#include <ossimUsgsDemTileSource.h>
| ossimUsgsDemTileSource () | |
| virtual bool | open () |
| Returns true if the "theImageFile can be opened. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 resLevel=0) |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| Override base-class method to make sure the internal geometry is explored before extending. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Initializes theGeometry from USGS DEM header. More... | |
| virtual | ~ossimUsgsDemTileSource () |
| const ossimUsgsDemTileSource & | operator= (const ossimUsgsDemTileSource &rhs) |
| ossimUsgsDemTileSource (const ossimUsgsDemTileSource &) | |
| bool | fillBuffer (T, const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile) |
| Returns true on success, false on error. More... | |
| void | gatherStatistics () |
Definition at line 24 of file ossimUsgsDemTileSource.h.
| ossimUsgsDemTileSource::ossimUsgsDemTileSource | ( | ) |
Definition at line 43 of file ossimUsgsDemTileSource.cpp.
protectedvirtual |
Definition at line 58 of file ossimUsgsDemTileSource.cpp.
References theDem, and theTile.
protected |
Definition at line 560 of file ossimUsgsDemTileSource.cpp.
protected |
Definition at line 173 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getBuf(), ossimDemGrid::getElevation(), ossimDemGrid::getHeader(), ossimDemHeader::getSpatialResZ(), ossimImageData::getWidth(), ossimIrect::lr(), MTRS_PER_FT, theDem, theFeetFlag, theNullValue, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
protected |
Definition at line 369 of file ossimUsgsDemTileSource.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Note that rrds 0 is the highest resolution rrds.
Definition at line 211 of file ossimUsgsDemTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 502 of file ossimUsgsDemTileSource.cpp.
Definition at line 497 of file ossimUsgsDemTileSource.cpp.
protectedvirtual |
This is called by base ossimImageHandler::getImageGeometry if theGeometry is not set. External callers should not go through this method but call "getImageGeometry" instead for efficiency reasons.
Definition at line 406 of file ossimUsgsDemTileSource.cpp.
References ossimDemGrid::getHeader(), and theDem.
Referenced by getImageGeometry().
Definition at line 512 of file ossimUsgsDemTileSource.cpp.
Definition at line 541 of file ossimUsgsDemTileSource.cpp.
References ossimImageMetaData::getMaxPix(), ossimImageMetaData::getNumberOfBands(), theMaxHeight, and ossimImageHandler::theMetaData.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 532 of file ossimUsgsDemTileSource.cpp.
References ossimImageMetaData::getMinPix(), ossimImageMetaData::getNumberOfBands(), ossimImageHandler::theMetaData, and theMinHeight.
Definition at line 527 of file ossimUsgsDemTileSource.cpp.
References theNullValue.
Satisfies pure virtual requirement from ImageHandler class.
Implements ossimImageSource.
Definition at line 517 of file ossimUsgsDemTileSource.cpp.
Definition at line 463 of file ossimUsgsDemTileSource.cpp.
References ossimDemGrid::getHeight(), ossimImageHandler::getNumberOfLines(), theDem, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Definition at line 522 of file ossimUsgsDemTileSource.cpp.
Definition at line 480 of file ossimUsgsDemTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimDemGrid::getWidth(), theDem, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 448 of file ossimUsgsDemTileSource.cpp.
References theScalarType.
Definition at line 507 of file ossimUsgsDemTileSource.cpp.
Definition at line 68 of file ossimUsgsDemTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 88 of file ossimUsgsDemTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillBuffer(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), status, theScalarType, theTile, ossimReferenced::unref(), and ossimImageData::validate().
Definition at line 458 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
Definition at line 453 of file ossimUsgsDemTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
Definition at line 550 of file ossimUsgsDemTileSource.cpp.
References theDem.
Keywords picked up by this method: dem_type: usgs_dem scalar_type: ossim_sint16 (default) or scalar_type: ossim_float32
Definition at line 313 of file ossimUsgsDemTileSource.cpp.
References ossimKeywordlist::find(), and ossimImageHandler::loadState().
If the extension is not equal to ".dem" this will attempt to look for an ".omd" file with the keyword pair "dem_type: usgs_dem" in it.
Optionally users can change the scalar type from signed 16 bit to float with the keyword pair "scalar_type: ossim_float32"
Definition at line 219 of file ossimUsgsDemTileSource.cpp.
protected |
Definition at line 555 of file ossimUsgsDemTileSource.cpp.
Definition at line 299 of file ossimUsgsDemTileSource.cpp.
References ossimKeywordlist::add().
protected |
Definition at line 177 of file ossimUsgsDemTileSource.h.
Referenced by fillBuffer(), getInternalImageGeometry(), getNumberOfLines(), getNumberOfSamples(), isOpen(), and ~ossimUsgsDemTileSource().
protected |
Definition at line 182 of file ossimUsgsDemTileSource.h.
Referenced by fillBuffer().
protected |
Definition at line 183 of file ossimUsgsDemTileSource.h.
protected |
Definition at line 181 of file ossimUsgsDemTileSource.h.
Referenced by getMaxPixelValue().
protected |
Definition at line 180 of file ossimUsgsDemTileSource.h.
Referenced by getMinPixelValue().
protected |
Definition at line 179 of file ossimUsgsDemTileSource.h.
Referenced by fillBuffer(), and getNullPixelValue().
protected |
This can be either OSSIM_SINT16 or OSSIM_FLOAT32.
Default = OSSIM_SINT16 Can be changed via ".omd" file keyword:
Definition at line 189 of file ossimUsgsDemTileSource.h.
Referenced by getOutputScalarType(), and getTile().
protected |
Definition at line 178 of file ossimUsgsDemTileSource.h.
Referenced by getTile(), getTileHeight(), getTileWidth(), and ~ossimUsgsDemTileSource().
