#include <ossimQuickbirdNitfTileSource.h>
| virtual bool | open () |
| Returns true if the image_file can be opened and is a valid nitf file. More... | |
Public Member Functions inherited from ossimNitfTileSource | |
| ossimNitfTileSource () | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| virtual void | close () |
| Closes file and destroys all memory allocated. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| ossim_uint32 | getNumberOfEntries () const |
| ossimString | getSecurityClassification () const |
| bool | getCacheEnabledFlag () const |
| void | setCacheEnabledFlag (bool flag) |
| const ossimNitfFileHeader * | getFileHeader () const |
| ossimNitfFileHeader * | getFileHeader () |
| const ossimNitfImageHeader * | getCurrentImageHeader () const |
| ossimNitfImageHeader * | getCurrentImageHeader () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Types inherited from ossimNitfTileSource | |
| enum | ReadMode { READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3, READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7, READ_JPEG_BLOCK = 8 } |
Protected Member Functions inherited from ossimNitfTileSource | |
| virtual | ~ossimNitfTileSource () |
| void | setBoundingRectangle (const ossimIrect &imageRect) |
| ossimNitfTileSource (const ossimNitfTileSource &obj) | |
| Copy constructor, disallow... More... | |
| ossimNitfTileSource & | operator= (const ossimNitfTileSource &rhs) |
| Operator=, disallow... More... | |
| bool | loadTile (const ossimIrect &clipRect) |
| Returns true on success, false on error. More... | |
| ossim_uint32 | getBlockNumber (const ossimIpt &block_origin) const |
| void | destroy () |
| Deletes all memory allocated by this object. More... | |
| virtual bool | parseFile () |
| Parses "theImageFile" and initializes all nitf headers. More... | |
| virtual bool | allocate () |
| Allocates everything for current entry. More... | |
| virtual bool | allocateBuffers () |
| Allocates buffers for current entry. More... | |
| virtual bool | canUncompress (const ossimNitfImageHeader *hdr) const |
| virtual void | initializeScalarType () |
| Initializes the data member "theScalarType" from the current entry. More... | |
| virtual void | initializeSwapBytesFlag () |
| Initializes the data member "theSwapBytesFlag" from the current entry. More... | |
| virtual void | initializeReadMode () |
| Initializes the data member "theReadMode" from the current entry. More... | |
| void | initializeBandCount () |
| Initializes the data member "theNumberOfBands" from the current entry. More... | |
| bool | initializeBlockSize () |
| Initializes the data member "theBlockSize" from the current entry. More... | |
| virtual bool | initializeImageRect () |
| Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More... | |
| void | initializeCacheSize () |
| Initializes the data member "theCacheSize". More... | |
| virtual void | initializeCacheTileInterLeaveType () |
| Initializes the data member "theCacheTileInterLeaveType". More... | |
| void | initializeCacheTile () |
| Initializes the cache tile size(width and height). More... | |
| virtual void | initializeCompressedBuf () |
| Initializes the data member theCompressedBuf. More... | |
| virtual void | initializeOutputTile () |
| Initializes the output tile size(width and height). More... | |
| void | initializeLut () |
| Initializes "theLut" if applicable. More... | |
| bool | loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect) |
| Loads a block of data to theCacheTile. More... | |
| virtual bool | loadBlock (ossim_uint32 x, ossim_uint32 y) |
| bool | getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const |
| ossim_uint32 | getNumberOfBlocks () const |
| std::streampos | getBandOffset () const |
| std::streampos | getBlockOffset () const |
| void | explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const |
| void | convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const |
| ossim_uint32 | getPartialReadSize (const ossimIpt &blockOrigin) const |
| bool | isVqCompressed (const ossimString &compressionCode) const |
| void | vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization unmasked image data. More... | |
| void | vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization masked image data. More... | |
| void | lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| virtual bool | scanForJpegBlockOffsets () |
| scans the file storing in offsets in "theNitfBlockOffset" and block sizes in "theNitfBlockSize". More... | |
| virtual bool | uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y) |
| Uncompresses a jpeg block using the jpeg-6b library. More... | |
| bool | loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const |
| Loads one of the default tables based on COMRAT value. More... | |
| bool | loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const |
| Loads default huffman tables. More... | |
Definition at line 19 of file ossimQuickbirdNitfTileSource.h.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 143 of file ossimQuickbirdNitfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getImageGeometry(), ossimImageGeometry::getTransform(), m_transform, ossimImageGeometry::setTransform(), and ossimRefPtr< T >::valid().
Reimplemented from ossimNitfTileSource.
Definition at line 162 of file ossimQuickbirdNitfTileSource.cpp.
References ossimNitfTileSource::loadState().
Definition at line 26 of file ossimQuickbirdNitfTileSource.cpp.
Definition at line 156 of file ossimQuickbirdNitfTileSource.cpp.
References ossimNitfTileSource::saveState().
protected |
Definition at line 41 of file ossimQuickbirdNitfTileSource.h.
Referenced by getImageGeometry().
