#include <ossimTopographicCorrectionFilter.h>
Public Types | |
| enum | ossimTopoCorrectionType { TOPO_CORRECTION_COSINE = 0, TOPO_CORRECTION_COSINE_C = 1, TOPO_CORRECTION_MINNAERT = 2 } |
| ossimTopographicCorrectionFilter () | |
| ossimTopographicCorrectionFilter (ossimImageSource *colorSource, ossimImageSource *elevSource) | |
| ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual double | getAzimuthAngle () const |
| virtual double | getElevationAngle () const |
| virtual void | setAzimuthAngle (double angle) |
| virtual void | setElevationAngle (double angle) |
| virtual ossimTopoCorrectionType | getTopoCorrectionType () const |
| virtual void | setTopoCorrectionType (ossimTopoCorrectionType topoType) |
| const std::vector< double > & | getGainValues () const |
| void | setGainValues (const std::vector< double > &gainValues) |
| const vector< double > & | getBiasValues () const |
| void | setBiasValues (const std::vector< double > &biasValues) |
| const vector< double > & | getKValues () const |
| double | getK (int idx) const |
| void | setK (int idx, double value) |
| void | setKValues (const vector< double > &kValues) |
| double | getC (int idx) const |
| void | setC (int idx, double value) |
| void | setCValues (const vector< double > &cValues) |
| void | computeLightDirection () |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimTopographicCorrectionFilter () |
| virtual void | allocate () |
| virtual void | executeTopographicCorrection (ossimRefPtr< ossimImageData > &outputData, ossimRefPtr< ossimImageData > &colorData, ossimRefPtr< ossimImageData > &normalData) |
| template<class T > | |
| void | executeTopographicCorrectionTemplate (T dummy, ossimRefPtr< ossimImageData > &outputData, ossimRefPtr< ossimImageData > &colorData, ossimRefPtr< ossimImageData > &normalData) |
| void | executeTopographicCorrectionMinnaertTemplate (T dummy, ossimRefPtr< ossimImageData > &outputData, ossimRefPtr< ossimImageData > &colorData, ossimRefPtr< ossimImageData > &normalData) |
| bool | computeNdvi (T dummy, ossim_float64 &result, ossim_uint32 offset, const std::vector< T *> &bands) const |
| void | resizeArrays (ossim_uint32 newSize) |
| bool | setCCmputedFlag () |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
class ossimTopographicCorrectionFilter
This clas is used to execute terrain correction. I t requires 2 inputs where the first input is a multi band data source to correct and the second is elevation normals used in light incident calculations.
A sample chain might look like:
landsatHandler —> Cache —> renderer —> cache ------------------------------------— |–> Topo correction filter —> Output ortho mosaic of elevation data-—> imageToPlaneNormals –> Cache —> Renderer –>Cache –
the ossimImageToPlaneNormalsFilter is used to take a single band elevation source and compute normals at each post. I suggest that you set the renderer to use a higher order convolution than just nearest neighbor, maybe Cubic. This way you have smoother interpolation as you change zoom levels.
Correction Types:
Cosine correction: In order for this to run it does not need any additional informat but the multi band source and an normal calculation input.
Cosine-C correction: In order for this to run it will need theC array populated for each band. It defaults to 0 forcing a default Cosine correction to take place.
Minnaert correction: In order for this to run it will need theK array populated for each band. The defaults should work pretty good
Definition at line 55 of file ossimTopographicCorrectionFilter.h.
| Enumerator | |
| TOPO_CORRECTION_COSINE | |
| TOPO_CORRECTION_COSINE_C | |
| TOPO_CORRECTION_MINNAERT | |
Definition at line 58 of file ossimTopographicCorrectionFilter.h.
| ossimTopographicCorrectionFilter::ossimTopographicCorrectionFilter | ( | ) |
Definition at line 29 of file ossimTopographicCorrectionFilter.cpp.
| ossimTopographicCorrectionFilter::ossimTopographicCorrectionFilter | ( | ossimImageSource * | colorSource, |
| ossimImageSource * | elevSource | ||
Definition at line 47 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::connectMyInputTo().
protectedvirtual |
Definition at line 63 of file ossimTopographicCorrectionFilter.cpp.
protectedvirtual |
Definition at line 158 of file ossimTopographicCorrectionFilter.cpp.
References computeLightDirection(), ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimImageData::getNumberOfBands(), ossimImageSource::getOutputBandList(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), PTR_CAST, resizeArrays(), theBandMapping, theBias, theGain, and theTile.
Referenced by getTile().
required to be overriden by derived classes
Reimplemented from ossimImageCombiner.
Definition at line 1193 of file ossimTopographicCorrectionFilter.cpp.
References PTR_CAST.
| void ossimTopographicCorrectionFilter::computeLightDirection | ( | ) |
Definition at line 203 of file ossimTopographicCorrectionFilter.cpp.
References ossimMatrix3x3::createRotationMatrix(), theLightDirection, theLightSourceAzimuthAngle, theLightSourceElevationAngle, and ossimColumnVector3d::unit().
Referenced by allocate(), and ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 831 of file ossimTopographicCorrectionFilter.cpp.
Definition at line 1202 of file ossimTopographicCorrectionFilter.cpp.
References initialize().
Definition at line 1207 of file ossimTopographicCorrectionFilter.cpp.
protectedvirtual |
Definition at line 222 of file ossimTopographicCorrectionFilter.cpp.
References executeTopographicCorrectionMinnaertTemplate(), executeTopographicCorrectionTemplate(), ossimRectilinearDataObject::getScalarType(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, theTopoCorrectionType, and TOPO_CORRECTION_MINNAERT.
protected |
Definition at line 447 of file ossimTopographicCorrectionFilter.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossim::min(), OSSIM_EMPTY, theBandMapping, theBias, theGain, theK, theLightDirection, x, and y.
Referenced by executeTopographicCorrection().
protected |
Definition at line 336 of file ossimTopographicCorrectionFilter.cpp.
References ossim::cosd(), FLT_EPSILON, ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, theBandMapping, theBias, theC, theGain, theLightDirection, theLightSourceElevationAngle, theTopoCorrectionType, TOPO_CORRECTION_COSINE_C, x, and y.
Definition at line 1174 of file ossimTopographicCorrectionFilter.cpp.
References theLightSourceAzimuthAngle.
| const vector< double > & ossimTopographicCorrectionFilter::getBiasValues | ( | ) | const |
Definition at line 1242 of file ossimTopographicCorrectionFilter.cpp.
References theBias.
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Definition at line 1128 of file ossimTopographicCorrectionFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimConnectableObject::getInput(), ossimIrect::makeNan(), and PTR_CAST.
| double ossimTopographicCorrectionFilter::getC | ( | int | idx | ) | const |
Definition at line 1282 of file ossimTopographicCorrectionFilter.cpp.
References theC.
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 1142 of file ossimTopographicCorrectionFilter.cpp.
References ossimImageSource::getDecimationFactor(), ossimConnectableObject::getInput(), ossimDpt::makeNan(), and PTR_CAST.
Definition at line 1155 of file ossimTopographicCorrectionFilter.cpp.
References ossimImageSource::getDecimationFactors(), ossimConnectableObject::getInput(), and PTR_CAST.
Definition at line 1179 of file ossimTopographicCorrectionFilter.cpp.
References theLightSourceElevationAngle.
| const std::vector< double > & ossimTopographicCorrectionFilter::getGainValues | ( | ) | const |
Definition at line 1232 of file ossimTopographicCorrectionFilter.cpp.
References theGain.
| double ossimTopographicCorrectionFilter::getK | ( | int | idx | ) | const |
Definition at line 1257 of file ossimTopographicCorrectionFilter.cpp.
References theK.
| const vector< double > & ossimTopographicCorrectionFilter::getKValues | ( | ) | const |
Definition at line 1252 of file ossimTopographicCorrectionFilter.cpp.
References theK.
Definition at line 1118 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageCombiner::getMaxPixelValue(), ossimImageSource::getMaxPixelValue(), and PTR_CAST.
Definition at line 1108 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageCombiner::getMinPixelValue(), ossimImageSource::getMinPixelValue(), and PTR_CAST.
Definition at line 1098 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageCombiner::getNullPixelValue(), ossimImageSource::getNullPixelValue(), and PTR_CAST.
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 1164 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNumberOfDecimationLevels(), and PTR_CAST.
Definition at line 1078 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNumberOfOutputBands(), and PTR_CAST.
Definition at line 1088 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossimImageCombiner::getOutputScalarType(), ossimImageSource::getOutputScalarType(), and PTR_CAST.
Definition at line 67 of file ossimTopographicCorrectionFilter.cpp.
References allocate(), executeTopographicCorrection(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimConnectableObject::getInput(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_EMPTY, PTR_CAST, ossimImageData::setHeight(), ossimImageData::setOrigin(), ossimImageData::setWidth(), theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), and ossimIrect::width().
Definition at line 1222 of file ossimTopographicCorrectionFilter.cpp.
References theTopoCorrectionType.
Reimplemented in ossimLandsatTopoCorrectionFilter.
Definition at line 150 of file ossimTopographicCorrectionFilter.cpp.
References ossimImageCombiner::initialize(), and theTile.
Referenced by connectInputEvent(), disconnectInputEvent(), ossimLandsatTopoCorrectionFilter::initialize(), propertyEvent(), and refreshEvent().
Definition at line 898 of file ossimTopographicCorrectionFilter.cpp.
References ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordlist::find(), and ossimKeywordNames::NUMBER_BANDS_KW.
Referenced by ossimLandsatTopoCorrectionFilter::loadState().
Definition at line 1212 of file ossimTopographicCorrectionFilter.cpp.
Definition at line 1217 of file ossimTopographicCorrectionFilter.cpp.
protected |
Definition at line 847 of file ossimTopographicCorrectionFilter.cpp.
References ossimConnectableObject::getInput(), ossim::min(), theBias, theC, theGain, and theK.
Referenced by allocate().
Definition at line 996 of file ossimTopographicCorrectionFilter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::AZIMUTH_ANGLE_KW, ossimKeywordNames::ELEVATION_ANGLE_KW, ossimKeywordNames::NUMBER_BANDS_KW, theC, theLightSourceAzimuthAngle, and theLightSourceElevationAngle.
Referenced by ossimLandsatTopoCorrectionFilter::saveState().
Definition at line 1184 of file ossimTopographicCorrectionFilter.cpp.
| void ossimTopographicCorrectionFilter::setBiasValues | ( | const std::vector< double > & | biasValues | ) |
Definition at line 1247 of file ossimTopographicCorrectionFilter.cpp.
References theBias.
| void ossimTopographicCorrectionFilter::setC | ( | int | idx, |
| double | value | ||
Definition at line 1294 of file ossimTopographicCorrectionFilter.cpp.
References theC.
protected |
| void ossimTopographicCorrectionFilter::setCValues | ( | const vector< double > & | cValues | ) |
Definition at line 1302 of file ossimTopographicCorrectionFilter.cpp.
References theC.
Definition at line 1189 of file ossimTopographicCorrectionFilter.cpp.
| void ossimTopographicCorrectionFilter::setGainValues | ( | const std::vector< double > & | gainValues | ) |
Definition at line 1237 of file ossimTopographicCorrectionFilter.cpp.
References theGain.
| void ossimTopographicCorrectionFilter::setK | ( | int | idx, |
| double | value | ||
Definition at line 1269 of file ossimTopographicCorrectionFilter.cpp.
References theK.
| void ossimTopographicCorrectionFilter::setKValues | ( | const vector< double > & | kValues | ) |
Definition at line 1277 of file ossimTopographicCorrectionFilter.cpp.
References theK.
Definition at line 1227 of file ossimTopographicCorrectionFilter.cpp.
protected |
Definition at line 156 of file ossimTopographicCorrectionFilter.h.
Referenced by allocate(), executeTopographicCorrectionMinnaertTemplate(), and executeTopographicCorrectionTemplate().
protected |
Definition at line 162 of file ossimTopographicCorrectionFilter.h.
Referenced by allocate(), executeTopographicCorrectionMinnaertTemplate(), executeTopographicCorrectionTemplate(), getBiasValues(), resizeArrays(), setBiasValues(), and ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 160 of file ossimTopographicCorrectionFilter.h.
Referenced by executeTopographicCorrectionTemplate(), getC(), resizeArrays(), saveState(), setC(), and setCValues().
mutableprotected |
Definition at line 182 of file ossimTopographicCorrectionFilter.h.
protected |
Definition at line 163 of file ossimTopographicCorrectionFilter.h.
Referenced by allocate(), executeTopographicCorrectionMinnaertTemplate(), executeTopographicCorrectionTemplate(), getGainValues(), resizeArrays(), setGainValues(), and ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 181 of file ossimTopographicCorrectionFilter.h.
Referenced by ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 161 of file ossimTopographicCorrectionFilter.h.
Referenced by executeTopographicCorrectionMinnaertTemplate(), getK(), getKValues(), resizeArrays(), setK(), and setKValues().
protected |
This is computed from the elevation and azimuth angles of the light source.
Definition at line 179 of file ossimTopographicCorrectionFilter.h.
Referenced by computeLightDirection(), executeTopographicCorrectionMinnaertTemplate(), and executeTopographicCorrectionTemplate().
protected |
Used for the light vector computation.
Definition at line 173 of file ossimTopographicCorrectionFilter.h.
Referenced by computeLightDirection(), getAzimuthAngle(), saveState(), setAzimuthAngle(), and ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 168 of file ossimTopographicCorrectionFilter.h.
Referenced by computeLightDirection(), executeTopographicCorrectionTemplate(), getElevationAngle(), saveState(), setElevationAngle(), and ossimLandsatTopoCorrectionFilter::setLandsatHeader().
protected |
Definition at line 185 of file ossimTopographicCorrectionFilter.h.
protected |
Definition at line 184 of file ossimTopographicCorrectionFilter.h.
protected |
The result of the illumination equation is stored in here. This is populated on each call to getTile.
Definition at line 154 of file ossimTopographicCorrectionFilter.h.
Referenced by allocate(), getTile(), and initialize().
protected |
Definition at line 183 of file ossimTopographicCorrectionFilter.h.
Referenced by executeTopographicCorrection(), executeTopographicCorrectionTemplate(), getTopoCorrectionType(), and setTopoCorrectionType().
