#include <ossimRgbToIndexFilter.h>
| ossimRgbToIndexFilter () | |
| ossimRgbToIndexFilter (ossimImageSource *inputSource, const ossimRgbLutDataObject &rgbLut) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
| void | setLut (ossimRgbLutDataObject &lut) |
| void | setLut (const ossimFilename &file) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimRgbToIndexFilter () |
| void | allocate () |
| virtual ossimRefPtr< ossimImageData > | convertInputTile (ossimRefPtr< ossimImageData > &tile) |
It will map the input data to an 8-bit index table. The table
Example keyword list:
type: ossimRgbToIndexFilter
If you want to load from a file then just do:
lut.filename: <full path="" to="" lut="" file>="">
If you have the lut table in line then it must look like this:
lut.entry0: 204 102 1 lut.entry1: 255 204 153 lut.entry2: 51 204 204 lut.number_of_entries: 3 lut.type: ossimRgbLutDataObject
Definition at line 44 of file ossimRgbToIndexFilter.h.
| ossimRgbToIndexFilter::ossimRgbToIndexFilter | ( | ) |
Initializes the min value to 0 and the max value to 4000.
Definition at line 22 of file ossimRgbToIndexFilter.cpp.
| ossimRgbToIndexFilter::ossimRgbToIndexFilter | ( | ossimImageSource * | inputSource, |
| const ossimRgbLutDataObject & | rgbLut | ||
Definition at line 29 of file ossimRgbToIndexFilter.cpp.
protectedvirtual |
Definition at line 37 of file ossimRgbToIndexFilter.cpp.
References theLut.
protected |
Definition at line 50 of file ossimRgbToIndexFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), and theTile.
Referenced by getTile().
protectedvirtual |
Definition at line 106 of file ossimRgbToIndexFilter.cpp.
References ossimRgbLutDataObject::findIndex(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theLut, and theTile.
Definition at line 61 of file ossimRgbToIndexFilter.cpp.
References ossimSource::disableSource(), and theTile.
Definition at line 220 of file ossimRgbToIndexFilter.cpp.
References ossimImageSource::getMaxPixelValue(), and ossimSource::isSourceEnabled().
Definition at line 210 of file ossimRgbToIndexFilter.cpp.
References ossimImageSource::getMinPixelValue(), and ossimSource::isSourceEnabled().
Definition at line 200 of file ossimRgbToIndexFilter.cpp.
References ossimImageSource::getNullPixelValue(), and ossimSource::isSourceEnabled().
Definition at line 175 of file ossimRgbToIndexFilter.cpp.
References ossimImageSource::getNumberOfOutputBands(), and ossimSource::isSourceEnabled().
Definition at line 185 of file ossimRgbToIndexFilter.cpp.
References ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and OSSIM_UCHAR.
Definition at line 67 of file ossimRgbToIndexFilter.cpp.
References allocate(), convertInputTile(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::makeBlank(), OSSIM_FULL, OSSIM_UCHAR, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Definition at line 42 of file ossimRgbToIndexFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Loads the state of this object.
Definition at line 165 of file ossimRgbToIndexFilter.cpp.
References ossimString::c_str(), ossimImageSourceFilter::loadState(), ossimRgbLutDataObject::loadState(), and theLut.
Saves the state of this object.
Definition at line 154 of file ossimRgbToIndexFilter.cpp.
References ossimString::c_str(), ossimImageSourceFilter::saveState(), ossimRgbLutDataObject::saveState(), and theLut.
| void ossimRgbToIndexFilter::setLut | ( | ossimRgbLutDataObject & | lut | ) |
Definition at line 195 of file ossimRgbToIndexFilter.cpp.
References ossimRgbLutDataObject::dup(), and theLut.
| void ossimRgbToIndexFilter::setLut | ( | const ossimFilename & | file | ) |
protected |
Definition at line 90 of file ossimRgbToIndexFilter.h.
Referenced by convertInputTile(), loadState(), saveState(), setLut(), and ~ossimRgbToIndexFilter().
protected |
Definition at line 91 of file ossimRgbToIndexFilter.h.
Referenced by allocate(), convertInputTile(), disableSource(), getTile(), and initialize().
