#include <ossimGeoPdfReader.h>
Classes | |
| struct | ossimFrameEntryData |
| ossimGeoPdfReader () | |
| default construtor More... | |
| virtual | ~ossimGeoPdfReader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Returns class name. More... | |
| Method to grab a tile(rectangle) from image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual bool | open () |
| Open method. More... | |
| Method to test for open file stream. More... | |
| virtual void | closeEntry () |
| Method to close current entry. More... | |
| ossimImageHandler () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| std::vector< ossimFrameEntryData > | getIntersectingEntries (const ossimIrect &rect) |
| It is important to note that each frame is organized into an easting northing type orientation. More... | |
Private Member Functions | |
| ossimProjection * | getGeoProjection () |
| ossimProjection * | getVPGeoProjection () |
| ossimProjection * | getLGIDictGeoProjection () |
| ossimProjection * | getProjectionFromStr (ossimString projContents) |
| ossimDrect | computeBoundingRect (ossimRefPtr< ossimImageGeometry > geoImage) |
| void | setPodofoInfo (PoDoFo::PdfObject *object) |
| void | setPodofoRefInfo (PoDoFo::PdfObject *object) |
| void | setPodofoArrayInfo (PoDoFo::PdfObject *object) |
| void | setPodofoDictInfo (PoDoFo::PdfObject *object) |
| void | parseTileStructure (std::vector< ossimString > tileInfo) |
| void | setPodofoImageInfo () |
| void | buildFrameEntryArray () |
| void | buildTileInfo (ossimString tileInfo) |
| void | resetCacheBuffer (ossimFrameEntryData entry) |
| void | fillTile (T, const ossimIrect &clip_rect, ossimImageData *tile) |
Definition at line 42 of file ossimGeoPdfReader.h.
| ossimGeoPdfReader::ossimGeoPdfReader | ( | ) |
default construtor
Definition at line 136 of file ossimGeoPdfReader.cpp.
virtural destructor
Definition at line 161 of file ossimGeoPdfReader.cpp.
References closeEntry().
private |
Definition at line 1255 of file ossimGeoPdfReader.cpp.
References m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, m_imageRect, m_numberOfBands, m_numberOfLines, m_numberOfSamples, m_numOfFramesHorizontal, m_numOfFramesVertical, m_podofoImageObjs, m_podofoTileInfo, and size.
private |
Definition at line 424 of file ossimGeoPdfReader.cpp.
References m_podofoTileInfo, and ossimString::split().
Referenced by parseTileStructure().
Definition at line 674 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::close(), m_cacheTile, m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, m_pageVector, m_pdfMemDocument, m_podofoImageObjs, m_podofoProjInfo, m_podofoTileInfo, and m_tile.
Referenced by ~ossimGeoPdfReader().
private |
Definition at line 441 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::empty(), ossimMapProjection::forward(), ossimImageGeometry::getProjection(), getValueFromMap(), ossimProjection::inverse(), ossimMapProjection::isGeographic(), ossimDrect::ll(), ossimDrect::lr(), m_isLGIDict, m_numberOfLines, m_numberOfSamples, m_podofoProjInfo, OSSIM_RIGHT_HANDED, ossimString::push_back(), ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlEastingNorthing(), ossimMapProjection::setUlTiePoints(), ossimString::split(), ossimString::substitute(), ossimString::toString(), ossimString::trim(), ossimDrect::ul(), ossimDrect::ur(), ossimImageGeometry::worldToLocal(), ossimDpt::x, and ossimDpt::y.
private |
Definition at line 829 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), getClassName(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimIrect::intersects(), ossimIrect::ll(), ossimImageData::loadTile(), m_cacheTile, m_isJpeg, ossimErrorCodes::OSSIM_ERROR, OSSIM_NULL, ossimSetError(), ossimIrect::ul(), ossimImageData::validate(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by getTile().
Returns class name.
Definition at line 239 of file ossimGeoPdfReader.cpp.
Referenced by fillTile().
| entryList | This is the list to initialize with entry indexes. |
Definition at line 734 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getEntryList(), getNumberOfEntries(), and m_pageVector.
private |
Definition at line 991 of file ossimGeoPdfReader.cpp.
References getLGIDictGeoProjection(), getVPGeoProjection(), and m_isLGIDict.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 936 of file ossimGeoPdfReader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile height which can be different than the internal image tile height on disk.
Implements ossimImageHandler.
Definition at line 926 of file ossimGeoPdfReader.cpp.
Definition at line 921 of file ossimGeoPdfReader.cpp.
| Method | to get geometry. |
Definition at line 967 of file ossimGeoPdfReader.cpp.
References m_pageVector.
Referenced by getImageGeometry().
protected |
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
| rect | the current region to render. |
Definition at line 1379 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimImageHandler::getImageRectangle(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), m_frameEntryArray, m_frameHeightVector, m_frameWidthVector, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
private |
Definition at line 1023 of file ossimGeoPdfReader.cpp.
References ossimString::empty(), getProjectionFromStr(), getValueFromMap(), and m_podofoProjInfo.
Referenced by getGeoProjection().
Returns long name.
Definition at line 234 of file ossimGeoPdfReader.cpp.
Definition at line 729 of file ossimGeoPdfReader.cpp.
Referenced by getEntryList().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 911 of file ossimGeoPdfReader.cpp.
References m_numberOfBands.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 244 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getNumberOfLines(), m_numberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 916 of file ossimGeoPdfReader.cpp.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 259 of file ossimGeoPdfReader.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 931 of file ossimGeoPdfReader.cpp.
References m_scalarType.
private |
Definition at line 1425 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::empty(), getValueFromMap(), ossimString::split(), ossimString::substitute(), and ossimString::trim().
Referenced by getLGIDictGeoProjection().
Returns short name.
Definition at line 229 of file ossimGeoPdfReader.cpp.
| rect | The zero based rectangle to grab. |
| resLevel | The reduced resolution level to grab from. |
Definition at line 749 of file ossimGeoPdfReader.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 769 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), fillTile(), ossimImageData::getImageRectangle(), ossimImageHandler::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), m_currentRow, ossimImageData::makeBlank(), ossimReferenced::ref(), resetCacheBuffer(), status, and ossimReferenced::unref().
private |
Definition at line 1004 of file ossimGeoPdfReader.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimEpsgProjectionFactory::createProjection(), ossimString::empty(), getValueFromMap(), ossimEpsgProjectionFactory::instance(), m_podofoProjInfo, ossimKeywordNames::PCS_CODE_KW, and ossimString::toString().
Definition at line 660 of file ossimGeoPdfReader.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimImageHandler::theImageFile.
Referenced by getIntersectingEntries(), and getTile().
Definition at line 977 of file ossimGeoPdfReader.cpp.
References ossimKeywordlist::find(), ossimImageHandler::loadState(), open(), and ossimKeywordNames::TYPE_KW.
Open method.
Definition at line 274 of file ossimGeoPdfReader.cpp.
Referenced by loadState().
private |
Definition at line 392 of file ossimGeoPdfReader.cpp.
References buildTileInfo(), ossimString::contains(), ossimString::downcase(), and m_podofoTileInfo.
Referenced by setPodofoImageInfo().
private |
Definition at line 166 of file ossimGeoPdfReader.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimImageData::loadBand(), ossimImageData::loadTile(), m_cacheSize, m_cacheTile, m_frameHeightVector, m_frameWidthVector, m_numberOfBands, ossimImageData::makeBlank(), OSSIM_BIP, ossimImageData::setImageRectangle(), ossimGeoPdfReader::ossimFrameEntryData::theCol, ossimGeoPdfReader::ossimFrameEntryData::theFrameEntry, ossimGeoPdfReader::ossimFrameEntryData::thePixelCol, ossimGeoPdfReader::ossimFrameEntryData::thePixelRow, ossimGeoPdfReader::ossimFrameEntryData::theRow, ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Definition at line 645 of file ossimGeoPdfReader.cpp.
References m_pageVector, ossimImageGeometry::saveState(), ossimImageHandler::saveState(), and ossimRefPtr< T >::valid().
| entryIdx | Entry number to select. |
Definition at line 629 of file ossimGeoPdfReader.cpp.
References m_imageRect, m_pageVector, ossimIrect::makeNan(), ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
private |
Definition at line 1051 of file ossimGeoPdfReader.cpp.
References setPodofoDictInfo(), and setPodofoRefInfo().
Referenced by setPodofoInfo().
private |
Definition at line 1082 of file ossimGeoPdfReader.cpp.
References m_podofoProjInfo, and setPodofoRefInfo().
Referenced by setPodofoArrayInfo(), setPodofoInfo(), and setPodofoRefInfo().
private |
Definition at line 1108 of file ossimGeoPdfReader.cpp.
References ossimString::contains(), ossimString::downcase(), m_isJpeg, m_pdfMemDocument, m_podofoImageObjs, m_podofoTileInfo, parseTileStructure(), and ossimString::push_back().
private |
Definition at line 1034 of file ossimGeoPdfReader.cpp.
References m_podofoProjInfo, setPodofoArrayInfo(), setPodofoDictInfo(), and setPodofoRefInfo().
private |
Definition at line 1068 of file ossimGeoPdfReader.cpp.
References m_pdfMemDocument, and setPodofoDictInfo().
Referenced by setPodofoArrayInfo(), setPodofoDictInfo(), and setPodofoInfo().
private |
Definition at line 323 of file ossimGeoPdfReader.h.
private |
Definition at line 322 of file ossimGeoPdfReader.h.
Referenced by resetCacheBuffer().
private |
Definition at line 321 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), fillTile(), and resetCacheBuffer().
private |
Definition at line 305 of file ossimGeoPdfReader.h.
private |
Definition at line 304 of file ossimGeoPdfReader.h.
private |
Definition at line 324 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), closeEntry(), and getIntersectingEntries().
private |
Definition at line 307 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), closeEntry(), getIntersectingEntries(), and resetCacheBuffer().
private |
Definition at line 306 of file ossimGeoPdfReader.h.
private |
Definition at line 298 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), and setCurrentEntry().
private |
Definition at line 318 of file ossimGeoPdfReader.h.
Referenced by fillTile(), and setPodofoImageInfo().
private |
Definition at line 317 of file ossimGeoPdfReader.h.
Referenced by computeBoundingRect(), and getGeoProjection().
private |
Has sub image offset.
Definition at line 299 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), getNumberOfInputBands(), getNumberOfOutputBands(), and resetCacheBuffer().
private |
Definition at line 300 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), computeBoundingRect(), and getNumberOfLines().
private |
Definition at line 301 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), computeBoundingRect(), and getNumberOfSamples().
private |
Definition at line 303 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray().
private |
Definition at line 302 of file ossimGeoPdfReader.h.
private |
Definition at line 319 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), getEntryList(), getInternalImageGeometry(), getNumberOfEntries(), saveState(), and setCurrentEntry().
private |
Definition at line 316 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), setPodofoImageInfo(), and setPodofoRefInfo().
private |
Definition at line 315 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), closeEntry(), and setPodofoImageInfo().
private |
Definition at line 311 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), computeBoundingRect(), getLGIDictGeoProjection(), getVPGeoProjection(), setPodofoDictInfo(), and setPodofoInfo().
private |
Definition at line 314 of file ossimGeoPdfReader.h.
Referenced by buildFrameEntryArray(), buildTileInfo(), closeEntry(), parseTileStructure(), and setPodofoImageInfo().
private |
Definition at line 308 of file ossimGeoPdfReader.h.
Referenced by getOutputScalarType().
private |
Definition at line 309 of file ossimGeoPdfReader.h.
Referenced by closeEntry(), and getTile().
