Finds auto-tie-points using the corss-correlation-based matching algorithm. More...
#include <ossimCorrelationSource.h>
| ossimCorrelationSource () | |
| ossimCorrelationSource (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| ossimCorrelationSource (AtpGenerator *generator) | |
| virtual | ~ossimCorrelationSource () |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 rLevel=0) |
| Derived classes implement their particular tiepoint matching algorithms for the requested tile. More... | |
| unsigned int | getNominalCmpPatchSize () const |
| For engineering use in annotating CMP image. More... | |
Public Member Functions inherited from ATP::AtpTileSource | |
| AtpTileSource (AtpGenerator *generator) | |
| virtual | ~AtpTileSource () |
| AtpList & | getTiePoints () |
| This list resets with every getTile() call , so make sure tiepoints from previous getTile() calls are being accumulated. More... | |
| void | filterPoints () |
| void | setTiePoints (ossim::TiePointList &atpList) |
| Used for testing. More... | |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| void | findFeatures (const ossimImageData *data, std::vector< ossimIpt > &featurePts) |
| Given an image tile, locates prominent features in that tile. Use. More... | |
| bool | correlate (std::shared_ptr< AutoTiePoint > atp) |
| bool | OpenCVCorrelation (std::shared_ptr< AutoTiePoint > atp, const ossimImageData *refpatch, const ossimImageData *cmppatch) |
Protected Member Functions inherited from ATP::AtpTileSource | |
| AtpTileSource () | |
| AtpTileSource (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | allocate () |
| void | filterWithParallax () |
| void | computeParallax () |
| void | computeParallaxStatistics () |
| void | filterWithoutParallax () |
| void | pruneList () |
| Caps the max number of TPs given the list, which is the list of filtered TPs for the tile. More... | |
| void | initializeStaticMembers () |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Static Protected Attributes inherited from ATP::AtpTileSource | |
| static double | s_minVectorResDiff = 0 |
| static double | s_maxDiffRatio = 1.0 |
| static double | s_cosMaxAngleDiff = 0 |
| static double | s_maxPaxDev = 1.0 |
| static double | s_maxPaxPix = 2.0 |
| static unsigned int | s_minNumConsistent = 3 |
| static unsigned int | s_percentConsistent = 50 |
| static unsigned int | s_numTpsPerTile = 2 |
| static bool | s_useRasterMode = false |
| static bool | s_initialized = false |
| static unsigned int | s_numFilterIterations = 0 |
Definition at line 21 of file ossimCorrelationSource.h.
| ATP::ossimCorrelationSource::ossimCorrelationSource | ( | ) |
Definition at line 19 of file ossimCorrelationSource.cpp.
| ATP::ossimCorrelationSource::ossimCorrelationSource | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 25 of file ossimCorrelationSource.cpp.
References initialize().
| ATP::ossimCorrelationSource::ossimCorrelationSource | ( | AtpGenerator * | generator | ) |
Definition at line 32 of file ossimCorrelationSource.cpp.
Definition at line 39 of file ossimCorrelationSource.cpp.
protected |
Definition at line 275 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asUint(), CINFO, CWARN, ossim::JsonConfig::diagnosticLevel(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ATP::AtpTileSource::m_generator, m_nominalCmpPatchSize, max, min, OpenCVCorrelation(), and OSSIM_FULL.
Referenced by getTile().
protected |
Definition at line 169 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asBool(), ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), CFATAL, CINFO, ATP::convertToIpl(), CWARN, ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossim::JsonConfig::getParameter(), ossimImageData::getPix(), ATP::AtpConfig::instance(), OSSIM_EMPTY, OSSIM_PARTIAL, ossimIrect::ul(), x, and y.
inline |
Definition at line 35 of file ossimCorrelationSource.h.
It is not clear what the output tile needs to be, since the product of this filter is the list of tiepoints (available through the getTiePoints() method). Recommend simply passing through the corresponding REF image tile.
Implements ATP::AtpTileSource.
Definition at line 79 of file ossimCorrelationSource.cpp.
References ATP::AtpTileSource::allocate(), ossim::JsonParam::asBool(), ossim::JsonParam::asUint(), CINFO, correlate(), ossim::JsonConfig::diagnosticLevel(), ATP::AtpTileSource::filterPoints(), findFeatures(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimConnectableObject::getNumberOfInputs(), ossim::JsonConfig::getParameter(), ATP::AtpConfig::instance(), ossimIrect::lr(), ATP::AtpTileSource::m_generator, ATP::AtpTileSource::m_tiePoints, ATP::AtpTileSource::m_tile, OSSIM_EMPTY, ossim::JsonConfig::paramExists(), ossimImageData::setImageRectangle(), ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Reimplemented from ATP::AtpTileSource.
Definition at line 43 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asUint(), ossimSensorModel::getNominalPosError(), ossim::JsonConfig::getParameter(), ATP::AtpTileSource::initialize(), ATP::AtpConfig::instance(), ATP::AtpTileSource::m_generator, m_nominalCmpPatchSize, ossimDpt::x, and ossimDpt::y.
Referenced by ossimCorrelationSource().
protected |
Definition at line 407 of file ossimCorrelationSource.cpp.
References ossim::JsonParam::asFloat(), ossim::JsonParam::asUint(), ATP::convertToIpl32(), ATP::copyIpl32ToOid(), ossimImageDataFactory::create(), CWARN, ossim::JsonConfig::diagnosticLevel(), ossimRefPtr< T >::get(), ossimImageData::getImageRectangle(), ossim::JsonConfig::getParameter(), ossimImageData::getWidth(), ossimImageData::initialize(), ATP::AtpConfig::instance(), ossimImageDataFactory::instance(), OSSIM_UINT8, ossim::JsonConfig::paramExists(), ossimIrect::ul(), ossimImageData::write(), ossimIpt::x, and ossimIpt::y.
Referenced by correlate().
protected |
Definition at line 47 of file ossimCorrelationSource.h.
Referenced by correlate(), and initialize().
