#include <ossimImageChain.h>
| ossimImageChain () | |
| virtual | ~ossimImageChain () |
| ossimConnectableObject::ConnectableObjectList & | getChainList () |
| const ossimConnectableObject::ConnectableObjectList & | getChainList () const |
| ossimConnectableObject * | operator[] (ossim_uint32 index) |
| virtual ossimConnectableObject * | getConnectableObject (ossim_uint32 index) |
| Same as operator[](ossim_uint32 i) More... | |
| virtual ossim_int32 | indexOf (ossimConnectableObject *obj) const |
| virtual ossimImageSource * | getFirstSource () |
| Return the first source which is the one that first receives the getTile request. More... | |
| virtual const ossimImageSource * | getFirstSource () const |
| virtual ossimObject * | getFirstObject () |
| virtual ossimImageSource * | getLastSource () |
| Return the last source which is the one that last receives the getTile request. More... | |
| virtual const ossimImageSource * | getLastSource () const |
| virtual ossimObject * | getLastObject () |
| bool | addFirst (ossimConnectableObject *obj) |
| Adds it to the start of the chain. More... | |
| bool | addLast (ossimConnectableObject *obj) |
| Adds it to the end. More... | |
| bool | deleteFirst () |
| Deletes the first object. More... | |
| bool | deleteLast () |
| Deletes the last object. More... | |
| bool | insertRight (ossimConnectableObject *newObj, ossimConnectableObject *rightOfThisObj) |
| bool | insertRight (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, const ossimId &id) |
| bool | insertLeft (ossimConnectableObject *newObj, ossimConnectableObject *leftOfThisObj) |
| bool | replace (ossimConnectableObject *newObj, ossimConnectableObject *oldObj) |
| virtual bool | add (ossimConnectableObject *source) |
| Will return true or false if an image source was added to the chain. More... | |
| Within the image chain will pass the head of the list. More... | |
| this call is passed to the head of the list. More... | |
| This call is passed to the head of the list. More... | |
| Will pass this call to the head of the list. More... | |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| Will save the state of the chain. More... | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| Will load the state. More... | |
| bool | canConnectMyInputTo (ossim_int32 myInputIndex, const ossimConnectableObject *object) const |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject::ConnectableObjectList findAllObjectsOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const RTTItypeid &typeInfo, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findFirstObjectOfType(const ossimString &className, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimId &id, bool recurse=true)) | |
| OSSIM_DEPRECATE_METHOD (virtual ossimConnectableObject *findObject(const ossimConnectableObject *obj, bool recurse=true)) | |
| virtual void | makeUniqueIds () |
| Will cycle through all sources setting their ids. More... | |
| virtual ossim_uint32 | getNumberOfObjects (bool recurse=true) const |
| Returns the number of objects within this container and all child containers. More... | |
| virtual ossim_uint32 | getNumberOfSources () const |
| Deprecated! Please use getNumberOfObjects(false). More... | |
| virtual bool | addChild (ossimConnectableObject *attachableObject) |
| Will add an object to the container and then set the added objects owner to this. More... | |
| virtual bool | removeChild (ossimConnectableObject *object) |
| Will remove the child from the container. More... | |
| virtual ossimConnectableObject * | removeChild (const ossimId &id) |
| virtual void | getChildren (vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag) |
| virtual void | disconnectOutputEvent (ossimConnectionEvent &event) |
| virtual void | connectOutputEvent (ossimConnectionEvent &event) |
| virtual void | objectDestructingEvent (ossimObjectDestructingEvent &event) |
| ProcessEvent. More... | |
| void | deleteList () |
| virtual ossimConnectableObject::ConnectableObjectList & | imageChainList () |
| These access methods greatly facilitate the implementation of an image chain adaptor class. More... | |
| virtual const ossimConnectableObject::ConnectableObjectList & | imageChainList () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual void | propertyEvent (ossimPropertyEvent &) |
| virtual void | refreshEvent (ossimRefreshEvent &) |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimConnectableContainerInterface | |
| ossimConnectableContainerInterface (ossimObject *obj) | |
| virtual | ~ossimConnectableContainerInterface () |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const RTTItypeid &typeInfo, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findFirstObjectOfType (const ossimString &className, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimId &id, bool recurse=true)=0 |
| virtual ossimConnectableObject * | findObject (const ossimConnectableObject *obj, bool recurse=true)=0 |
| ossimObject * | getObject () |
| const ossimObject * | getObject () const |
| void | deleteAllChildren () |
| virtual void | getChildren (std::vector< ossimConnectableObject *> &children, bool immediateChildrenOnlyFlag)=0 |
| void | prepareForRemoval (ossimConnectableObject *connectableObject) |
| Inserts all of this object's children and inputs into the container provided. More... | |
| bool | addAllSources (map< ossimId, vector< ossimId > > &idMapping, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| For dynamic loading to take place we must allocate all objects first and then assign id's later. More... | |
| void | findInputConnectionIds (vector< ossimId > &result, const ossimKeywordlist &kwl, const char *prefix=NULL) |
| bool | connectAllSources (const map< ossimId, vector< ossimId > > &idMapping) |
Definition at line 23 of file ossimImageChain.h.
| ossimImageChain::ossimImageChain | ( | ) |
Definition at line 60 of file ossimImageChain.cpp.
References ossimListenerManager::addListener(), and ossimConnectableContainerInterface::theBaseObject.
Definition at line 75 of file ossimImageChain.cpp.
References deleteList(), and ossimListenerManager::removeListener().
We will add a visitor interface for all connectable objects.
Reimplemented from ossimConnectableObject.
Definition at line 1779 of file ossimImageChain.cpp.
References ossimConnectableObject::accept(), ossimRefPtr< T >::get(), ossimVisitor::getVisitorType(), ossimVisitor::hasVisited(), imageChainList(), ossimVisitor::setVisitorType(), ossimVisitor::stopTraversal(), ossimVisitor::turnOffVisitorType(), ossimVisitor::visit(), ossimVisitor::VISIT_CHILDREN, ossimVisitor::VISIT_INPUTS, and ossimVisitor::VISIT_OUTPUTS.
Referenced by ATP::AtpAnnotatedImage::AtpAnnotatedImage(), connectAllSources(), ATP::AtpGenerator::getImageHandler(), insertLeft(), insertRight(), removeChild(), and ossimIgen::setView().
It will add and do a connection to the previous source automatically. This is a chain and the order of insertion matters. It adds it to the beginning of the list. The last one added is the first one to receive the getTile. Basically inserts to the right of the rightmost filter
Definition at line 602 of file ossimImageChain.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::changeOwner(), ossimConnectableObject::connectInputList(), ossimConnectableObject::disconnectAllOutputs(), ossimListenerManager::fireEvent(), ossimConnectableObject::getInputList(), ossimConnectableObject::getInputListIsFixedFlag(), ossimConnectableObject::getOutputListIsFixedFlag(), imageChainList(), OSSIM_EVENT_ADD_OBJECT_ID, size, ossimConnectableObject::theInputListIsFixedFlag, ossimConnectableObject::theInputObjectList, and ossimConnectableObject::theOutputListIsFixedFlag.
Referenced by addChild(), addLast(), ATP::AtpAnnotatedImage::AtpAnnotatedImage(), ATP::AtpGenerator::constructChain(), ossimChipProcTool::createInputChain(), ossimShorelineTool::doThreshold(), ossimShorelineTool::execute(), ossimIgenGenerator::generateGeoTiledSpecList(), ossimIgenGenerator::generateNoTiledSpecList(), ossimIgenGenerator::generatePixelTiledSpecList(), ossimChipProcTool::getChip(), ossimBandMergeTool::initHistogramStretch(), ossimSubImageTool::initialize(), ossimBandMergeTool::initProcessingChain(), ossimHillshadeTool::initProcessingChain(), ossimSlopeTool::initProcessingChain(), ossimShorelineTool::initProcessingChain(), ossimHdf5Tool::initProcessingChain(), ossimHlzTool::initProcessingChain(), ossimViewshedTool::initProcessingChain(), insertLeft(), insertRight(), ossimHdf5Tool::loadImageFiles(), and ossimMultiThreadSequencer::setToStartOfSequence().
protected |
We must remember the id's so we can do this. we will create a map that takes the id of the source as a key and a vector of input id's to connect it's inputs to.
Definition at line 1216 of file ossimImageChain.cpp.
References ossimString::c_str(), ossimKeywordlist::getSubstringKeyList(), ossimImageSource::loadState(), ossimString::toInt(), and ossimString::toString().
Referenced by loadState().
Implements ossimConnectableContainerInterface.
Definition at line 479 of file ossimImageChain.cpp.
References add().
| bool ossimImageChain::addFirst | ( | ossimConnectableObject * | obj | ) |
This is the first one to receive the getTile request. This basically inserts it to the right of the right most filter. Returns true on success, false on error.
Definition at line 81 of file ossimImageChain.cpp.
References getFirstObject(), and insertRight().
Referenced by ossimSingleImageChain::addBandSelector(), ossimSingleImageChain::addBrightnessContrast(), ossimSingleImageChain::addCache(), ossimSingleImageChain::addGeoPolyCutter(), ossimSingleImageChain::addHistogramRemapper(), ossimSingleImageChain::addNullPixelFlip(), ossimSingleImageChain::addResampler(), ossimSingleImageChain::addScalarRemapper(), ossimSingleImageChain::addSharpen(), ossimSingleImageChain::createRenderedChain(), and ossimIgen::outputProduct().
| bool ossimImageChain::addLast | ( | ossimConnectableObject * | obj | ) |
Adds it to the end.
this is the last one to receive the getTile request. This basically inserts it to the left of the left most filter. Returns true on success, false on error.
Definition at line 89 of file ossimImageChain.cpp.
References add(), ossimListenerManager::addListener(), ossimConnectableObject::changeOwner(), ossimConnectableObject::connectInputList(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectAllInputs(), ossimListenerManager::fireEvent(), ossimConnectableObject::getInputList(), ossimConnectableObject::getInputListIsFixedFlag(), ossimConnectableObject::getNumberOfInputs(), imageChainList(), OSSIM_EVENT_ADD_OBJECT_ID, ossimConnectableObject::setNumberOfInputs(), size, and ossimConnectableObject::theInputListIsFixedFlag.
Referenced by ossimSingleImageChain::addImageHandler(), insertLeft(), and ossimHdf5Tool::loadImageFiles().
inlinevirtual |
required to be overriden by derived classes
Implements ossimConnectableObject.
Definition at line 207 of file ossimImageChain.h.
References ossimConnectableObject::canConnectMyInputTo(), and PTR_CAST.
protected |
Definition at line 1363 of file ossimImageChain.cpp.
References accept(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectMyInput(), ossimConnectableContainerInterface::findObject(), ossimIdVisitor::getObject(), PTR_CAST, ossimIdVisitor::reset(), ossimIdVisitor::setId(), and ossimVisitor::VISIT_CHILDREN.
Reimplemented from ossimConnectableObjectListener.
Definition at line 1650 of file ossimImageChain.cpp.
References ossimConnectableObject::findInputIndex(), ossimEvent::getObject(), imageChainList(), initialize(), size, and theLoadStateFlag.
Definition at line 1678 of file ossimImageChain.cpp.
| bool ossimImageChain::deleteFirst | ( | ) |
Note this is really most right of the chain. Returns true if deletion occurred, false if the chain is empty.
Definition at line 1577 of file ossimImageChain.cpp.
References ossimListenerManager::fireEvent(), imageChainList(), OSSIM_EVENT_REMOVE_OBJECT_ID, prepareForRemoval(), and size.
| bool ossimImageChain::deleteLast | ( | ) |
Note this is really most left of the chain. Returns true if deletion occurred, false if the chain is empty.
Definition at line 1593 of file ossimImageChain.cpp.
Referenced by ossimSingleImageChain::reset().
| void ossimImageChain::deleteList | ( | ) |
Definition at line 1609 of file ossimImageChain.cpp.
References ossimListenerManager::fireEvent(), imageChainList(), OSSIM_EVENT_REMOVE_OBJECT_ID, and prepareForRemoval().
Referenced by loadState(), and ~ossimImageChain().
Definition at line 1548 of file ossimImageChain.cpp.
References ossimSource::disableSource(), imageChainList(), PTR_CAST, and ossimSource::theEnableFlag.
Definition at line 1629 of file ossimImageChain.cpp.
References ossimEvent::getObject(), ossimConnectionEvent::getOldObject(), imageChainList(), and size.
Definition at line 1646 of file ossimImageChain.cpp.
Definition at line 1529 of file ossimImageChain.cpp.
References ossimSource::enableSource(), imageChainList(), PTR_CAST, and ossimSource::theEnableFlag.
protected |
Definition at line 1329 of file ossimImageChain.cpp.
References ossimKeywordlist::find(), ossimKeywordlist::getSubstringKeyList(), ossimString::toInt(), ossimString::toLong(), and ossimString::toString().
Definition at line 1043 of file ossimImageChain.cpp.
References ossimConnectableObject::getInput(), imageChainList(), ossimSource::isSourceEnabled(), ossimDrect::makeNan(), PTR_CAST, and size.
Referenced by ossimChipProcTool::computeAdjustedViewFromGrect(), and ossimIgen::initializeChain().
inline |
Definition at line 31 of file ossimImageChain.h.
inline |
Definition at line 32 of file ossimImageChain.h.
Definition at line 563 of file ossimImageChain.cpp.
References imageChainList(), and PTR_CAST.
| index | Index of object to get. |
Definition at line 1753 of file ossimImageChain.cpp.
References imageChainList(), and size.
Referenced by operator[]().
Will return the decimation factor for the given resolution level.
the decimation is the scale from Resolution 0 or full res. Usually this is a power of 2 decimation where the decimation result is 1.0/2^resoltion.
Definition at line 1131 of file ossimImageChain.cpp.
References ossimConnectableObject::getInput(), imageChainList(), ossimSource::isSourceEnabled(), ossimDpt::makeNan(), PTR_CAST, and size.
Definition at line 1162 of file ossimImageChain.cpp.
References ossimConnectableObject::getInput(), imageChainList(), ossimSource::isSourceEnabled(), PTR_CAST, and size.
Definition at line 144 of file ossimImageChain.cpp.
Referenced by addFirst().
Definition at line 126 of file ossimImageChain.cpp.
Referenced by ossimShorelineTool::autoComputeThreshold(), processEvent(), and ossimImageChainMtAdaptor::setOriginalChain().
Definition at line 136 of file ossimImageChain.cpp.
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 1107 of file ossimImageChain.cpp.
Referenced by ossimSingleImageChain::addGeoPolyCutter(), ossimSubImageTool::execute(), ATP::AtpGenerator::initialize(), and ossimIgen::initializeChain().
Definition at line 172 of file ossimImageChain.cpp.
Definition at line 154 of file ossimImageChain.cpp.
Referenced by ATP::AtpGenerator::getValidVertices().
Definition at line 164 of file ossimImageChain.cpp.
Definition at line 921 of file ossimImageChain.cpp.
References ossim::defaultMax(), ossimConnectableObject::getInput(), ossimImageSource::getMaxPixelValue(), getOutputScalarType(), imageChainList(), ossimSource::isSourceEnabled(), PTR_CAST, and size.
Definition at line 894 of file ossimImageChain.cpp.
References ossim::defaultMin(), ossimConnectableObject::getInput(), getOutputScalarType(), imageChainList(), ossimSource::isSourceEnabled(), PTR_CAST, and size.
Definition at line 867 of file ossimImageChain.cpp.
References ossim::defaultNull(), ossimConnectableObject::getInput(), getOutputScalarType(), imageChainList(), ossimSource::isSourceEnabled(), PTR_CAST, and size.
Referenced by ossimViewshedTool::computeViewshed().
Will return the number of resolution levels.
Note: resolution level 0 is included in the return count.
Definition at line 1188 of file ossimImageChain.cpp.
Implements ossimImageSource.
Definition at line 840 of file ossimImageChain.cpp.
| recurse | If true and object is a contains containers; all objects will be conter. If false only the objects of this container will be counted (theImageChainList.size()). |
Definition at line 451 of file ossimImageChain.cpp.
References ossimConnectableContainerInterface::getNumberOfObjects(), imageChainList(), and PTR_CAST.
Referenced by getNumberOfSources().
Definition at line 470 of file ossimImageChain.cpp.
References getNumberOfObjects(), ossimNotify(), and ossimNotifyLevel_NOTICE.
Initializes bandList.
This implementation initializes to the zero based order of input bands. Derived classes that are band selectors should override.
| bandList | Initialized by this. |
Definition at line 948 of file ossimImageChain.cpp.
References ossimImageSource::getOutputBandList(), imageChainList(), ossimSource::isSourceEnabled(), size, and ossimRefPtr< T >::valid().
Definition at line 962 of file ossimImageChain.cpp.
References ossimConnectableObject::getInput(), imageChainList(), ossimSource::isSourceEnabled(), OSSIM_SCALAR_UNKNOWN, PTR_CAST, and size.
Referenced by ATP::AtpGenerator::constructChain(), ossimChipProcTool::createInputChain(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), and ossimHdf5Tool::loadImageFiles().
Reimplemented in ossimImageChainMtAdaptor.
Definition at line 796 of file ossimImageChain.cpp.
References ossimRefPtr< T >::get(), ossimConnectableObject::getInput(), ossimImageSource::getTile(), imageChainList(), ossimSource::isSourceEnabled(), PTR_CAST, and size.
Referenced by ossimHlzTool::getChip(), ossimShorelineTool::getChip(), ossimViewshedTool::getChip(), ossimChipProcTool::getChip(), and ossimImageChainMtAdaptor::getTile().
Definition at line 1016 of file ossimImageChain.cpp.
Definition at line 989 of file ossimImageChain.cpp.
Definition at line 1075 of file ossimImageChain.cpp.
inlinevirtual |
They shouldn't be accessed directly by any other classes. These methods really should be "protected" but the compiler complains if this base class' declarations are "protected".
Definition at line 373 of file ossimImageChain.h.
Referenced by accept(), add(), addLast(), connectInputEvent(), deleteFirst(), deleteLast(), deleteList(), disableSource(), disconnectInputEvent(), enableSource(), getBoundingRect(), getChildren(), getConnectableObject(), getDecimationFactor(), getDecimationFactors(), getFirstObject(), getFirstSource(), getImageGeometry(), getLastObject(), getLastSource(), getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), getNumberOfDecimationLevels(), getNumberOfInputBands(), getNumberOfObjects(), getOutputBandList(), getOutputScalarType(), getTile(), getTileHeight(), getTileWidth(), getValidImageVertices(), ossimImageChainMtAdaptor::imageChainList(), indexOf(), insertLeft(), insertRight(), makeUniqueIds(), objectDestructingEvent(), propagateEventToInputs(), propagateEventToOutputs(), removeChild(), replace(), and saveState().
inlinevirtual |
Definition at line 374 of file ossimImageChain.h.
Definition at line 1764 of file ossimImageChain.cpp.
References imageChainList().
Referenced by replace().
Definition at line 1497 of file ossimImageChain.cpp.
Referenced by ATP::AtpAnnotatedImage::AtpAnnotatedImage(), connectInputEvent(), ossimSingleImageChain::createRenderedChain(), ossimShorelineTool::execute(), ossimIgen::initializeChain(), and ossimHdf5Tool::loadImageFiles().
| bool ossimImageChain::insertLeft | ( | ossimConnectableObject * | newObj, |
| const ossimId & | id | ||
Definition at line 748 of file ossimImageChain.cpp.
References accept(), ossimConnectableContainerInterface::findObject(), ossimIdVisitor::getObject(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
Referenced by ossimSingleImageChain::addScalarRemapper().
| ossimConnectableObject * | leftOfThisObj | ||
Definition at line 711 of file ossimImageChain.cpp.
References add(), addLast(), ossimListenerManager::addListener(), ossimConnectableObject::changeOwner(), ossimConnectableObject::connectInputList(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::disconnectAllInputs(), ossimListenerManager::fireEvent(), ossimConnectableObject::getInputList(), imageChainList(), OSSIM_EVENT_ADD_OBJECT_ID, and size.
| bool ossimImageChain::insertRight | ( | ossimConnectableObject * | newObj, |
| ossimConnectableObject * | rightOfThisObj | ||
Definition at line 649 of file ossimImageChain.cpp.
References add(), ossimListenerManager::addListener(), ossimConnectableObject::changeOwner(), ossimConnectableObject::connectMyInputTo(), ossimConnectableObject::connectOutputList(), ossimConnectableObject::disconnectAllOutputs(), ossimListenerManager::fireEvent(), ossimConnectableObject::getOutputList(), imageChainList(), OSSIM_EVENT_ADD_OBJECT_ID, and size.
Referenced by addFirst(), and insertRight().
Definition at line 687 of file ossimImageChain.cpp.
References accept(), ossimConnectableContainerInterface::findObject(), ossimIdVisitor::getObject(), insertRight(), and ossimVisitor::VISIT_CHILDREN.
Definition at line 1468 of file ossimImageChain.cpp.
References addAllSources(), CLOG, connectAllSources(), deleteList(), ossimImageSource::loadState(), and theLoadStateFlag.
the idLast wlil be updated so we can recurse into other containers.
Definition at line 430 of file ossimImageChain.cpp.
References imageChainList(), ossimIdManager::instance(), ossimConnectableContainerInterface::makeUniqueIds(), PTR_CAST, and ossimConnectableObject::setId().
Definition at line 1706 of file ossimImageChain.cpp.
References ossimEvent::getObject(), imageChainList(), PTR_CAST, and removeChild().
| ossimConnectableObject * ossimImageChain::operator[] | ( | ossim_uint32 | index | ) |
Definition at line 1748 of file ossimImageChain.cpp.
References getConnectableObject().
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfTypeconst RTTItypeid &typeInfo, bool recurse=true | ) |
These methods are now deprecated. You can achieve the same thing by using the new visitor design pattern. If this does not achieve exactly what you want then you can derive new rules by overriding the virtual visit method in ossimVisitor
ossimTypeIdVisitor visitor(tyeId, false, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimCollectionVisitor::List& collection = visitor.getObjects();
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject::ConnectableObjectList | findAllObjectsOfTypeconst ossimString &className, bool recurse=true | ) |
ossimTypeNameVisitor visitor(typeName, false, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimCollectionVisitor::List& collection = visitor.getObjects();
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findFirstObjectOfTypeconst RTTItypeid &typeInfo, bool recurse=true | ) |
ossimTypeIdVisitor visitor(tyeId, true, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.getObject();
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findFirstObjectOfTypeconst ossimString &className, bool recurse=true | ) |
ossimTypeNameVisitor visitor(className, true, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.getObject();
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findObjectconst ossimId &id, bool recurse=true | ) |
ossimIdVisitor visitor(tyeId, true, ossimVisitor::VISIT_CHILDREN); connectableObject->accept(visitor); ossimRefPtr<ossimConnectableObject> obj = visitor.getObject();
| ossimImageChain::OSSIM_DEPRECATE_METHOD | ( | virtual ossimConnectableObject * | findObjectconst ossimConnectableObject *obj, bool recurse=true | ) |
protected |
Since this is itself a form of container, this method will consolidate this chain with the argument container. Consequently, this chain object will not be represented in the container, but its children will be, with correct input and output connections to external objects. Ownership of children will pass to the argument container.
Definition at line 1567 of file ossimImageChain.cpp.
References ossimConnectableObject::changeOwner(), ossimConnectableObject::disconnect(), and ossimListenerManager::removeListener().
Referenced by deleteFirst(), deleteLast(), and deleteList().
ProcessEvent.
The defaul is to do nothing. Derived classes need to override this class.
Definition at line 37 of file ossimImageChain.cpp.
References ossimEvent::getCurrentObject(), getFirstSource(), ossimConnectableObject::getOutputList(), ossimEvent::isPropagatingToOutputs(), ossimConnectableObjectListener::processEvent(), and PTR_CAST.
Definition at line 1732 of file ossimImageChain.cpp.
Definition at line 1716 of file ossimImageChain.cpp.
Changes the owner of the child to be NULL;
Definition at line 484 of file ossimImageChain.cpp.
References ossimListenerManager::addListener(), ossimListenerManager::fireEvent(), imageChainList(), OSSIM_EVENT_REMOVE_OBJECT_ID, size, ossimConnectableObject::theInputListIsFixedFlag, and ossimConnectableObject::theInputObjectList.
Referenced by ossimSingleImageChain::close(), objectDestructingEvent(), and removeChild().
Definition at line 550 of file ossimImageChain.cpp.
References accept(), ossimIdVisitor::getObject(), removeChild(), ossimVisitor::VISIT_CHILDREN, and ossimVisitor::VISIT_INPUTS.
| bool ossimImageChain::replace | ( | ossimConnectableObject * | newObj, |
| ossimConnectableObject * | oldObj | ||
Definition at line 771 of file ossimImageChain.cpp.
References ossimListenerManager::addListener(), ossimConnectableObject::changeOwner(), ossimConnectableObject::connectInputList(), ossimConnectableObject::connectOutputList(), ossimConnectableObject::getInputList(), ossimConnectableObject::getOutputList(), imageChainList(), indexOf(), and ossimListenerManager::removeListener().
Definition at line 1436 of file ossimImageChain.cpp.
References ossimString::c_str(), imageChainList(), ossimImageSource::saveState(), and ossimString::toString().
Referenced by ossimIgenGenerator::generateGeoTiledSpecList(), ossimIgenGenerator::generateNoTiledSpecList(), and ossimIgenGenerator::generatePixelTiledSpecList().
protected |
Definition at line 396 of file ossimImageChain.h.
protected |
This will hold a sequence of image sources.
theFirst one in the list will be the head of the list and the last one is the tail.
Definition at line 394 of file ossimImageChain.h.
Referenced by ossimImageChainMtAdaptor::imageChainList().
mutableprotected |
Definition at line 398 of file ossimImageChain.h.
Referenced by connectInputEvent(), and loadState().
