#include <ossimKakaduJpipHandler.h>
Classes | |
| struct | Box |
Public Types | |
| typedef std::vector< kdu_core::kdu_byte > | ByteBuffer |
| typedef std::vector< Box > | BoxList |
| typedef std::vector< ossimIrect > | RectList |
| typedef std::vector< ossimString > | StringList |
| typedef std::vector< ossimIpt > | RLevelBlockSizeList |
| typedef std::vector< ossimAppFixedTileCache::ossimAppFixedCacheId > | RLevelCacheList |
| ossimKakaduJpipHandler () | |
| virtual | ~ossimKakaduJpipHandler () |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Pure virtual, derived classes must implement. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| virtual void | extractBoxes (BoxList &boxList) |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ossimRefPtr< ossimImageData > | getTileAtRes (const ossimIrect &rect, ossim_uint32 resLevel=0) |
| virtual void | extractBoxes (BoxList &boxList, kdu_supp::jp2_input_box *pParentBox) |
| void | showBoxes (kdu_supp::jp2_input_box *pParentBox=0) |
| bool | makeConnectionIfNeeded (kdu_supp::kdu_client *client) |
| int | convertClassIdToKdu (int id) |
| void | allocateTile () |
| void | deleteRlevelCache () |
| void | performRlevelSetup (kdu_core::kdu_codestream &codestream) |
| bool | loadClient (kdu_supp::kdu_client *client, kdu_supp::kdu_window &window) |
| bool | openStream () |
| void | flushCache () |
| void | initializeRlevelCache () |
| void | allocateSession () |
Definition at line 25 of file ossimKakaduJpipHandler.h.
| typedef std::vector<Box> ossimKakaduJpipHandler::BoxList |
Definition at line 34 of file ossimKakaduJpipHandler.h.
| typedef std::vector<kdu_core::kdu_byte> ossimKakaduJpipHandler::ByteBuffer |
Definition at line 28 of file ossimKakaduJpipHandler.h.
| typedef std::vector<ossimIrect> ossimKakaduJpipHandler::RectList |
Definition at line 35 of file ossimKakaduJpipHandler.h.
| typedef std::vector<ossimIpt> ossimKakaduJpipHandler::RLevelBlockSizeList |
Definition at line 37 of file ossimKakaduJpipHandler.h.
| typedef std::vector<ossimAppFixedTileCache::ossimAppFixedCacheId> ossimKakaduJpipHandler::RLevelCacheList |
Definition at line 38 of file ossimKakaduJpipHandler.h.
| typedef std::vector<ossimString> ossimKakaduJpipHandler::StringList |
Definition at line 36 of file ossimKakaduJpipHandler.h.
| ossimKakaduJpipHandler::ossimKakaduJpipHandler | ( | ) |
Definition at line 24 of file ossimKakaduJpipHandler.cpp.
Definition at line 37 of file ossimKakaduJpipHandler.cpp.
protected |
Definition at line 434 of file ossimKakaduJpipHandler.cpp.
References ossimHttpRequest::addHeaderOption(), ossimString::c_str(), ossimWebRequestFactoryRegistry::createHttp(), ossimString::empty(), ossimWebRequest::getResponse(), ossimHttpResponse::getStatusCode(), ossimHttpResponse::headerKwl(), ossimWebRequestFactoryRegistry::instance(), m_baseUrl, m_cid, m_path, m_request, m_transport, ossimHttpRequest::set(), ossimUrl::setParams(), ossimString::substitute(), ossimUrl::toString(), ossimString::trim(), and ossimRefPtr< T >::valid().
Referenced by loadClient().
protected |
Definition at line 766 of file ossimKakaduJpipHandler.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_tile, and ossimRefPtr< T >::valid().
Referenced by getTileAtRes().
Definition at line 46 of file ossimKakaduJpipHandler.cpp.
References ossimImageHandler::close(), deleteRlevelCache(), m_client, m_headerClient, m_jp2Family, m_request, ossimNotify(), and ossimNotifyLevel_WARN.
Referenced by loadState(), open(), and openStream().
protected |
Definition at line 105 of file ossimKakaduJpipHandler.cpp.
protected |
Definition at line 1066 of file ossimKakaduJpipHandler.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), and m_rlevelBlockCache.
Referenced by close(), initializeRlevelCache(), and performRlevelSetup().
Definition at line 196 of file ossimKakaduJpipHandler.cpp.
References loadClient(), m_client, m_headerClient, and m_jp2Family.
protectedvirtual |
protected |
Definition at line 1230 of file ossimKakaduJpipHandler.cpp.
References ossimAppFixedTileCache::flush(), ossimAppFixedTileCache::instance(), and m_rlevelBlockCache.
Referenced by setProperty().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 1160 of file ossimKakaduJpipHandler.cpp.
References ossimString::c_str(), ossimImageGeometryRegistry::createGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getCurrentEntry(), ossimImageHandler::getImageGeometry(), ossimInfoBase::getKeywordlist(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimKakaduJpipInfo::setHandler(), ossimImageHandler::theGeometry, ossimString::toString(), and ossimRefPtr< T >::valid().
Implements ossimImageHandler.
Definition at line 707 of file ossimKakaduJpipHandler.cpp.
References ossimIpt::hasNans(), m_tileSize, and ossimIpt::y.
Definition at line 702 of file ossimKakaduJpipHandler.cpp.
References ossimIpt::hasNans(), m_tileSize, and ossimIpt::x.
This returns the total number of decimation levels.
It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 756 of file ossimKakaduJpipHandler.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), m_overviewDimensions, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getTile(), and getTileAtRes().
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 692 of file ossimKakaduJpipHandler.cpp.
References m_nInputBands.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 664 of file ossimKakaduJpipHandler.cpp.
References ossimImageHandler::getNumberOfLines(), m_overviewDimensions, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 697 of file ossimKakaduJpipHandler.cpp.
References m_nOutputBands.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 678 of file ossimKakaduJpipHandler.cpp.
References ossimImageHandler::getNumberOfSamples(), m_overviewDimensions, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 712 of file ossimKakaduJpipHandler.cpp.
References m_bitDepth, m_signed, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT8, OSSIM_UINT11, OSSIM_UINT12, OSSIM_UINT13, OSSIM_UINT14, OSSIM_UINT15, OSSIM_UINT16, and OSSIM_UINT8.
Referenced by open().
Definition at line 1140 of file ossimKakaduJpipHandler.cpp.
References ossimRefPtr< T >::get(), m_quality, ossimProperty::setCacheRefreshBit(), ossimProperty::setFullRefreshBit(), and ossimString::toString().
Definition at line 1154 of file ossimKakaduJpipHandler.cpp.
References ossimImageHandler::getPropertyNames(), and ossimKeywordNames::QUALITY_KW.
Definition at line 792 of file ossimKakaduJpipHandler.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnect(), ossimRefPtr< T >::get(), getNumberOfDecimationLevels(), ossimImageRenderer::getResampler(), ossimImageRenderer::getTile(), getTileAtRes(), ossimIrect::lr(), m_quality, ossimNotify(), ossimNotifyLevel_WARN, ossimImageViewAffineTransform::scale(), ossimFilterResampler::setFilterType(), ossimMemoryImageSource::setImage(), ossimImageRenderer::setImageViewTransform(), ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
protected |
Definition at line 866 of file ossimKakaduJpipHandler.cpp.
References ossimAppFixedTileCache::addTile(), allocateTile(), ossim::clipRegionToImage(), ossimIrect::clipToRect(), ossim::copyRegionToTile(), ossimImageDataFactory::create(), ossimRefPtr< T >::get(), ossimImageHandler::getBoundingRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), getNumberOfDecimationLevels(), getNumberOfInputBands(), ossimImageHandler::getOverviewTile(), ossimImageSource::getTile(), ossimAppFixedTileCache::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimAppFixedTileCache::instance(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), loadClient(), ossimImageData::loadTile(), ossimIrect::lr(), m_client, m_nQualityLayers, m_overviewDimensions, m_rlevelBlockCache, m_rlevelTileSize, m_tile, m_useOurGrab, ossimImageData::makeBlank(), OSSIM_BSQ, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimIrect::stretchToTileBoundary(), ossimImageHandler::theOverview, ossimString::toString(), ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by getTile().
protected |
Definition at line 1100 of file ossimKakaduJpipHandler.cpp.
References deleteRlevelCache(), ossimAppFixedTileCache::instance(), m_overviewDimensions, m_rlevelBlockCache, m_rlevelTileSize, and ossimIrect::stretchToTileBoundary().
inlinevirtual |
Indicates whether or not the image is tiled internally.
This implementation returns true if (getImageTileWidth() && getImageTileHeight()) are both non zero. Override in the image handler if something else is desired. Returns true if tiled, false if not.
Definition at line 56 of file ossimKakaduJpipHandler.h.
References ossimIpt::hasNans(), and m_tileSize.
Definition at line 99 of file ossimKakaduJpipHandler.cpp.
References m_client.
Referenced by getTileAtRes(), and open().
protected |
Definition at line 482 of file ossimKakaduJpipHandler.cpp.
References ossimHttpRequest::addHeaderOption(), allocateSession(), ossimString::c_str(), ossimHttpRequest::clearHeaderOptions(), ossimWebRequestFactoryRegistry::createHttp(), ossimString::empty(), ossimRefPtr< T >::get(), ossimWebRequest::getResponse(), ossimHttpResponse::getStatusCode(), ossimHttpResponse::headerKwl(), ossimWebRequestFactoryRegistry::instance(), m_baseUrl, m_cid, m_path, m_request, m_transport, m_useOurGrab, ossimHttpRequest::set(), ossimUrl::setParams(), ossimString::substitute(), ossimString::toString(), ossimString::trim(), and ossimRefPtr< T >::valid().
Referenced by extractBoxes(), getTileAtRes(), and openStream().
Definition at line 1190 of file ossimKakaduJpipHandler.cpp.
References close(), ossimKeywordlist::find(), ossimImageHandler::loadState(), m_baseUrl, m_quality, openStream(), and ossimKeywordNames::QUALITY_KW.
protected |
Definition at line 1053 of file ossimKakaduJpipHandler.cpp.
References ossimString::c_str(), ossimString::empty(), ossimUrl::getIp(), ossimUrl::getPath(), ossimUrl::getPort(), m_baseUrl, and m_requestQueueId.
Pure virtual open.
Derived classes must implement.
Definition at line 402 of file ossimKakaduJpipHandler.cpp.
References ossimKeywordlist::addFile(), close(), ossimString::downcase(), ossimFilename::exists(), ossimFilename::ext(), ossimImageHandler::getFilename(), getOutputScalarType(), isOpen(), loadState(), m_baseUrl, openStream(), and OSSIM_SCALAR_UNKNOWN.
protected |
Definition at line 260 of file ossimKakaduJpipHandler.cpp.
References close(), ossimImageHandler::completeOpen(), ossimString::downcase(), ossimUrl::getProtocol(), loadClient(), m_baseUrl, m_bitDepth, m_bYCC, m_client, m_headerClient, m_imageBounds, m_jp2Family, m_nInputBands, m_nOutputBands, m_nQualityLayers, m_resLevels, m_signed, m_tileSize, m_useOurGrab, ossimIrect::makeNan(), performRlevelSetup(), ossimUrl::setProtocol(), showBoxes(), ossimIpt::x, and ossimIpt::y.
Referenced by loadState(), and open().
protected |
Definition at line 1076 of file ossimKakaduJpipHandler.cpp.
References deleteRlevelCache(), ossimIrect::height(), ossimAppFixedTileCache::instance(), m_overviewDimensions, m_resLevels, m_rlevelBlockCache, m_rlevelTileSize, m_tileSize, ossimIrect::stretchToTileBoundary(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by openStream().
Definition at line 1213 of file ossimKakaduJpipHandler.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimUrl::getProtocol(), m_baseUrl, m_quality, ossimKeywordNames::QUALITY_KW, ossimImageHandler::saveState(), ossimUrl::setProtocol(), and ossimUrl::toString().
Definition at line 1115 of file ossimKakaduJpipHandler.cpp.
References ossim::almostEqual(), flushCache(), ossimRefPtr< T >::get(), m_client, m_quality, ossimImageHandler::setProperty(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
protected |
Definition at line 146 of file ossimKakaduJpipHandler.cpp.
References m_jp2Family.
protected |
Definition at line 89 of file ossimKakaduJpipHandler.h.
Referenced by allocateSession(), loadClient(), loadState(), makeConnectionIfNeeded(), open(), openStream(), and saveState().
protected |
Definition at line 94 of file ossimKakaduJpipHandler.h.
Referenced by getOutputScalarType(), and openStream().
protected |
Definition at line 99 of file ossimKakaduJpipHandler.h.
protected |
Definition at line 110 of file ossimKakaduJpipHandler.h.
Referenced by allocateSession(), and loadClient().
protected |
Definition at line 104 of file ossimKakaduJpipHandler.h.
Referenced by close(), extractBoxes(), getTileAtRes(), isOpen(), openStream(), and setProperty().
protected |
Definition at line 103 of file ossimKakaduJpipHandler.h.
Referenced by close(), extractBoxes(), and openStream().
protected |
Definition at line 97 of file ossimKakaduJpipHandler.h.
protected |
Definition at line 105 of file ossimKakaduJpipHandler.h.
Referenced by close(), extractBoxes(), openStream(), and showBoxes().
protected |
Definition at line 91 of file ossimKakaduJpipHandler.h.
Referenced by getNumberOfInputBands(), and openStream().
protected |
Definition at line 92 of file ossimKakaduJpipHandler.h.
Referenced by getNumberOfOutputBands(), and openStream().
protected |
Definition at line 95 of file ossimKakaduJpipHandler.h.
Referenced by getTileAtRes(), and openStream().
protected |
Definition at line 90 of file ossimKakaduJpipHandler.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), getTileAtRes(), initializeRlevelCache(), and performRlevelSetup().
protected |
Definition at line 111 of file ossimKakaduJpipHandler.h.
protected |
Definition at line 102 of file ossimKakaduJpipHandler.h.
Referenced by getProperty(), getTile(), loadState(), saveState(), and setProperty().
protected |
Definition at line 113 of file ossimKakaduJpipHandler.h.
Referenced by allocateSession(), close(), and loadClient().
protected |
Definition at line 106 of file ossimKakaduJpipHandler.h.
Referenced by makeConnectionIfNeeded().
protected |
Definition at line 98 of file ossimKakaduJpipHandler.h.
Referenced by openStream(), and performRlevelSetup().
protected |
Definition at line 108 of file ossimKakaduJpipHandler.h.
Referenced by deleteRlevelCache(), flushCache(), getTileAtRes(), initializeRlevelCache(), and performRlevelSetup().
protected |
Definition at line 107 of file ossimKakaduJpipHandler.h.
Referenced by getTileAtRes(), initializeRlevelCache(), and performRlevelSetup().
protected |
Definition at line 93 of file ossimKakaduJpipHandler.h.
protected |
Definition at line 100 of file ossimKakaduJpipHandler.h.
Referenced by allocateTile(), and getTileAtRes().
protected |
Definition at line 96 of file ossimKakaduJpipHandler.h.
Referenced by getImageTileHeight(), getImageTileWidth(), isImageTiled(), openStream(), and performRlevelSetup().
protected |
Definition at line 112 of file ossimKakaduJpipHandler.h.
protected |
Definition at line 88 of file ossimKakaduJpipHandler.h.
Referenced by getTileAtRes(), loadClient(), and openStream().
protected |
Definition at line 114 of file ossimKakaduJpipHandler.h.
