#include <ossimEsriShapeFileFilter.h>
| ossimEsriShapeFileFilter (ossimImageSource *inputSource=NULL) | |
| ~ossimEsriShapeFileFilter () | |
| virtual bool | setView (ossimObject *baseObject) |
| virtual ossimObject * | getView () |
| virtual const ossimObject * | getView () const |
| virtual bool | addObject (ossimAnnotationObject *anObject) |
| virtual void | transformObjects (ossimImageGeometry *geom=0) |
| virtual void | setImageGeometry (ossimImageGeometry *projection) |
| virtual void | computeBoundingRect () |
| virtual void | drawAnnotations (ossimRefPtr< ossimImageData > tile) |
| virtual bool | loadShapeFile (const ossimFilename &shapeFile) |
| virtual ossimFilename | getFilename () const |
| virtual ossim_int32 | getMaxQuadTreeLevels () const |
| virtual void | setMaxQuadTreeLevels (ossim_int32 levels) |
| virtual void | setBrushColor (const ossimRgbVector &brushColor) |
| virtual void | setPenColor (const ossimRgbVector &penColor) |
| virtual ossimRgbVector | getPenColor () const |
| virtual ossimRgbVector | getBrushColor () const |
| virtual bool | getFillFlag () const |
| virtual void | setFillFlag (bool flag) |
| virtual ossimString | getFeatureName () const |
| virtual void | setFeatureName (const ossimString &name) |
| virtual void | setThickness (ossim_int32 thickness) |
| virtual ossim_int32 | getThickness () const |
| virtual void | setPointRadius (double r) |
| virtual double | getPointRadius () const |
| virtual ossimAnnotationObject * | nextObject (bool restart=false) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
Public Member Functions inherited from ossimAnnotationSource | |
| ossimAnnotationSource (ossimImageSource *inputSource=0) | |
| virtual | ~ossimAnnotationSource () |
| virtual void | setNumberOfBands (ossim_uint32 bands) |
| virtual bool | deleteObject (ossimAnnotationObject *anObject) |
| AnnotationObjectListType | pickObjects (const ossimDpt &imagePoint) |
| AnnotationObjectListType | pickObjects (const ossimDrect &imageRect) |
| const AnnotationObjectListType & | getObjectList () const |
| AnnotationObjectListType & | getObjectList () |
| void | deleteAll () |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
Public Member Functions inherited from ossimViewInterface | |
| ossimViewInterface () | |
| ossimViewInterface (ossimObject *base) | |
| virtual | ~ossimViewInterface () |
| virtual void | refreshView () |
| ossimObject * | getBaseObject () |
| void | removeViewProjection () |
| void | deleteCache () |
| void | checkAndSetDefaultView () |
| virtual void | loadPolygon (ossimShapeObject &obj) |
| virtual void | loadPoint (ossimShapeObject &obj) |
| virtual void | loadArc (ossimShapeObject &obj) |
Protected Member Functions inherited from ossimAnnotationSource | |
| void | allocate (const ossimIrect &rect) |
| void | destroy () |
| ossimAnnotationSource (const ossimAnnotationSource &rhs) | |
Public Types inherited from ossimAnnotationSource | |
| typedef std::vector< ossimRefPtr< ossimAnnotationObject > > | AnnotationObjectListType |
class ossimEsriShapeFileFilter
This class is used to render shape files. Iif this filter has an input connection to an ossimImageSourceInterface then it will draw any vectors over the input tile. If it is not connected it will just render its vector data to a tile and return it.
supported keywords:
max_quadtree_levels: // number of levels for faster hit testing
// defaults to 10 fill_flag: // 1 for true 0 for false. Default is false
// and specifies how all closed surfaces are
// to be drawnfeature_name: // currently not used.
pen_color: // specified in Red Green Blue and is the color used
// if the fill flag is not specified. Future changes
// might be to include this as an outline color for
// filled objects. Default is white. Example: 255 255 255 brush_color: // Color used by objects that have the fill flag enabled
// format is Red Green Blue. Default is white.line_thickness: // line drawing thickness in pixels.
border_size: // can be us feet, feet, meters, degrees,
// will automatically expand all polygons by the
// specified size. Uses the centroid to estimate
// non degree units when converting to degrees. point_width_height: // Specifies the width and height of a point object in
// pixels. Default is 1 and has the following format
// w h. Example 1 1filename: // The esri shape file to be used
example Keyword list: See ossimAnnotationSource for any additional keywords
brush_color: 255 255 255 feature_name: filename: fill_flag: 0 max_quadtree_levels: 10 pen_color: 255 255 255 point_width_height: 1 1 thickness: 1 border_size: 25 meters type: ossimEsriShapeFileFilter
Definition at line 84 of file ossimEsriShapeFileFilter.h.
| ossimEsriShapeFileFilter::ossimEsriShapeFileFilter | ( | ossimImageSource * | inputSource = NULL | ) |
Definition at line 44 of file ossimEsriShapeFileFilter.cpp.
References ossimDrect::makeNan(), ossim::nan(), ossimAnnotationSource::setNumberOfBands(), theBoundingRect, theMaxArray, theMinArray, and ossimViewInterface::theObject.
| ossimEsriShapeFileFilter::~ossimEsriShapeFileFilter | ( | ) |
Definition at line 66 of file ossimEsriShapeFileFilter.cpp.
References deleteCache(), removeViewProjection(), and theTree.
Will add an object to the list. it will own the object added.
Reimplemented from ossimAnnotationSource.
Definition at line 116 of file ossimEsriShapeFileFilter.cpp.
References ossimNotify(), and ossimNotifyLevel_WARN.
protected |
Definition at line 309 of file ossimEsriShapeFileFilter.cpp.
References getImageGeometry(), theImageGeometry, transformObjects(), and ossimRefPtr< T >::valid().
Referenced by loadShapeFile(), and loadState().
Definition at line 126 of file ossimEsriShapeFileFilter.cpp.
References ossimDrect::combine(), ossimDrect::hasNans(), ossimDrect::makeNan(), theBoundingRect, and theShapeCache.
Referenced by transformObjects().
protected |
Definition at line 292 of file ossimEsriShapeFileFilter.cpp.
References theShapeCache.
Referenced by loadShapeFile(), loadState(), and ~ossimEsriShapeFileFilter().
Definition at line 169 of file ossimEsriShapeFileFilter.cpp.
References ossimAnnotationSource::drawAnnotations(), ossimImageData::getImageRectangle(), ossimShapeFile::isOpen(), ossimGpt::latd(), ossimIrect::ll(), ossimImageGeometry::localToWorld(), ossimGpt::lond(), ossimIrect::lr(), ossimDrect::lr(), n, OSSIM_RIGHT_HANDED, ossimRgbImage::setCurrentImageData(), SHPTreeFindLikelyShapes(), ossimAnnotationSource::theImage, theImageGeometry, theShapeCache, theShapeFile, theTree, ossimIrect::ul(), ossimDrect::ul(), ossimIrect::ur(), ossimRefPtr< T >::valid(), ossimIpt::x, ossimDpt::x, ossimIpt::y, and ossimDpt::y.
Will return the bounding rectangle.
Definition at line 152 of file ossimEsriShapeFileFilter.cpp.
References ossimImageSource::getBoundingRect(), ossimConnectableObject::getInput(), ossimSource::isSourceEnabled(), PTR_CAST, and theBoundingRect.
inlinevirtual |
Definition at line 144 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 158 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 115 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 149 of file ossimEsriShapeFileFilter.h.
The geometry contains full-to-local image transform as well as projection (image-to-world)
Definition at line 278 of file ossimEsriShapeFileFilter.cpp.
References theImageGeometry.
Referenced by checkAndSetDefaultView().
inlinevirtual |
Definition at line 119 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 139 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 179 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 171 of file ossimEsriShapeFileFilter.h.
Implements ossimViewInterface.
Definition at line 106 of file ossimEsriShapeFileFilter.cpp.
References ossimRefPtr< T >::get(), and theImageGeometry.
Definition at line 111 of file ossimEsriShapeFileFilter.cpp.
protectedvirtual |
Definition at line 514 of file ossimEsriShapeFileFilter.cpp.
References ossimString::clear(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimShapeObject::getId(), ossimShapeObject::getNumberOfParts(), ossimShapeObject::getPartByName(), ossimShapeObject::getPartType(), ossimRgbVector::getR(), ossimShapeObject::getShapeObject(), ossimShapeObject::getTypeByName(), SHPObject::nVertices, ossimNotify(), ossimNotifyLevel_WARN, SHPObject::padfX, SHPObject::padfY, SHPObject::panPartStart, ossimAnnotationObject::setName(), SHPP_RING, theBrushColor, theFeatureName, theFillFlag, thePenColor, theShapeCache, and theThickness.
Referenced by loadShapeFile().
protectedvirtual |
Definition at line 479 of file ossimEsriShapeFileFilter.cpp.
References ossimShapeObject::getId(), ossimShapeObject::getNumberOfVertices(), ossimShapeObject::getShapeObject(), n, OSSIM_PIXEL, SHPObject::padfX, SHPObject::padfY, ossimGeoAnnotationEllipseObject::setEllipseWidthHeightUnitType(), ossimAnnotationObject::setName(), theBrushColor, theFeatureName, theFillFlag, thePenColor, thePointWidthHeight, theShapeCache, and theThickness.
protectedvirtual |
Definition at line 401 of file ossimEsriShapeFileFilter.cpp.
References ossimString::clear(), ossimRgbVector::getB(), ossimRgbVector::getG(), ossimShapeObject::getId(), ossimShapeObject::getNumberOfParts(), ossimShapeObject::getPartByName(), ossimShapeObject::getPartType(), ossimRgbVector::getR(), ossimShapeObject::getShapeObject(), ossimShapeObject::getTypeByName(), ossimGeoPolygon::getVertexList(), SHPObject::nVertices, ossimNotify(), ossimNotifyLevel_WARN, SHPObject::padfX, SHPObject::padfY, SHPObject::panPartStart, ossimAnnotationObject::setName(), SHPP_RING, ossimGeoPolygon::stretchOut(), theBorderSize, theBrushColor, theFeatureName, theFillFlag, thePenColor, theShapeCache, and theThickness.
Will delete the current objects within the layer and add all objects in the passed in file.
Definition at line 321 of file ossimEsriShapeFileFilter.cpp.
References checkAndSetDefaultView(), ossimAnnotationSource::deleteAll(), deleteCache(), ossimShapeFile::getBounds(), ossimShapeFile::getHandle(), ossimShapeFile::getNumberOfShapes(), ossimShapeFile::isOpen(), loadArc(), loadPoint(), loadPolygon(), ossimShapeObject::loadShape(), ossimShapeFile::open(), ossimNotify(), ossimNotifyLevel_WARN, SHPCreateTree(), SHPT_ARC, SHPT_ARCZ, SHPT_NULL, SHPT_POINT, SHPT_POINTZ, SHPT_POLYGON, SHPT_POLYGONZ, theCurrentObject, theImageGeometry, theMaxArray, theMaxQuadTreeLevels, theMinArray, theShapeCache, theShapeFile, theTree, transformObjects(), and ossimRefPtr< T >::valid().
Referenced by loadState().
Definition at line 654 of file ossimEsriShapeFileFilter.cpp.
References ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimString::c_str(), checkAndSetDefaultView(), deleteCache(), ossimKeywordNames::FEATURE_NAME_KW, ossimKeywordNames::FILENAME_KW, ossimKeywordNames::FILL_FLAG_KW, ossimKeywordlist::find(), ossimUnitConversionTool::getValue(), loadShapeFile(), ossimAnnotationSource::loadState(), ossimImageGeometry::loadState(), ossimKeywordNames::MAX_QUADTREE_LEVELS_KW, OSSIM_DEGREES, OSSIM_FEET, OSSIM_METERS, OSSIM_US_SURVEY_FEET, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, theBorderSize, theBorderSizeUnits, theBrushColor, theFeatureName, theFillFlag, theImageGeometry, theMaxQuadTreeLevels, thePenColor, thePointWidthHeight, theThickness, ossimKeywordNames::THICKNESS_KW, ossimString::toBool(), ossimString::toLong(), and ossimString::upcase().
inlinevirtual |
Definition at line 184 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 287 of file ossimEsriShapeFileFilter.cpp.
Referenced by ~ossimEsriShapeFileFilter().
Saves the current state of this object.
Definition at line 580 of file ossimEsriShapeFileFilter.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::BORDER_SIZE_KW, ossimKeywordNames::BRUSH_COLOR_KW, ossimString::c_str(), ossimKeywordNames::FEATURE_NAME_KW, ossimKeywordNames::FILENAME_KW, ossimKeywordNames::FILL_FLAG_KW, ossimRgbVector::getB(), ossimShapeFile::getFilename(), ossimRgbVector::getG(), ossimRgbVector::getR(), ossimKeywordNames::MAX_QUADTREE_LEVELS_KW, ossimKeywordNames::PEN_COLOR_KW, ossimKeywordNames::POINT_WIDTH_HEIGHT_KW, ossimAnnotationSource::saveState(), ossimImageGeometry::saveState(), theBorderSize, theBrushColor, theFeatureName, theFillFlag, theImageGeometry, theMaxQuadTreeLevels, thePenColor, thePointWidthHeight, theShapeFile, theThickness, ossimKeywordNames::THICKNESS_KW, ossimString::toString(), ossimRefPtr< T >::valid(), ossimDpt::x, and ossimDpt::y.
inlinevirtual |
Definition at line 129 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 162 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 154 of file ossimEsriShapeFileFilter.h.
Definition at line 268 of file ossimEsriShapeFileFilter.cpp.
References theImageGeometry, and transformObjects().
inlinevirtual |
Definition at line 124 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 134 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 175 of file ossimEsriShapeFileFilter.h.
inlinevirtual |
Definition at line 167 of file ossimEsriShapeFileFilter.h.
The derived classes should overrid this method and return true or false whether it was able to cast the past in view to a view that it can interface to. So if you are a projective view you might cast to an ossimProjection. The ownsTheView specifies whether or not it owns the passed in view pointer. This will specifiy whether or not the derived classes need to re-allocate the pointer or just delete its old pointer and set it to the passed in pointer.
Definition at line 78 of file ossimEsriShapeFileFilter.cpp.
References PTR_CAST, ossimImageGeometry::setProjection(), theImageGeometry, and ossimRefPtr< T >::valid().
Definition at line 241 of file ossimEsriShapeFileFilter.cpp.
References computeBoundingRect(), ossimRefPtr< T >::get(), PTR_CAST, theImageGeometry, theShapeCache, and ossimGeoAnnotationObject::transform().
Referenced by checkAndSetDefaultView(), loadShapeFile(), and setImageGeometry().
protected |
Definition at line 252 of file ossimEsriShapeFileFilter.h.
Referenced by loadPolygon(), loadState(), and saveState().
protected |
Definition at line 253 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 258 of file ossimEsriShapeFileFilter.h.
Referenced by computeBoundingRect(), getBoundingRect(), and ossimEsriShapeFileFilter().
protected |
Definition at line 247 of file ossimEsriShapeFileFilter.h.
Referenced by loadArc(), loadPoint(), loadPolygon(), loadState(), and saveState().
protected |
Specifies if its image/pixel space, Geographic, projected ...etc.
Definition at line 229 of file ossimEsriShapeFileFilter.h.
mutableprotected |
Definition at line 255 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 250 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 248 of file ossimEsriShapeFileFilter.h.
protected |
This holds the output projection. This is used to transform the objects to the projection plane.
Definition at line 218 of file ossimEsriShapeFileFilter.h.
Referenced by checkAndSetDefaultView(), drawAnnotations(), getImageGeometry(), getView(), loadShapeFile(), loadState(), removeViewProjection(), saveState(), setImageGeometry(), setView(), and transformObjects().
protected |
Definition at line 243 of file ossimEsriShapeFileFilter.h.
Referenced by loadShapeFile(), and ossimEsriShapeFileFilter().
protected |
Definition at line 245 of file ossimEsriShapeFileFilter.h.
Referenced by loadShapeFile(), loadState(), and saveState().
protected |
Definition at line 242 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 246 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 251 of file ossimEsriShapeFileFilter.h.
Referenced by loadPoint(), loadState(), and saveState().
protected |
Definition at line 257 of file ossimEsriShapeFileFilter.h.
Referenced by computeBoundingRect(), deleteCache(), drawAnnotations(), loadArc(), loadPoint(), loadPolygon(), loadShapeFile(), and transformObjects().
protected |
Definition at line 240 of file ossimEsriShapeFileFilter.h.
Referenced by drawAnnotations(), loadShapeFile(), and saveState().
protected |
If the shape file is projected we must know the projector. This will allow us to define the geographic objects correctly.
Definition at line 224 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 249 of file ossimEsriShapeFileFilter.h.
protected |
Definition at line 238 of file ossimEsriShapeFileFilter.h.
Referenced by drawAnnotations(), loadShapeFile(), and ~ossimEsriShapeFileFilter().
protected |
If its projected this spceifies the type of unit. We need to know if the projection is in meters, feet, us survey feet ... etc.
Definition at line 236 of file ossimEsriShapeFileFilter.h.
