Class to fill a patch from input tiles requested on even tile boundaries with a tile size typically matching the input, with some output tile size different from the input. More...
#include <ossimTiledImagePatch.h>
| ossimTiledImagePatch () | |
| Initializes bounding rects and tile size(if not set) from input. More... | |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| const ossimIpt & | getInputTileSize () const |
| bool | setInputTileSize (const ossimIpt &tileSize) |
| Sets the input tile size. More... | |
| Method to the load the class state from a keyword list. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimTiledImagePatch () |
| virtual protected destructor More... | |
Private Member Functions | |
| void | allocateTile () |
| Allocates the tile. More... | |
| bool | isValidRLevel (ossim_uint32 resLevel) const |
| Test the bounds of resLevel. More... | |
| ossimTiledImagePatch (const ossimTiledImagePatch &) | |
| Private to disallow use... More... | |
| ossimTiledImagePatch & | operator= (const ossimTiledImagePatch &) |
Private Attributes | |
| ossimRefPtr< ossimImageData > | m_tile |
| ossimIpt | m_inputTileSize |
Definition at line 29 of file ossimTiledImagePatch.h.
| ossimTiledImagePatch::ossimTiledImagePatch | ( | ) |
default constructor
Definition at line 21 of file ossimTiledImagePatch.cpp.
protectedvirtual |
private |
Definition at line 222 of file ossimTiledImagePatch.cpp.
private |
Allocates the tile.
Called on first getTile.
Definition at line 209 of file ossimTiledImagePatch.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
Definition at line 154 of file ossimTiledImagePatch.cpp.
| const ossimIpt & ossimTiledImagePatch::getInputTileSize | ( | ) | const |
Definition at line 169 of file ossimTiledImagePatch.cpp.
References m_inputTileSize.
Definition at line 159 of file ossimTiledImagePatch.cpp.
Definition at line 164 of file ossimTiledImagePatch.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 56 of file ossimTiledImagePatch.cpp.
References allocateTile(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. |
Definition at line 81 of file ossimTiledImagePatch.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageSource::getBoundingRect(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageSource::getTile(), ossimIpt::hasNans(), ossimImageData::initialize(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimImageData::loadTile(), ossimIrect::lr(), m_inputTileSize, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, status, ossimImageSourceFilter::theInputConnection, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, x, ossimIpt::y, and y.
Definition at line 34 of file ossimTiledImagePatch.cpp.
References ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), ossimIpt::hasNans(), ossimImageSourceFilter::initialize(), m_inputTileSize, m_tile, ossimImageSourceFilter::theInputConnection, ossimIpt::x, and ossimIpt::y.
private |
Definition at line 215 of file ossimTiledImagePatch.cpp.
References ossimImageSource::getNumberOfDecimationLevels().
| kwl | |
| prefix |
Definition at line 189 of file ossimTiledImagePatch.cpp.
References ossimKeywordlist::findKey(), ossimImageSourceFilter::loadState(), m_inputTileSize, and ossimIpt::toPoint().
private |
Definition at line 229 of file ossimTiledImagePatch.cpp.
| kwl | |
| prefix |
Definition at line 201 of file ossimTiledImagePatch.cpp.
References ossimKeywordlist::addPair(), m_inputTileSize, ossimImageSourceFilter::saveState(), ossimString::string(), and ossimIpt::toString().
| bool ossimTiledImagePatch::setInputTileSize | ( | const ossimIpt & | tileSize | ) |
| tileSize |
Definition at line 174 of file ossimTiledImagePatch.cpp.
References ossimIpt::hasNans(), m_inputTileSize, ossimIpt::makeNan(), status, ossimIpt::x, and ossimIpt::y.
Referenced by ossimSingleImageChain::createRenderedChain().
private |
Definition at line 119 of file ossimTiledImagePatch.h.
Referenced by getInputTileSize(), getTile(), initialize(), loadState(), saveState(), and setInputTileSize().
private |
Definition at line 118 of file ossimTiledImagePatch.h.
Referenced by allocateTile(), getTile(), and initialize().
