#include <ossimConnectableContainer.h>
Public Types | |
| typedef std::map< ossim_int64, ossimRefPtr< ossimConnectableObject > > | connectablObjectMapType |
| ossimConnectableContainer (ossimConnectableObject *owner=0) | |
| virtual ossimConnectableObject * | getConnectableObject (ossim_uint32 index) |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (ossimConnectableObject *findObject(const ossimId &id, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (ossimConnectableObject *findObject(const ossimConnectableObject *obj, bool recurse=true)) | |
| Please use the new ossimVisitor design pattern to visit objects in the container. More... | |
| void | makeUniqueIds () |
| ossim_uint32 | getNumberOfObjects (bool recurse=true) const |
| virtual bool | addChild (ossimConnectableObject *attachableObject) |
| virtual bool | removeChild (ossimConnectableObject *object) |
| virtual bool | canConnectMyInputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| virtual bool | canConnectMyOutputTo (ossim_int32 index, const ossimConnectableObject *obj) const |
| virtual void | getChildren (std::vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag) |
| void | deleteAllChildren () |
| ossimObject () | |
| ossimListenerManager () | |
Public Member Functions inherited from ossimConnectableContainerInterface | |
| ossimConnectableContainerInterface (ossimObject *obj) | |
| virtual | ~ossimConnectableContainerInterface () |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimId &id, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimConnectableObject *obj, bool recurse=true)=0 |
| ossimObject * | getObject () |
| const ossimObject * | getObject () const |
| ProcessEvent. More... | |
| virtual void | disconnectInputEvent (ossimConnectionEvent &) |
| virtual void | connectInputEvent (ossimConnectionEvent &) |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimConnectableContainer () |
| ossimConnectableContainer (const ossimConnectableContainer &rhs) | |
| void | removeAllListeners () |
| bool | addAllObjects (std::map< ossimId, std::vector< ossimId > > &idMapping, const ossimKeywordlist &kwl, const char *prefix) |
| bool | connectAllObjects (const std::map< ossimId, std::vector< ossimId > > &idMapping) |
| void | findInputConnectionIds (std::vector< ossimId > &result, const ossimKeywordlist &kwl, const char *prefix) |
Protected Attributes | |
| connectablObjectMapType | theObjectMap |
| ossimConnectableContainerChildListener * | theChildListener |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimConnectableContainerInterface | |
| ossimObject * | theBaseObject |
Protected Attributes inherited from ossimListener | |
| bool | theListenerEnableFlag |
Definition at line 22 of file ossimConnectableContainer.h.
| typedef std::map<ossim_int64, ossimRefPtr<ossimConnectableObject> > ossimConnectableContainer::connectablObjectMapType |
Definition at line 28 of file ossimConnectableContainer.h.
| ossimConnectableContainer::ossimConnectableContainer | ( | ossimConnectableObject * | owner = 0 | ) |
Definition at line 81 of file ossimConnectableContainer.cpp.
References ossimConnectableContainerChildListener, ossimConnectableContainerInterface::theBaseObject, and theChildListener.
protectedvirtual |
Definition at line 89 of file ossimConnectableContainer.cpp.
References deleteAllChildren(), and theChildListener.
protected |
We will add a visitor interface for all connectable objects.
Reimplemented from ossimConnectableObject.
Definition at line 775 of file ossimConnectableContainer.cpp.
References ossimConnectableObject::accept(), ossimRefPtr< T >::get(), ossimVisitor::getVisitorType(), ossimVisitor::hasVisited(), ossimVisitor::setVisitorType(), ossimVisitor::stopTraversal(), theObjectMap, ossimVisitor::turnOffVisitorType(), ossimRefPtr< T >::valid(), ossimVisitor::visit(), ossimVisitor::VISIT_CHILDREN, ossimVisitor::VISIT_INPUTS, and ossimVisitor::VISIT_OUTPUTS.
Referenced by addChild(), connectAllObjects(), and ossimIgen::outputProduct().
protected |
Definition at line 580 of file ossimConnectableContainer.cpp.
References ossimKeywordlist::getSubstringKeyList(), ossimString::toInt(), and ossimString::toString().
Referenced by loadState().
Will add an object to the container and then set the added objects owner to this.
Implements ossimConnectableContainerInterface.
Definition at line 390 of file ossimConnectableContainer.cpp.
References accept(), ossimId::getId(), ossimConnectableObject::getId(), ossimIdVisitor::getObject(), theChildListener, theObjectMap, ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by fillContainer(), and ossimConnectableObject::fillContainer().
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 763 of file ossimConnectableContainer.cpp.
default implementation is to allow anyone to connect to us.
Definition at line 769 of file ossimConnectableContainer.cpp.
protected |
Definition at line 680 of file ossimConnectableContainer.cpp.
References accept(), ossimConnectableObject::connectMyInputTo(), ossimIdVisitor::getObject(), ossimNotify(), ossimNotifyLevel_FATAL, ossimIdVisitor::reset(), ossimIdVisitor::setId(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
| void ossimConnectableContainer::deleteAllChildren | ( | ) |
Definition at line 541 of file ossimConnectableContainer.cpp.
References ossimConnectableObject::disconnect(), removeAllListeners(), ossimListenerManager::removeListener(), theChildListener, and theObjectMap.
Referenced by ~ossimConnectableContainer(), and ossimIgen::~ossimIgen().
Inserts all of this object's children and inputs into the container provided. Since this is itself a container, this method will consolidate this with the argument container. Consequently, this object will not be represented in the argument container but its children will be. Ownership of children will pass to the argument container.
Definition at line 808 of file ossimConnectableContainer.cpp.
References addChild(), ossimRefPtr< T >::get(), theObjectMap, and ossimRefPtr< T >::valid().
protected |
Definition at line 646 of file ossimConnectableContainer.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getNumberOfSubstringKeys(), ossimKeywordlist::getSubstringKeyList(), ossimId::INVALID_ID, ossimString::toLong(), and ossimString::toString().
Definition at line 495 of file ossimConnectableContainer.cpp.
References ossimConnectableContainerInterface::getChildren(), PTR_CAST, and theObjectMap.
| index | Index of object to get. |
Definition at line 737 of file ossimConnectableContainer.cpp.
References theObjectMap.
Returns the number of objects within this container and all child containers.
Definition at line 364 of file ossimConnectableContainer.cpp.
References ossimConnectableContainerInterface::getNumberOfObjects(), PTR_CAST, and theObjectMap.
Definition at line 727 of file ossimConnectableContainer.cpp.
Definition at line 732 of file ossimConnectableContainer.cpp.
Definition at line 438 of file ossimConnectableContainer.cpp.
References addAllObjects(), ossimString::c_str(), connectAllObjects(), ossimConnectableObject::loadState(), ossimNotify(), and ossimNotifyLevel_FATAL.
Will cycle through all sources setting their ids. the idLast wlil be updated so we can recurse into other containers.
Definition at line 329 of file ossimConnectableContainer.cpp.
References ossimConnectableObject::getId(), ossimIdManager::instance(), ossimConnectableContainerInterface::makeUniqueIds(), PTR_CAST, ossimConnectableObject::setId(), and theObjectMap.
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfTypeconst RTTItypeid &typeInfo, bool recurse=true | ) |
These methods are now deprecated. You can achieve the same thing by using the new visitor design pattern. If this does not achieve exactly what you want then you can derive new rules by overriding the virtual visit method in ossimVisitor
ossimTypeNameVisitor visitor("<put type name here>", false, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimCollectionVisitor::List& collection = visitor.getObjects();
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfTypeconst ossimString &className, bool recurse=true | ) |
ossimConnectableTypeIdVisitor visitor(typeId, false, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimConnectableCollectionVisitor::List& collection = visitor.getObjects();
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findFirstObjectOfTypeconst RTTItypeid &typeInfo, bool recurse=true | ) |
ossimTypeIdVisitor visitor(typeId, true, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.getObject();
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findFirstObjectOfTypeconst ossimString &className, bool recurse=true | ) |
ossimTypeNameVisitor visitor(className, true, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.getObject();
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | ossimConnectableObject * | findObjectconst ossimId &id, bool recurse=true | ) |
ossimIdVisitor visitor(id, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.object();
| ossimConnectableContainer::OSSIM_DEPRECATE_METHOD | ( | ossimConnectableObject * | findObjectconst ossimConnectableObject *obj, bool recurse=true | ) |
protected |
Definition at line 562 of file ossimConnectableContainer.cpp.
References ossimListenerManager::removeListener(), theChildListener, and theObjectMap.
Referenced by deleteAllChildren().
Will remove the child from the container. Changes the owner of the child to be NULL;
Definition at line 415 of file ossimConnectableContainer.cpp.
References ossimConnectableObject::changeOwner(), ossimId::getId(), ossimConnectableObject::getId(), ossimConnectableObject::getOwner(), ossimListenerManager::removeListener(), theChildListener, and theObjectMap.
Referenced by ossimConnectableContainerChildListener::objectDestructingEvent().
Method to save the state of the object to a keyword list. Return true if ok or false on error.
Definition at line 463 of file ossimConnectableContainer.cpp.
References ossimConnectableObject::saveState(), theObjectMap, and ossimString::toString().
protected |
Definition at line 209 of file ossimConnectableContainer.h.
Referenced by addChild(), deleteAllChildren(), ossimConnectableContainer(), removeAllListeners(), removeChild(), and ~ossimConnectableContainer().
protected |
Every object added must have a unique id. We will sort them in a easy to query form. Since the container can have hundreds of objects we will use a more efficient map that allows us to do binary searches of the objects.
map<key, value> The key will be the objectsUnique id and the value is a pointer to the attachable object.
Definition at line 207 of file ossimConnectableContainer.h.
Referenced by accept(), addChild(), deleteAllChildren(), fillContainer(), getChildren(), getConnectableObject(), getNumberOfObjects(), makeUniqueIds(), removeAllListeners(), removeChild(), and saveState().
