#include <ossimJpegTileSource.h>
Classes | |
| class | PrivateData |
| ossimJpegTileSource () | |
| ossimJpegTileSource (const ossimKeywordlist &kwl, const char *prefix=0) | |
| ossimJpegTileSource (const char *jpeg_file) | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| bool | isOpen () const |
| bool | open (const ossimFilename &jpeg_file) |
| Returns true if the image_file can be opened and is a valid tiff file. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| Gets a property for matching name. More... | |
| Gets a list of property names available. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimJpegTileSource () |
| virtual bool | open () |
| Returns true if no errors initializing object. More... | |
| void | allocate () |
| void | destroy () |
| void | restart () |
| void | fillTile (const ossimIrect &clip_rect, ossimImageData *tile) |
Definition at line 25 of file ossimJpegTileSource.h.
| ossimJpegTileSource::ossimJpegTileSource | ( | ) |
Definition at line 82 of file ossimJpegTileSource.cpp.
| ossimJpegTileSource::ossimJpegTileSource | ( | const ossimKeywordlist & | kwl, |
| const char * | prefix = 0 |
Definition at line 101 of file ossimJpegTileSource.cpp.
References loadState(), ossimErrorCodes::OSSIM_ERROR, and ossimErrorStatusInterface::theErrorStatus.
| ossimJpegTileSource::ossimJpegTileSource | ( | const char * | jpeg_file | ) |
Definition at line 125 of file ossimJpegTileSource.cpp.
References open(), ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_WARN, and ossimErrorStatusInterface::theErrorStatus.
protectedvirtual |
protected |
Definition at line 185 of file ossimJpegTileSource.cpp.
References ossimImageDataFactory::create(), ossim::defaultTileSize(), ossimAppFixedTileCache::deleteCache(), ossimImageData::dup(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimAppFixedTileCache::instance(), ossimAppFixedTileCache::newTileCache(), ossimImageData::setImageRectangle(), theCacheId, theCacheSize, theCacheTile, theImageRect, theLineBuffer, theNumberOfBands, theTile, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Definition at line 449 of file ossimJpegTileSource.cpp.
References destroy().
protected |
Definition at line 161 of file ossimJpegTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theFilePtr, theLineBuffer, thePrivateData, and theTile.
Referenced by close(), open(), and ~ossimJpegTileSource().
protected |
Definition at line 291 of file ossimJpegTileSource.cpp.
References ossimIrect::completely_within(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimIrect::height(), ossimImageData::makeBlank(), ossimIrect::set_lrx(), ossimIrect::set_ulx(), ossimIrect::stretchToTileBoundary(), theCacheSize, theFilePtr, x, and ossimIpt::y.
Referenced by getTile().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 702 of file ossimJpegTileSource.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Note that rrds 0 is the highest resolution rrds.
Definition at line 418 of file ossimJpegTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by fillTile(), getInternalImageGeometry(), and getTile().
Implements ossimImageHandler.
Definition at line 647 of file ossimJpegTileSource.cpp.
Definition at line 642 of file ossimJpegTileSource.cpp.
protectedvirtual |
| Method | to get geometry from the xml file or internal geotiff tags. |
Definition at line 738 of file ossimJpegTileSource.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getFilename(), getImageRectangle(), ossimXmpInfo::getProjection(), ossimXmpInfo::open(), ossimImageGeometry::setProjection(), and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
Definition at line 657 of file ossimJpegTileSource.cpp.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 662 of file ossimJpegTileSource.cpp.
References theNumberOfBands.
Referenced by getNumberOfOutputBands().
Definition at line 611 of file ossimJpegTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), ossimIrect::lr(), theImageRect, ossimImageHandler::theOverview, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimIpt::y.
Referenced by getImageRectangle().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 667 of file ossimJpegTileSource.cpp.
References getNumberOfInputBands().
Definition at line 628 of file ossimJpegTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimIrect::lr(), theImageRect, ossimImageHandler::theOverview, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimIpt::x.
Definition at line 672 of file ossimJpegTileSource.cpp.
References OSSIM_UCHAR.
| name | The name of the property to get. |
Definition at line 553 of file ossimJpegTileSource.cpp.
References ossimImageHandler::getProperty().
| propertyNames | The list to push back names to. |
Definition at line 562 of file ossimJpegTileSource.cpp.
References ossimImageHandler::getPropertyNames().
Definition at line 652 of file ossimJpegTileSource.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 225 of file ossimJpegTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), theTile, and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 245 of file ossimJpegTileSource.cpp.
References ossimIrect::clipToRect(), fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, and ossimReferenced::unref().
Definition at line 579 of file ossimJpegTileSource.cpp.
References ossimImageData::getHeight(), theTile, and ossimRefPtr< T >::valid().
Definition at line 571 of file ossimJpegTileSource.cpp.
References ossimImageData::getWidth(), theTile, and ossimRefPtr< T >::valid().
Definition at line 677 of file ossimJpegTileSource.cpp.
References theFilePtr.
Determines if the passed in reslution level is valid.
If this reader is used as an overview the caller should pass in a resLevel relative to the full image.
| resLevel | zero base resolution level. |
Definition at line 587 of file ossimJpegTileSource.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 438 of file ossimJpegTileSource.cpp.
References ossimImageHandler::loadState(), and open().
Referenced by ossimJpegTileSource().
Definition at line 457 of file ossimJpegTileSource.cpp.
References open(), and ossimImageHandler::theImageFile.
protectedvirtual |
Notes:
Definition at line 468 of file ossimJpegTileSource.cpp.
References ossimString::c_str(), destroy(), ossimString::empty(), ossimErrorCodes::OSSIM_ERROR, ossimErrorStatusInterface::theErrorStatus, theFilePtr, and ossimImageHandler::theImageFile.
Referenced by loadState(), open(), and ossimJpegTileSource().
protected |
Definition at line 682 of file ossimJpegTileSource.cpp.
References ossimJpegStdIOSrc(), ossimJpegTileSource::PrivateData::theCinfo, theFilePtr, thePrivateData, and TRUE.
Definition at line 429 of file ossimJpegTileSource.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 203 of file ossimJpegTileSource.h.
protected |
Definition at line 210 of file ossimJpegTileSource.h.
Referenced by allocate(), and destroy().
protected |
Definition at line 206 of file ossimJpegTileSource.h.
Referenced by allocate(), and fillTile().
protected |
Definition at line 200 of file ossimJpegTileSource.h.
protected |
Definition at line 202 of file ossimJpegTileSource.h.
Referenced by destroy(), fillTile(), isOpen(), open(), and restart().
protected |
Definition at line 204 of file ossimJpegTileSource.h.
Referenced by allocate(), getNumberOfLines(), and getNumberOfSamples().
protected |
Definition at line 201 of file ossimJpegTileSource.h.
protected |
Definition at line 205 of file ossimJpegTileSource.h.
Referenced by allocate(), and getNumberOfInputBands().
protected |
Definition at line 208 of file ossimJpegTileSource.h.
protected |
Definition at line 199 of file ossimJpegTileSource.h.
Referenced by allocate(), destroy(), getTile(), getTileHeight(), and getTileWidth().
