#include <ossimMrSidReader.h>
| ossimMrSidReader () | |
| default construtor More... | |
| virtual | ~ossimMrSidReader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Returns class name. More... | |
| Method to grab a tile(rectangle) from image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Gets the decimation factor for a resLevel. More... | |
| Get array of decimations for all levels. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual bool | open () |
| Open method. More... | |
| Method to test for open file stream. More... | |
| virtual void | closeEntry () |
| Method to close current entry. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Gets the image geometry from external ".geom" or ".aux.xml" file. More... | |
| Method to get geometry from internal mrsid tags. More... | |
Private Member Functions | |
| bool | computeDecimationFactors (std::vector< ossimDpt > &decimations) const |
| bool | getImageDimensions (std::vector< ossimIrect > &tileDims) const |
| ossimProjection * | getGeoProjection () |
| void | getDataType () |
| void | computeMinMax () |
| bool | getMetadataElement (LTIMetadataDatabase metaDb, const char *tagName, void *pValue, int iLength=0) |
Private Attributes | |
| MrSIDImageReader * | theReader |
| LTINavigator * | theImageNavigator |
| ossim_uint32 | theMinDwtLevels |
| ossimIrect | theImageRect |
| std::vector< ossimIrect > | theMrSidDims |
| Has sub image offset. More... | |
| ossim_uint32 | theNumberOfBands |
| ossimScalarType | theScalarType |
| ossimRefPtr< ossimImageData > | theTile |
Definition at line 38 of file ossimMrSidReader.h.
| ossimMrSidReader::ossimMrSidReader | ( | ) |
default construtor
virtural destructor
Definition at line 85 of file ossimMrSidReader.cpp.
References closeEntry(), theImageNavigator, and theReader.
Definition at line 319 of file ossimMrSidReader.cpp.
References ossimImageHandler::close(), and theTile.
Referenced by ~ossimMrSidReader().
private |
Definition at line 522 of file ossimMrSidReader.cpp.
References getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), ossimDpt::x, and ossimDpt::y.
Referenced by getDecimationFactors().
private |
Definition at line 999 of file ossimMrSidReader.cpp.
Returns class name.
Definition at line 112 of file ossimMrSidReader.cpp.
private |
Definition at line 633 of file ossimMrSidReader.cpp.
References OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, theReader, and theScalarType.
| resLevel | Reduced resolution set for requested decimation. |
| result | ossimDpt to initialize with requested decimation. |
Definition at line 117 of file ossimMrSidReader.cpp.
References ossimImageGeometry::decimationFactor(), ossimDpt::makeNan(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
| decimations | Vector to initialize with decimations. |
Definition at line 130 of file ossimMrSidReader.cpp.
References computeDecimationFactors(), ossimImageGeometry::decimationFactors(), ossimImageGeometry::getNumberOfDecimations(), ossimImageGeometry::setDiscreteDecimation(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
protectedvirtual |
Definition at line 480 of file ossimMrSidReader.cpp.
References ossimFilename::exists(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimAuxXmlSupportData::getProjection(), ossimImageGeometry::setProjection(), ossimImageHandler::theImageFile, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry().
private |
Definition at line 692 of file ossimMrSidReader.cpp.
References ossimKeywordlist::add(), ossimString::contains(), ossimProjectionFactoryRegistry::createProjection(), ossimKeywordNames::DATUM_KW, ossimString::downcase(), ossimString::empty(), ossimFilename::exists(), ossimKeywordlist::findKey(), ossimAuxFileHandler::getDatumName(), ossimWkt::getKwl(), getMetadataElement(), getNumberOfLines(), getNumberOfSamples(), ossimAuxFileHandler::getProjectionName(), ossimAuxFileHandler::getUnitType(), ossimProjectionFactoryRegistry::instance(), ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimAuxFileHandler::open(), ossimNotify(), ossimNotifyLevel_WARN, ossimWkt::parse(), ossimKeywordNames::PCS_CODE_KW, ossimKeywordNames::PIXEL_SCALE_UNITS_KW, ossimKeywordNames::PIXEL_SCALE_XY_KW, ossimKeywordNames::PROJECTION_KW, ossimFilename::setExtension(), ossimString::size(), ossimImageHandler::theImageFile, theReader, ossimKeywordNames::TIE_POINT_UNITS_KW, ossimKeywordNames::TIE_POINT_XY_KW, ossimDpt::toString(), and ossimKeywordNames::TYPE_KW.
private |
Definition at line 588 of file ossimMrSidReader.cpp.
References ossimIrect::height(), theImageRect, theReader, and ossimIrect::width().
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 447 of file ossimMrSidReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
Referenced by getTile().
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile height which can be different than the internal image tile height on disk.
Implements ossimImageHandler.
Definition at line 428 of file ossimMrSidReader.cpp.
References ossimIrect::height(), theImageRect, and theMrSidDims.
Definition at line 414 of file ossimMrSidReader.cpp.
References theImageRect, theMrSidDims, and ossimIrect::width().
protectedvirtual |
Definition at line 503 of file ossimMrSidReader.cpp.
Returns long name.
Definition at line 107 of file ossimMrSidReader.cpp.
private |
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 161 of file ossimMrSidReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), theMinDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by computeDecimationFactors().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 404 of file ossimMrSidReader.cpp.
References theNumberOfBands.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 184 of file ossimMrSidReader.cpp.
References ossimImageHandler::getNumberOfSamples(), ossimImageHandler::isValidRLevel(), theMinDwtLevels, theMrSidDims, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by computeDecimationFactors(), and getGeoProjection().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 409 of file ossimMrSidReader.cpp.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 205 of file ossimMrSidReader.cpp.
Definition at line 442 of file ossimMrSidReader.cpp.
References theScalarType.
Returns short name.
Definition at line 102 of file ossimMrSidReader.cpp.
| rect | The zero based rectangle to grab. |
| resLevel | The reduced resolution level to grab from. |
Definition at line 326 of file ossimMrSidReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageGeometry::decimationFactor(), ossimImageHandler::getBoundingRect(), ossimImageData::getBuf(), getImageGeometry(), getOutputScalarType(), ossimImageSource::getTile(), ossimIrect::height(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimDpt::lat, ossimImageData::loadBand(), ossimIrect::lr(), ossimImageData::makeBlank(), ossimImageData::setImageRectangle(), ossimRectilinearDataObject::setScalarType(), ossimImageHandler::theGeometry, theImageNavigator, theMinDwtLevels, theNumberOfBands, ossimImageHandler::theOverview, theReader, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Definition at line 314 of file ossimMrSidReader.cpp.
References ossimRefPtr< T >::get(), and theTile.
Definition at line 620 of file ossimMrSidReader.cpp.
References ossimImageHandler::loadState(), and open().
Open method.
Definition at line 226 of file ossimMrSidReader.cpp.
Referenced by loadState().
private |
Definition at line 221 of file ossimMrSidReader.h.
Referenced by getTile(), and ~ossimMrSidReader().
private |
Definition at line 224 of file ossimMrSidReader.h.
Referenced by getImageDimensions(), getImageTileHeight(), and getImageTileWidth().
private |
Definition at line 223 of file ossimMrSidReader.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), and getTile().
private |
Image dimensions for each level.
Definition at line 227 of file ossimMrSidReader.h.
Referenced by getImageTileHeight(), getImageTileWidth(), getNumberOfLines(), and getNumberOfSamples().
private |
Definition at line 229 of file ossimMrSidReader.h.
Referenced by getNumberOfInputBands(), getNumberOfOutputBands(), and getTile().
private |
Definition at line 220 of file ossimMrSidReader.h.
Referenced by getDataType(), getGeoProjection(), getImageDimensions(), getTile(), and ~ossimMrSidReader().
private |
Definition at line 230 of file ossimMrSidReader.h.
Referenced by getDataType(), and getOutputScalarType().
private |
Definition at line 231 of file ossimMrSidReader.h.
Referenced by closeEntry(), getTile(), and isOpen().
