFilter::getTile(), ossimEquationCombiner::getTile(), ossimKakaduJpipHandler::getTileAtRes(), ossimImageRenderer::getTileAtResLevel(), ossimGdalDatasetRasterBand::IReadBlock(), ossimGeoidImage::offsetFromEllipsoidTemplate(), ossimGeoidImage::open(), ossimMultiThreadSequencer::ossimGetTileJob::run(), ossimScaleFilter::runFilterTemplate(), ossimImageHandlerMtAdaptor::setAdaptee(), and ossimGpkgReader::uncompressPngTile().
Reimplemented in ossimEquationCombiner, ossimMaskFilter, ossimImageChain, ossimPixelFlipper, ossimIndexToRgbLutFilter, ossimBumpShadeTileSource, ossimBandLutFilter, ossimCibCadrgTileSource, ossimNitfTileSource, ossimTiledImageHandler, ossimPiecewiseRemapper, ossimKakaduJp2Reader, ossimRangeDomeTileSource, ossimRpfCacheTileSource, ossimKakaduJ2kReader, ossimGeoPdfReader, ossimImageSourceSequencer, ossimGridRemapSource, ossimTiffTileSource, ossimLasReader, ossimMG4LidarReader, ossimMrSidReader, ossimWatermarkFilter, ossimBitMaskTileSource, ossimPointCloudImageHandler, ossimRLevelFilter, ossimTopographicCorrectionFilter, ossimBandSeparateHandler, ossimHdfReader, ossimImageCacheTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimBandClipFilter, ossimKMeansFilter, ossimGdalTileSource, ossimOpjJp2Reader, ossimHistogramRemapper, ossimSubImageTileSource, ossimH5ImageHandler, ossimPngReader, ossimConvolutionFilter1D, ossimDtedTileSource, ossimKmlSuperOverlayReader, ossimVideoImageHandler, ossimMeanMedianFilter, ossimRgbToIndexFilter, ossimCcfTileSource, ossimHdf5ImageHandler, ossimValueAssignImageSourceFilter, ossimImageChainMtAdaptor, ossimMemoryImageSource, ossimNBandToIndexFilter, ossimGpkgReader, ossimVideoImageSource, ossimHsiRemapper, ossimScaleFilter, ossimBandAverageFilter, ossimElevImageSource, ossimConvolutionSource, ossimImageRenderer, ossimSlopeFilter, ossimTiledImagePatch, ossimImageGaussianFilter, ossimJpegTileSource, ossimVpfTileSource, ossimKakaduJpipHandler, ossimAnnotationSource, ossimUsgsDemTileSource, ossimGeneralRasterTileSource, ossimLocalCorrelationFusion, ossimLinearStretchRemapper, ossimShiftFilter, ossimTableRemapper, ATP::AtpTileSource, ossimRectangleCutFilter, ossimMapCompositionSource, ossimTwoColorView, ossimImageHandlerMtAdaptor, ossimBandSelector, ossimClosestToCenterCombiner, ossimSFIMFusion, ossimAOD, ossimAtCorrRemapper, ossimPolyCutter, ossimBandMergeSource, ossimBrightnessContrastSource, ossimCacheTileSource, ossimGammaRemapper, ossimHistogramMatchFilter, ossimMaxMosaic, ossimScalarRemapper, ossimNullPixelFlip, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ATP::ossimCorrelationSource, ATP::ossimDescriptorSource, ossimEdgeFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimElevRemapper, ossimFeatherMosaic, ossimDilationFilter, ossimImageSharpenFilter, ossimSICDToDetectedImage, ossimFftFilter, ossimTrimFilter, ossimBrightnessMatch, ossimDespeckleFilter, ossimMultiBandHistogramTileSource, ossimErosionFilter, ossimHistogramEqualization, ossimBlendMosaic, ossimColorNormalizedFusion, ossimHistogramThreshholdFilter, ossimCastTileSourceFilter, ossimHsiToRgbSource, ossimImageToPlaneNormalFilter, ossimJpegYCbCrToRgbSource, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimRgbToJpegYCbCrSource, ossimHsvToRgbSource, and ossimIntensityAdjustmentFilter.
Definition at line 51 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), getTile(), and PTR_CAST.
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method. |
Reimplemented in ossimCibCadrgTileSource, ossimBumpShadeTileSource, ossimRpfCacheTileSource, ossimGeoPdfReader, ossimTiffTileSource, ossimLasReader, ossimRangeDomeTileSource, ossimPointCloudImageHandler, ossimImageCacheTileSource, ossimAdrgTileSource, ossimH5ImageHandler, ossimPngReader, ossimDtedTileSource, ossimHdfReader, ossimCcfTileSource, ossimHdf5ImageHandler, ossimGpkgReader, ossimJpegTileSource, ossimTiledImagePatch, ossimUsgsDemTileSource, ossimGeneralRasterTileSource, ossimImageHandlerMtAdaptor, ossimBandMergeSource, and ossimPointCloudUtilityFilter.
Definition at line 64 of file ossimImageSource.cpp.
References ossimImageData::getImageRectangle(), getTile(), ossimImageData::loadTile(), and status.
Returns the default processing tile height.
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimTiffTileSource, ossimImageChain, ossimPngReader, ossimLasReader, ossimGdalTileSource, ossimNitfTileSource, ossimGpkgReader, ossimAdrgTileSource, ossimOgrVectorTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimPointCloudImageHandler, ossimImageCacheBase, ossimImageSourceSequencer, ossimUsgsDemTileSource, ossimJpegTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimElevImageSource, ossimImageHandlerMtAdaptor, ossimImageCombiner, and ossimCacheTileSource.
Definition at line 146 of file ossimImageSource.cpp.
References ossim::defaultTileSize(), ossimConnectableObject::getInput(), getTileHeight(), PTR_CAST, and ossimIpt::y.
Referenced by ossimRgbToGreyFilter::allocate(), ossimLinearStretchRemapper::allocate(), ossimTiledImageHandler::allocate(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageDataFactory::create(), ossimCacheTileSource::getCacheId(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimImageRenderer::getTileAtResLevel(), ossimImageCombiner::getTileHeight(), ossimImageHandlerMtAdaptor::getTileHeight(), ossimVpfTileSource::getTileHeight(), getTileHeight(), ossimOgrGdalTileSource::getTileHeight(), ossimTiledImagePatch::initialize(), ossimImageSourceSequencer::initialize(), and ossimOverviewSequencer::initialize().
Returns the default processing tile width.
Reimplemented in ossimCibCadrgTileSource, ossimRpfCacheTileSource, ossimTiffTileSource, ossimImageChain, ossimLasReader, ossimPngReader, ossimGdalTileSource, ossimNitfTileSource, ossimGpkgReader, ossimOgrVectorTileSource, ossimAdrgTileSource, ossimOgrGdalTileSource, ossimCcfTileSource, ossimDtedTileSource, ossimPointCloudImageHandler, ossimImageCacheBase, ossimImageSourceSequencer, ossimUsgsDemTileSource, ossimJpegTileSource, ossimVpfTileSource, ossimElevImageSource, ossimGeneralRasterTileSource, ossimImageHandlerMtAdaptor, ossimImageCombiner, and ossimCacheTileSource.
Definition at line 132 of file ossimImageSource.cpp.
References ossim::defaultTileSize(), ossimConnectableObject::getInput(), getTileWidth(), PTR_CAST, and ossimIpt::x.
Referenced by ossimRgbToGreyFilter::allocate(), ossimLinearStretchRemapper::allocate(), ossimTiledImageHandler::allocate(), ossimImageHistogramSource::computeFastModeHistogram(), ossimImageDataFactory::create(), ossimCacheTileSource::getCacheId(), ossimImageHandlerMtAdaptor::getTile(), getTile(), ossimImageRenderer::getTileAtResLevel(), ossimImageCombiner::getTileWidth(), ossimImageHandlerMtAdaptor::getTileWidth(), ossimVpfTileSource::getTileWidth(), getTileWidth(), ossimOgrGdalTileSource::getTileWidth(), ossimTiledImagePatch::initialize(), ossimImageSourceSequencer::initialize(), and ossimOverviewSequencer::initialize().
ordering specifies how the vertices should be arranged.
valid image vertices is basically the tightly fit convex hull of the image. Usually an image has NULL values and are internally not upright rectangular. This can cause problems some spatial filters.
The default implementation is to return the bounding rect.
Reimplemented in ossimPointCloudImageHandler.
Definition at line 192 of file ossimImageSource.cpp.
References getBoundingRect(), ossimConnectableObject::getInput(), getValidImageVertices(), ossimIrect::ll(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, PTR_CAST, ossimIrect::ul(), and ossimIrect::ur().
Referenced by ossimErosionFilter::getTile(), ossimDilationFilter::getTile(), ossimTrimFilter::getValidImageVertices(), ossimSubImageTileSource::getValidImageVertices(), ossimImageRenderer::getValidImageVertices(), getValidImageVertices(), ossimImageHandler::getValidImageVertices(), ossimFeatherMosaic::initialize(), and ossimPixelFlipper::initialize().
pure virtual |
Implemented in ossimImageChain, ossimMapCompositionSource, ossimEquationCombiner, ossimBumpShadeTileSource, ossimMaskFilter, ossimIndexToRgbLutFilter, ossimBandLutFilter, ossimPixelFlipper, ossimAtCorrGridRemapper, ossimKMeansFilter, ossimBandSelector, ossimElevImageSource, ossimTopographicCorrectionFilter, ossimPiecewiseRemapper, ossimRangeDomeTileSource, ossimTwoColorView, ossimBandAverageFilter, ossimWatermarkFilter, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimBrightnessContrastSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimVideoImageSource, ossimBandClipFilter, ossimHistogramRemapper, ossimValueAssignImageSourceFilter, ossimImageHandler, ossimConvolutionFilter1D, ossimImageSourceSequencer, ossimMemoryImageSource, ossimMeanMedianFilter, ossimImageChainMtAdaptor, ossimScaleFilter, ossimAnnotationSource, ossimIntensityAdjustmentFilter, ossimLinearStretchRemapper, ossimImageRenderer, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimLocalCorrelationFusion, ossimTableRemapper, ossimImageGaussianFilter, ossimRectangleCutFilter, ossimHsiRemapper, ossimSlopeFilter, ossimImageSourceFilter, ossimPolyCutter, ossimImageMpiMWriterSequenceConnection, ossimHistogramMatchFilter, ossimShiftFilter, ossimTiledImagePatch, ossimSFIMFusion, ossimSICDToDetectedImage, ossimBandMergeSource, ossimMaxMosaic, ossimCacheTileSource, ossimImageCombiner, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ossimVideoImageHandler, ossimAOD, ossimAtCorrRemapper, ossimEdgeFilter, ossimHistogramThreshholdFilter, ossimHistoMatchRemapper, ATP::AtpTileSource, ossim3x3ConvolutionFilter, ossimGammaRemapper, ossimHistogramEqualization, ossimNullPixelFlip, ossimImageMpiSWriterSequenceConnection, ossimFeatherMosaic, ossimFusionCombiner, ossimHsiToRgbSource, ossimImageSharpenFilter, ossimRgbToHsiSource, ossimRgbToHsvSource, ossimBrightnessMatch, ossimEastingNorthingCutter, ossimTrimFilter, ATP::ossimCorrelationSource, ATP::ossimDescriptorSource, ossimFftFilter, ossimHsvToRgbSource, ossimScalarRemapper, ossimDespeckleFilter, ossimElevRemapper, ossimDilationFilter, ossimJpegYCbCrToRgbSource, ossimCastTileSourceFilter, ossimErosionFilter, ossimOrthoImageMosaic, ossimBlendMosaic, and ossimLandsatTopoCorrectionFilter.
Referenced by ossimImageToPlaneNormalFilter::initialize(), ossimBandLutFilter::initialize(), ossimIndexToRgbLutFilter::initialize(), ossimBumpShadeTileSource::initialize(), and ossimHlzTool::initProcessingChain().
This should be replaced by a getPhotoInterpretation().
Reimplemented in ossimGdalTileSource.
Definition at line 358 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), isIndexedData(), and PTR_CAST.
Referenced by isIndexedData(), and ossimGdalWriter::isInputDataIndexed().
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimCibCadrgTileSource, ossimEquationCombiner, ossimEsriShapeFileFilter, ossimLasReader, ossimKakaduJp2Reader, ossimImageChain, ossimMapCompositionSource, ossimKakaduJ2kReader, ossimPointCloudImageHandler, ossimMrSidReader, ossimGeoPdfReader, ossimMG4LidarReader, ossimBumpShadeTileSource, ossimTiffTileSource, ossimRpfCacheTileSource, ossimMaskFilter, ossimHdfReader, ossimIndexToRgbLutFilter, ossimImageSourceSequencer, ossimPixelFlipper, ossimHistogramMatchFilter, ossimNitfTileSource, ossimScaleFilter, ossimBandLutFilter, ossimBandSelector, ossimCcfTileSource, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimPiecewiseRemapper, ossimOgrVectorTileSource, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimAtCorrGridRemapper, ossimWatermarkFilter, ossimGdalTileSource, ossimKMeansFilter, ossimHdf5ImageHandler, ossimGpkgReader, ossimUsgsDemTileSource, ossimJpegTileSource, ossimImageCacheBase, ossimGeoPolyCutter, ossimTopographicCorrectionFilter, ossimKmlSuperOverlayReader, ossimRangeDomeTileSource, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimElevImageSource, ossimAnnotationSource, ossimBandAverageFilter, ossimBrightnessContrastSource, ossimMeanMedianFilter, ossimTiledImagePatch, ossimMemoryImageSource, ossimGridRemapSource, ossimRgbToIndexFilter, ossimNBandToIndexFilter, ossimGdalOgrVectorAnnotation, ossimImageRenderer, ossimMultiBandHistogramTileSource, ossimScalarRemapper, ossimSubImageTileSource, ossimRLevelFilter, ossimValueAssignImageSourceFilter, ossimConvolutionFilter1D, ossimTiledImageHandler, ossimBandClipFilter, ossimKakaduJpipHandler, ossimSlopeFilter, ossimBandSeparateHandler, ossimplugins::ossimTerraSarTiffReader, ossimGeoAnnotationSource, ossimLocalCorrelationFusion, ossimplugins::ossimRadarSat2TiffReader, ossimEnviTileSource, ossimLandsatTileSource, ossimImageChainMtAdaptor, ossimHsiRemapper, ossimSFIMFusion, ossimDilationFilter, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimFftFilter, ossimImageGaussianFilter, ossimLinearStretchRemapper, ossimCacheTileSource, ossimEdgeFilter, ossimMultiThreadSequencer, ossimImageHandlerMtAdaptor, ossimMaxMosaic, ossimSrtmTileSource, ossimRgbToGreyFilter, ossimElevationMosaic, ossimImageMosaic, ossimPolyCutter, ossimErosionFilter, ossimRectangleCutFilter, ossimHistoMatchRemapper, ossim3x3ConvolutionFilter, ossimConvolutionSource, ossimImageToPlaneNormalFilter, ossimAOD, ossimAtCorrRemapper, ossimERSTileSource, ossimImageSourceFilter, ossimGammaRemapper, ossimElevRemapper, ossimImageSharpenFilter, ossimBlendMosaic, ossimBrightnessMatch, ossimImageCombiner, ossimQuickbirdNitfTileSource, ossimHistogramEqualization, ossimHistogramThreshholdFilter, ossimTrimFilter, ossimImageSourceHistogramFilter, ossimLandsatTopoCorrectionFilter, ossimVpfAnnotationSource, ossimDoqqTileSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 183 of file ossimImageSource.cpp.
References ossimSource::loadState().
Referenced by ossimImageChain::addAllSources(), ossimImageCombiner::loadState(), ossimERSTileSource::loadState(), ossimImageSourceFilter::loadState(), ossimImageHandlerMtAdaptor::loadState(), ossimVectorRenderer::loadState(), ossimMemoryImageSource::loadState(), ossimElevImageSource::loadState(), ossimImageSourceSequencer::loadState(), ossimMaskFilter::loadState(), and ossimImageChain::loadState().
protected |
Definition at line 375 of file ossimImageSource.cpp.
Default method to call input's saveImageGeometry.
Reimplemented in ossimImageHandler.
Definition at line 288 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and saveImageGeometry().
Referenced by saveImageGeometry().
Definition at line 297 of file ossimImageSource.cpp.
Reimplemented in ossimHistogramRemapper, ossimImageHandler, ossimGeoPdfReader, ossimEsriShapeFileFilter, ossimEquationCombiner, ossimLasReader, ossimImageChain, ossimMapCompositionSource, ossimCibCadrgTileSource, ossimPointCloudImageHandler, ossimBumpShadeTileSource, ossimMaskFilter, ossimTiffTileSource, ossimHistogramMatchFilter, ossimIndexToRgbLutFilter, ossimPixelFlipper, ossimRpfCacheTileSource, ossimBandLutFilter, ossimNitfTileSource, ossimScaleFilter, ossimAtCorrGridRemapper, ossimBandSelector, ossimCcfTileSource, ossimKMeansFilter, ossimOgrGdalTileSource, ossimAdrgTileSource, ossimDtedTileSource, ossimOgrVectorTileSource, ossimPiecewiseRemapper, ossimH5ImageHandler, ossimOpjJp2Reader, ossimPngReader, ossimGdalTileSource, ossimTopographicCorrectionFilter, ossimHdf5ImageHandler, ossimGpkgReader, ossimRangeDomeTileSource, ossimBrightnessContrastSource, ossimJpegTileSource, ossimTiledImagePatch, ossimGeoPolyCutter, ossimUsgsDemTileSource, ossimWatermarkFilter, ossimKmlSuperOverlayReader, ossimBandAverageFilter, ossimVpfTileSource, ossimGeneralRasterTileSource, ossimGridRemapSource, ossimElevImageSource, ossimAnnotationSource, ossimMeanMedianFilter, ossimMemoryImageSource, ossimMultiBandHistogramTileSource, ossimSubImageTileSource, ossimRgbToIndexFilter, ossimGdalOgrVectorAnnotation, ossimNBandToIndexFilter, ossimRLevelFilter, ossimImageCacheBase, ossimImageRenderer, ossimBandClipFilter, ossimConvolutionFilter1D, ossimScalarRemapper, ossimKakaduJpipHandler, ossimTiledImageHandler, ossimValueAssignImageSourceFilter, ossimImageChainMtAdaptor, ossimBandSeparateHandler, ossimSlopeFilter, ossimLocalCorrelationFusion, ossimFftFilter, ossimplugins::ossimTerraSarTiffReader, ossimImageGaussianFilter, ossimSFIMFusion, ossimCacheTileSource, ossimGeoAnnotationSource, ossimplugins::ossimRadarSat2TiffReader, ossimLinearStretchRemapper, ossimDilationFilter, ossimEdgeFilter, ossimHsiRemapper, ossimEnviTileSource, ossimCastTileSourceFilter, ossimVectorRenderer, ossimTableRemapper, ossimImageHandlerMtAdaptor, ossim3x3ConvolutionFilter, ossimImageSourceFilter, ossimImageToPlaneNormalFilter, ossimRectangleCutFilter, ossimMaxMosaic, ossimImageSharpenFilter, ossimRgbToGreyFilter, ossimElevationMosaic, ossimErosionFilter, ossimImageMosaic, ossimPolyCutter, ossimSrtmTileSource, ossimBrightnessMatch, ossimElevRemapper, ossimImageCombiner, ossimHistogramEqualization, ossimConvolutionSource, ossimHistogramThreshholdFilter, ossimImageSourceHistogramFilter, ossimTrimFilter, ossimLandsatTopoCorrectionFilter, ossimBlendMosaic, ossimQuickbirdNitfTileSource, ossimVpfAnnotationSource, ossimDespeckleFilter, and ossimEastingNorthingCutter.
Definition at line 177 of file ossimImageSource.cpp.
References ossimSource::saveState().
Referenced by ossimImageCombiner::saveState(), ossimImageSourceFilter::saveState(), ossimImageHandlerMtAdaptor::saveState(), ossimImageRenderer::saveState(), ossimMemoryImageSource::saveState(), ossimElevImageSource::saveState(), ossimImageChain::saveState(), and ossimImageHandler::saveState().
Default implementation sets geometry of the first input to the geometry specified.
Definition at line 279 of file ossimImageSource.cpp.
References ossimConnectableObject::getInput(), PTR_CAST, and setImageGeometry().
Referenced by setImageGeometry().
Reimplemented in ossimImageHandler, ossimLasReader, ossimTiffTileSource, ossimBumpShadeTileSource, ossimGdalTileSource, ossimPixelFlipper, ossimPointCloudImageHandler, ossimNitfTileSource, ossimH5ImageHandler, ossimEquationCombiner, ossimMapCompositionSource, ossimOgrGdalTileSource, ossimHdf5ImageHandler, ossimMaskFilter, ossimWatermarkFilter, ossimBandSelector, ossimPngReader, ossimImageRenderer, ossimGpkgReader, ossimRangeDomeTileSource, ossimNBandToIndexFilter, ossimScalarRemapper, ossimHistogramMatchFilter, ossimPolyCutter, ossimBrightnessContrastSource, ossimGdalOgrVectorAnnotation, ossimMeanMedianFilter, ossimSlopeFilter, ossimCastTileSourceFilter, ossimConvolutionFilter1D, ossimKakaduJpipHandler, ossimCacheTileSource, ossimImageSourceFilter, ossimFftFilter, ossimSFIMFusion, ossimImageGaussianFilter, ossimImageToPlaneNormalFilter, ossimEdgeFilter, ossimTrimFilter, ossimSICDToDetectedImage, ossimDilationFilter, ossimHsiRemapper, ossim3x3ConvolutionFilter, ossimImageSharpenFilter, ossimErosionFilter, ossimBrightnessMatch, and ossimDespeckleFilter.
Definition at line 348 of file ossimImageSource.cpp.
References ossimSource::setProperty().
Referenced by ossimImageSourceFilter::setProperty(), ossimEquationCombiner::setProperty(), and ossimBumpShadeTileSource::setProperty().
