#include <ossimSICDToDetectedImage.h>
| ossimSICDToDetectedImage () | |
| Currently works with SICD data but will generally work for conforming Complex formats. More... | |
| Applies the sqrt(I^2 + Q^2) to generate the Detected SAR image. More... | |
| Calls base ossimImageSourceFilter::initialize() to reset connection if needed then nulls out tiles. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimSICDToDetectedImage () |
| void | allocate () |
| Called to initialize tiles by first get tile when theTile or theNormTile are not initialized. More... | |
| template<class T > | |
| void | processComplexTile (T dummy, ossimImageData *tile) |
| Applies the brightness contrast to tile. More... | |
| void | processAmplitudeAngleTile (T dummy, ossimImageData *tile) |
Definition at line 13 of file ossimSICDToDetectedImage.h.
| ossimSICDToDetectedImage::ossimSICDToDetectedImage | ( | ) |
protectedvirtual |
Definition at line 28 of file ossimSICDToDetectedImage.cpp.
protected |
Definition at line 158 of file ossimSICDToDetectedImage.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), ossimImageSourceFilter::theInputConnection, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 189 of file ossimSICDToDetectedImage.cpp.
References ossimImageSourceFilter::getProperty().
Definition at line 194 of file ossimSICDToDetectedImage.cpp.
References ossimImageSourceFilter::getPropertyNames().
For 8 bit data the input is assumed to be Magnitude and Phase (Not complex format) and so it simply returns the magnitude which is the Detected SAR image.
Definition at line 32 of file ossimSICDToDetectedImage.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_FLOAT32, OSSIM_NULL, OSSIM_SINT16, OSSIM_SINT8, OSSIM_UINT16, OSSIM_UINT8, processAmplitudeAngleTile(), processComplexTile(), ossimImageData::setImageRectangle(), ossimImageSourceFilter::theInputConnection, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 152 of file ossimSICDToDetectedImage.cpp.
References ossimImageSourceFilter::initialize(), and theTile.
protected |
Definition at line 133 of file ossimSICDToDetectedImage.cpp.
References ossimImageData::getBuf(), ossimImageData::getHeight(), ossimImageData::getWidth(), and theTile.
protected |
This method simply applies brightness contrast to all bands. Called if input does not have three bands.
Definition at line 114 of file ossimSICDToDetectedImage.cpp.
Definition at line 177 of file ossimSICDToDetectedImage.cpp.
References ossimImageSourceFilter::setProperty().
protected |
Definition at line 67 of file ossimSICDToDetectedImage.h.
Referenced by allocate(), getTile(), initialize(), processAmplitudeAngleTile(), and processComplexTile().
