This is a 2 color view of the input. More...
#include <ossimTwoColorView.h>
Public Types | |
| enum | ossimTwoColorMultiViewOutputSource { UNKNOWN = 0, MIN = 1, OLD = 2, NEW = 3 } |
| Enumerations for mapping inputs to red, green and blue output channels. More... | |
| ossimTwoColorView () | |
| ossimScalarType | getOutputScalarType () const |
| double | getNullPixelValue (ossim_uint32 band) const |
| double | getMinPixelValue (ossim_uint32 band) const |
| double | getMaxPixelValue (ossim_uint32 band) const |
| void | setBandIndexMapping (ossim_uint32 oldInputBandIndex, ossim_uint32 newInputBandIndex, ossimTwoColorMultiViewOutputSource redOutputSource, ossimTwoColorMultiViewOutputSource grnOutputSource, ossimTwoColorMultiViewOutputSource bluOutputSource) |
| Sets which bands to use from inputs, and which inputs to use for output red, green and blue channels. More... | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | allocate () |
| void | runAlgorithm (ossimImageData *newData, ossimImageData *oldData) |
| void | runNative8 (ossimImageData *newData, ossimImageData *oldData) |
| void | runNorm (ossimImageData *newData, ossimImageData *oldData) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
It basically allows for a change detection and by default will take the first input and map it to the blue channel and takes the second input and maps to the red channel. The unused channel is mapped to a min pixel value.
Definition at line 18 of file ossimTwoColorView.h.
| Enumerator | |
| UNKNOWN | |
| MIN | |
| OLD | |
| NEW | |
Definition at line 26 of file ossimTwoColorView.h.
| ossimTwoColorView::ossimTwoColorView | ( | ) |
Definition at line 16 of file ossimTwoColorView.cpp.
protected |
Definition at line 359 of file ossimTwoColorView.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_twoColorTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Reimplemented from ossimImageCombiner.
Definition at line 81 of file ossimTwoColorView.cpp.
References ossimImageCombiner::getMaxPixelValue(), ossimSource::isSourceEnabled(), and m_byPassFlag.
Definition at line 72 of file ossimTwoColorView.cpp.
References ossimImageCombiner::getMinPixelValue(), ossimSource::isSourceEnabled(), and m_byPassFlag.
Definition at line 63 of file ossimTwoColorView.cpp.
References ossimImageCombiner::getNullPixelValue(), ossimSource::isSourceEnabled(), and m_byPassFlag.
Definition at line 31 of file ossimTwoColorView.cpp.
References ossimImageSource::getNumberOfOutputBands(), ossimSource::isSourceEnabled(), and m_byPassFlag.
Definition at line 40 of file ossimTwoColorView.cpp.
References ossimImageCombiner::getOutputScalarType(), ossimSource::isSourceEnabled(), m_byPassFlag, and OSSIM_UINT8.
Definition at line 90 of file ossimTwoColorView.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimImageCombiner::getNextTile(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), m_byPassFlag, m_newInput, m_oldInput, m_twoColorTile, ossimImageData::makeBlank(), runAlgorithm(), ossimImageData::setImageRectangle(), ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 369 of file ossimTwoColorView.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageCombiner::initialize(), m_byPassFlag, m_nativeFlag, m_newInput, m_newInputBandIndex, m_oldInput, m_oldInputBandIndex, m_twoColorTile, OSSIM_UINT8, and ossimRefPtr< T >::valid().
protected |
Definition at line 118 of file ossimTwoColorView.cpp.
References m_nativeFlag, runNative8(), and runNorm().
protected |
Definition at line 130 of file ossimTwoColorView.cpp.
References ossimImageData::getBuf(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), m_grnSource, m_newInputBandIndex, m_oldInputBandIndex, m_redSource, m_twoColorTile, n, NEW, OLD, and ossimRefPtr< T >::valid().
Referenced by runAlgorithm().
protected |
Definition at line 222 of file ossimTwoColorView.cpp.
References ossimImageData::copyTileBandToNormalizedBuffer(), ossimImageData::getBuf(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), m_grnSource, m_newInputBandIndex, m_oldInputBandIndex, m_redSource, m_twoColorTile, n, NEW, OLD, and ossimRefPtr< T >::valid().
| void ossimTwoColorView::setBandIndexMapping | ( | ossim_uint32 | oldInputBandIndex, |
| ossim_uint32 | newInputBandIndex, | ||
| ossimTwoColorMultiViewOutputSource | redOutputSource, | ||
| ossimTwoColorMultiViewOutputSource | grnOutputSource, | ||
| ossimTwoColorMultiViewOutputSource | bluOutputSource | ||
This method does no error checking as the inputs may or may not be set prior to this call. ossimTwoColorView::initialize() will verify once inputs are established. So if an input band is out of range band 0 (first band) will be used.
Callers should ensure initialize is called after this.
| oldInputBandIndex | Zero based band index for old input. Default=0 |
| newInputBandIndex | Zero based band index for new input. Default=0. |
| redOutputSource | default=OLD. Can be: ossimTwoColorMultiViewOutputSource::OLD ossimTwoColorMultiViewOutputSource::NEW ossimTwoColorMultiViewOutputSource::MIN |
| grnOutputSource | default=NEW. Can be: ossimTwoColorMultiViewOutputSource::OLD ossimTwoColorMultiViewOutputSource::NEW ossimTwoColorMultiViewOutputSource::MIN |
| bluOutputSource | default=NEW. Can be: ossimTwoColorMultiViewOutputSource::OLD ossimTwoColorMultiViewOutputSource::NEW ossimTwoColorMultiViewOutputSource::MIN |
Definition at line 49 of file ossimTwoColorView.cpp.
References m_bluSource, m_grnSource, m_newInputBandIndex, m_oldInputBandIndex, and m_redSource.
protected |
Definition at line 101 of file ossimTwoColorView.h.
Referenced by setBandIndexMapping().
protected |
Definition at line 92 of file ossimTwoColorView.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfOutputBands(), getOutputScalarType(), getTile(), and initialize().
protected |
Definition at line 100 of file ossimTwoColorView.h.
Referenced by runNative8(), runNorm(), and setBandIndexMapping().
protected |
Definition at line 93 of file ossimTwoColorView.h.
Referenced by initialize(), and runAlgorithm().
protected |
Definition at line 95 of file ossimTwoColorView.h.
Referenced by getTile(), and initialize().
protected |
Definition at line 97 of file ossimTwoColorView.h.
Referenced by initialize(), runNative8(), runNorm(), and setBandIndexMapping().
protected |
Definition at line 96 of file ossimTwoColorView.h.
protected |
Definition at line 98 of file ossimTwoColorView.h.
protected |
Definition at line 99 of file ossimTwoColorView.h.
protected |
Definition at line 94 of file ossimTwoColorView.h.
Referenced by allocate(), getTile(), initialize(), runNative8(), and runNorm().
