#include <ossimRpfCacheTileSource.h>
Classes | |
| struct | ossimFrameEntryData |
| Protected structure that is only used internally by this class. More... | |
Public Types | |
| enum | ossimRpfCacheProductType { OSSIM_PRODUCT_TYPE_UNKNOWN = 0, OSSIM_PRODUCT_TYPE_CIB = 1, OSSIM_PRODUCT_TYPE_CADRG = 2 } |
| Basic enumeration. More... | |
| ossimRpfCacheTileSource () | |
| Default constructor. More... | |
| This method is defined in the base class ossimObject. More... | |
| virtual void | close () |
| Closes this image handler and deletes any allocated data. More... | |
| virtual bool | open () |
| Pure virtual open. More... | |
| Returns a pointer to an ossimImageDataObject given a rectangluar region of interest. More... | |
| Satisfies pure virtual requirement from ImageHandler class. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Method to load the state of an object from a keyword list. More... | |
Populates the geometry object with image geometry information. More... | |
| This method allows you to query the scalar type of the output data. More... | |
| This method allows you to query the number of input bands. More... | |
| This method allows one to query the number of output bands. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| bool | isValidRLevel (ossim_uint32 reduced_res_level) const |
| bool | isOpen () const |
| Determines if its open if there eists a table of contents object. More... | |
| bool | isCib () const |
| bool | isCadrg () const |
| Gets a property for matching name. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Static Public Attributes | |
| static const ossim_uint32 | CIBCADRG_FRAME_WIDTH = 1536 |
| CONSTANT representing the width of a Frame. More... | |
| static const ossim_uint32 | CIBCADRG_FRAME_HEIGHT = 1536 |
| CONSTANT representing the height of a Frame. More... | |
| virtual | ~ossimRpfCacheTileSource () |
| Destructor. More... | |
| void | setActualImageRect () |
| Will shift the rect and clamp it so not to go outside the -180 to 180 degree range. More... | |
| void | checkLongitude (ossim_float64 &leftLon, const ossim_float64 &rightLon) const |
| Method to test for 180.0 <–> 180.00 and set leftLon to -180 if both left and right are 180.0 degrees. More... | |
| virtual bool | setEntryToRender (ossim_uint32 index) |
| Sets the entry to render. More... | |
| vector< ossimFrameEntryData > | getIntersectingEntries (const ossimIrect &rect) |
| It is important to note that each frame is organized into an easting northing type orientation. More... | |
| void | fillTile (const ossimIrect &tileRect, const vector< ossimFrameEntryData > &framesInvolved, ossimImageData *tile) |
| This is a wrapper for the fill cib and fill cadrg. More... | |
| void | fillSubTileCib (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile) |
| Will uncompress the CIB file using a VQ decompression algorithm. More... | |
| void | fillSubTileCadrg (const ossimRpfFrame &aFrame, const ossimIrect &tileRect, const ossimFrameEntryData &frameEntryData, ossimImageData *tile) |
| Will uncompress the CADRG file using a VQ decompression algorithm. More... | |
| void | allocateForProduct () |
| Will allocate an internal buffer for the given product. More... | |
| void | deleteAll () |
| void | populateLut () |
| bool | buildFrameEntryArray (ossimFilename imageFile) |
Definition at line 22 of file ossimRpfCacheTileSource.h.
Basic enumeration.
This should be either a CIB or a CADRG product type.
| Enumerator | |
| OSSIM_PRODUCT_TYPE_UNKNOWN | |
| OSSIM_PRODUCT_TYPE_CIB | |
| OSSIM_PRODUCT_TYPE_CADRG | |
Definition at line 31 of file ossimRpfCacheTileSource.h.
| ossimRpfCacheTileSource::ossimRpfCacheTileSource | ( | ) |
Initializes all internal attributes to a default state.
Definition at line 51 of file ossimRpfCacheTileSource.cpp.
protectedvirtual |
Destructor.
Will return allocated memory back to the heap.
Definition at line 92 of file ossimRpfCacheTileSource.cpp.
References close(), m_compressedBuffer, m_uncompressedBuffer, and m_workFrame.
protected |
If the product is a CIB then it is a single band OSSIM_UCHAR buffer and if its a CADRG it is a 3 band OSSIM_UCHAR buffer.
Definition at line 1111 of file ossimRpfCacheTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_compressedBuffer, m_productType, m_tile, m_uncompressedBuffer, OSSIM_PRODUCT_TYPE_CIB, and OSSIM_PRODUCT_TYPE_UNKNOWN.
protected |
Definition at line 190 of file ossimRpfCacheTileSource.cpp.
protected |
| leftLon | Left hand side longitude of scene. This is the value that will be flipped to -180 if test is true. |
| rightLon | Right hand side of scene. |
Definition at line 357 of file ossimRpfCacheTileSource.cpp.
References ossim::almostEqual().
Definition at line 123 of file ossimRpfCacheTileSource.cpp.
References deleteAll().
Referenced by ~ossimRpfCacheTileSource().
protected |
Definition at line 1144 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::theOverview.
Referenced by close().
protectedvirtual |
Virtual method determines the decimation factors at each resolution level.
This base class implementation computes the decimation by considering the ratios in image size between resolution levels, with fuzzy logic for rounding ratios to the nearest power of 2 if possible. Derived classes need to override this method if the decimations are provided as part of the image metadata.
Definition at line 1307 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::establishDecimationFactors(), and ossimImageHandler::theDecimationFactors.
protected |
| aFrame | Frame that overlaps the requested tile rect. |
| tileRect | The region requested to render. |
| frameEntryData | The frame entry data. |
Definition at line 832 of file ossimRpfCacheTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrame::fillSubFrameBuffer(), ossimRpfFrame::getColorGrayscaleTable(), ossimRpfFrame::getCompressionSection(), ossimRpfCompressionSection::getTable(), ossimIrect::height(), ossimImageData::loadTile(), m_compressedBuffer, m_uncompressedBuffer, OSSIM_BSQ, ossimRpfCacheTileSource::ossimFrameEntryData::thePixelCol, ossimRpfCacheTileSource::ossimFrameEntryData::thePixelRow, ossimIrect::ul(), ossimIrect::width(), ossimIpt::x, and ossimIpt::y.
Referenced by fillTile().
protected |
Definition at line 976 of file ossimRpfCacheTileSource.cpp.
protected |
It takes the frames involved that were found in the getIntersectingEntries and call the appropriate fill cib or fill cadrg on each frame entry data. It will loop through making sure that the frame file exists before calling the associated fill routines.
| tileRect | Region to fill. |
| framesInvolved | All intersecting frames used to render the region. |
Definition at line 798 of file ossimRpfCacheTileSource.cpp.
References fillSubTileCadrg(), fillSubTileCib(), m_productType, m_workFrame, ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CIB, and ossimRpfFrame::parseFile().
Referenced by getTile().
| entryList | This is the list to initialize with entry indexes. |
Definition at line 730 of file ossimRpfCacheTileSource.cpp.
This method is used to relay projection/model information to users. Returns true if geometry info is present, false if not. Keywords supported by this class are:
* datum: // datum code> // Datum code * ul_lat: // upper left latitude * ul_lon: // upper left longitude * ll_lat: // lower left latitude * ll_lon: // lower left longitude * lr_lat: // lower right latitude * lr_lon: // lower right longitude * ur_lat: // upper right latitude * ur_lon: // upper right longitude * number_input_bands: * number_output_bands: * number_lines: * number_samples: * decimal_degrees_per_pixel_lat: // specifies the spacing per pixel along Y direction * decimal_degrees_per_pixel_lon: // specifies the spacing per pixel along X direction * origin_latitude: // specifies the origin or center of the projector for the latitude * central_meridian: // specifies the origin or center of the projector for the longitude * tie_point_lat: // tie point lat. Represents the latitude of the upper left center of pixel * tie_point_lon: // tie point lon. Represents the longitude of the upper left center of pixel * zone: // zone read from the CIB/CADRG boundary info * type: // class name of the object for factory driven reconstruction * map_scale: // Map scale of the image *
Definition at line 545 of file ossimRpfCacheTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordNames::DATUM_KW, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LAT, ossimKeywordNames::DECIMAL_DEGREES_PER_PIXEL_LON, ossimRefPtr< T >::get(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), ossimImageHandler::initImageParameters(), ossimDpt::lat, ossimGpt::latd(), ossimKeywordNames::LL_LAT_KW, ossimKeywordNames::LL_LON_KW, ossimImageGeometry::loadState(), ossimDpt::lon, ossimGpt::lond(), ossimKeywordNames::LR_LAT_KW, ossimKeywordNames::LR_LON_KW, m_bBox_LL_Lat, m_bBox_LL_Lon, m_bBox_UR_Lat, m_bBox_UR_Lon, ossimKeywordNames::NUMBER_INPUT_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::ORIGIN_LATITUDE_KW, ossimImageHandler::theGeometry, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimKeywordNames::TIE_POINT_XY_KW, ossimDpt::toString(), ossimKeywordNames::TYPE_KW, ossimKeywordNames::UL_LAT_KW, ossimKeywordNames::UL_LON_KW, ossimKeywordNames::UR_LAT_KW, ossimKeywordNames::UR_LON_KW, and ossimRefPtr< T >::valid().
| reduced_res_level | Which res level to get the bounds for. 0 represents the default and is the full resolution. |
Definition at line 537 of file ossimRpfCacheTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by getIntersectingEntries(), and getTile().
Implements ossimImageHandler.
Definition at line 1203 of file ossimRpfCacheTileSource.cpp.
Definition at line 1198 of file ossimRpfCacheTileSource.cpp.
protected |
This means that a frame at 0,0 is at the lower left corner. Each frame's pixel data is has 0,0 at the upper left.
It will take the curent region to render and then find all entries that intersect that region.
| rect | the current region to render. |
Definition at line 762 of file ossimRpfCacheTileSource.cpp.
References CIBCADRG_FRAME_HEIGHT, CIBCADRG_FRAME_WIDTH, ossimIrect::clipToRect(), ossimRpfFrameEntry::exists(), getImageRectangle(), ossimIrect::intersects(), isOpen(), ossimIrect::lr(), m_frameEntryArray, ossimIrect::ul(), ossimIpt::x, and ossimIpt::y.
This class overrides the default implementation to return its own long name.
Definition at line 117 of file ossimRpfCacheTileSource.cpp.
If an image is band selectable this will allow one to select the bands you wish to read in. This indicates that the number of input bands might not match the number of output bands.
Implements ossimImageSource.
Definition at line 462 of file ossimRpfCacheTileSource.cpp.
References m_productType, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, and OSSIM_PRODUCT_TYPE_UNKNOWN.
Referenced by getImageGeometry().
| reduced_res_level | The reduced res level to query number of lines from. |
Definition at line 504 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), m_numberOfLines, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry(), and getImageRectangle().
This might not be the same as the n umber of input bands.
Definition at line 483 of file ossimRpfCacheTileSource.cpp.
Referenced by getImageGeometry(), and getTile().
| reduced_res_level | The reduced res level to query number of samples from. |
Definition at line 518 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), m_numberOfSamples, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
This is simply the data type, i.e. whether its OSSIM_FLOAT, OSSIM_DOUBLE, OSSIM_UCHAR, ... etc. This means that if there are bands of different scalar types from a single image then they must be casted to the highest precision type.
Definition at line 698 of file ossimRpfCacheTileSource.cpp.
References OSSIM_UCHAR.
| name | The name of the property to get. |
Definition at line 1218 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::getProperty(), m_productType, OSSIM_PRODUCT_TYPE_CADRG, and OSSIM_PRODUCT_TYPE_CIB.
This class overrides the default implementation to return its own short name.
Definition at line 112 of file ossimRpfCacheTileSource.cpp.
| rect | The region of interest to return. |
| resLevel | From which resolution set are we querying (default is 0 full res). |
Definition at line 379 of file ossimRpfCacheTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 399 of file ossimRpfCacheTileSource.cpp.
References fillTile(), getImageRectangle(), ossimImageData::getImageRectangle(), getIntersectingEntries(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), isValidRLevel(), m_productType, ossimImageData::makeBlank(), OSSIM_PRODUCT_TYPE_UNKNOWN, status, and ossimImageData::validate().
Definition at line 708 of file ossimRpfCacheTileSource.cpp.
References m_tileSize, and ossimIpt::y.
Definition at line 703 of file ossimRpfCacheTileSource.cpp.
References m_tileSize, and ossimIpt::x.
| bool ossimRpfCacheTileSource::isCadrg | ( | ) | const |
Definition at line 1213 of file ossimRpfCacheTileSource.cpp.
References m_productType, and OSSIM_PRODUCT_TYPE_CADRG.
| bool ossimRpfCacheTileSource::isCib | ( | ) | const |
Definition at line 1208 of file ossimRpfCacheTileSource.cpp.
References m_productType, and OSSIM_PRODUCT_TYPE_CIB.
Definition at line 128 of file ossimRpfCacheTileSource.cpp.
References ossimString::downcase(), ossimFilename::ext(), and ossimImageHandler::theImageFile.
Referenced by getIntersectingEntries(), getTile(), and setEntryToRender().
| reduced_res_level | passed in resolution level. |
Definition at line 746 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::isValidRLevel(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Loading with a prefix.
Loading without a prefix.
Since all objects are factory created you can go through the registry and pass the keyword list in.
| kwl | Keywordlist that holds the state information for this object. |
| prefix | prefix value prepended to all keywords to uniquely locate the state attributes for this object. |
Definition at line 1157 of file ossimRpfCacheTileSource.cpp.
Pure virtual open.
Derived classes must implement.
Definition at line 143 of file ossimRpfCacheTileSource.cpp.
protected |
Definition at line 1235 of file ossimRpfCacheTileSource.cpp.
References ossimRpfFrame::getColorGrayscaleTable(), m_fileNames, m_productType, ossimErrorCodes::OSSIM_OK, OSSIM_PRODUCT_TYPE_CADRG, OSSIM_PRODUCT_TYPE_CIB, OSSIM_UINT8, ossimRpfFrame::parseFile(), and ossimImageHandler::theLut.
Referenced by setEntryToRender().
| kwl | Keywordlist to save the state of the object to. |
| prefix | prefix to prepend to the keywords. This will help uniquely identify each keyword if multiple objects are saved to the same list. |
Definition at line 1149 of file ossimRpfCacheTileSource.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 532 of file ossimRpfCacheTileSource.cpp.
References m_actualImageRect, m_numberOfLines, and m_numberOfSamples.
| entryIdx | Entry number to select. |
Definition at line 713 of file ossimRpfCacheTileSource.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), setEntryToRender(), ossimImageHandler::theGeometry, and ossimImageHandler::theOverviewFile.
protectedvirtual |
Definition at line 735 of file ossimRpfCacheTileSource.cpp.
References isOpen(), and populateLut().
Referenced by setCurrentEntry().
static |
This should be 1536.
Definition at line 292 of file ossimRpfCacheTileSource.h.
Referenced by fillSubTileCadrg(), fillSubTileCib(), and getIntersectingEntries().
static |
Definition at line 287 of file ossimRpfCacheTileSource.h.
protected |
This holds the image bounds for the current entry.
Definition at line 436 of file ossimRpfCacheTileSource.h.
Referenced by setActualImageRect().
protected |
Definition at line 488 of file ossimRpfCacheTileSource.h.
protected |
Definition at line 487 of file ossimRpfCacheTileSource.h.
protected |
Definition at line 490 of file ossimRpfCacheTileSource.h.
protected |
Definition at line 489 of file ossimRpfCacheTileSource.h.
protected |
This is for storage of a single compressed buffer.
Definition at line 441 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), fillSubTileCadrg(), fillSubTileCib(), and ~ossimRpfCacheTileSource().
protected |
The size of the input frames.
Definition at line 470 of file ossimRpfCacheTileSource.h.
Referenced by populateLut().
protected |
Definition at line 494 of file ossimRpfCacheTileSource.h.
Referenced by getIntersectingEntries().
protected |
This will be computed based on the frames organized within the directory.
The CibCadrg have fixed size frames of 1536x1536 and we must count how many there are.
Definition at line 453 of file ossimRpfCacheTileSource.h.
Referenced by getNumberOfLines(), and setActualImageRect().
protected |
Definition at line 460 of file ossimRpfCacheTileSource.h.
Referenced by getNumberOfSamples(), and setActualImageRect().
protected |
Definition at line 492 of file ossimRpfCacheTileSource.h.
protected |
Definition at line 491 of file ossimRpfCacheTileSource.h.
protected |
Holds the enumeration specifying the product type.
The product type can be a CIB or a CADRG product.
Definition at line 481 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), fillTile(), getNumberOfInputBands(), getNumberOfOutputBands(), getProperty(), getTile(), isCadrg(), isCib(), and populateLut().
protected |
This is the actual data returned from a getTile request.
Definition at line 465 of file ossimRpfCacheTileSource.h.
Referenced by allocateForProduct(), and getTile().
protected |
The size of the output tile.
Definition at line 475 of file ossimRpfCacheTileSource.h.
Referenced by getTileHeight(), and getTileWidth().
protected |
This is used as a buffer to uncompress the data to.
Definition at line 446 of file ossimRpfCacheTileSource.h.
mutableprotected |
Definition at line 483 of file ossimRpfCacheTileSource.h.
Referenced by fillTile(), and ~ossimRpfCacheTileSource().
