#include <ossimERSTileSource.h>
| ossimERSTileSource () | |
| ossimERSTileSource (const ossimKeywordlist &kwl, const char *prefix=0) | |
| virtual ossimString | className () const |
| virtual bool | open (const ossimFilename &filename) |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
Public Member Functions inherited from ossimGeneralRasterTileSource | |
| ossimGeneralRasterTileSource () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| virtual bool | open (const ossimGeneralRasterInfo &info) |
| Override base getXXXXPixValue methods since the null/min/max can be set to something different. More... | |
| Initializes bandList to the zero based order of output bands. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimERSTileSource () |
Protected Member Functions inherited from ossimGeneralRasterTileSource | |
| virtual | ~ossimGeneralRasterTileSource () |
| virtual bool | fillBuffer (const ossimIpt &origin, const ossimIpt &size) |
| Methods return true on succes false on error. More... | |
| virtual bool | fillBIP (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBIL (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBSQ (const ossimIpt &origin, const ossimIpt &size) |
| virtual bool | fillBsqMultiFile (const ossimIpt &origin, const ossimIpt &size) |
| virtual ossimKeywordlist | getHdrInfo (ossimFilename hdrFile) |
| virtual ossimKeywordlist | getXmlInfo (ossimFilename xmlFile) |
| bool | initializeHandler () |
Private Member Functions | |
| void | openHeader (const ossimFilename &file) |
Private Attributes | |
| ossimERS * | theHdr |
Definition at line 24 of file ossimERSTileSource.h.
| ossimERSTileSource::ossimERSTileSource | ( | ) |
Definition at line 33 of file ossimERSTileSource.cpp.
| ossimERSTileSource::ossimERSTileSource | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix = 0 |
Definition at line 42 of file ossimERSTileSource.cpp.
References loadState(), ossimErrorCodes::OSSIM_ERROR, and ossimErrorStatusInterface::theErrorStatus.
protectedvirtual |
Definition at line 215 of file ossimERSTileSource.cpp.
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Reimplemented from ossimGeneralRasterTileSource.
Definition at line 144 of file ossimERSTileSource.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimImageGeometry::loadState(), ossimImageHandler::theGeometry, theHdr, and ossimERS::toOssimProjectionGeom().
Definition at line 210 of file ossimERSTileSource.cpp.
Definition at line 205 of file ossimERSTileSource.cpp.
Definition at line 188 of file ossimERSTileSource.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimGeneralRasterTileSource::loadState(), ossimImageSource::loadState(), and ossimGeneralRasterTileSource::open().
Referenced by ossimERSTileSource().
Definition at line 65 of file ossimERSTileSource.cpp.
References ossimKeywordlist::addFile(), ossimString::c_str(), ossimString::empty(), ossimERS::errorStatus(), ossimFilename::exists(), ossimFilename::fileNoExtension(), ossimGeneralRasterInfo::getImageMetaData(), ossimImageMetaData::getMaxPix(), ossimImageMetaData::getMaxValuesValidFlag(), ossimImageMetaData::getMinPix(), ossimImageMetaData::getMinValuesValidFlag(), ossimImageMetaData::getNullPix(), ossimImageMetaData::getNullValuesValidFlag(), ossimImageMetaData::loadState(), ossimGeneralRasterInfo::NONE, ossimGeneralRasterTileSource::open(), OSSIM_BIL, ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_INFO, ossimFilename::path(), ossimGeneralRasterInfo::print(), ossimString::push_back(), ossimImageMetaData::setMaxPix(), ossimImageMetaData::setMinPix(), ossimImageMetaData::setNullPix(), ossimERS::theBands, ossimERS::theCelltype, ossimERS::theHasNullCells, theHdr, ossimERS::theLine, ossimImageHandler::theMetaData, ossimERS::theNullCell, and ossimERS::theSample.
private |
private |
Definition at line 51 of file ossimERSTileSource.h.
Referenced by getImageGeometry(), open(), and ~ossimERSTileSource().
