#include <ossimVectorRenderer.h>
| ossimVectorRenderer () | |
| ossimVectorRenderer (ossimImageSource *inputSource, ossimImageViewTransform *transform=NULL) | |
| virtual ossimImageData * | renderVectorData () const =0 |
| Renders the vector data to a data object. More... | |
| virtual vector< ossimDpt3d > | getObject (ossim_uint32 index) const =0 |
| Returns vector of ossimDpt3d points representing the data object at the index passed in. More... | |
| virtual void | setImageViewTransform (ossimImageViewTransform *transform) |
| Sets the ImageViewTransform to be used for converting vector data. More... | |
| virtual void | setAreaOfInterest (const ossimDrect &aoi) |
| Sets the area of interest. More... | |
| virtual ossimDrect | getAreaOfInterest () const |
| Returns the current area of interest as an ossimDrect. More... | |
| virtual ossimDrect | getBoundingRect (long resLevel=0) const |
| Returns the full bounding rectangle of current vector data loaded. More... | |
| virtual ossim_int32 | getNumberOfAoiObjects () const |
| Returns the number of vector objects in the area of interest. More... | |
| virtual ossim_int32 | getNumberOfObjects () const |
| Returns the total number of vector objects in the full bounding rectangle. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimVectorRenderer () |
| virtual void | setBoundingRect (ossimDrect &rect) |
| Sets the bounding rectangle of current vector data loaded. More... | |
| virtual void | setNumberOfAoiObjects (ossim_int32 number_of_objects) |
| Sets the number of vector objects in the area of interest. More... | |
| virtual void | setNumberOfObjects (ossim_int32 number_of_objects) |
| Sets the number of vector objects in the full bounding rectangle. More... | |
Private Attributes | |
| ossimImageViewTransform * | theImageViewTransform |
| ossimDrect | theBoundingRect |
| ossimDrect | theAreaOfInterest |
| ossim_int32 | theNumberOfAoiObjects |
| ossim_int32 | theNumberOfObjects |
Definition at line 24 of file ossimVectorRenderer.h.
| ossimVectorRenderer::ossimVectorRenderer | ( | ) |
Definition at line 29 of file ossimVectorRenderer.cpp.
| ossimVectorRenderer::ossimVectorRenderer | ( | ossimImageSource * | inputSource, |
| ossimImageViewTransform * | transform = NULL |
Definition at line 40 of file ossimVectorRenderer.cpp.
protectedvirtual |
Definition at line 53 of file ossimVectorRenderer.cpp.
References theImageViewTransform.
Definition at line 101 of file ossimVectorRenderer.cpp.
References theAreaOfInterest.
Definition at line 106 of file ossimVectorRenderer.cpp.
References theBoundingRect.
Definition at line 111 of file ossimVectorRenderer.cpp.
References theNumberOfAoiObjects.
Definition at line 116 of file ossimVectorRenderer.cpp.
References theNumberOfObjects.
pure virtual |
Implementors should set an error and return an empty vector if the index is out of range.
Definition at line 68 of file ossimVectorRenderer.cpp.
References ossimString::c_str(), ossimImageViewTransformFactory::instance(), ossimImageSource::loadState(), and theImageViewTransform.
pure virtual |
The area which is imaged is the area of interest. The scale is determined by the output view projection of the ImageViewTransform.
Definition at line 62 of file ossimVectorRenderer.cpp.
This will be used by the renderVectorData.
Definition at line 96 of file ossimVectorRenderer.cpp.
protectedvirtual |
Definition at line 121 of file ossimVectorRenderer.cpp.
Definition at line 87 of file ossimVectorRenderer.cpp.
protectedvirtual |
Definition at line 126 of file ossimVectorRenderer.cpp.
protectedvirtual |
Definition at line 131 of file ossimVectorRenderer.cpp.
private |
Definition at line 112 of file ossimVectorRenderer.h.
Referenced by getAreaOfInterest(), and setAreaOfInterest().
private |
Definition at line 111 of file ossimVectorRenderer.h.
Referenced by getBoundingRect(), and setBoundingRect().
private |
Definition at line 110 of file ossimVectorRenderer.h.
Referenced by loadState(), setImageViewTransform(), and ~ossimVectorRenderer().
private |
Definition at line 113 of file ossimVectorRenderer.h.
Referenced by getNumberOfAoiObjects(), and setNumberOfAoiObjects().
private |
Definition at line 114 of file ossimVectorRenderer.h.
Referenced by getNumberOfObjects(), and setNumberOfObjects().
