#include <ossimDilationFilter.h>
| ossimDilationFilter (ossimObject *owner=NULL) | |
| void | setWindowSize (ossim_uint32 windowSize) |
| Size of resampling kernel width & height. More... | |
| ossim_uint32 | getWindowSize () const |
| void | setRecursiveFlag (bool flag=true) |
| Set if getTile is to be called recursively until all pixels have been assigned non-null. More... | |
| bool | getRecursiveFlag () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimDilationFilter () |
| template<class T > | |
| void | doDilation (T scalarType, ossimRefPtr< ossimImageData > &inputData) |
class ossimDilationFilter
Allows you to change between a median or mean filter. You can also specify a window size which the median or mean is computed and the center pixel is replaced.
Definition at line 23 of file ossimDilationFilter.h.
| ossimDilationFilter::ossimDilationFilter | ( | ossimObject * | owner = NULL | ) |
Definition at line 29 of file ossimDilationFilter.cpp.
References ossimConnectableObject::setDescription().
protectedvirtual |
Definition at line 40 of file ossimDilationFilter.cpp.
protected |
Definition at line 126 of file ossimDilationFilter.cpp.
References ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getHeight(), ossimImageData::getImageRectangle(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getWidth(), ossimPolygon::isPointWithin(), ossimImageData::loadTile(), ossim::min(), OSSIM_EMPTY, OSSIM_FULL, status, theNullFoundFlag, theRecursiveFlag, theTempTile, theTile, theValidImagePoly, theWindowSize, ossimIrect::ul(), ossimImageData::validate(), x, and y.
Referenced by getTile().
Definition at line 268 of file ossimDilationFilter.cpp.
Definition at line 286 of file ossimDilationFilter.cpp.
inline |
Definition at line 41 of file ossimDilationFilter.h.
Definition at line 50 of file ossimDilationFilter.cpp.
References doDilation(), ossimImageData::dup(), ossimImageData::getBuf(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimImageSource::getValidImageVertices(), getWindowSize(), ossimSource::isSourceEnabled(), ossimIrect::lr(), OSSIM_CLOCKWISE_ORDER, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageData::setImageRectangleAndBands(), theNullFoundFlag, theRecursiveFlag, theTile, theValidImagePoly, ossimIrect::ul(), ossimRefPtr< T >::valid(), ossimIpt::x, and ossimIpt::y.
inline |
Definition at line 34 of file ossimDilationFilter.h.
Definition at line 44 of file ossimDilationFilter.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
Definition at line 300 of file ossimDilationFilter.cpp.
References ossimKeywordlist::find().
Definition at line 293 of file ossimDilationFilter.cpp.
References ossimKeywordlist::add().
Definition at line 245 of file ossimDilationFilter.cpp.
References ossimRefPtr< T >::valid().
inline |
This is only valid for "fill null" modes.
Definition at line 40 of file ossimDilationFilter.h.
inline |
Definition at line 33 of file ossimDilationFilter.h.
protected |
Definition at line 67 of file ossimDilationFilter.h.
Referenced by doDilation(), and getTile().
protected |
Definition at line 65 of file ossimDilationFilter.h.
protected |
Definition at line 63 of file ossimDilationFilter.h.
Referenced by doDilation().
protected |
Definition at line 62 of file ossimDilationFilter.h.
Referenced by doDilation(), getTile(), and initialize().
protected |
Definition at line 66 of file ossimDilationFilter.h.
protected |
Used for recursion when recursive fill enabled
Definition at line 64 of file ossimDilationFilter.h.
