Intended mainly to provide a mechanism for mutex-locking access to a shared resource during a getTile operation on an ossimImageHandler. More...
#include <ossimImageHandlerMtAdaptor.h>
| ossimImageHandlerMtAdaptor (ossimImageHandler *adaptee=0, bool use_cache=false, ossim_uint32 cache_tile_size=64) | |
| void | setAdaptee (ossimImageHandler *handler) |
| Sets the handler being adapted. More... | |
| virtual bool | canConnectMyInputTo (ossim_int32 i, const ossimConnectableObject *obj) const |
| Only an ossimImageHandler is allowed as input here. More... | |
| Intercepts the getTile call intended for the adaptee and sets a mutex lock around the adaptee's getTile call. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Pure virtual, derived classes must implement. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
| void | setCacheTileSize (ossim_uint32 cache_tile_size) |
| void | setUseCache (bool use_cache) |
| void | writeTime () const |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Attributes | |
| double | d_getTileT |
| ossim_uint32 | d_cacheTileSize |
Static Public Attributes | |
| static const char * | ADAPTEE_ID_KW = "adaptee_id" |
| virtual | ~ossimImageHandlerMtAdaptor () |
| Protected destructor forces using reference pointer for instantiation. More... | |
Friends | |
| class | ossimMtDebug |
This is needed for multi-threaded implementation.
Definition at line 20 of file ossimImageHandlerMtAdaptor.h.
| ossimImageHandlerMtAdaptor::ossimImageHandlerMtAdaptor | ( | ossimImageHandler * | adaptee = 0, |
| bool | use_cache = false, |
| ossim_uint32 | cache_tile_size = 64 |
Definition at line 31 of file ossimImageHandlerMtAdaptor.cpp.
References setAdaptee(), setCacheTileSize(), and setUseCache().
protectedvirtual |
Definition at line 53 of file ossimImageHandlerMtAdaptor.cpp.
References d_fauxTile, m_adaptedHandler, and m_cache.
Definition at line 108 of file ossimImageHandlerMtAdaptor.cpp.
Definition at line 343 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::close(), ossimImageHandler::closeOverview(), d_fauxTile, ossimConnectableObject::disconnectAllOutputs(), m_adaptedHandler, m_cache, ossimListenerManager::removeListener(), and ossimRefPtr< T >::valid().
Implements ossimImageHandler.
Definition at line 322 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getImageTileHeight(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 315 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getImageTileWidth(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 329 of file ossimImageHandlerMtAdaptor.cpp.
References ossimObject::getLongName(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 425 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getMaxPixelValue(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 418 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getMinPixelValue(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 432 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getNullPixelValue(), m_adaptedHandler, and ossimRefPtr< T >::valid().
This returns the total number of decimation levels.
It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 373 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 280 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getNumberOfInputBands(), m_adaptedHandler, and ossimRefPtr< T >::valid().
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 301 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getNumberOfLines(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 356 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getNumberOfOutputBands(), m_adaptedHandler, and ossimRefPtr< T >::valid().
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 308 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::getNumberOfSamples(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 397 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getOutputScalarType(), m_adaptedHandler, OSSIM_SCALAR_UNKNOWN, and ossimRefPtr< T >::valid().
Definition at line 336 of file ossimImageHandlerMtAdaptor.cpp.
References ossimObject::getShortName(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 123 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), m_adaptedHandler, ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
Definition at line 143 of file ossimImageHandlerMtAdaptor.cpp.
Definition at line 211 of file ossimImageHandlerMtAdaptor.cpp.
References d_useCache, ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossimCacheTileSource::getTile(), ossimImageSource::getTile(), m_adaptedHandler, m_cache, m_mutex, ossimReferenced::ref(), status, ossimReferenced::unref(), and ossimRefPtr< T >::valid().
Returns the default processing tile height.
Definition at line 411 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getTileHeight(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Returns the default processing tile width.
Definition at line 404 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageSource::getTileWidth(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 287 of file ossimImageHandlerMtAdaptor.cpp.
References ossimImageHandler::isOpen(), m_adaptedHandler, and ossimRefPtr< T >::valid().
Definition at line 261 of file ossimImageHandlerMtAdaptor.cpp.
References ADAPTEE_ID_KW, ossimString::empty(), ossimKeywordlist::find(), ossimImageSource::loadState(), and m_adaptedHandler.
Pure virtual open.
Derived classes must implement.
Definition at line 294 of file ossimImageHandlerMtAdaptor.cpp.
References m_adaptedHandler, ossimImageHandler::open(), and ossimRefPtr< T >::valid().
Definition at line 244 of file ossimImageHandlerMtAdaptor.cpp.
References ADAPTEE_ID_KW, ossimKeywordlist::add(), ossimId::getId(), ossimConnectableObject::getId(), m_adaptedHandler, ossimImageSource::saveState(), and ossimRefPtr< T >::valid().
| void ossimImageHandlerMtAdaptor::setAdaptee | ( | ossimImageHandler * | handler | ) |
Definition at line 63 of file ossimImageHandlerMtAdaptor.cpp.
References ossimConnectableObject::changeOwner(), ossimConnectableObject::connectMyOutputTo(), d_cacheTileSize, d_fauxTile, d_useCache, d_useFauxTile, ossimConnectableObject::disconnectMyOutputs(), ossimImageData::dup(), ossimRefPtr< T >::get(), ossimConnectableObject::getOutputList(), ossimImageSource::getTile(), m_adaptedHandler, m_cache, and ossimCacheTileSource::setTileSize().
Referenced by ossimImageHandlerMtAdaptor().
| void ossimImageHandlerMtAdaptor::setCacheTileSize | ( | ossim_uint32 | cache_tile_size | ) |
Definition at line 368 of file ossimImageHandlerMtAdaptor.cpp.
References d_cacheTileSize.
| void ossimImageHandlerMtAdaptor::setUseCache | ( | bool | use_cache | ) |
Definition at line 363 of file ossimImageHandlerMtAdaptor.cpp.
References d_useCache.
| void ossimImageHandlerMtAdaptor::writeTime | ( | ) | const |
Definition at line 380 of file ossimImageHandlerMtAdaptor.cpp.
References ossim::getTime().
friend |
Definition at line 90 of file ossimImageHandlerMtAdaptor.h.
Referenced by ossimMtDebug::instance().
static |
Definition at line 23 of file ossimImageHandlerMtAdaptor.h.
Referenced by loadState(), and saveState().
| ossim_uint32 ossimImageHandlerMtAdaptor::d_cacheTileSize |
Definition at line 77 of file ossimImageHandlerMtAdaptor.h.
Referenced by setAdaptee(), and setCacheTileSize().
protected |
Definition at line 89 of file ossimImageHandlerMtAdaptor.h.
Referenced by close(), setAdaptee(), and ~ossimImageHandlerMtAdaptor().
| double ossimImageHandlerMtAdaptor::d_getTileT |
Definition at line 76 of file ossimImageHandlerMtAdaptor.h.
Referenced by ossimMultiThreadSequencer::handlerGetTileT().
protected |
Definition at line 87 of file ossimImageHandlerMtAdaptor.h.
Referenced by getTile(), setAdaptee(), and setUseCache().
protected |
Definition at line 88 of file ossimImageHandlerMtAdaptor.h.
Referenced by setAdaptee().
protected |
Definition at line 83 of file ossimImageHandlerMtAdaptor.h.
Referenced by close(), getImageTileHeight(), getImageTileWidth(), getLongName(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), getOutputScalarType(), getShortName(), getTile(), getTileHeight(), getTileWidth(), isOpen(), loadState(), open(), saveState(), setAdaptee(), and ~ossimImageHandlerMtAdaptor().
protected |
Definition at line 84 of file ossimImageHandlerMtAdaptor.h.
Referenced by close(), getTile(), setAdaptee(), and ~ossimImageHandlerMtAdaptor().
mutableprotected |
Definition at line 85 of file ossimImageHandlerMtAdaptor.h.
Referenced by getTile().
