Concrete class for reading VIIRS data from HDF5 file. More...
#include <ossimViirsHandler.h>
| ossimViirsHandler () | |
Public Member Functions inherited from ossimHdf5ImageHandler | |
| ossimHdf5ImageHandler () | |
| virtual | ~ossimHdf5ImageHandler () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| virtual void | close () |
| Close method. More... | |
| ossimRefPtr< ossimHdf5ImageDataset > | getCurrentDataset () |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| virtual bool | open () |
| The derived class needs to initialize the raster dataset names m_renderableNames in their constructor, for this method to work. More... | |
| const std::vector< ossimString > & | getRenderableSetNames () |
| void | addRenderable (const ossimString &datasetName) |
| Adds the dataset name, either the full HDF5 path or the simple object name, to the list of renderable datasets. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Protected Member Functions inherited from ossimHdf5ImageHandler | |
| void | allocate () |
| Allocates the tile. More... | |
Protected Attributes inherited from ossimHdf5ImageHandler | |
| std::vector< ossimString > | m_renderableNames |
| ossimRefPtr< ossimHdf5 > | m_hdf5 |
| std::vector< ossimRefPtr< ossimHdf5ImageDataset > > | m_entries |
| ossim_uint32 | m_currentEntry |
| ossimRefPtr< ossimImageData > | m_tile |
| std::mutex | m_mutex |
Protected Attributes inherited from ossimImageHandler | |
| ossimFilename | theImageFile |
| ossimFilename | theOverviewFile |
| ossimFilename | theSupplementaryDirectory |
| ossimRefPtr< ossimImageHandler > | theOverview |
| vector< ossimIpt > | theValidImageVertices |
| ossimImageMetaData | theMetaData |
| ossimRefPtr< ossimImageGeometry > | theGeometry |
| ossimRefPtr< ossimNBandLutDataObject > | theLut |
| std::vector< ossimDpt > | theDecimationFactors |
| ossimString | theImageID |
| ossim_uint32 | theStartingResLevel |
| theStartingResLevel If set to something other than zero(default) this is indicative that the reader is an overview. More... | |
| bool | theOpenOverviewFlag |
| If true opening of overviews will be attempted. More... | |
| ossimPixelType | thePixelType |
| std::shared_ptr< ossim::ImageHandlerState > | m_state |
Protected Attributes inherited from ossimSource | |
| bool | theEnableFlag |
| bool | theInitializedFlag |
Protected Attributes inherited from ossimConnectableObject | |
| ossimId | theId |
| ossimString | theDescription |
| ossimObject * | theOwner |
| bool | theInputListIsFixedFlag |
| Indicates whether the theInputObjectList is fixed. More... | |
| bool | theOutputListIsFixedFlag |
| Indicates whether the theOutputObjectList is fixed. More... | |
| ConnectableObjectList | theInputObjectList |
| Holds a list of input objects. More... | |
| ConnectableObjectList | theOutputObjectList |
| Holds a list of output objects. More... | |
Protected Attributes inherited from ossimListenerManager | |
| std::list< ossimListener * > | theListenerList |
| bool | theEnabledFlag |
| std::list< ossimListener * > | theDelayedAdd |
| std::list< ossimListener * > | theDelayedRemove |
| bool | theFireEventFlag |
Definition at line 21 of file include/ossim/hdf5/ossimViirsHandler.h.
| ossimViirsHandler::ossimViirsHandler | ( | ) |
Definition at line 15 of file src/hdf5/ossimViirsHandler.cpp.
References ossimHdf5ImageHandler::m_renderableNames.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 20 of file src/hdf5/ossimViirsHandler.cpp.
References ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), ossimHdf5GridModel::initialize(), ossimHdf5ImageHandler::isOpen(), ossimHdf5ImageHandler::m_hdf5, ossimImageHandler::theGeometry, and ossimRefPtr< T >::valid().
Reimplemented from ossimHdf5ImageHandler.
Definition at line 45 of file src/hdf5/ossimViirsHandler.cpp.
