This is the image handler for providing mask pixels to an ossimMaskFilter object. More...
#include <ossimBitMaskTileSource.h>
| ossimBitMaskTileSource () | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &tile_rect, ossim_uint32 rLevel=0) |
| Return a tile of masks. More... | |
| virtual bool | isValidRLevel (ossim_uint32 res_level) const |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 res_level=0) const |
| Pure virtual, derived classes must implement. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 res_level=0) const |
| virtual bool | open () |
| Pure virtual open. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual double | getNullPixelValue (ossim_uint32) const |
| virtual double | getMinPixelValue (ossim_uint32) const |
| virtual double | getMaxPixelValue (ossim_uint32) const |
| There is no geometry associated with a mask file – it is pixel-for-pixel mapped to an image file. More... | |
| Overrides base class implementation. More... | |
| void | setAssociatedImageHandler (ossimImageHandler *handler) |
| For backward compatibility with older mask format ("Ming Mask"), provide for associating the mask with an image handler: More... | |
| void | setAssociatedMaskWriter (ossimBitMaskWriter *maskWriter) |
| This class can be used during overview generation, in which case there will be a simultaneous mask writing. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimBitMaskTileSource () |
| bool | isSupportedExtension () |
| Returns true if this handler recognizes the file name extension as an OSSIM raster mask file. More... | |
This class takes care of reading the custom, bit-compressed OSSIM bit mask file format.
When the developer needs to mask an image, the following needs to be done:
Creating the Mask:
Using the Mask:
The OSSIM bit mask file contains a small header that consists of: magic number, starting res level, number of res levels num columns at starting res level, num rows at starting res level, num columns at 2nd res level, num rows at 2nd res level, etc., for all res levels <space> <compressed binary="" mask="" data>="">
The number of rows and columns represents the number of bytes in the mask, with each byte containing 8 alpha mask bits representing 8 pixels in the original image.
This class functions as an image handler, returning 255 for unmasked pixels, and 0 for masked pixels.
For debug purposes, this code initializes the tile to all 128's so that the ossimMaskFilter can recognize uninitialized mask data.
Definition at line 64 of file ossimBitMaskTileSource.h.
| ossimBitMaskTileSource::ossimBitMaskTileSource | ( | ) |
Definition at line 35 of file ossimBitMaskTileSource.cpp.
protectedvirtual |
Definition at line 45 of file ossimBitMaskTileSource.cpp.
References close().
Definition at line 53 of file ossimBitMaskTileSource.cpp.
References ossimImageHandler::close(), m_buffers, m_bufferSizes, and m_tile.
Referenced by open(), and ~ossimBitMaskTileSource().
protectedvirtual |
Definition at line 353 of file ossimBitMaskTileSource.cpp.
References m_buffers, and ossimImageHandler::theDecimationFactors.
Referenced by open().
The image file must have the valid geometry.
Definition at line 337 of file ossimBitMaskTileSource.cpp.
inlinevirtual |
Implements ossimImageHandler.
Definition at line 82 of file ossimBitMaskTileSource.h.
inlinevirtual |
Definition at line 81 of file ossimBitMaskTileSource.h.
inlinevirtual |
Definition at line 90 of file ossimBitMaskTileSource.h.
inlinevirtual |
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 89 of file ossimBitMaskTileSource.h.
inlinevirtual |
Definition at line 88 of file ossimBitMaskTileSource.h.
Definition at line 345 of file ossimBitMaskTileSource.cpp.
References ossimImageHandler::theDecimationFactors.
inlinevirtual |
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 78 of file ossimBitMaskTileSource.h.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 309 of file ossimBitMaskTileSource.cpp.
References isValidRLevel(), m_bufferSizes, ossimBitMaskWriter::m_bufferSizes, m_maskWriter, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 79 of file ossimBitMaskTileSource.h.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 323 of file ossimBitMaskTileSource.cpp.
References isValidRLevel(), m_bufferSizes, ossimBitMaskWriter::m_bufferSizes, m_maskWriter, n, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 80 of file ossimBitMaskTileSource.h.
References OSSIM_UINT8.
These are "bit masks", i.e., either 0 (hide) or 1 (show). The pixels' remaining 7 bits are cleared and should not be used.
Definition at line 198 of file ossimBitMaskTileSource.cpp.
References ossimIrect::completely_within(), ossimImageDataFactory::create(), for(), ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageHandler::getImageRectangle(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimImageDataFactory::instance(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), ossimIrect::lr(), m_buffers, ossimBitMaskWriter::m_buffers, m_maskWriter, m_tile, ossimImageData::makeBlank(), ossimImageData::setImageRectangle(), ossimImageData::setWidthHeight(), ossimIrect::size(), ossimImageHandler::theStartingResLevel, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimImageData::validate(), ossimIrect::width(), x, and y.
Definition at line 178 of file ossimBitMaskTileSource.cpp.
References m_buffers, m_maskWriter, and ossimRefPtr< T >::valid().
Referenced by getTile().
protected |
Definition at line 186 of file ossimBitMaskTileSource.cpp.
References ossimFilename::ext(), and ossimImageHandler::theImageFile.
Determines if the passed in reslution level is valid.
If this reader is used as an overview the caller should pass in a resLevel relative to the full image.
| resLevel | zero base resolution level. |
Definition at line 294 of file ossimBitMaskTileSource.cpp.
References m_buffers, ossimBitMaskWriter::m_buffers, m_maskWriter, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
Referenced by getNumberOfLines(), getNumberOfSamples(), and getTile().
Pure virtual open.
Derived classes must implement.
Definition at line 72 of file ossimBitMaskTileSource.cpp.
References ossimString::chars(), close(), ossimImageDataFactory::create(), establishDecimationFactors(), ossimImageHandler::getBoundingRect(), ossimImageHandler::getNumberOfDecimationLevels(), ossimImageData::initialize(), ossimImageDataFactory::instance(), isSupportedExtension(), m_buffers, m_bufferSizes, m_handler, m_tile, ossimBitMaskWriter::MASK_FILE_MAGIC_NUMBER, ossimNotify(), ossimNotifyLevel_FATAL, ossimIrect::size(), size, ossimImageHandler::theImageFile, ossimImageHandler::theStartingResLevel, ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
| void ossimBitMaskTileSource::setAssociatedImageHandler | ( | ossimImageHandler * | handler | ) |
Definition at line 381 of file ossimBitMaskTileSource.cpp.
References m_handler.
| void ossimBitMaskTileSource::setAssociatedMaskWriter | ( | ossimBitMaskWriter * | maskWriter | ) |
Instead of accessing a mask file (which may not yet exist), the mask buffer of the writer will be accessed directly instead of our own buffer.
Definition at line 370 of file ossimBitMaskTileSource.cpp.
References m_maskWriter, ossimBitMaskWriter::m_startingResLevel, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
protected |
Definition at line 117 of file ossimBitMaskTileSource.h.
Referenced by close(), establishDecimationFactors(), getTile(), isOpen(), isValidRLevel(), and open().
protected |
Definition at line 118 of file ossimBitMaskTileSource.h.
Referenced by close(), getNumberOfLines(), getNumberOfSamples(), and open().
protected |
Definition at line 122 of file ossimBitMaskTileSource.h.
Referenced by open(), and setAssociatedImageHandler().
protected |
Definition at line 127 of file ossimBitMaskTileSource.h.
Referenced by getNumberOfLines(), getNumberOfSamples(), getTile(), isOpen(), isValidRLevel(), and setAssociatedMaskWriter().
protected |
Definition at line 116 of file ossimBitMaskTileSource.h.
