#include <ossimElevImageSource.h>
| ossimElevImageSource () | |
| ossimElevImageSource (ossimObject *owner) | |
| ossimElevImageSource (ossimObject *owner, const ossimGpt &tie, double latSpacing, double lonSpacing, ossim_uint32 numberLines, ossim_uint32 numberSamples) | |
| ossimElevImageSource (ossimObject *owner, const ossimKeywordlist &kwl, const char *prefix=0) | |
| virtual bool | getImageGeometry (ossimKeywordlist &kwl, const char *prefix=0) |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| bool | canConnectMyInputTo (ossim_int32, const ossimConnectableObject *) const |
| virtual void | changeTileSize (const ossimIpt &size) |
| virtual ossimGpt | getTiePoint () const |
| virtual ossim_float64 | getLatitudeSpacing () const |
| virtual ossim_float64 | getLongitudeSpacing () const |
| virtual void | setTiePoint (const ossimGpt &gpt) |
| virtual void | setLatitudeSpacing (ossim_float64 sp) |
| virtual void | setLongitudeSpacing (ossim_float64 sp) |
| virtual void | setNumberOfLines (ossim_uint32 lines) |
| virtual void | setNumberOfSamples (ossim_uint32 samps) |
| virtual void | setMinPixelValue (ossim_float64 min_pix) |
| virtual void | setMaxPixelValue (ossim_float64 max_pix) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimElevImageSource () |
Definition at line 25 of file ossimElevImageSource.h.
| ossimElevImageSource::ossimElevImageSource | ( | ) |
Definition at line 30 of file ossimElevImageSource.cpp.
| ossimElevImageSource::ossimElevImageSource | ( | ossimObject * | owner | ) |
Definition at line 46 of file ossimElevImageSource.cpp.
| ossimElevImageSource::ossimElevImageSource | ( | ossimObject * | owner, |
| const ossimGpt & | tie, | ||
| double | latSpacing, | ||
| double | lonSpacing, | ||
| ossim_uint32 | numberLines, | ||
| ossim_uint32 | numberSamples | ||
Definition at line 62 of file ossimElevImageSource.cpp.
References initialize().
| const ossimKeywordlist & | kwl, | ||
| const char * | prefix = 0 |
Definition at line 85 of file ossimElevImageSource.cpp.
References loadState(), and ossimErrorStatusInterface::setErrorStatus().
protectedvirtual |
Definition at line 108 of file ossimElevImageSource.cpp.
inlinevirtual |
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 94 of file ossimElevImageSource.h.
Definition at line 684 of file ossimElevImageSource.cpp.
inlinevirtual |
Returns the absolute bounding rectangle of the image. The upper left corner may be non-zero if this is a subimage.
Definition at line 75 of file ossimElevImageSource.h.
References getImageRectangle().
Satisfy pure virtuals from base classes...
Definition at line 635 of file ossimElevImageSource.cpp.
References ossimDpt::line, and ossimDpt::samp.
Definition at line 648 of file ossimElevImageSource.cpp.
Populates the keyword list with image geometry information. This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not.
Definition at line 617 of file ossimElevImageSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimLlxyProjection::saveState(), theLatSpacing, theLonSpacing, theNumberOfLines, and theTiePoint.
Returns the zero-based (relative) image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 604 of file ossimElevImageSource.cpp.
References theNumberOfLines, and theNumberOfSamps.
Referenced by getBoundingRect(), and getTile().
inlinevirtual |
Definition at line 116 of file ossimElevImageSource.h.
References theLatSpacing.
inlinevirtual |
Definition at line 117 of file ossimElevImageSource.h.
References theLonSpacing.
Definition at line 761 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimElevSource::getMaxHeightAboveMSL(), ossimImageData::getMaxPix(), theElevManager, and theTile.
Referenced by saveState().
Definition at line 739 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimElevSource::getMinHeightAboveMSL(), ossimImageData::getMinPix(), theElevManager, and theTile.
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 655 of file ossimElevImageSource.cpp.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 660 of file ossimElevImageSource.cpp.
Definition at line 713 of file ossimElevImageSource.cpp.
References theNumberOfLines.
inlinevirtual |
Returns the number of bands in the image. Alway one for this source.
Definition at line 61 of file ossimElevImageSource.h.
Definition at line 726 of file ossimElevImageSource.cpp.
References theNumberOfSamps.
Definition at line 665 of file ossimElevImageSource.cpp.
References OSSIM_FLOAT.
inlinevirtual |
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 112 of file ossimElevImageSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimElevSource::getHeightAboveMSL(), getImageRectangle(), ossimElevSource::getMaxHeightAboveMSL(), ossimElevSource::getMinHeightAboveMSL(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimIrect::intersects(), ossimSource::isSourceEnabled(), ossimGpt::latd(), ossimGpt::lond(), ossimIrect::lr(), ossimImageData::makeBlank(), ossimImageData::setHeight(), ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setOrigin(), ossimImageData::setWidth(), theElevManager, theLatSpacing, theLonSpacing, theTiePoint, theTile, ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Returns the default processing tile height.
Definition at line 677 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getHeight(), and theTile.
Returns the default processing tile width.
Definition at line 670 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getWidth(), and theTile.
Definition at line 494 of file ossimElevImageSource.cpp.
Referenced by ossimElevImageSource().
Definition at line 324 of file ossimElevImageSource.cpp.
References ossimKeywordlist::find(), ossimErrorStatusInterface::getErrorStatus(), ossimGpt::latd(), ossimImageSource::loadState(), ossimErrorCodes::OSSIM_ERROR, theTiePoint, and ossimKeywordNames::TIE_POINT_LAT_KW.
Definition at line 262 of file ossimElevImageSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimErrorStatusInterface::getErrorStatus(), getMaxPixelValue(), getMinPixelValue(), ossimGpt::latd(), ossimGpt::lond(), ossimKeywordNames::MAX_VALUE_KW, ossimKeywordNames::MIN_VALUE_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimErrorCodes::OSSIM_ERROR, ossimImageSource::saveState(), theLatSpacing, theLonSpacing, theNumberOfLines, theNumberOfSamps, theTiePoint, ossimKeywordNames::TIE_POINT_LAT_KW, and ossimKeywordNames::TIE_POINT_LON_KW.
inlinevirtual |
Definition at line 125 of file ossimElevImageSource.h.
inlinevirtual |
Definition at line 126 of file ossimElevImageSource.h.
Definition at line 803 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::setMaxPix(), and theTile.
Definition at line 783 of file ossimElevImageSource.cpp.
References ossimRefPtr< T >::get(), ossimImageData::setMinPix(), and theTile.
inlinevirtual |
Definition at line 127 of file ossimElevImageSource.h.
inlinevirtual |
Definition at line 128 of file ossimElevImageSource.h.
inlinevirtual |
protected |
Definition at line 135 of file ossimElevImageSource.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), and getTile().
protected |
Definition at line 138 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getLatitudeSpacing(), getTile(), saveState(), and setLatitudeSpacing().
protected |
Definition at line 139 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getLongitudeSpacing(), getTile(), saveState(), and setLongitudeSpacing().
protected |
Definition at line 140 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getImageRectangle(), getNumberOfLines(), saveState(), and setNumberOfLines().
protected |
Definition at line 141 of file ossimElevImageSource.h.
Referenced by getImageRectangle(), getNumberOfSamples(), saveState(), and setNumberOfSamples().
protected |
Definition at line 137 of file ossimElevImageSource.h.
Referenced by getImageGeometry(), getTiePoint(), getTile(), loadState(), saveState(), and setTiePoint().
protected |
Definition at line 136 of file ossimElevImageSource.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), getTile(), getTileHeight(), getTileWidth(), setMaxPixelValue(), and setMinPixelValue().
