Class to shift/stretch input values to given min/max. More...
#include <ossimShiftFilter.h>
| ossimShiftFilter () | |
| virtual double | getNullPixelValue (ossim_uint32 band) const |
| virtual double | getMinPixelValue (ossim_uint32 band) const |
| virtual double | getMaxPixelValue (ossim_uint32 band) const |
| void | setNullPixelValue (double null) |
| Set the null output pixel. More... | |
| void | setMinPixelValue (double min) |
| Set the min output pixel. More... | |
| void | setMaxPixelValue (double max) |
| Set the max output pixel. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimShiftFilter () |
| virtual protected destructor More... | |
Private Member Functions | |
| ossimShiftFilter (const ossimShiftFilter &) | |
| Private to disallow use... More... | |
| ossimShiftFilter & | operator= (const ossimShiftFilter &) |
| void | allocate () |
| Allocates the tile. More... | |
| template<class T > | |
| void | fillTile (T dummy, const ossimImageData *inputTile, ossimImageData *outputTile) const |
| Template to fill the tile. More... | |
Private Attributes | |
| ossimRefPtr< ossimImageData > | m_tile |
| double | m_min |
| double | m_max |
| double | m_null |
Callers must set the min, max, null output values. Input data shifted stretch base on:
pix = outMin + (inPix - inMin) * (outMax-outMin)/(inMax-inMin)
See ossim-shift-filter-test.cpp for concrete example of usage.
Definition at line 32 of file ossimShiftFilter.h.
| ossimShiftFilter::ossimShiftFilter | ( | ) |
default constructor
Definition at line 26 of file ossimShiftFilter.cpp.
protectedvirtual |
private |
private |
Allocates the tile.
Called on first getTile.
Definition at line 297 of file ossimShiftFilter.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and m_tile.
Referenced by getTile().
private |
| dummy | template type. |
| inputTile | |
| outputTile |
Definition at line 176 of file ossimShiftFilter.cpp.
References ossimImageData::getBuf(), ossimImageData::getMaxPix(), ossimImageData::getMinPix(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), m_max, m_min, m_null, and ossimImageData::validate().
Definition at line 225 of file ossimShiftFilter.cpp.
Definition at line 230 of file ossimShiftFilter.cpp.
Definition at line 268 of file ossimShiftFilter.cpp.
References ossimImageSource::getMaxPixelValue(), ossim::isnan(), m_max, and ossimSource::theEnableFlag.
Definition at line 254 of file ossimShiftFilter.cpp.
References ossimImageSource::getMinPixelValue(), ossim::isnan(), m_min, and ossimSource::theEnableFlag.
Definition at line 240 of file ossimShiftFilter.cpp.
References ossimImageSource::getNullPixelValue(), ossim::isnan(), m_null, and ossimSource::theEnableFlag.
Definition at line 235 of file ossimShiftFilter.cpp.
Definition at line 66 of file ossimShiftFilter.cpp.
References allocate(), fillTile(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossim::isnan(), ossimSource::isSourceEnabled(), m_max, m_min, m_null, m_tile, ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_NORMALIZED_DOUBLE, OSSIM_NORMALIZED_FLOAT, OSSIM_NULL, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT32, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, and ossimImageData::validate().
Definition at line 45 of file ossimShiftFilter.cpp.
private |
Definition at line 310 of file ossimShiftFilter.cpp.
| void ossimShiftFilter::setMaxPixelValue | ( | double | max | ) |
Definition at line 292 of file ossimShiftFilter.cpp.
Referenced by ossimHdf5Tool::initProcessingChain().
| void ossimShiftFilter::setMinPixelValue | ( | double | min | ) |
Definition at line 287 of file ossimShiftFilter.cpp.
| void ossimShiftFilter::setNullPixelValue | ( | double | null | ) |
Definition at line 282 of file ossimShiftFilter.cpp.
References m_null.
private |
Definition at line 99 of file ossimShiftFilter.h.
Referenced by fillTile(), getMaxPixelValue(), getTile(), and setMaxPixelValue().
private |
Definition at line 98 of file ossimShiftFilter.h.
Referenced by fillTile(), getMinPixelValue(), getTile(), and setMinPixelValue().
private |
Definition at line 100 of file ossimShiftFilter.h.
Referenced by fillTile(), getNullPixelValue(), getTile(), and setNullPixelValue().
private |
Definition at line 97 of file ossimShiftFilter.h.
Referenced by allocate(), and getTile().
