#include <ossimGeoAnnotationSource.h>
| ossimGeoAnnotationSource (ossimImageGeometry *geom=NULL, bool ownsProjectionFlag=false) | |
| ossimGeoAnnotationSource (ossimImageSource *inputSource, ossimImageGeometry *geom=NULL, bool ownsProjectionFlag=false) | |
| virtual bool | addObject (ossimAnnotationObject *anObject) |
| virtual void | computeBoundingRect () |
| virtual void | transformObjects (ossimImageGeometry *geom=0) |
| virtual void | setGeometry (ossimImageGeometry *projection) |
| virtual bool | setView (ossimObject *baseObject) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| Saves the current state of this object. More... | |
Public Member Functions inherited from ossimAnnotationSource | |
| ossimAnnotationSource (ossimImageSource *inputSource=0) | |
| virtual | ~ossimAnnotationSource () |
| virtual void | setNumberOfBands (ossim_uint32 bands) |
| virtual bool | deleteObject (ossimAnnotationObject *anObject) |
| AnnotationObjectListType | pickObjects (const ossimDpt &imagePoint) |
| AnnotationObjectListType | pickObjects (const ossimDrect &imageRect) |
| const AnnotationObjectListType & | getObjectList () const |
| AnnotationObjectListType & | getObjectList () |
| void | deleteAll () |
| virtual void | drawAnnotations (ossimRefPtr< ossimImageData > tile) |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| virtual | ~ossimGeoAnnotationSource () |
Protected Member Functions inherited from ossimAnnotationSource | |
| void | allocate (const ossimIrect &rect) |
| void | destroy () |
| ossimAnnotationSource (const ossimAnnotationSource &rhs) | |
Friends | |
| std::ostream & | operator<< (std::ostream &out, const ossimGeoAnnotationSource &rhs) |
Public Types inherited from ossimAnnotationSource | |
| typedef std::vector< ossimRefPtr< ossimAnnotationObject > > | AnnotationObjectListType |
Definition at line 21 of file ossimGeoAnnotationSource.h.
| ossimGeoAnnotationSource::ossimGeoAnnotationSource | ( | ossimImageGeometry * | geom = NULL, |
| bool | ownsProjectionFlag = false |
Definition at line 34 of file ossimGeoAnnotationSource.cpp.
References ossimViewInterface::theObject.
| ossimGeoAnnotationSource::ossimGeoAnnotationSource | ( | ossimImageSource * | inputSource, |
Definition at line 43 of file ossimGeoAnnotationSource.cpp.
protectedvirtual |
Definition at line 53 of file ossimGeoAnnotationSource.cpp.
Will add an object to the list. it will own the object added. If the object is not geographic
Reimplemented from ossimAnnotationSource.
Definition at line 57 of file ossimGeoAnnotationSource.cpp.
References ossimAnnotationSource::addObject(), computeBoundingRect(), ossimRefPtr< T >::get(), m_geometry, PTR_CAST, ossimGeoAnnotationObject::transform(), and ossimRefPtr< T >::valid().
Reimplemented in ossimVpfAnnotationSource.
Definition at line 119 of file ossimGeoAnnotationSource.cpp.
References ossimDrect::combine(), ossimDrect::makeNan(), ossimAnnotationSource::theAnnotationObjectList, and ossimAnnotationSource::theRectangle.
Referenced by addObject(), and transformObjects().
Returns the image geometry object associated with this tile source or NULL if not defined.
The geometry contains full-to-local image transform as well as projection (image-to-world). Default implementation returns the image geometry object associated with the next
(left) input source (if any) connected to this source in the chain, or NULL.
Definition at line 168 of file ossimGeoAnnotationSource.cpp.
References ossimImageSource::getImageGeometry(), m_geometry, and ossimRefPtr< T >::valid().
Referenced by ossimVpfTileSource::getImageGeometry().
Implements ossimViewInterface.
Definition at line 109 of file ossimGeoAnnotationSource.cpp.
References ossimRefPtr< T >::get(), and m_geometry.
Referenced by ossimVpfTileSource::getView().
Definition at line 114 of file ossimGeoAnnotationSource.cpp.
Definition at line 184 of file ossimGeoAnnotationSource.cpp.
References ossimString::c_str(), ossimImageGeometry::hasProjection(), ossimAnnotationSource::loadState(), ossimImageGeometry::loadState(), and m_geometry.
Definition at line 177 of file ossimGeoAnnotationSource.cpp.
References ossimAnnotationSource::saveState().
Definition at line 75 of file ossimGeoAnnotationSource.cpp.
References ossimRefPtr< T >::get(), m_geometry, and transformObjects().
Referenced by setView().
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 81 of file ossimGeoAnnotationSource.cpp.
References ossimRefPtr< T >::get(), m_geometry, PTR_CAST, setGeometry(), ossimImageGeometry::setProjection(), and ossimRefPtr< T >::valid().
Referenced by ossimVpfTileSource::setView().
Definition at line 140 of file ossimGeoAnnotationSource.cpp.
References computeBoundingRect(), ossimRefPtr< T >::get(), m_geometry, ossimAnnotationSource::theAnnotationObjectList, and ossimGeoAnnotationObject::transform().
Referenced by setGeometry().
friend |
protected |
Definition at line 66 of file ossimGeoAnnotationSource.h.
Referenced by addObject(), getImageGeometry(), getView(), loadState(), ossimVpfAnnotationSource::ossimVpfAnnotationSource(), setGeometry(), setView(), and transformObjects().
