#include <ossimBandSelector.h>
Public Types | |
| enum | ossimBandSelectorWithinRangeFlagState { ossimBandSelectorWithinRangeFlagState_NOT_SET = 0, ossimBandSelectorWithinRangeFlagState_IN_RANGE = 1, ossimBandSelectorWithinRangeFlagState_OUT_OF_RANGE = 2 } |
| ossimBandSelector () | |
| virtual | ~ossimBandSelector () |
| Initializes bandList to the zero based order of output bands. More... | |
| virtual void | setThreeBandRgb () |
| Will set to three bands (rgb) out. More... | |
| virtual void | setOutputBandList (const vector< ossim_uint32 > &outputBandList, bool disablePassThru=false) |
| Sets the output band list. More... | |
| Returns the number of input bands. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Override base class so that a disableSource event does not reinitialize the object and enable itself. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| void | checkPassThrough () |
| Will check all combinations of the band list to see if its. More... | |
| bool | outputBandsWithinInputRange () const |
| ossimRefPtr< ossimImageHandler > | getBandSelectableImageHandler () const |
| Finds and returns band selectable image handler. More... | |
| bool | getRgbBandList (std::vector< ossim_uint32 > &bandList) const |
| Attempts to derive rgb bands from image handler to the left of the band selector. More... | |
Definition at line 20 of file ossimBandSelector.h.
| Enumerator | |
| ossimBandSelectorWithinRangeFlagState_NOT_SET | |
| ossimBandSelectorWithinRangeFlagState_IN_RANGE | |
| ossimBandSelectorWithinRangeFlagState_OUT_OF_RANGE | |
Definition at line 24 of file ossimBandSelector.h.
| ossimBandSelector::ossimBandSelector | ( | ) |
Definition at line 30 of file ossimBandSelector.cpp.
protected |
Definition at line 276 of file ossimBandSelector.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
protected |
Definition at line 459 of file ossimBandSelector.cpp.
References ossimImageSource::getOutputBandList(), m_outputBandList, m_passThroughFlag, outputBandsWithinInputRange(), and ossimImageSourceFilter::theInputConnection.
Referenced by setOutputBandList().
protected |
To get a valid pointer there must be one and only one image handler on the input connection and it must be a band selector. In other words, must be a single image chain input and ossimImageHandler::isBandSelector() must return true.
GP: We will only allow the immediate input check for an image handler and if one is present then check if selectable
Definition at line 653 of file ossimBandSelector.cpp.
References ossimConnectableObject::accept(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimImageHandler::isBandSelector(), ossimImageSourceFilter::theInputConnection, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by getNumberOfInputBands(), and setOutputBandList().
Definition at line 556 of file ossimBandSelector.cpp.
Definition at line 345 of file ossimBandSelector.cpp.
References DBL_EPSILON, ossimImageSource::getMaxPixelValue(), isSourceEnabled(), m_outputBandList, and ossimImageSourceFilter::theInputConnection.
Definition at line 296 of file ossimBandSelector.cpp.
References ossimImageSource::getMinPixelValue(), isSourceEnabled(), m_outputBandList, and ossimImageSourceFilter::theInputConnection.
Definition at line 320 of file ossimBandSelector.cpp.
References ossimImageSource::getNullPixelValue(), isSourceEnabled(), m_outputBandList, and ossimImageSourceFilter::theInputConnection.
Overrides ossimImageSourceFilter::getNumberOfInputBands to check for a single image chain band selectable image handler on the input. If one is present it returns it's number of input bands instead of the number of the input connection's output bands(our input). This is needed so callers, e.g. band selector dialog box can query the number of bands available.
Definition at line 183 of file ossimBandSelector.cpp.
References getBandSelectableImageHandler(), ossimImageSourceFilter::getNumberOfInputBands(), ossimImageSource::getNumberOfInputBands(), and ossimRefPtr< T >::valid().
Referenced by outputBandsWithinInputRange().
Definition at line 161 of file ossimBandSelector.cpp.
References ossimImageSourceFilter::getNumberOfInputBands(), isSourceEnabled(), and m_outputBandList.
Referenced by ossimSingleImageChain::setToThreeBands().
Definition at line 540 of file ossimBandSelector.cpp.
References ossimImageSource::getOutputBandList(), isSourceEnabled(), m_outputBandList, and ossimImageSourceFilter::theInputConnection.
Referenced by getProperty().
Definition at line 603 of file ossimBandSelector.cpp.
References ossimProperty::clearChangeType(), getOutputBandList(), ossimImageSourceFilter::getProperty(), ossimString::join(), m_outputBandList, ossimProperty::setCacheRefreshBit(), ossimProperty::setReadOnlyFlag(), ossim::toSimpleStringList(), and ossimString::toString().
Definition at line 647 of file ossimBandSelector.cpp.
References ossimImageSourceFilter::getPropertyNames().
protected |
Must be one and only one image handler on the input connection. In other words, must be a single image chain input.
Definition at line 696 of file ossimBandSelector.cpp.
References ossimConnectableObject::accept(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimImageHandler::getRgbBandList(), ossimImageSourceFilter::theInputConnection, ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Definition at line 561 of file ossimBandSelector.cpp.
Definition at line 49 of file ossimBandSelector.cpp.
References allocate(), ossimImageData::assignBand(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), isSourceEnabled(), m_outputBandList, m_passThroughFlag, m_tile, m_withinRangeFlag, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, ossimBandSelectorWithinRangeFlagState_IN_RANGE, ossimBandSelectorWithinRangeFlagState_NOT_SET, ossimBandSelectorWithinRangeFlagState_OUT_OF_RANGE, outputBandsWithinInputRange(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 202 of file ossimBandSelector.cpp.
Referenced by loadState(), and setThreeBandRgb().
Definition at line 284 of file ossimBandSelector.cpp.
References ossimSource::isSourceEnabled(), and m_passThroughFlag.
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfOutputBands(), getOutputBandList(), and getTile().
Definition at line 400 of file ossimBandSelector.cpp.
References ossimKeywordNames::BANDS_KW, ossimString::downcase(), ossimString::empty(), ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), initialize(), ossimImageSourceFilter::loadState(), m_delayLoadRgbFlag, m_outputBandList, ossimString::toInt(), ossim::toSimpleVector(), and ossimString::toString().
protected |
Definition at line 502 of file ossimBandSelector.cpp.
References getNumberOfInputBands(), m_outputBandList, and ossimImageSourceFilter::theInputConnection.
Referenced by checkPassThrough(), and getTile().
Definition at line 369 of file ossimBandSelector.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BANDS_KW, m_outputBandList, ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW, ossimImageSourceFilter::saveState(), and ossim::toSimpleStringList().
| outputBandList | List of zero based bands. |
| disablePassThru | If true, forces the band selection to be performed by this filter. Otherwise, the image handler to the left is directed to select bands if it has that capability (default behavior). |
Definition at line 120 of file ossimBandSelector.cpp.
References checkPassThrough(), getBandSelectableImageHandler(), ossimImageData::getNumberOfBands(), ossimImageSource::getOutputScalarType(), ossimRectilinearDataObject::getScalarType(), m_outputBandList, m_passThroughFlag, m_tile, m_withinRangeFlag, ossimBandSelectorWithinRangeFlagState_NOT_SET, ossimImageHandler::setOutputBandList(), ossimImageSourceFilter::theInputConnection, and ossimRefPtr< T >::valid().
Referenced by ossimSingleImageChain::addBandSelector(), ATP::AtpAnnotatedImage::AtpAnnotatedImage(), ATP::AtpGenerator::constructChain(), main(), ossimSingleImageChain::setBandSelection(), and setProperty().
Definition at line 566 of file ossimBandSelector.cpp.
References ossimProperty::getName(), m_outputBandList, setOutputBandList(), ossimImageSourceFilter::setProperty(), ossimString::split(), ossim::toSimpleVector(), ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
This will attempt to auto detect the zero based rgb band order from the input image handler. If the result is < 3 bands we will not increase the band output by adding more bands. For example,
if the input is grey or thermal then it will just output one band for a default allocation. Note, this can be overriden by explicitly setting the output band list.
If the image handler implemented getRgbBandList(...) it will use that: bands = 2,1,0 ( or whatever handler thinks rgb is ) else if 3 band or greater and can't determine rgb: bands = 0,1,2 else (less than three bands) bands = 0
Definition at line 113 of file ossimBandSelector.cpp.
References initialize(), m_delayLoadRgbFlag, and m_outputBandList.
Referenced by ossimSingleImageChain::setDefaultBandSelection(), and ossimSingleImageChain::setToThreeBands().
protected |
Definition at line 183 of file ossimBandSelector.h.
protected |
Definition at line 184 of file ossimBandSelector.h.
protected |
Definition at line 180 of file ossimBandSelector.h.
Referenced by checkPassThrough(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfOutputBands(), getOutputBandList(), getProperty(), getTile(), loadState(), outputBandsWithinInputRange(), saveState(), setOutputBandList(), setProperty(), and setThreeBandRgb().
protected |
Definition at line 182 of file ossimBandSelector.h.
Referenced by checkPassThrough(), getTile(), isSourceEnabled(), and setOutputBandList().
protected |
Definition at line 179 of file ossimBandSelector.h.
Referenced by allocate(), getTile(), setOutputBandList(), and ~ossimBandSelector().
protected |
Definition at line 181 of file ossimBandSelector.h.
Referenced by getTile(), and setOutputBandList().
