#include <ossimGeoPolyCutter.h>
| ossimGeoPolyCutter () | |
| virtual void | setPolygon (const vector< ossimDpt > &polygon, ossim_uint32 i=0) |
| virtual void | setPolygon (const vector< ossimIpt > &polygon, ossim_uint32 i=0) |
| virtual void | setPolygon (const vector< ossimGpt > &polygon, ossim_uint32 i=0) |
| virtual void | setPolygon (const ossimGeoPolygon &polygon, ossim_uint32 i=0) |
| virtual void | addPolygon (const vector< ossimIpt > &polygon) |
| virtual void | addPolygon (const vector< ossimDpt > &polygon) |
| virtual void | addPolygon (const vector< ossimGpt > &polygon) |
| virtual void | addPolygon (const ossimPolygon &polygon) |
| virtual void | addPolygon (const ossimGeoPolygon &polygon) |
| virtual void | setNumberOfPolygons (ossim_uint32 count) |
| virtual std::vector< ossimGeoPolygon > & | getGeoPolygonList () |
| virtual const std::vector< ossimGeoPolygon > & | getGeoPolygonList () const |
| virtual bool | setView (ossimObject *baseObject) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
Public Member Functions inherited from ossimPolyCutter | |
| ossimPolyCutter () | |
| ossimPolyCutter (ossimImageSource *inputSource, const ossimPolygon &polygon) | |
| virtual std::vector< ossimPolygon > & | getPolygonList () |
| virtual const std::vector< ossimPolygon > & | getPolygonList () const |
| void | setCutType (ossimPolyCutterCutType cutType) |
| ossimPolyCutterCutType | getCutType () const |
| void | clear () |
| const ossimIrect & | getRectangle () const |
| void | setRectangle (const ossimIrect &rect) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| virtual | ~ossimGeoPolyCutter () |
| void | invertPolygon (int polygonNumber) |
| void | transformVertices () |
| void | transformVertices (int i) |
Protected Member Functions inherited from ossimPolyCutter | |
| virtual | ~ossimPolyCutter () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | computeBoundingRect () |
Public Types inherited from ossimPolyCutter | |
| enum | ossimPolyCutterCutType { OSSIM_POLY_NULL_INSIDE = 0, OSSIM_POLY_NULL_OUTSIDE = 1 } |
This classes overrides the 2-d counter part ossimPolyCutter. It will automatically map 2-D to 3-D (ground) polygons if you add 2-D polygons and will automatically compute the forward transform when adding a ground polygon.
you can set the view trough the ossimViewInterface by calling setView(object, true); it will cast to an ossimProjection and use that as the transformation. For igen this is set automatically and does not need to be set by the user.
This class has no keywords but does use 2 prefix values to store out the view and the ground polygon for example if we have only one polygon then here is a sample keyword list for the polygons: NOTE we can have any number of polygons just increment the geo_polygon0 to geo_polygon1 .. geo_polygonN for the Nth one
geo_polygon0.datum: WGE geo_polygon0.number_vertices: 18 geo_polygon0.type: ossimGeoPolygon geo_polygon0.v0: 38.023634368488452 -122.542245818545709 nan geo_polygon0.v1: 38.016619667868909 -122.548990722987568 nan geo_polygon0.v2: 38.018238444934966 -122.546292761210807 nan geo_polygon0.v3: 38.012932453440698 -122.547911538276864 nan geo_polygon0.v4: 38.014731094625191 -122.542065954427244 nan geo_polygon0.v5: 38.007446597827986 -122.541796158249582 nan geo_polygon0.v6: 38.009694899308606 -122.537569351466018 nan geo_polygon0.v7: 38.005108364288141 -122.537119691169892 nan geo_polygon0.v8: 38.008255986361007 -122.532353292030976 nan geo_polygon0.v9: 38.003039926925965 -122.531274107320272 nan geo_polygon0.v10: 38.013292181677599 -122.529565398195004 nan geo_polygon0.v11: 38.009874763427050 -122.526867436418243 nan geo_polygon0.v12: 38.019587425823332 -122.528306349365849 nan geo_polygon0.v13: 38.023904164666128 -122.537299555288328 nan geo_polygon0.v14: 38.024983349376825 -122.544584052085540 nan geo_polygon0.v15: 38.023904164666128 -122.548720926809878 nan geo_polygon0.v16: 38.022195455540853 -122.562210735693611 nan geo_polygon0.v17: 38.019317629645663 -122.562930192167400 nan
the example for the view information is
view.central_meridian: -123.000000000000000 view.datum: WGE view.decimal_degrees_per_pixel_lat: 0.000089932059225 view.decimal_degrees_per_pixel_lon: 0.000089932059225 view.ellipse_code: WE view.ellipse_name: WGS 84 view.false_easting: 0.000000000000000 view.false_northing: 0.000000000000000 view.major_axis: 6378137.000000000000000 view.meters_per_pixel_x: 10.000000000000000 view.meters_per_pixel_y: 10.000000000000000 view.minor_axis: 6356752.314199999906123 view.origin_latitude: 0.000000000000000 view.rotation: 0.000000000000000 view.scale_x: 1.000000000000000 view.scale_y: 1.000000000000000 view.tie_point_easting: 0.000000000000000 view.tie_point_lat: 0.000000000000000 view.tie_point_lon: -123.000000000000000 view.tie_point_northing: 0.000000000000000 view.translation_x: 0.000000000000000 view.translation_y: 0.000000000000000 view.type: ossimEquDistCylProjection
Definition at line 88 of file ossimGeoPolyCutter.h.
| ossimGeoPolyCutter::ossimGeoPolyCutter | ( | ) |
Definition at line 22 of file ossimGeoPolyCutter.cpp.
References ossimViewInterface::theObject.
protectedvirtual |
Definition at line 32 of file ossimGeoPolyCutter.cpp.
Will invert this polygon out to world space and add it to the polygon list
Reimplemented from ossimPolyCutter.
Definition at line 182 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::addPolygon(), invertPolygon(), m_geoPolygonList, m_viewGeometry, ossimPolyCutter::thePolygonList, and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addGeoPolyCutterPolygon(), and ossimTilingPoly::nextFeature().
Will invert the passed in polygon to world space and add to the polygon list
Definition at line 192 of file ossimGeoPolyCutter.cpp.
Will add the ground polygon to the list
Definition at line 171 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, m_viewGeometry, ossimPolyCutter::thePolygonList, transformVertices(), and ossimRefPtr< T >::valid().
Will invert te polygon to ground and add.
Definition at line 202 of file ossimGeoPolyCutter.cpp.
Will add the passed in polygon.
Definition at line 212 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::addPolygon(), m_geoPolygonList, m_viewGeometry, transformVertices(), and ossimRefPtr< T >::valid().
This should only be used for informational uses only. If updates are to be made please go through the access methods that change the polygon data.
Definition at line 236 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList.
Definition at line 241 of file ossimGeoPolyCutter.cpp.
Implements ossimViewInterface.
Definition at line 305 of file ossimGeoPolyCutter.cpp.
References ossimRefPtr< T >::get(), and m_viewGeometry.
Definition at line 310 of file ossimGeoPolyCutter.cpp.
protected |
Utility method used to invert any passed in projected polygons to be changed or added to the list.
| polygonNumber | the index of the polygon to invert to ground. |
Definition at line 246 of file ossimGeoPolyCutter.cpp.
References ossimGeoPolygon::clear(), ossimPolygon::getVertexCount(), ossimImageGeometry::localToWorld(), m_geoPolygonList, m_viewGeometry, ossimGeoPolygon::resize(), and ossimPolyCutter::thePolygonList.
Referenced by addPolygon(), and setPolygon().
Definition at line 73 of file ossimGeoPolyCutter.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), ossimImageSourceFilter::loadState(), ossimImageGeometry::loadState(), m_geoPolygonList, m_viewGeometry, ossimPolyCutter::OSSIM_POLY_NULL_INSIDE, ossimPolyCutter::OSSIM_POLY_NULL_OUTSIDE, ossimPolyCutter::theCutType, ossimPolyCutter::thePolygonList, ossimString::toInt(), ossimString::toString(), and transformVertices().
Definition at line 36 of file ossimGeoPolyCutter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), m_geoPolygonList, ossimPolyCutter::thePolygonList, and ossimString::toString().
Will set the number of polygons and will call the base class set number of polygons.
Definition at line 223 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, and ossimPolyCutter::setNumberOfPolygons().
Sets the polygon to the specified polygon index. /param polygon A vector of points in projected 2-D. /param i index of the polygon to change.
Definition at line 128 of file ossimGeoPolyCutter.cpp.
References invertPolygon(), m_viewGeometry, ossimPolyCutter::setPolygon(), and ossimRefPtr< T >::valid().
Referenced by ossimIgenGenerator::generateGeoTiledSpecList(), ossimIgenGenerator::generateNoTiledSpecList(), ossimIgenGenerator::generatePixelTiledSpecList(), and ossimTilingPoly::nextFeature().
Definition at line 138 of file ossimGeoPolyCutter.cpp.
Sets the polygon to the specified polygon index. /param polygon A Ground polygon. /param i index of the polygon to change.
Definition at line 148 of file ossimGeoPolyCutter.cpp.
References m_geoPolygonList, and transformVertices().
Definition at line 159 of file ossimGeoPolyCutter.cpp.
References ossimGeoPolygon::getVertexList(), m_geoPolygonList, and transformVertices().
Will set the view to the passed in object. Once set it will project the ground polygon relative to the passed in view.
Definition at line 263 of file ossimGeoPolyCutter.cpp.
References ossimRefPtr< T >::get(), ossimImageGeometry::isEqualTo(), m_viewGeometry, ossimNotify(), ossimNotifyLevel_WARN, transformVertices(), and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addGeoPolyCutter(), and ossimTilingPoly::nextFeature().
protected |
Transforms all vertices based on the current m_viewProjection.
Definition at line 315 of file ossimGeoPolyCutter.cpp.
References ossimPolyCutter::computeBoundingRect(), ossimPolygon::getVertexCount(), m_geoPolygonList, m_viewGeometry, ossimPolygon::resize(), ossimGeoPolygon::size(), ossimPolyCutter::thePolygonList, ossimRefPtr< T >::valid(), ossimImageGeometry::worldToLocal(), x, and y.
Referenced by addPolygon(), loadState(), setPolygon(), and setView().
protected |
Transforms the specified polygon index.
| i | The polygon index to project. |
Definition at line 351 of file ossimGeoPolyCutter.cpp.
protected |
Definition at line 215 of file ossimGeoPolyCutter.h.
Referenced by addPolygon(), getGeoPolygonList(), invertPolygon(), loadState(), saveState(), setNumberOfPolygons(), setPolygon(), and transformVertices().
protected |
The view projection used to project the ground coordinates.
Definition at line 213 of file ossimGeoPolyCutter.h.
Referenced by addPolygon(), getView(), invertPolygon(), loadState(), setPolygon(), setView(), and transformVertices().
