#include <ossimLandsatTopoCorrectionFilter.h>
| ossimLandsatTopoCorrectionFilter () | |
| ossimLandsatTopoCorrectionFilter (ossimImageSource *colorSource, ossimImageSource *elevSource, const ossimFilename &landsatFileName=ossimFilename("")) | |
| virtual void | setLandsatHeader (const ossimFilename &header) |
| virtual ossimFilename | getLandsatHeader () const |
Public Member Functions inherited from ossimTopographicCorrectionFilter | |
| ossimTopographicCorrectionFilter () | |
| ossimTopographicCorrectionFilter (ossimImageSource *colorSource, ossimImageSource *elevSource) | |
| ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual double | getAzimuthAngle () const |
| virtual double | getElevationAngle () const |
| virtual void | setAzimuthAngle (double angle) |
| virtual void | setElevationAngle (double angle) |
| virtual ossimTopoCorrectionType | getTopoCorrectionType () const |
| virtual void | setTopoCorrectionType (ossimTopoCorrectionType topoType) |
| const std::vector< double > & | getGainValues () const |
| void | setGainValues (const std::vector< double > &gainValues) |
| const vector< double > & | getBiasValues () const |
| void | setBiasValues (const std::vector< double > &biasValues) |
| const vector< double > & | getKValues () const |
| double | getK (int idx) const |
| void | setK (int idx, double value) |
| void | setKValues (const vector< double > &kValues) |
| double | getC (int idx) const |
| void | setC (int idx, double value) |
| void | setCValues (const vector< double > &cValues) |
| void | computeLightDirection () |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Types inherited from ossimTopographicCorrectionFilter | |
| enum | ossimTopoCorrectionType { TOPO_CORRECTION_COSINE = 0, TOPO_CORRECTION_COSINE_C = 1, TOPO_CORRECTION_MINNAERT = 2 } |
Definition at line 14 of file ossimLandsatTopoCorrectionFilter.h.
| ossimLandsatTopoCorrectionFilter::ossimLandsatTopoCorrectionFilter | ( | ) |
Definition at line 24 of file ossimLandsatTopoCorrectionFilter.cpp.
| ossimLandsatTopoCorrectionFilter::ossimLandsatTopoCorrectionFilter | ( | ossimImageSource * | colorSource, |
| ossimImageSource * | elevSource, | ||
| const ossimFilename & | landsatFileName = ossimFilename("") |
Definition at line 34 of file ossimLandsatTopoCorrectionFilter.cpp.
protectedvirtual |
Definition at line 30 of file ossimLandsatTopoCorrectionFilter.cpp.
protected |
Definition at line 72 of file ossimLandsatTopoCorrectionFilter.cpp.
References ossimConnectableObject::accept(), ossimFilename::exists(), ossimDirectory::findAllFilesThatMatch(), ossimImageHandler::getFilename(), ossimConnectableObject::getInput(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimDirectory::open(), ossimFilename::path(), ossimFilename::setExtension(), ossimRefPtr< T >::valid(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by initialize().
inlinevirtual |
Definition at line 23 of file ossimLandsatTopoCorrectionFilter.h.
Reimplemented from ossimTopographicCorrectionFilter.
Definition at line 43 of file ossimLandsatTopoCorrectionFilter.cpp.
References findLandsatHeader(), ossimTopographicCorrectionFilter::initialize(), setLandsatHeader(), and theLandsatHeader.
Definition at line 335 of file ossimLandsatTopoCorrectionFilter.cpp.
References ossimKeywordNames::FILENAME_KW, ossimKeywordlist::find(), ossimTopographicCorrectionFilter::loadState(), and setLandsatHeader().
Definition at line 349 of file ossimLandsatTopoCorrectionFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimKeywordNames::FILENAME_KW, ossimTopographicCorrectionFilter::saveState(), and theLandsatHeader.
Definition at line 57 of file ossimLandsatTopoCorrectionFilter.cpp.
References ossimString::c_str(), ossimTopographicCorrectionFilter::computeLightDirection(), ossimFfL7::getBias(), ossimFfL7::getGain(), ossimFfL7::getJulianDay(), ossimFfL7::getSunAzimuth(), ossimFfL7::getSunElevation(), ossimTopographicCorrectionFilter::theBias, ossimTopographicCorrectionFilter::theGain, ossimTopographicCorrectionFilter::theJulianDay, theLandsatHeader, ossimTopographicCorrectionFilter::theLightSourceAzimuthAngle, and ossimTopographicCorrectionFilter::theLightSourceElevationAngle.
Referenced by initialize(), and loadState().
protected |
Definition at line 35 of file ossimLandsatTopoCorrectionFilter.h.
Referenced by initialize(), saveState(), and setLandsatHeader().
