Class to scan pixels and flip target dn value to a replacement dn value. More...
#include <ossimPixelFlipper.h>
Public Types | |
| enum | ReplacementMode { REPLACE_BAND_IF_TARGET = 0, REPLACE_BAND_IF_PARTIAL_TARGET = 1, REPLACE_ALL_BANDS_IF_PARTIAL_TARGET = 2, REPLACE_ONLY_FULL_TARGETS = 3, REPLACE_ALL_BANDS_IF_ANY_TARGET = 4 } |
| Target Replacement Mode: More... | |
| enum | ClampingMode { DISABLED = 0, CLAMPING_LO = 1, CLAMPING_HI = 2, CLAMPING_LO_AND_HI = 3 } |
| When either a lo and/or hi clamp value is set, the clamping mode will be enabled accordingly and override any target replacement defined. More... | |
| enum | ClipMode { NONE = 0, BOUNDING_RECT = 1, VALID_VERTICES = 2 } |
| ossimPixelFlipper (ossimObject *owner=NULL) | |
| Initializes the state of the object from theInputConnection. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| void | setTargetValue (ossim_float64 target_value) |
| void | setTargetRange (ossim_float64 target_min, ossim_float64 target_max) |
| Instead of a single value for a target, this method allows for specifying a range of values to flip to the replacement. More... | |
| void | setReplacementValue (ossim_float64 replacement_value) |
| void | setClampValue (ossim_float64 clamp_value, bool is_high_clamp_value=true) |
| void | setClampValues (ossim_float64 clamp_value_lo, ossim_float64 clamp_value_hi) |
| void | setReplacementMode (ossimPixelFlipper::ReplacementMode mode) |
| bool | setReplacementMode (const ossimString &modeString) |
| Accepts a string that must match the enumerator's label (can be lower case) and sets the replacement mode accordingly. More... | |
| void | setClipMode (const ossimString &modeString) |
| Clipping here refers to bounding rect or valid polygon (spacial) clipping, where all pixels outside the valid area are mapped to the replacement value. More... | |
| void | setClipMode (ClipMode mode) |
| ossim_float64 | getReplacementValue () const |
| ossimPixelFlipper::ReplacementMode | getReplacementMode () const |
| ossimString | getReplacementModeString () const |
| ossimString | getClipModeString () const |
| ClipMode | getClipMode () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Static Public Attributes | |
| static const char | PF_TARGET_VALUE_KW [] = "target_value" |
| static const char | PF_TARGET_RANGE_KW [] = "target_range" |
| static const char | PF_REPLACEMENT_VALUE_KW [] = "replacement_value" |
| static const char | PF_REPLACEMENT_MODE_KW [] = "replacement_mode" |
| static const char | PF_CLAMP_VALUE_KW [] = "clamp_value" |
| static const char | PF_CLAMP_VALUE_LO_KW [] = "clamp_value_lo" |
| static const char | PF_CLAMP_VALUE_HI_KW [] = "clamp_value_hi" |
| static const char | PF_CLIP_MODE_KW [] = "border_clip_mode" |
| virtual | ~ossimPixelFlipper () |
| destructor More... | |
| template<class T > | |
| void | flipPixels (T dummy, ossimImageData *inpuTile, ossim_uint32 resLevel) |
| This object can be used outside of an image chain for offline processing of existing tile. More... | |
| void | clipTile (T dummy, ossimImageData *inpuTile, ossim_uint32 resLevel) |
| bool | inRange (ossim_float64 value) const |
| Verifies pixel is in range. More... | |
| void | allocateClipTileBuffer (ossimRefPtr< ossimImageData > inputImage) |
This was written to fix problems with null pixels, i.e. an image has a digital number(dn) of 255 for null and it is desired to use a dn of 0 as a null. This can really be used to flip any pixel value to another.
Definition at line 37 of file ossimPixelFlipper.h.
| Enumerator | |
| DISABLED | |
| CLAMPING_LO | |
| CLAMPING_HI | |
| CLAMPING_LO_AND_HI | |
Definition at line 94 of file ossimPixelFlipper.h.
| Enumerator | |
| NONE | |
| BOUNDING_RECT | |
| VALID_VERTICES | |
Definition at line 102 of file ossimPixelFlipper.h.
Examples given for 3-band pixel values as (R, G, B) with target = 0, and replacement = 1
If mode is REPLACE_BAND_IF_TARGET (default): Any pixel band with value of target will be replaced. (0, 0, 0) becomes (1, 1, 1) (0, 3, 2) becomes (1, 3, 2)
If mode is REPLACE_BAND_IF_PARTIAL_TARGET: A band with target value will be replaced only if at least one other band in the pixel does not have the target. (0, 0, 0) remains (0, 0, 0) (0, 3, 2) becomes (1, 3, 2)
If mode is REPLACE_ALL_BANDS_IF_PARTIAL_TARGET: All bands of the pixel will be replaced if any but not all bands in the pixel have the target value. (0, 0, 0) remains (0, 0, 0) (0, 3, 2) becomes (1, 1, 1)
If mode is REPLACE_ONLY_FULL_TARGETS: All bands in the pixel will be replaced only if they all have the target. (0, 0, 0) becomes (1, 1, 1) (0, 3, 2) remains (0, 3, 2)
If mode is REPLACE_ALL_BANDS_IF_ANY_TARGET: All bands in the pixel will be replaced if even one band has the target. (0, 0, 0) becomes (1, 1, 1) (0, 3, 2) remains (1, 1, 1)
| Enumerator | |
| REPLACE_BAND_IF_TARGET | |
| REPLACE_BAND_IF_PARTIAL_TARGET | |
| REPLACE_ALL_BANDS_IF_PARTIAL_TARGET | |
| REPLACE_ONLY_FULL_TARGETS | |
| REPLACE_ALL_BANDS_IF_ANY_TARGET | |
Definition at line 81 of file ossimPixelFlipper.h.
| ossimPixelFlipper::ossimPixelFlipper | ( | ossimObject * | owner = NULL | ) |
default constructor
Definition at line 43 of file ossimPixelFlipper.cpp.
protectedvirtual |
protected |
Definition at line 543 of file ossimPixelFlipper.cpp.
References ossimImageData::dup(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::setImageRectangle(), theClipTileBuffer, and ossimRefPtr< T >::valid().
Referenced by clipTile().
protected |
Definition at line 425 of file ossimPixelFlipper.cpp.
References allocateClipTileBuffer(), BOUNDING_RECT, ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getWidth(), ossimIrect::intersects(), ossimPolygon::isPointWithin(), ossimIrect::ll(), ossimImageData::loadTile(), ossimIrect::lr(), ossimImageData::makeBlank(), NONE, OSSIM_EMPTY, OSSIM_FULL, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimImageData::setNull(), theBoundingRects, theClipMode, theClipTileBuffer, theValidVertices, ossimIrect::ul(), ossimIrect::ur(), ossimRefPtr< T >::valid(), VALID_VERTICES, ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
protected |
Definition at line 158 of file ossimPixelFlipper.cpp.
References BOUNDING_RECT, ossimIrect::completely_within(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimIrect::intersects(), ossim::isnan(), ossimIrect::ll(), ossimIrect::lr(), REPLACE_ALL_BANDS_IF_ANY_TARGET, REPLACE_ALL_BANDS_IF_PARTIAL_TARGET, REPLACE_BAND_IF_PARTIAL_TARGET, REPLACE_BAND_IF_TARGET, REPLACE_ONLY_FULL_TARGETS, theBoundingRects, theClampingMode, theClampValueHi, theClampValueLo, theClipMode, theReplacementMode, theReplacementValue, theTargetValueHi, theTargetValueLo, theValidVertices, ossimIrect::ul(), ossimIrect::ur(), VALID_VERTICES, ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
| ossimPixelFlipper::ClipMode ossimPixelFlipper::getClipMode | ( | ) | const |
Definition at line 967 of file ossimPixelFlipper.cpp.
References theClipMode.
| ossimString ossimPixelFlipper::getClipModeString | ( | ) | const |
Definition at line 956 of file ossimPixelFlipper.cpp.
References BOUNDING_RECT, theClipMode, and VALID_VERTICES.
Referenced by print(), and saveState().
Definition at line 660 of file ossimPixelFlipper.cpp.
References ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), MAX, MIN, and theClampValueHi.
Definition at line 671 of file ossimPixelFlipper.cpp.
References ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), MAX, MIN, and theClampValueLo.
Definition at line 603 of file ossimPixelFlipper.cpp.
References ossimImageSource::getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, theClampValueHi, and ossimImageSourceFilter::theInputConnection.
Definition at line 986 of file ossimPixelFlipper.cpp.
References PF_TARGET_RANGE_KW, PF_TARGET_VALUE_KW, ossimProperty::setCacheRefreshBit(), theMutex, theTargetValueLo, and ossimString::toString().
Definition at line 1133 of file ossimPixelFlipper.cpp.
References PF_TARGET_VALUE_KW.
| ossimPixelFlipper::ReplacementMode ossimPixelFlipper::getReplacementMode | ( | ) | const |
Definition at line 930 of file ossimPixelFlipper.cpp.
References theReplacementMode.
| ossimString ossimPixelFlipper::getReplacementModeString | ( | ) | const |
Definition at line 935 of file ossimPixelFlipper.cpp.
References REPLACE_ALL_BANDS_IF_ANY_TARGET, REPLACE_ALL_BANDS_IF_PARTIAL_TARGET, REPLACE_BAND_IF_PARTIAL_TARGET, REPLACE_BAND_IF_TARGET, REPLACE_ONLY_FULL_TARGETS, and theReplacementMode.
| ossim_float64 ossimPixelFlipper::getReplacementValue | ( | ) | const |
Definition at line 925 of file ossimPixelFlipper.cpp.
References theReplacementValue.
Definition at line 1148 of file ossimPixelFlipper.cpp.
| tile_rect | Rectangle to fill tile with. |
| resLevel | Reduced resolution level to grab from. |
Definition at line 72 of file ossimPixelFlipper.cpp.
References flipPixels(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT32, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_UINT16, OSSIM_UINT32, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageSourceFilter::theInputConnection, theMutex, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimBitMaskWriter::generateMask().
Definition at line 571 of file ossimPixelFlipper.cpp.
References ossimImageSource::getBoundingRect(), ossimImageSource::getNumberOfDecimationLevels(), ossimImageSource::getValidImageVertices(), ossimImageSourceFilter::initialize(), OSSIM_CLOCKWISE_ORDER, theBoundingRects, theMutex, and theValidVertices.
protected |
Definition at line 1153 of file ossimPixelFlipper.cpp.
References ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNullPixelValue(), ossimNotify(), ossimNotifyLevel_WARN, and ossimImageSourceFilter::theInputConnection.
Referenced by setClampValue(), and setReplacementValue().
Definition at line 682 of file ossimPixelFlipper.cpp.
References ossimString::after(), ossimString::before(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), PF_CLAMP_VALUE_HI_KW, PF_CLAMP_VALUE_KW, PF_CLAMP_VALUE_LO_KW, PF_CLIP_MODE_KW, PF_REPLACEMENT_MODE_KW, PF_REPLACEMENT_VALUE_KW, PF_TARGET_RANGE_KW, PF_TARGET_VALUE_KW, setClampValue(), setClipMode(), setReplacementMode(), setReplacementValue(), setTargetRange(), setTargetValue(), status, and ossimString::toFloat64().
Referenced by ossimBitMaskWriter::loadState().
Definition at line 972 of file ossimPixelFlipper.cpp.
References ossimString::c_str(), getClipModeString(), getReplacementModeString(), theClampValueHi, theClampValueLo, theReplacementValue, theTargetValueHi, and theTargetValueLo.
Definition at line 751 of file ossimPixelFlipper.cpp.
References ossimKeywordlist::add(), getClipModeString(), getReplacementModeString(), PF_CLAMP_VALUE_HI_KW, PF_CLAMP_VALUE_LO_KW, PF_CLIP_MODE_KW, PF_REPLACEMENT_MODE_KW, PF_REPLACEMENT_VALUE_KW, PF_TARGET_RANGE_KW, PF_TARGET_VALUE_KW, ossimImageSourceFilter::saveState(), theClampingMode, theClampValueHi, theClampValueLo, theReplacementValue, theTargetValueHi, theTargetValueLo, and ossimString::toString().
| void ossimPixelFlipper::setClampValue | ( | ossim_float64 | clamp_value, |
| bool | is_high_clamp_value = true |
| clamp_value | If set all pixel values above this range will (or below if clamp_max_value = false) be clamped to clamp_value. Must be less than max pixel (or greater than the min pixel) value of the input and cannot be null. |
Definition at line 817 of file ossimPixelFlipper.cpp.
References CLAMPING_HI, CLAMPING_LO, inRange(), theClampingMode, theClampValueHi, theClampValueLo, and theMutex.
Referenced by loadState(), and setClampValues().
| void ossimPixelFlipper::setClampValues | ( | ossim_float64 | clamp_value_lo, |
| ossim_float64 | clamp_value_hi | ||
Definition at line 839 of file ossimPixelFlipper.cpp.
References DISABLED, setClampValue(), and theClampingMode.
| void ossimPixelFlipper::setClipMode | ( | const ossimString & | modeString | ) |
Definition at line 895 of file ossimPixelFlipper.cpp.
References BOUNDING_RECT, ossimString::downcase(), NONE, ossimNotify(), ossimNotifyLevel_WARN, and VALID_VERTICES.
Referenced by loadState().
| void ossimPixelFlipper::setClipMode | ( | ossimPixelFlipper::ClipMode | mode | ) |
Definition at line 889 of file ossimPixelFlipper.cpp.
References theClipMode, and theMutex.
Definition at line 1087 of file ossimPixelFlipper.cpp.
References PF_TARGET_VALUE_KW, setTargetValue(), and ossimString::toDouble().
| void ossimPixelFlipper::setReplacementMode | ( | ossimPixelFlipper::ReplacementMode | mode | ) |
Definition at line 846 of file ossimPixelFlipper.cpp.
References theMutex, and theReplacementMode.
Referenced by ossimBitMaskWriter::initializeFlipper(), and loadState().
| bool ossimPixelFlipper::setReplacementMode | ( | const ossimString & | modeString | ) |
If the string is not understood, the mode remains unchanged and FALSE is returned.
Definition at line 852 of file ossimPixelFlipper.cpp.
References ossimNotify(), ossimNotifyLevel_WARN, REPLACE_ALL_BANDS_IF_ANY_TARGET, REPLACE_ALL_BANDS_IF_PARTIAL_TARGET, REPLACE_BAND_IF_PARTIAL_TARGET, REPLACE_BAND_IF_TARGET, REPLACE_ONLY_FULL_TARGETS, theMutex, theReplacementMode, and ossimString::upcase().
| void ossimPixelFlipper::setReplacementValue | ( | ossim_float64 | replacement_value | ) |
| replacement_value | This is the value to flip target to. |
Definition at line 806 of file ossimPixelFlipper.cpp.
References inRange(), theMutex, and theReplacementValue.
| void ossimPixelFlipper::setTargetRange | ( | ossim_float64 | target_min, |
| ossim_float64 | target_max | ||
The replacement mode is still referenced.
| This | is the value to flip. |
Definition at line 793 of file ossimPixelFlipper.cpp.
References theMutex, theTargetValueHi, and theTargetValueLo.
Referenced by loadState(), and ossimBitMaskWriter::setBogusPixelRange().
| void ossimPixelFlipper::setTargetValue | ( | ossim_float64 | target_value | ) |
| target_value | This is the value to flip. |
Definition at line 780 of file ossimPixelFlipper.cpp.
Referenced by ossimBitMaskWriter::initializeFlipper(), loadState(), ossimBitMaskWriter::setBogusPixel(), and setProperty().
static |
Definition at line 46 of file ossimPixelFlipper.h.
Referenced by loadState(), and saveState().
static |
Definition at line 44 of file ossimPixelFlipper.h.
static |
Definition at line 45 of file ossimPixelFlipper.h.
static |
Definition at line 47 of file ossimPixelFlipper.h.
static |
Definition at line 43 of file ossimPixelFlipper.h.
static |
Definition at line 42 of file ossimPixelFlipper.h.
static |
Definition at line 41 of file ossimPixelFlipper.h.
Referenced by getProperty(), loadState(), and saveState().
static |
Definition at line 40 of file ossimPixelFlipper.h.
Referenced by getProperty(), getPropertyNames(), loadState(), saveState(), and setProperty().
mutableprotected |
Definition at line 267 of file ossimPixelFlipper.h.
Referenced by clipTile(), flipPixels(), and initialize().
protected |
Definition at line 244 of file ossimPixelFlipper.h.
Referenced by flipPixels(), saveState(), setClampValue(), and setClampValues().
protected |
Definition at line 243 of file ossimPixelFlipper.h.
Referenced by flipPixels(), getMaxPixelValue(), getOutputScalarType(), print(), saveState(), and setClampValue().
protected |
The range of desired pixel values.
Any pixels outside this range are set to the corresponding clamp value. Note that theReplacementValue is not referenced when clamping.
Definition at line 242 of file ossimPixelFlipper.h.
Referenced by flipPixels(), getMinPixelValue(), print(), saveState(), and setClampValue().
protected |
Border Clip mode.
This will flip to nulls any pixel value outside the specified mode.
Valid modes are:
none bounding_rect valid_vertices
if the mode is "none" then nothing is done. if the mode is "bounding_rect" then the bounding rect for the requested rlevel is used and every pixel outside that
Definition at line 261 of file ossimPixelFlipper.h.
Referenced by clipTile(), flipPixels(), getClipMode(), getClipModeString(), and setClipMode().
protected |
Definition at line 269 of file ossimPixelFlipper.h.
Referenced by allocateClipTileBuffer(), and clipTile().
mutableprotected |
For lock and unlock.
Definition at line 264 of file ossimPixelFlipper.h.
Referenced by getProperty(), getTile(), initialize(), setClampValue(), setClipMode(), setReplacementMode(), setReplacementValue(), setTargetRange(), and setTargetValue().
protected |
See documentation for ReplacementMode enum above.
Definition at line 238 of file ossimPixelFlipper.h.
Referenced by flipPixels(), getReplacementMode(), getReplacementModeString(), and setReplacementMode().
protected |
When target values are defined, this is the value the pixel will assume if the pixel falls within the target range (according to the rules for replacement mode)
Definition at line 237 of file ossimPixelFlipper.h.
Referenced by flipPixels(), getReplacementValue(), print(), saveState(), and setReplacementValue().
protected |
Definition at line 233 of file ossimPixelFlipper.h.
Referenced by flipPixels(), print(), saveState(), setTargetRange(), and setTargetValue().
protected |
The value range to replace.
For a single value replacement, both Lo and Hi are equal. Any pixel within this range will be remapped to the replacement value
Definition at line 232 of file ossimPixelFlipper.h.
Referenced by flipPixels(), getProperty(), print(), saveState(), setTargetRange(), and setTargetValue().
mutableprotected |
Definition at line 266 of file ossimPixelFlipper.h.
