#include <ossimAtCorrGridRemapper.h>
| ossimAtCorrGridRemapper (ossimObject *owner=NULL, ossimImageSource *inputSource=NULL, const ossimString &sensorType="") | |
| void | setGridRect (const ossimIrect &rect) |
| void | setGridSize (ossim_uint32 numberOfBands, const ossimIpt &gridSize) |
| ossimIpt | getGridSize () const |
| void | getValues (ossim_uint32 band, ossim_uint32 row, ossim_uint32 col, double &a, double &b, double &c) |
| void | getValues (const ossimDpt &pt, ossim_uint32 band, double &a, double &b, double &c) |
| void | setValues (ossim_uint32 band, ossim_uint32 row, ossim_uint32 col, const double &a, const double &b, const double &c) |
Public Member Functions inherited from ossimAtCorrRemapper | |
| ossimAtCorrRemapper (ossimObject *owner=NULL, ossimImageSource *inputSource=NULL, const ossimString &sensorType="") | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| virtual ostream & | print (ostream &os) const |
| vector< double > | getNormMinPixelValues () const |
| vector< double > | getNormMaxPixelValues () const |
| void | getNormMinPixelValues (vector< double > &v) const |
| void | getNormMaxPixelValues (vector< double > &v) const |
| const ossimString & | getSensorType () const |
| void | setSensorType (const ossimString &sensorType) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimAtCorrGridRemapper () |
| virtual void | interpolate (const ossimDpt &pt, int band, double &a, double &b, double &c) const |
| virtual void | setBaseToAverage () |
Protected Member Functions inherited from ossimAtCorrRemapper | |
| virtual | ~ossimAtCorrRemapper () |
| void | verifyEnabled () |
Protected Attributes | |
| ossimIrect | theGridBounds |
| ossimIpt | theUlGridBound |
| ossimIpt | theGridSize |
| std::vector< std::vector< std::vector< double > > > | theAGrid |
| std::vector< std::vector< std::vector< double > > > | theBGrid |
| std::vector< std::vector< std::vector< double > > > | theCGrid |
Protected Attributes inherited from ossimAtCorrRemapper | |
| ossimRefPtr< ossimImageData > | theTile |
| double * | theSurfaceReflectance |
| bool | theUseInterpolationFlag |
| vector< double > | theMinPixelValue |
| vector< double > | theMaxPixelValue |
| vector< double > | theXaArray |
| vector< double > | theXbArray |
| vector< double > | theXcArray |
| vector< double > | theBiasArray |
| vector< double > | theGainArray |
| vector< double > | theCalCoefArray |
| vector< double > | theBandWidthArray |
| ossimString | theSensorType |
Protected Attributes inherited from ossimImageSourceFilter | |
| ossimImageSource * | theInputConnection |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimListener | |
| bool | theListenerEnableFlag |
The grid is encoded into band separate grid and allows bilinear interpolation of atmospheric correction coefficients. It uses the implementation found in ossimAtCorrRemapper. The base class will call interpolate to calculate the a, b, c coefficients used. This class just overrides the base interpolation method. For gridded remappers
Sample keywordlist includes:
band1.grid.rows: 4 band1.grid.cols: 4 band1.grid.a1: band1.grid.b1: band1.grid.c1: band1.grid.a2: band1.grid.b2: band1.grid.c2: band1.grid.a3: band1.grid.b3: band1.grid.c3: band1.grid.a4: band1.grid.b4: band1.grid.c4: band2.grid.rows: 4 band2.grid.cols: 4 band2.grid.a1: band2.grid.b1: band2.grid.c1: band2.grid.a2: band2.grid.b2: band2.grid.c2: band2.grid.a3: band2.grid.b3: band2.grid.c3: band2.grid.a4: band2.grid.b4: band2.grid.c4:
Definition at line 57 of file ossimAtCorrGridRemapper.h.
| ossimAtCorrGridRemapper::ossimAtCorrGridRemapper | ( | ossimObject * | owner = NULL, |
| ossimImageSource * | inputSource = NULL, |
| const ossimString & | sensorType = "" |
Definition at line 15 of file ossimAtCorrGridRemapper.cpp.
References ossimAtCorrRemapper::theUseInterpolationFlag.
protectedvirtual |
Definition at line 23 of file ossimAtCorrGridRemapper.cpp.
inline |
inline |
Definition at line 77 of file ossimAtCorrGridRemapper.h.
References theAGrid.
inline |
Definition at line 89 of file ossimAtCorrGridRemapper.h.
References interpolate().
Reimplemented from ossimAtCorrRemapper.
Definition at line 78 of file ossimAtCorrGridRemapper.cpp.
References ossimImageSource::getBoundingRect(), ossimAtCorrRemapper::initialize(), ossimIrect::makeNan(), setBaseToAverage(), theAGrid, theBGrid, theCGrid, theGridBounds, ossimImageSourceFilter::theInputConnection, theUlGridBound, ossimAtCorrRemapper::theUseInterpolationFlag, and ossimIrect::ul().
protectedvirtual |
Definition at line 27 of file ossimAtCorrGridRemapper.cpp.
References ossimIrect::height(), ossimAtCorrRemapper::interpolate(), ossimIrect::pointWithin(), theAGrid, theBGrid, theCGrid, theGridBounds, theGridSize, theUlGridBound, ossimIrect::width(), ossimIpt::x, ossimDpt::x, x, ossimIpt::y, ossimDpt::y, and y.
Referenced by getValues().
Definition at line 197 of file ossimAtCorrGridRemapper.cpp.
References ossimKeywordlist::find(), ossimImageData::getNumberOfBands(), setBaseToAverage(), theAGrid, theBGrid, theCGrid, theGridSize, ossimAtCorrRemapper::theSurfaceReflectance, ossimAtCorrRemapper::theTile, ossimAtCorrRemapper::theUseInterpolationFlag, ossimString::toDouble(), ossimString::toString(), ossimString::toULong(), ossimIpt::x, and ossimIpt::y.
Definition at line 290 of file ossimAtCorrGridRemapper.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), size, theAGrid, theGridSize, ossimString::toString(), ossimIpt::x, and ossimIpt::y.
protectedvirtual |
Definition at line 129 of file ossimAtCorrGridRemapper.cpp.
References theAGrid, theBGrid, theCGrid, theGridSize, ossimAtCorrRemapper::theXaArray, ossimAtCorrRemapper::theXbArray, ossimAtCorrRemapper::theXcArray, ossimIpt::x, and ossimIpt::y.
Referenced by initialize(), and loadState().
inline |
Definition at line 66 of file ossimAtCorrGridRemapper.h.
References theGridBounds, theUlGridBound, and ossimIrect::ul().
| void ossimAtCorrGridRemapper::setGridSize | ( | ossim_uint32 | numberOfBands, |
| const ossimIpt & | gridSize | ||
Definition at line 101 of file ossimAtCorrGridRemapper.cpp.
References theAGrid, theBGrid, theCGrid, theGridSize, ossimIpt::x, and ossimIpt::y.
inline |
Definition at line 98 of file ossimAtCorrGridRemapper.h.
References theAGrid, theBGrid, and theCGrid.
protected |
Definition at line 126 of file ossimAtCorrGridRemapper.h.
Referenced by getValues(), initialize(), interpolate(), loadState(), saveState(), setBaseToAverage(), setGridSize(), and setValues().
protected |
Definition at line 127 of file ossimAtCorrGridRemapper.h.
Referenced by initialize(), interpolate(), loadState(), setBaseToAverage(), setGridSize(), and setValues().
protected |
Definition at line 128 of file ossimAtCorrGridRemapper.h.
protected |
Definition at line 123 of file ossimAtCorrGridRemapper.h.
Referenced by initialize(), interpolate(), and setGridRect().
protected |
Definition at line 125 of file ossimAtCorrGridRemapper.h.
Referenced by getGridSize(), interpolate(), loadState(), saveState(), setBaseToAverage(), and setGridSize().
protected |
Definition at line 124 of file ossimAtCorrGridRemapper.h.
