#include <ossimPointCloudUtilityFilter.h>
| ossimPointCloudUtilityFilter (ossimPointCloudTool *pc_util) | |
| virtual | ~ossimPointCloudUtilityFilter () |
| virtual bool | getTile (ossimImageData *result, ossim_uint32 resLevel) |
| ossimScalarType | getOutputScalarType () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Definition at line 25 of file ossimPointCloudUtilityFilter.h.
| ossimPointCloudUtilityFilter::ossimPointCloudUtilityFilter | ( | ossimPointCloudTool * | pc_util | ) |
Definition at line 22 of file ossimPointCloudUtilityFilter.cpp.
inlinevirtual |
Definition at line 29 of file ossimPointCloudUtilityFilter.h.
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 88 of file ossimPointCloudUtilityFilter.cpp.
References ossimPointCloudTool::m_prodGeom, m_util, and ossimRefPtr< T >::valid().
inlinevirtual |
Definition at line 35 of file ossimPointCloudUtilityFilter.h.
inlinevirtual |
Definition at line 33 of file ossimPointCloudUtilityFilter.h.
References OSSIM_FLOAT32.
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method. |
Definition at line 27 of file ossimPointCloudUtilityFilter.cpp.
References ossimElevManager::getHeightAboveEllipsoid(), ossimImageData::getImageRectangle(), ossimImageData::getPix(), ossimPointCloudImageHandler::getTile(), ossimPointCloudImageHandler::HIGHEST, ossimPointCloudTool::HIGHEST_DEM, ossimPointCloudTool::HIGHEST_LOWEST, ossimElevManager::instance(), ossimImageGeometry::localToWorld(), ossimPointCloudImageHandler::LOWEST, ossimPointCloudTool::LOWEST_DEM, ossimPointCloudTool::m_operation, ossimPointCloudTool::m_pciHandler, ossimPointCloudTool::m_prodGeom, m_util, ossimPointCloudImageHandler::setCurrentEntry(), ossimImageData::setValue(), and ossimImageData::validate().
protected |
Definition at line 40 of file ossimPointCloudUtilityFilter.h.
Referenced by getImageGeometry(), and getTile().
