class for vertical or horizontal convolution More...
#include <ossimConvolutionFilter1D.h>
| ossimConvolutionFilter1D (ossimObject *owner=NULL) | |
| own class methods More... | |
| virtual const std::vector< ossim_float64 > & | getKernel () const |
| virtual void | setKernel (const std::vector< ossim_float64 > &aKernel) |
| virtual bool | isHorizontal () const |
| virtual void | setIsHorizontal (bool aIsHz) |
| virtual ossim_int32 | getCenterOffset () const |
| virtual void | setCenterOffset (ossim_int32 aCenterOffset) |
| virtual bool | isStrictNoData () const |
| virtual void | setStrictNoData (bool aStrict) |
| inherited methods More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimConvolutionFilter1D () |
| void | allocate () |
| Allocates theTile. More... | |
| void | clearNullMinMax () |
| Clears data members theNullPixValue, theMinPixValue, and theMaxPixValue. More... | |
| void | computeNullMinMax () |
| Computes null, min, and max considering input connection and theKernel. More... | |
| template<class T > | |
| void | convolveFull (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
| void | convolvePartial (T, ossimRefPtr< ossimImageData > inputData, ossimRefPtr< ossimImageData > outputData) |
Protected Attributes | |
| ossim_int32 | theCenterOffset |
| offset of center point in the Kernel More... | |
| ossimRefPtr< ossimImageData > | theTile |
| std::vector< ossim_float64 > | theKernel |
| bool | theIsHz |
| bool | theStrictNoData |
| isHorizontal convolution? More... | |
| std::vector< double > | theNullPixValue |
| strictly no NODATA values used More... | |
| std::vector< double > | theMinPixValue |
| std::vector< double > | theMaxPixValue |
Protected Attributes inherited from ossimImageSourceFilter | |
| ossimImageSource * | theInputConnection |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Protected Attributes inherited from ossimListener | |
| bool | theListenerEnableFlag |
PROPERTIES: -KernelSize : length of linear kernel (>=1) NOTE - you need to exit the property editor for the kernel to be resized -Kernel : Kernel vector (line matrix) -Horizontal : boolean, otherwise vertical kernel -CenterOffset : center pixel position in the kernel, starting at 0 -StrictNoData : controls NODATA use true : any NODATA pixel in the convolution will make the center pixel NODATA false : if center is NODATA, then output center is NODATA, other NODATA pixels are processed as if they were zero in the convolution
Definition at line 32 of file ossimConvolutionFilter1D.h.
| ossimConvolutionFilter1D::ossimConvolutionFilter1D | ( | ossimObject * | owner = NULL | ) |
own class methods
Definition at line 24 of file ossimConvolutionFilter1D.cpp.
References theKernel.
protectedvirtual |
Definition at line 38 of file ossimConvolutionFilter1D.cpp.
protected |
Allocates theTile.
Definition at line 353 of file ossimConvolutionFilter1D.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimImageSourceFilter::theInputConnection, and theTile.
Referenced by getTile().
protected |
Definition at line 600 of file ossimConvolutionFilter1D.cpp.
References theMaxPixValue, theMinPixValue, and theNullPixValue.
Referenced by initialize(), loadState(), setKernel(), and setProperty().
protected |
Definition at line 607 of file ossimConvolutionFilter1D.cpp.
References ossim::defaultMax(), ossim::defaultMin(), ossim::defaultNull(), ossimImageSource::getMaxPixelValue(), ossimImageSource::getMinPixelValue(), ossimImageSource::getNullPixelValue(), ossimImageSource::getNumberOfOutputBands(), ossimImageSource::getOutputScalarType(), ossimImageSourceFilter::theInputConnection, theKernel, theMaxPixValue, theMinPixValue, and theNullPixValue.
protected |
Convolve full means that the input data is full and has no null data. We don't have to compare for nulls here
Definition at line 277 of file ossimConvolutionFilter1D.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theIsHz, and theKernel.
protected |
Convolve partial means that the input data is has some null data. We will have to compare nulls
Definition at line 191 of file ossimConvolutionFilter1D.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), getMaxPixelValue(), getMinPixelValue(), ossimImageData::getNullPix(), getNullPixelValue(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), theCenterOffset, theIsHz, theKernel, and theStrictNoData.
inlinevirtual |
Definition at line 46 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 40 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 56 of file ossimConvolutionFilter1D.h.
Definition at line 590 of file ossimConvolutionFilter1D.cpp.
References ossimImageSource::getMaxPixelValue(), ossimSource::isSourceEnabled(), and theMaxPixValue.
Referenced by convolveFull(), and convolvePartial().
Definition at line 580 of file ossimConvolutionFilter1D.cpp.
References ossimImageSource::getMinPixelValue(), ossimSource::isSourceEnabled(), and theMinPixValue.
Definition at line 570 of file ossimConvolutionFilter1D.cpp.
References ossim::defaultNull(), ossimImageSource::getOutputScalarType(), ossimSource::isSourceEnabled(), and theNullPixValue.
Referenced by convolvePartial().
Definition at line 422 of file ossimConvolutionFilter1D.cpp.
References ossimImageSourceFilter::getProperty(), ossimNumericProperty::ossimNumericPropertyType_INT, PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, theCenterOffset, theIsHz, theKernel, theStrictNoData, and ossimString::toString().
Definition at line 456 of file ossimConvolutionFilter1D.cpp.
References ossimImageSourceFilter::getPropertyNames(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, and PROPNAME_STRICTNODATA.
inlinevirtual |
inherited methods
Definition at line 55 of file ossimConvolutionFilter1D.h.
Definition at line 42 of file ossimConvolutionFilter1D.cpp.
References allocate(), computeNullMinMax(), convolveFull(), convolvePartial(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimIrect::lr(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_FULL, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theCenterOffset, ossimImageSourceFilter::theInputConnection, theIsHz, theKernel, theNullPixValue, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIpt::x, and ossimIpt::y.
Referenced by ossimImageGaussianFilter::getTile().
Definition at line 340 of file ossimConvolutionFilter1D.cpp.
References clearNullMinMax(), and theTile.
Referenced by ossimImageGaussianFilter::initializeProcesses().
inlinevirtual |
Definition at line 43 of file ossimConvolutionFilter1D.h.
inlinevirtual |
Definition at line 49 of file ossimConvolutionFilter1D.h.
Definition at line 499 of file ossimConvolutionFilter1D.cpp.
References ossimString::c_str(), clearNullMinMax(), ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, setCenterOffset(), setIsHorizontal(), setStrictNoData(), theKernel, ossimString::toDouble(), ossimString::toString(), and ossimString::toUInt32().
Definition at line 466 of file ossimConvolutionFilter1D.cpp.
References ossimKeywordlist::add(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, ossimImageSourceFilter::saveState(), theCenterOffset, theIsHz, theKernel, theStrictNoData, and ossimString::toString().
inlinevirtual |
Definition at line 47 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), and ossimImageGaussianFilter::updateKernels().
inlinevirtual |
Definition at line 44 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), and ossimImageGaussianFilter::ossimImageGaussianFilter().
Definition at line 563 of file ossimConvolutionFilter1D.cpp.
References clearNullMinMax(), and theKernel.
Referenced by ossimImageGaussianFilter::updateKernels().
Definition at line 366 of file ossimConvolutionFilter1D.cpp.
References ossimNumericProperty::asInt32(), ossimNumericProperty::asUInt32(), clearNullMinMax(), ossimRefPtr< T >::get(), ossimBooleanProperty::getBoolean(), ossimProperty::getName(), ossimMatrixProperty::getNumberOfCols(), PROPNAME_CENTEROFFSET, PROPNAME_ISHZ, PROPNAME_KERNEL, PROPNAME_KERNELSIZE, PROPNAME_STRICTNODATA, PTR_CAST, ossimImageSourceFilter::setProperty(), theCenterOffset, theIsHz, theKernel, and theStrictNoData.
inlinevirtual |
Definition at line 50 of file ossimConvolutionFilter1D.h.
Referenced by loadState(), ossimImageGaussianFilter::ossimImageGaussianFilter(), and ossimImageGaussianFilter::setStrictNoData().
protected |
Definition at line 111 of file ossimConvolutionFilter1D.h.
Referenced by convolvePartial(), getProperty(), getTile(), saveState(), and setProperty().
protected |
Definition at line 114 of file ossimConvolutionFilter1D.h.
Referenced by convolveFull(), convolvePartial(), getProperty(), getTile(), saveState(), and setProperty().
protected |
Definition at line 113 of file ossimConvolutionFilter1D.h.
Referenced by computeNullMinMax(), convolveFull(), convolvePartial(), getProperty(), getTile(), loadState(), ossimConvolutionFilter1D(), saveState(), setKernel(), and setProperty().
protected |
Definition at line 119 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMaxPixelValue().
protected |
Definition at line 118 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), and getMinPixelValue().
protected |
Definition at line 117 of file ossimConvolutionFilter1D.h.
Referenced by clearNullMinMax(), computeNullMinMax(), getNullPixelValue(), and getTile().
protected |
Definition at line 115 of file ossimConvolutionFilter1D.h.
Referenced by convolvePartial(), getProperty(), saveState(), and setProperty().
protected |
Definition at line 112 of file ossimConvolutionFilter1D.h.
Referenced by allocate(), getTile(), and initialize().
