#include <ossimOrthoImageMosaic.h>
| ossimOrthoImageMosaic () | |
| ossimOrthoImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| Returns the geometry associated with the full mosaic. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &origin, ossim_uint32 resLevel=0) |
| ossimIrect | getRelativeRect (ossim_uint32 index, ossim_uint32 resLevel=0) const |
Public Member Functions inherited from ossimImageMosaic | |
| ossimImageMosaic () | |
| ossimImageMosaic (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &origin, ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimOrthoImageMosaic () |
| void | computeBoundingRect (ossim_uint32 resLevel=0) |
| void | updateGeometry () |
| If this object is maintaining an ossimImageGeometry, this method needs to be called after each time the contents of the mosaic changes. More... | |
Protected Member Functions inherited from ossimImageMosaic | |
| virtual | ~ossimImageMosaic () |
| void | allocate () |
| Called on first getTile, will initialize all data needed. More... | |
| template<class T > | |
| ossimRefPtr< ossimImageData > | combine (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| ossimRefPtr< ossimImageData > | combineNorm (T, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Definition at line 17 of file ossimOrthoImageMosaic.h.
| ossimOrthoImageMosaic::ossimOrthoImageMosaic | ( | ) |
Definition at line 24 of file ossimOrthoImageMosaic.cpp.
References m_Delta, m_UpperLeftTie, and ossimDpt::makeNan().
| ossimOrthoImageMosaic::ossimOrthoImageMosaic | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 34 of file ossimOrthoImageMosaic.cpp.
protectedvirtual |
Definition at line 44 of file ossimOrthoImageMosaic.cpp.
protected |
Definition at line 367 of file ossimOrthoImageMosaic.cpp.
References getRelativeRect(), m_BoundingRect, m_InputTiePoints, and ossimIrect::makeNan().
This will return the bounding rect of the source.
We can have several sources which are in a chain to modify the bounding image rect. lets say you are next to an image handler then it will return the bounding rect for that image. If you are at the right side of a resampler then you will get a bounding rect along the image view plane. This is going to be a very import method for both image writers, mosaics or anything that needs to operate only within the bounds of an image.
Reimplemented from ossimImageCombiner.
Definition at line 158 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimDpt::hasNans(), m_BoundingRect, ossimDpt::makeNan(), and PTR_CAST.
This object maintains it's own geometry instance.
Definition at line 108 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), m_Geometry, PTR_CAST, updateGeometry(), and ossimRefPtr< T >::valid().
Referenced by ossimTiledElevationDatabase::mapRegion().
Definition at line 290 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), getRelativeRect(), OSSIM_NULL, PTR_CAST, size, status, and ossimImageCombiner::theCurrentIndex.
Definition at line 51 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), getRelativeRect(), ossimIrect::hasNans(), ossimIrect::intersects(), m_InputTiePoints, and PTR_CAST.
Definition at line 80 of file ossimOrthoImageMosaic.cpp.
| ossimIrect ossimOrthoImageMosaic::getRelativeRect | ( | ossim_uint32 | index, |
| ossim_uint32 | resLevel = 0 |
| ) | const |
Definition at line 399 of file ossimOrthoImageMosaic.cpp.
References ossimConnectableObject::getInput(), ossimDpt::hasNans(), ossimIrect::hasNans(), m_Delta, m_InputTiePoints, m_UpperLeftTie, ossimIrect::makeNan(), PTR_CAST, ossimDpt::x, and ossimDpt::y.
Referenced by computeBoundingRect(), getNextTile(), getNumberOfOverlappingImages(), and getOverlappingImages().
Reimplemented from ossimImageMosaic.
Definition at line 181 of file ossimOrthoImageMosaic.cpp.
References m_Delta, m_InputTiePoints, m_UpperLeftTie, and ossimDpt::makeNan().
protected |
Definition at line 133 of file ossimOrthoImageMosaic.cpp.
References ossimGpt::datum(), ossimImageGeometry::getProjection(), m_Delta, m_Geometry, m_Units, m_UpperLeftTie, ossimMapProjection::origin(), PTR_CAST, ossimMapProjection::setDecimalDegreesPerPixel(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setUlEastingNorthing(), ossimMapProjection::setUlGpt(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
Referenced by getImageGeometry().
protected |
Definition at line 54 of file ossimOrthoImageMosaic.h.
Referenced by computeBoundingRect(), and getBoundingRect().
protected |
Holds R0 delta and will be scaled for different r-level requests.
Definition at line 52 of file ossimOrthoImageMosaic.h.
Referenced by getRelativeRect(), initialize(), ossimOrthoImageMosaic(), and updateGeometry().
protected |
The input image geometry, altered by the map tiepoint.
Definition at line 56 of file ossimOrthoImageMosaic.h.
Referenced by getImageGeometry(), and updateGeometry().
protected |
Definition at line 51 of file ossimOrthoImageMosaic.h.
Referenced by computeBoundingRect(), getNumberOfOverlappingImages(), getOverlappingImages(), getRelativeRect(), and initialize().
protected |
Definition at line 55 of file ossimOrthoImageMosaic.h.
Referenced by updateGeometry().
protected |
Will hold the upper left tie of the mosaic.
Definition at line 53 of file ossimOrthoImageMosaic.h.
