#include <ossimKMeansFilter.h>
Public Types | |
| enum | ThresholdMode { NONE =0, MEAN =1, SIGMA_WEIGHTED =2, VARIANCE_WEIGHTED =3 } |
| ossimKMeansFilter () | |
| ossimKMeansFilter (ossimImageSource *input_source, ossimMultiBandHistogram *histogram=0) | |
| Quicker constructor handles connections to source and optional histogram. More... | |
| ~ossimKMeansFilter () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| void | setInputHistogram (ossimMultiBandHistogram *histo) |
| Sets the input source's histogram for quicker K-means analysis. More... | |
| void | setNumClusters (ossim_uint32 K) |
| Defines how many classification clusters will be resolved. More... | |
| void | setClusterPixelValues (const ossim_uint32 *dns, ossim_uint32 K) |
| Optionally define the output digital numbers for each cluster to be used for remapping the input pixels. More... | |
| void | setThresholdMode (ThresholdMode mode) |
| Special use case is to use K-means for thresholding an image into two values based on the histogram's clustering. More... | |
| const ossimKMeansClustering * | getBandClassifier (ossim_uint32 band=0) const |
| Callers may be interested in reporting the cluster statistics computed by this class. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| bool | computeKMeans () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | clear () |
Definition at line 50 of file ossimKMeansFilter.h.
| Enumerator | |
| NONE | |
| MEAN | |
| SIGMA_WEIGHTED | |
| VARIANCE_WEIGHTED | |
Definition at line 53 of file ossimKMeansFilter.h.
| ossimKMeansFilter::ossimKMeansFilter | ( | ) |
Definition at line 23 of file ossimKMeansFilter.cpp.
References ossimConnectableObject::setDescription().
| ossimKMeansFilter::ossimKMeansFilter | ( | ossimImageSource * | input_source, |
| ossimMultiBandHistogram * | histogram = 0 |
Definition at line 34 of file ossimKMeansFilter.cpp.
| ossimKMeansFilter::~ossimKMeansFilter | ( | ) |
Definition at line 47 of file ossimKMeansFilter.cpp.
protected |
Definition at line 146 of file ossimKMeansFilter.cpp.
References ossimImageDataFactory::create(), ossimImageSourceFilter::getNumberOfInputBands(), initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_classifiers, m_initialized, m_numClusters, m_tile, max, min, ossimImageData::setMaxPix(), ossimImageData::setMinPix(), and ossimRefPtr< T >::valid().
Referenced by getTile().
protected |
Definition at line 286 of file ossimKMeansFilter.cpp.
References m_classifiers, m_initialized, and m_numClusters.
Referenced by setNumClusters().
protected |
Definition at line 220 of file ossimKMeansFilter.cpp.
References ossimKMeansClustering::computeKmeans(), ossimHistogram::GetCounts(), ossimMultiBandHistogram::getHistogram(), ossimKMeansClustering::getMean(), ossimImageSourceFilter::getNumberOfInputBands(), ossimKMeansClustering::getNumClusters(), ossimHistogram::GetRes(), ossimKMeansClustering::getSigma(), ossimHistogram::GetVals(), initialize(), m_classifiers, m_histogram, m_initialized, m_numClusters, m_thresholdMode, m_thresholds, MEAN, NONE, ossimKMeansClustering::setNumClusters(), ossimKMeansClustering::setPopulations(), ossimKMeansClustering::setSamples(), ossimKMeansClustering::setVerbose(), SIGMA_WEIGHTED, ossimRefPtr< T >::valid(), and VARIANCE_WEIGHTED.
| const ossimKMeansClustering * ossimKMeansFilter::getBandClassifier | ( | ossim_uint32 | band = 0 | ) | const |
Returns the clusters (of size K) for the band index specified.
Definition at line 331 of file ossimKMeansFilter.cpp.
References m_classifiers.
Definition at line 414 of file ossimKMeansFilter.cpp.
References m_maxPixelValue.
Definition at line 407 of file ossimKMeansFilter.cpp.
References m_minPixelValue.
Definition at line 395 of file ossimKMeansFilter.cpp.
References m_numClusters, OSSIM_SCALAR_UNKNOWN, OSSIM_UINT16, and OSSIM_UINT8.
Definition at line 58 of file ossimKMeansFilter.cpp.
References allocate(), computeKMeans(), ossimImageData::getBuf(), ossimKMeansClustering::getCluster(), ossimDataObject::getDataObjectStatus(), ossimMultiBandHistogram::getHistogram(), ossimImageSource::getNullPixelValue(), ossimImageSourceFilter::getNumberOfInputBands(), ossimImageData::getPix(), ossimImageSource::getTile(), initialize(), ossimIrect::lr(), m_classifiers, m_histogram, m_initialized, m_numClusters, m_pixelValues, m_thresholds, m_tile, ossimImageData::makeBlank(), ossimKMeansClustering::Cluster::max, ossimKMeansClustering::Cluster::min, OSSIM_EMPTY, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Definition at line 181 of file ossimKMeansFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageHistogramSource::execute(), ossimMultiBandHistogram::getHistogram(), ossimImageHistogramSource::getHistogram(), ossimMultiResLevelHistogram::getMultiBandHistogram(), ossimImageSourceFilter::getNumberOfInputBands(), ossimHistogram::GetRangeMax(), ossimHistogram::GetRangeMin(), ossimImageSourceFilter::initialize(), m_histogram, m_initialized, m_maxPixelValue, m_minPixelValue, m_tile, OSSIM_HISTO_MODE_FAST, ossimImageHistogramSource::setComputationMode(), ossimImageHistogramSource::setMaxNumberOfRLevels(), ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
Referenced by allocate(), computeKMeans(), and getTile().
Definition at line 383 of file ossimKMeansFilter.cpp.
References ossimImageSourceFilter::loadState().
Definition at line 338 of file ossimKMeansFilter.cpp.
References ossimKeywordlist::add(), ossimString::chars(), ossimKMeansClustering::getCluster(), ossimImageSourceFilter::getNumberOfInputBands(), m_classifiers, m_numClusters, ossimKMeansClustering::Cluster::max, ossimKMeansClustering::Cluster::mean, ossimKMeansClustering::Cluster::min, ossimImageSourceFilter::saveState(), ossimKMeansClustering::Cluster::sigma, and ossimString::toString().
| void ossimKMeansFilter::setClusterPixelValues | ( | const ossim_uint32 * | dns, |
| ossim_uint32 | K | ||
K is the size of the array, resetting any previously set K value. If thresholding enabled (see setThreshold()), then only the first two values are referenced. LIMITATION: Curently, only UInt8 supported, so dns and K values must be 0-255.
Definition at line 318 of file ossimKMeansFilter.cpp.
References m_numClusters, m_pixelValues, and setNumClusters().
| void ossimKMeansFilter::setInputHistogram | ( | ossimMultiBandHistogram * | histo | ) |
Definition at line 51 of file ossimKMeansFilter.cpp.
References m_histogram, m_initialized, and m_thresholds.
| void ossimKMeansFilter::setNumClusters | ( | ossim_uint32 | K | ) |
The input connection should be made prior so that the number of bands is known. LIMITATION: Curently, only K values < 256 are supported.
Definition at line 298 of file ossimKMeansFilter.cpp.
References clear(), m_numClusters, and m_pixelValues.
Referenced by setClusterPixelValues().
| void ossimKMeansFilter::setThresholdMode | ( | ThresholdMode | mode | ) |
The threshold point can be left at the default boundary between clusters, or alternatively, can be computed according to predefined modes. Currently support the following modes (where mn and sn is the mean and sigma of nth cluster, respectively):
NONE Implies MEAN for multiple clusters. MEAN (m0 + m1)/2 SIGMA_WEIGHTED (s1*m0 + s0*m1)/(s0 + s1) VARIANCE_WEIGHTED (s1*s1*m0 + s0*s0*m1)/(s0*s0 + s1*s1)
Definition at line 293 of file ossimKMeansFilter.cpp.
References m_thresholdMode.
protected |
Definition at line 124 of file ossimKMeansFilter.h.
Referenced by allocate(), clear(), computeKMeans(), getBandClassifier(), getTile(), and saveState().
protected |
Have num_bands entries.
Definition at line 125 of file ossimKMeansFilter.h.
Referenced by computeKMeans(), getTile(), initialize(), and setInputHistogram().
protected |
Definition at line 132 of file ossimKMeansFilter.h.
Referenced by allocate(), clear(), computeKMeans(), getTile(), initialize(), and setInputHistogram().
protected |
Definition at line 129 of file ossimKMeansFilter.h.
Referenced by getMaxPixelValue(), and initialize().
protected |
Definition at line 128 of file ossimKMeansFilter.h.
Referenced by getMinPixelValue(), and initialize().
protected |
Definition at line 126 of file ossimKMeansFilter.h.
Referenced by allocate(), clear(), computeKMeans(), getOutputScalarType(), getTile(), saveState(), setClusterPixelValues(), and setNumClusters().
protected |
Definition at line 131 of file ossimKMeansFilter.h.
protected |
Definition at line 127 of file ossimKMeansFilter.h.
Referenced by getTile(), setClusterPixelValues(), and setNumClusters().
protected |
Definition at line 133 of file ossimKMeansFilter.h.
Referenced by computeKMeans(), and setThresholdMode().
protected |
Definition at line 134 of file ossimKMeansFilter.h.
Referenced by computeKMeans(), getTile(), and setInputHistogram().
protected |
Definition at line 130 of file ossimKMeansFilter.h.
Referenced by allocate(), getTile(), and initialize().
