class ossimHistogramMatchFilter More...
#include <ossimHistogramMatchFilter.h>
| ossimHistogramMatchFilter () | |
| Calls the owned equalizers to create a match composite image. More... | |
| Initializes the input and target equalizer filters. More... | |
| void | setInputHistogram (const ossimFilename &inputHistogram) |
| void | setTargetHistogram (const ossimFilename &targetHistogram) |
| Returns a property given the name. More... | |
| Returns a list of proeprties. More... | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | autoLoadInputHistogram () |
| Will search the input chain and get the histogram_filename property of the image handler. More... | |
This class owns two ossimHistogramEqualization filters and will chain them together. It will make the left most filter the forward transform by transforming the input input to an equalized space defined by the input histogram. The right filter is the target histogram to match. It will take the equalized space and invert it to a target histogram.
There is an auto load input histogram flag that if set true will always try to search for an input handler and get the input handlers histogram file. and set it. If this is enabled then the only other field that is required is to specify the target histogram. If a target histogram is not specified then the output
will be an equalized image without the target applied.
Definition at line 24 of file ossimHistogramMatchFilter.h.
| ossimHistogramMatchFilter::ossimHistogramMatchFilter | ( | ) |
Definition at line 9 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), ossimHistogramEqualization::setInverseFlag(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
protected |
Once retrieved it calls the setInputHistogram with the found histogram filename. It does nothing if the histogram filename does not exist
Definition at line 235 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::accept(), ossimFilename::exists(), ossimCollectionVisitor::getObjectAs(), ossimCollectionVisitor::getObjects(), ossimImageHandler::getProperty(), setInputHistogram(), ossimRefPtr< T >::valid(), ossimProperty::valueToString(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by getTile(), and initialize().
| event | Connection event |
Definition at line 56 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::connectInputEvent(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), ossimHistogramEqualization::initialize(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
Definition at line 73 of file ossimHistogramMatchFilter.cpp.
References ossimConnectableObject::connectMyInputTo(), ossimImageSourceFilter::disconnectInputEvent(), ossimConnectableObject::disconnectMyInput(), ossimConnectableObject::getInput(), ossimHistogramEqualization::initialize(), theInputHistogramEqualizer, and theTargetHistogramEqualizer.
Valid names are: auto_load_input_histogram_flag input_histogram_filename output_histogram_filename
Example:
ossimRefPtr<ossimProperty> prop = obj->getProperty("auto_load_input_histogram_flag");
Definition at line 132 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::getProperty(), ossimFilenameProperty::ossimFilenamePropertyIoType_INPUT, ossimProperty::setCacheRefreshBit(), ossimFilenameProperty::setIoType(), theAutoLoadInputHistogramFlag, theInputHistogramFilename, and theTargetHistogramFilename.
Valid properties are:
Is a boolean property and specifes whether or not the input histogram will be auto searched from
the conected input source chain.input_histogram_filename
Holds the input histogram filenameoutput_histogram_filename
holds the output histogram filename
Definition at line 163 of file ossimHistogramMatchFilter.cpp.
References ossimImageSourceFilter::getPropertyNames().
Definition at line 21 of file ossimHistogramMatchFilter.cpp.
References autoLoadInputHistogram(), ossimHistogramEqualization::getTile(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), theAutoLoadInputHistogramFlag, ossimImageSourceFilter::theInputConnection, theInputHistogramFilename, and theTargetHistogramEqualizer.
Definition at line 90 of file ossimHistogramMatchFilter.cpp.
References autoLoadInputHistogram(), ossimHistogramEqualization::initialize(), ossimImageSourceFilter::initialize(), theAutoLoadInputHistogramFlag, theInputHistogramEqualizer, theInputHistogramFilename, and theTargetHistogramEqualizer.
Referenced by setProperty().
Keywords to search and load:
| kwl | Holds the keywords for this object to load prefixed by the passed in prefix parameter |
| prefix | Is the prefix value prepended to all keywords |
Definition at line 172 of file ossimHistogramMatchFilter.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), setInputHistogram(), setTargetHistogram(), theAutoLoadInputHistogramFlag, and ossimString::toBool().
Keywords:
| kwl | This object will store the keywords in kwl and prefix by the parameter prefix |
Definition at line 205 of file ossimHistogramMatchFilter.cpp.
References ossimKeywordlist::add(), ossimString::c_str(), ossimImageSourceFilter::saveState(), theAutoLoadInputHistogramFlag, theInputHistogramFilename, and theTargetHistogramFilename.
| void ossimHistogramMatchFilter::setInputHistogram | ( | const ossimFilename & | inputHistogram | ) |
| inputHistogram | Input histogram to load |
Definition at line 42 of file ossimHistogramMatchFilter.cpp.
References ossimHistogramEqualization::initialize(), ossimHistogramEqualization::setHistogram(), theInputHistogramEqualizer, and theInputHistogramFilename.
Referenced by autoLoadInputHistogram(), loadState(), and setProperty().
holds the output histogram filename | property | Is the property to set. |
Definition at line 105 of file ossimHistogramMatchFilter.cpp.
References initialize(), setInputHistogram(), ossimImageSourceFilter::setProperty(), setTargetHistogram(), theAutoLoadInputHistogramFlag, ossimRefPtr< T >::valid(), and ossimProperty::valueToString().
| void ossimHistogramMatchFilter::setTargetHistogram | ( | const ossimFilename & | targetHistogram | ) |
| targetHistogram | Target histogram to match |
Definition at line 49 of file ossimHistogramMatchFilter.cpp.
References ossimHistogramEqualization::initialize(), ossimHistogramEqualization::setHistogram(), theTargetHistogramEqualizer, and theTargetHistogramFilename.
Referenced by loadState(), and setProperty().
protected |
Definition at line 170 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), getTile(), initialize(), loadState(), saveState(), and setProperty().
protected |
Definition at line 166 of file ossimHistogramMatchFilter.h.
Referenced by connectInputEvent(), disconnectInputEvent(), initialize(), ossimHistogramMatchFilter(), and setInputHistogram().
protected |
Definition at line 168 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), getTile(), initialize(), saveState(), and setInputHistogram().
protected |
Definition at line 167 of file ossimHistogramMatchFilter.h.
Referenced by connectInputEvent(), disconnectInputEvent(), getTile(), initialize(), ossimHistogramMatchFilter(), and setTargetHistogram().
protected |
Definition at line 169 of file ossimHistogramMatchFilter.h.
Referenced by getProperty(), saveState(), and setTargetHistogram().
