#include <ossimVpfTileSource.h>
| ossimVpfTileSource () | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual bool | open () |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual bool | setView (ossimObject *baseObject) |
| void | getAllFeatures (std::vector< ossimVpfAnnotationFeatureInfo *> &featureList) |
| void | setAllFeatures (std::vector< ossimVpfAnnotationFeatureInfo *> &featureList) |
| void | transformObjects () |
| void | computeBoundingRect () |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| virtual | ~ossimVpfTileSource () |
Definition at line 21 of file ossimVpfTileSource.h.
| ossimVpfTileSource::ossimVpfTileSource | ( | ) |
Definition at line 15 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, ossimAnnotationSource::setNumberOfBands(), and ossimViewInterface::theObject.
protectedvirtual |
Definition at line 24 of file ossimVpfTileSource.cpp.
References m_AnnotationSource.
Definition at line 46 of file ossimVpfTileSource.cpp.
References ossimVpfAnnotationSource::close(), and m_AnnotationSource.
| void ossimVpfTileSource::computeBoundingRect | ( | ) |
Definition at line 202 of file ossimVpfTileSource.cpp.
References ossimVpfAnnotationSource::computeBoundingRect(), and m_AnnotationSource.
| void ossimVpfTileSource::getAllFeatures | ( | std::vector< ossimVpfAnnotationFeatureInfo *> & | featureList | ) |
Definition at line 187 of file ossimVpfTileSource.cpp.
References ossimVpfAnnotationSource::getAllFeatures(), and m_AnnotationSource.
Definition at line 109 of file ossimVpfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimGeoAnnotationSource::getImageGeometry(), ossimImageHandler::initImageParameters(), m_AnnotationSource, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. Note that rrds 0 is the highest resolution rrds.
Definition at line 101 of file ossimVpfTileSource.cpp.
References ossimAnnotationSource::getBoundingRect(), and m_AnnotationSource.
Returns the tile width of the image or 0 if the image is not tiled. Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 147 of file ossimVpfTileSource.cpp.
Definition at line 142 of file ossimVpfTileSource.cpp.
Definition at line 167 of file ossimVpfTileSource.cpp.
References ossimImageSource::getMaxPixelValue(), and m_AnnotationSource.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 162 of file ossimVpfTileSource.cpp.
References ossimImageSource::getMinPixelValue(), and m_AnnotationSource.
Definition at line 157 of file ossimVpfTileSource.cpp.
References ossimImageSource::getNullPixelValue(), and m_AnnotationSource.
Returns the number of reduced resolution data sets (rrds). Note: The full res image is counted as a data set so an image with no reduced resolution data set will have a count of one.
Definition at line 96 of file ossimVpfTileSource.cpp.
Returns the number of bands in the image. Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 62 of file ossimVpfTileSource.cpp.
References ossimAnnotationSource::getNumberOfOutputBands(), and m_AnnotationSource.
Definition at line 72 of file ossimVpfTileSource.cpp.
References ossimAnnotationSource::getBoundingRect(), ossimIrect::hasNans(), ossimIrect::height(), m_AnnotationSource, ossimIrect::ul(), and ossimIpt::x.
Returns the number of bands in a tile returned from this TileSource. Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 67 of file ossimVpfTileSource.cpp.
Returns the number of bands available from an image. Satisfies pure virtual from ImageHandler class.
Definition at line 84 of file ossimVpfTileSource.cpp.
Definition at line 127 of file ossimVpfTileSource.cpp.
References ossimAnnotationSource::getOutputScalarType(), and m_AnnotationSource.
Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. Satisfies pure virtual from TileSource class.
Definition at line 56 of file ossimVpfTileSource.cpp.
References ossimAnnotationSource::getTile(), and m_AnnotationSource.
Returns the height of the output tile.
Definition at line 137 of file ossimVpfTileSource.cpp.
References ossimImageSource::getTileHeight(), and m_AnnotationSource.
Returns the width of the output tile.
Definition at line 132 of file ossimVpfTileSource.cpp.
References ossimImageSource::getTileWidth(), and m_AnnotationSource.
Implements ossimViewInterface.
Definition at line 172 of file ossimVpfTileSource.cpp.
References ossimGeoAnnotationSource::getView(), and m_AnnotationSource.
Definition at line 177 of file ossimVpfTileSource.cpp.
Definition at line 152 of file ossimVpfTileSource.cpp.
References ossimVpfAnnotationSource::isOpen(), and m_AnnotationSource.
Definition at line 35 of file ossimVpfTileSource.cpp.
References ossimVpfAnnotationSource::loadState(), ossimImageHandler::loadState(), and m_AnnotationSource.
Definition at line 51 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, ossimVpfAnnotationSource::open(), and ossimImageHandler::theImageFile.
Definition at line 29 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, and ossimVpfAnnotationSource::saveState().
| void ossimVpfTileSource::setAllFeatures | ( | std::vector< ossimVpfAnnotationFeatureInfo *> & | featureList | ) |
Definition at line 192 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, and ossimVpfAnnotationSource::setAllFeatures().
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 182 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, and ossimGeoAnnotationSource::setView().
| void ossimVpfTileSource::transformObjects | ( | ) |
Definition at line 197 of file ossimVpfTileSource.cpp.
References m_AnnotationSource, and ossimVpfAnnotationSource::transformObjects().
protected |
Definition at line 158 of file ossimVpfTileSource.h.
Referenced by close(), computeBoundingRect(), getAllFeatures(), getImageGeometry(), getImageRectangle(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), getOutputScalarType(), getTile(), getTileHeight(), getTileWidth(), getView(), isOpen(), loadState(), open(), ossimVpfTileSource(), saveState(), setAllFeatures(), setView(), transformObjects(), and ~ossimVpfTileSource().
