This will be a base for all combiners. More...
#include <ossimImageCombiner.h>
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Combiners take N inputs and will produce a single output.
Definition at line 21 of file ossimImageCombiner.h.
| ossimImageCombiner::ossimImageCombiner | ( | ) |
Definition at line 20 of file ossimImageCombiner.cpp.
References ossimListenerManager::addListener(), and theComputeFullResBoundsFlag.
| ossimImageCombiner::ossimImageCombiner | ( | ossimObject * | owner, |
| int | numberOfInputs, | ||
| int | numberOfOutputs, | ||
| bool | inputListIsFixedFlag, | ||
| bool | outputListIsFixedFlag | ||
Definition at line 37 of file ossimImageCombiner.cpp.
| ossimImageCombiner::ossimImageCombiner | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 57 of file ossimImageCombiner.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::connectMyInputTo(), initialize(), and theComputeFullResBoundsFlag.
protectedvirtual |
Definition at line 78 of file ossimImageCombiner.cpp.
References ossimListenerManager::removeListener().
required to be overriden by derived classes
Implements ossimConnectableObject.
Reimplemented in ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, and ossimFusionCombiner.
Definition at line 652 of file ossimImageCombiner.cpp.
References PTR_CAST.
Reimplemented from ossimConnectableObjectListener.
Reimplemented in ossimBumpShadeTileSource, and ossimTopographicCorrectionFilter.
Definition at line 621 of file ossimImageCombiner.cpp.
References initialize().
Definition at line 626 of file ossimImageCombiner.cpp.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Reimplemented in ossimTopographicCorrectionFilter, ossimFusionCombiner, and ossimOrthoImageMosaic.
Definition at line 83 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimIrect::hasNans(), ossimIrect::makeNan(), precomputeBounds(), PTR_CAST, theComputeFullResBoundsFlag, and theFullResBounds.
Reimplemented in ossimEquationCombiner, ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, ossimBandMergeSource, and ossimTwoColorView.
Definition at line 236 of file ossimImageCombiner.cpp.
References DBL_EPSILON, ossimConnectableObject::getInput(), ossimImageSource::getMaxPixelValue(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getNumberOfOutputBands(), ossim::nan(), and PTR_CAST.
Referenced by ossimTwoColorView::getMaxPixelValue(), and ossimTopographicCorrectionFilter::getMaxPixelValue().
Definition at line 196 of file ossimImageCombiner.cpp.
References DBL_EPSILON, ossimConnectableObject::getInput(), ossimImageSource::getMinPixelValue(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getNumberOfOutputBands(), ossim::nan(), and PTR_CAST.
Referenced by ossimTwoColorView::getMinPixelValue(), and ossimTopographicCorrectionFilter::getMinPixelValue().
Definition at line 511 of file ossimImageCombiner.cpp.
References theCurrentIndex.
Referenced by ossimElevationMosaic::combine(), ossimImageMosaic::combine(), ossimElevationMosaic::combineNorm(), ossimImageMosaic::combineNorm(), ossimMaxMosaic::combineNorm(), ossimBlendMosaic::combineNorm(), and ossimClosestToCenterCombiner::getTile().
Definition at line 536 of file ossimImageCombiner.cpp.
References ossimImageData::copyTileToNormalizedBuffer(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), getNextTile(), ossimImageData::getNumberOfBands(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::initialize(), OSSIM_NORMALIZED_FLOAT, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangleAndBands(), size, theCurrentIndex, theNormTile, and ossimRefPtr< T >::valid().
Definition at line 356 of file ossimImageCombiner.cpp.
Referenced by ossimElevationMosaic::combine(), ossimImageMosaic::combine(), ossimMaxMosaic::combine(), ossimBlendMosaic::combine(), ossimFeatherMosaic::combine(), getNextNormTile(), ossimElevationMosaic::getTile(), ossimImageMosaic::getTile(), ossimBandMergeSource::getTile(), ossimMaxMosaic::getTile(), and ossimTwoColorView::getTile().
Reimplemented in ossimOrthoImageMosaic.
Definition at line 380 of file ossimImageCombiner.cpp.
References ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getTile(), ossimIrect::hasNans(), ossimIrect::intersects(), OSSIM_EMPTY, OSSIM_NULL, precomputeBounds(), PTR_CAST, size, status, theComputeFullResBoundsFlag, theCurrentIndex, theFullResBounds, and ossimRefPtr< T >::valid().
Definition at line 447 of file ossimImageCombiner.cpp.
References ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getTile(), ossimIrect::hasNans(), ossimIrect::intersects(), OSSIM_EMPTY, OSSIM_NULL, precomputeBounds(), PTR_CAST, size, status, theComputeFullResBoundsFlag, theCurrentIndex, and theFullResBounds.
Reimplemented in ossimEquationCombiner, ossimTopographicCorrectionFilter, ossimBandMergeSource, and ossimTwoColorView.
Definition at line 174 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), PTR_CAST, and theInputToPassThrough.
Referenced by ossimTwoColorView::getNullPixelValue(), and ossimTopographicCorrectionFilter::getNullPixelValue().
Implements ossimImageSource.
Definition at line 127 of file ossimImageCombiner.cpp.
References theLargestNumberOfInputBands.
Definition at line 569 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getNumberOfInputs(), ossimIrect::intersects(), precomputeBounds(), theComputeFullResBoundsFlag, and theFullResBounds.
Reimplemented in ossimEquationCombiner, ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, ATP::AtpTileSource, ossimTwoColorView, and ossimFusionCombiner.
Definition at line 132 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, PTR_CAST, and theInputToPassThrough.
Referenced by ossimFusionCombiner::getOutputScalarType(), ossimTwoColorView::getOutputScalarType(), and ossimTopographicCorrectionFilter::getOutputScalarType().
Definition at line 595 of file ossimImageCombiner.cpp.
Returns the default processing tile height.
Definition at line 160 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getTileHeight(), PTR_CAST, and theInputToPassThrough.
Referenced by ossimEquationCombiner::initialize().
Returns the default processing tile width.
Definition at line 146 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getTileWidth(), PTR_CAST, and theInputToPassThrough.
Definition at line 641 of file ossimImageCombiner.cpp.
References theHasDifferentInputs.
Referenced by ossimBlendMosaic::getTile(), ossimImageMosaic::getTile(), ossimElevationMosaic::getTile(), ossimMaxMosaic::getTile(), and ossimBlendMosaic::initialize().
Reimplemented in ossimEquationCombiner, ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, ossimTwoColorView, ossimLocalCorrelationFusion, ossimSFIMFusion, ossimBandMergeSource, ossimMaxMosaic, ossimElevationMosaic, ossimImageMosaic, ATP::AtpTileSource, ossimFeatherMosaic, ossimFusionCombiner, ATP::ossimCorrelationSource, ATP::ossimDescriptorSource, ossimOrthoImageMosaic, ossimBlendMosaic, and ossimLandsatTopoCorrectionFilter.
Definition at line 276 of file ossimImageCombiner.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), OSSIM_SCALAR_UNKNOWN, PTR_CAST, ossim::scalarSizeInBytes(), size, theComputeFullResBoundsFlag, theHasDifferentInputs, theInputToPassThrough, and theLargestNumberOfInputBands.
Referenced by connectInputEvent(), disconnectInputEvent(), ossimFusionCombiner::initialize(), ATP::AtpTileSource::initialize(), ossimElevationMosaic::initialize(), ossimImageMosaic::initialize(), ossimBandMergeSource::initialize(), ossimMaxMosaic::initialize(), ossimTwoColorView::initialize(), ossimTopographicCorrectionFilter::initialize(), ossimBumpShadeTileSource::initialize(), ossimEquationCombiner::initialize(), ossimImageCombiner(), propertyEvent(), refreshEvent(), and ossimGpkgWriter::reInitializeCombiners().
Reimplemented in ossimEquationCombiner, ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, ossimLocalCorrelationFusion, ossimSFIMFusion, ossimMaxMosaic, ossimElevationMosaic, ossimImageMosaic, ossimBlendMosaic, and ossimLandsatTopoCorrectionFilter.
Definition at line 326 of file ossimImageCombiner.cpp.
References ossimImageSource::loadState().
Referenced by ossimElevationMosaic::loadState(), ossimImageMosaic::loadState(), ossimMaxMosaic::loadState(), ossimSFIMFusion::loadState(), and ossimLocalCorrelationFusion::loadState().
protected |
Definition at line 658 of file ossimImageCombiner.cpp.
References ossimImageSource::getBoundingRect(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), PTR_CAST, theComputeFullResBoundsFlag, and theFullResBounds.
Referenced by getBoundingRect(), getNextTile(), getNumberOfOverlappingImages(), and getOverlappingImages().
Definition at line 631 of file ossimImageCombiner.cpp.
Definition at line 636 of file ossimImageCombiner.cpp.
Reimplemented in ossimEquationCombiner, ossimBumpShadeTileSource, ossimTopographicCorrectionFilter, ossimLocalCorrelationFusion, ossimSFIMFusion, ossimMaxMosaic, ossimElevationMosaic, ossimImageMosaic, ossimLandsatTopoCorrectionFilter, and ossimBlendMosaic.
Definition at line 646 of file ossimImageCombiner.cpp.
References ossimImageSource::saveState().
Referenced by ossimElevationMosaic::saveState(), ossimImageMosaic::saveState(), ossimMaxMosaic::saveState(), ossimSFIMFusion::saveState(), and ossimLocalCorrelationFusion::saveState().
Definition at line 333 of file ossimImageCombiner.cpp.
References theComputeFullResBoundsFlag.
mutableprotected |
Definition at line 134 of file ossimImageCombiner.h.
Referenced by ATP::AtpTileSource::AtpTileSource(), getBoundingRect(), getNextTile(), getNumberOfOverlappingImages(), getOverlappingImages(), initialize(), ossimImageCombiner(), precomputeBounds(), and updateRects().
protected |
Definition at line 135 of file ossimImageCombiner.h.
Referenced by getNextNormTile(), ossimOrthoImageMosaic::getNextTile(), and getNextTile().
mutableprotected |
Definition at line 133 of file ossimImageCombiner.h.
Referenced by ossimClosestToCenterCombiner::findIdx(), getBoundingRect(), getNextTile(), getNumberOfOverlappingImages(), getOverlappingImages(), and precomputeBounds().
protected |
Definition at line 131 of file ossimImageCombiner.h.
Referenced by hasDifferentInputs(), and initialize().
protected |
Definition at line 130 of file ossimImageCombiner.h.
Referenced by getNullPixelValue(), getOutputScalarType(), getTileHeight(), getTileWidth(), and initialize().
protected |
Definition at line 129 of file ossimImageCombiner.h.
Referenced by ossimElevationMosaic::combine(), ossimImageMosaic::combine(), ossimMaxMosaic::combine(), ossimBlendMosaic::combine(), ossimFeatherMosaic::combine(), ossimElevationMosaic::combineNorm(), ossimImageMosaic::combineNorm(), ossimMaxMosaic::combineNorm(), ossimBlendMosaic::combineNorm(), getNumberOfInputBands(), ossimBlendMosaic::initialize(), ossimFeatherMosaic::initialize(), and initialize().
protected |
Definition at line 132 of file ossimImageCombiner.h.
Referenced by getNextNormTile().
