#include <ossimFusionCombiner.h>
| ossimFusionCombiner () | |
| ossimFusionCombiner (ossimObject *owner) | |
| ossimScalarType | getOutputScalarType () const |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Definition at line 21 of file ossimFusionCombiner.h.
| ossimFusionCombiner::ossimFusionCombiner | ( | ) |
Definition at line 17 of file ossimFusionCombiner.cpp.
| ossimFusionCombiner::ossimFusionCombiner | ( | ossimObject * | owner | ) |
Definition at line 27 of file ossimFusionCombiner.cpp.
protectedvirtual |
Definition at line 36 of file ossimFusionCombiner.cpp.
References theInputConnection, and theIntensityConnection.
required to be overriden by derived classes
Reimplemented from ossimImageCombiner.
Definition at line 68 of file ossimFusionCombiner.cpp.
References PTR_CAST.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 42 of file ossimFusionCombiner.cpp.
References ossimIrect::clipToRect(), ossimImageSource::getBoundingRect(), ossimIrect::makeNan(), theInputConnection, and theIntensityConnection.
protected |
Definition at line 86 of file ossimFusionCombiner.cpp.
References ossimImageData::copyTileToNormalizedBuffer(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimIrect::height(), ossimImageData::initialize(), OSSIM_NORMALIZED_FLOAT, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangleAndBands(), theIntensityConnection, theNormIntensity, ossimRefPtr< T >::valid(), and ossimIrect::width().
Referenced by ossimColorNormalizedFusion::getTile().
protected |
Definition at line 117 of file ossimFusionCombiner.cpp.
References ossimImageData::copyTileToNormalizedBuffer(), ossimImageDataFactory::create(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), OSSIM_NORMALIZED_FLOAT, ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangleAndBands(), theInputConnection, theNormTile, theTile, ossimRefPtr< T >::valid(), and ossimIrect::width().
Referenced by ossimColorNormalizedFusion::getTile(), ossimSFIMFusion::getTile(), and ossimLocalCorrelationFusion::getTile().
Definition at line 75 of file ossimFusionCombiner.cpp.
References ossimImageCombiner::getOutputScalarType(), ossimImageSource::getOutputScalarType(), and theInputConnection.
Reimplemented in ossimLocalCorrelationFusion, and ossimSFIMFusion.
Definition at line 168 of file ossimFusionCombiner.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimImageSource::getNumberOfOutputBands(), ossimImageCombiner::initialize(), ossimImageData::initialize(), ossimImageDataFactory::instance(), PTR_CAST, theInputConnection, theIntensityConnection, and theTile.
Referenced by ossimSFIMFusion::initialize(), ossimLocalCorrelationFusion::initialize(), and ossimChipperUtil::initializePsmChain().
protected |
Definition at line 37 of file ossimFusionCombiner.h.
Referenced by getBoundingRect(), getNormTile(), getOutputScalarType(), ossimColorNormalizedFusion::getTile(), ossimSFIMFusion::getTile(), ossimLocalCorrelationFusion::getTile(), initialize(), ossimSFIMFusion::initialize(), and ~ossimFusionCombiner().
protected |
Definition at line 38 of file ossimFusionCombiner.h.
Referenced by getBoundingRect(), getNormIntensity(), ossimColorNormalizedFusion::getTile(), ossimSFIMFusion::getTile(), ossimLocalCorrelationFusion::getTile(), initialize(), ossimSFIMFusion::initialize(), ossimLocalCorrelationFusion::initialize(), and ~ossimFusionCombiner().
protected |
Definition at line 36 of file ossimFusionCombiner.h.
Referenced by getNormIntensity().
protected |
Definition at line 35 of file ossimFusionCombiner.h.
Referenced by getNormTile().
protected |
Definition at line 34 of file ossimFusionCombiner.h.
Referenced by getNormTile(), ossimColorNormalizedFusion::getTile(), ossimSFIMFusion::getTile(), ossimLocalCorrelationFusion::getTile(), and initialize().
