An image mosaic is a simple combiner that will just do a simple mosaic. More...
#include <ossimImageMosaic.h>
| ossimImageMosaic () | |
| ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimImageMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
It just checks NULL pix values until it finds a pixel that is not empty and copies it out to the output. The list will have same size tiles and have the same number of bands.
Definition at line 26 of file ossimImageMosaic.h.
| ossimImageMosaic::ossimImageMosaic | ( | ) |
Definition at line 21 of file ossimImageMosaic.cpp.
| ossimImageMosaic::ossimImageMosaic | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 28 of file ossimImageMosaic.cpp.
protectedvirtual |
Definition at line 35 of file ossimImageMosaic.cpp.
protected |
Definition at line 241 of file ossimImageMosaic.cpp.
References ossimImageDataFactory::create(), ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and theTile.
Referenced by getTile(), ossimClosestToCenterCombiner::getTile(), ossimBlendMosaic::initialize(), and ossimFeatherMosaic::initialize().
protected |
Definition at line 409 of file ossimImageMosaic.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageCombiner::getNextNormTile(), ossimImageCombiner::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, ossimImageCombiner::theLargestNumberOfInputBands, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by getTile().
protected |
Definition at line 264 of file ossimImageMosaic.cpp.
References ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageCombiner::getNextNormTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), OSSIM_EMPTY, OSSIM_FULL, OSSIM_NULL, ossimImageCombiner::theLargestNumberOfInputBands, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Reimplemented in ossimClosestToCenterCombiner, ossimFeatherMosaic, and ossimBlendMosaic.
Definition at line 39 of file ossimImageMosaic.cpp.
References allocate(), combine(), combineNorm(), ossimImageData::getHeight(), ossimImageCombiner::getNextTile(), ossimConnectableObject::getNumberOfInputs(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getWidth(), ossimImageCombiner::hasDifferentInputs(), ossimIrect::height(), ossimImageData::initialize(), ossimImageData::makeBlank(), OSSIM_DOUBLE, OSSIM_FLOAT, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT32, OSSIM_SINT8, OSSIM_SSHORT16, OSSIM_UCHAR, OSSIM_UINT32, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, OSSIM_USHORT16, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setHeight(), ossimImageData::setOrigin(), ossimImageData::setWidth(), size, theTile, ossimIrect::ul(), ossimRefPtr< T >::valid(), and ossimIrect::width().
Referenced by ossimBlendMosaic::getTile(), ossimFeatherMosaic::getTile(), ossimClosestToCenterCombiner::getTile(), and ossimTiledElevationDatabase::mapRegion().
Reimplemented from ossimImageCombiner.
Reimplemented in ossimFeatherMosaic, ossimOrthoImageMosaic, and ossimBlendMosaic.
Definition at line 235 of file ossimImageMosaic.cpp.
References ossimImageCombiner::initialize(), and theTile.
Referenced by ossimBlendMosaic::initialize(), and ossimFeatherMosaic::initialize().
Reimplemented in ossimBlendMosaic.
Definition at line 258 of file ossimImageMosaic.cpp.
References ossimImageCombiner::loadState().
Referenced by ossimBlendMosaic::loadState().
Definition at line 252 of file ossimImageMosaic.cpp.
References ossimImageCombiner::saveState().
Referenced by ossimBlendMosaic::saveState().
protected |
Definition at line 59 of file ossimImageMosaic.h.
Referenced by allocate(), combine(), ossimBlendMosaic::combine(), ossimFeatherMosaic::combine(), combineNorm(), ossimBlendMosaic::combineNorm(), ossimClosestToCenterCombiner::findIdx(), ossimBlendMosaic::getTile(), ossimFeatherMosaic::getTile(), getTile(), ossimClosestToCenterCombiner::getTile(), ossimFeatherMosaic::initialize(), and initialize().
