This class defines an abstract Handler which all image handlers(loaders) should derive from. More...
#include <ossimTiledImageHandler.h>
Classes | |
| class | ossimTileFile |
| Class for record of one tile file: More... | |
| ossimTiledImageHandler () | |
| virtual | ~ossimTiledImageHandler () |
| Destructor: More... | |
| virtual bool | open ()=0 |
| *virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the tile height of the image or 0 if the image is not tiled. More... | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel) |
| Fills the requested tile by pulling pixels from multiple file tiles as needed. More... | |
| Returns scalar type of first tile (should be the same for all tiles) More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| Returns overall bounding rect in image space. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| void | allocate () |
| Initialize tile buffer to match image datatype. More... | |
Definition at line 30 of file ossimTiledImageHandler.h.
| ossimTiledImageHandler::ossimTiledImageHandler | ( | ) |
Constructor (default):
Definition at line 43 of file ossimTiledImageHandler.cpp.
Destructor:
Definition at line 59 of file ossimTiledImageHandler.cpp.
References close().
protected |
Initialize tile buffer to natch image datatype.
Definition at line 94 of file ossimTiledImageHandler.cpp.
References ossimImageData::dup(), ossimImageHandler::getBoundingRect(), ossimImageSource::getTileHeight(), ossimImageSource::getTileWidth(), m_tile, m_tileFiles, ossimNotify(), ossimNotifyLevel_FATAL, ossimIrect::set_lr(), and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 68 of file ossimTiledImageHandler.cpp.
References m_tileFiles.
Referenced by ~ossimTiledImageHandler().
Definition at line 388 of file ossimTiledImageHandler.cpp.
References ossimImageHandler::getDecimationFactor(), m_fullImgRect, and ossimIrect::ul().
Referenced by ossimQuickbirdRpcModel::ossimQuickbirdRpcModel().
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile height which can be different than the internal image tile height on disk.
Implements ossimImageHandler.
Definition at line 363 of file ossimTiledImageHandler.cpp.
Definition at line 346 of file ossimTiledImageHandler.cpp.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 332 of file ossimTiledImageHandler.cpp.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 271 of file ossimTiledImageHandler.cpp.
References ossimIrect::hasNans(), ossimIrect::height(), and m_fullImgRect.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 286 of file ossimTiledImageHandler.cpp.
References ossimIrect::hasNans(), m_fullImgRect, and ossimIrect::width().
Definition at line 377 of file ossimTiledImageHandler.cpp.
References m_tileFiles, and OSSIM_SCALAR_UNKNOWN.
Definition at line 118 of file ossimTiledImageHandler.cpp.
References allocate(), ossimIrect::clipToRect(), ossimDataObject::getDataObjectStatus(), ossimImageSource::getTile(), ossimIrect::intersects(), ossimImageData::loadTile(), m_fullImgRect, m_startOvrResLevel, m_tile, m_tileFiles, ossimImageData::makeBlank(), OSSIM_BSQ, OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, ossimImageData::setImageRectangle(), ossimImageHandler::theOverview, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimImageData::validate().
Indicates whether or not the image is tiled internally.
This implementation returns true if (getImageTileWidth() && getImageTileHeight()) are both non zero. Override in the image handler if something else is desired. Returns true if tiled, false if not.
Definition at line 324 of file ossimTiledImageHandler.cpp.
Definition at line 83 of file ossimTiledImageHandler.cpp.
Definition at line 309 of file ossimTiledImageHandler.cpp.
References ossimImageHandler::loadState(), and open().
pure virtual |
Implemented in ossimQbTileFilesHandler.
Referenced by loadState().
Definition at line 300 of file ossimTiledImageHandler.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 119 of file ossimTiledImageHandler.h.
protected |
Definition at line 120 of file ossimTiledImageHandler.h.
Referenced by ossimQbTileFilesHandler::computeImageRects(), ossimQbTileFilesHandler::getImageGeometry(), getImageRectangle(), getNumberOfLines(), getNumberOfSamples(), and getTile().
protected |
Definition at line 121 of file ossimTiledImageHandler.h.
protected |
Definition at line 118 of file ossimTiledImageHandler.h.
Referenced by allocate(), and getTile().
protected |
Definition at line 117 of file ossimTiledImageHandler.h.
Referenced by allocate(), close(), ossimQbTileFilesHandler::computeImageRects(), getImageTileHeight(), getImageTileWidth(), getNumberOfInputBands(), getOutputScalarType(), getTile(), and isOpen().
