#include <ossimBrightnessContrastSource.h>
| ossimBrightnessContrastSource () | |
| Currently works in hsi space so must be one or three bands. More... | |
| Will apply the algorithm: i*c + b where b is brightnes c is contrast i is the input value. More... | |
| virtual void | setBrightnessContrast (ossim_float64 brightness, ossim_float64 contrast) |
| virtual void | setBrightness (ossim_float64 brightness) |
| virtual void | setContrast (ossim_float64 contrast) |
| virtual ossim_float64 | getBrightness () const |
| virtual ossim_float64 | getContrast () const |
| Calls base ossimImageSourceFilter::initialize() to reset connection if needed then nulls out tiles. More... | |
| Keywords searched for by this method. More... | |
| Keywords saved to list by this method. More... | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimBrightnessContrastSource () |
| void | allocate () |
| Called to initialize tiles by first get tile when theTile or theNormTile are not initialized. More... | |
| void | processRgbTile () |
| Applies the brightness contrast to tile. More... | |
| void | processNBandTile () |
Definition at line 14 of file ossimBrightnessContrastSource.h.
| ossimBrightnessContrastSource::ossimBrightnessContrastSource | ( | ) |
Todo: Make work with nband.
protectedvirtual |
Definition at line 37 of file ossimBrightnessContrastSource.cpp.
protected |
Definition at line 177 of file ossimBrightnessContrastSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::getNumberOfBands(), ossimImageData::initialize(), ossimImageDataFactory::instance(), ossimSource::isSourceEnabled(), OSSIM_FLOAT32, ossimImageSourceFilter::theInputConnection, theNormTile, theTile, and ossimRefPtr< T >::valid().
Referenced by getTile().
Definition at line 306 of file ossimBrightnessContrastSource.cpp.
References theBrightness.
Referenced by getProperty(), and setContrast().
Definition at line 311 of file ossimBrightnessContrastSource.cpp.
References theContrast.
Referenced by getProperty(), and setBrightness().
Definition at line 222 of file ossimBrightnessContrastSource.cpp.
References getBrightness(), getContrast(), ossimImageSourceFilter::getProperty(), ossimNumericProperty::ossimNumericPropertyType_FLOAT64, ossimProperty::setCacheRefreshBit(), ossimNumericProperty::setNumericType(), and ossimString::toString().
Definition at line 246 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::getPropertyNames().
Definition at line 41 of file ossimBrightnessContrastSource.cpp.
References allocate(), ossimImageData::copyNormalizedBufferToTile(), ossimImageData::copyTileToNormalizedBuffer(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getNumberOfBands(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), OSSIM_EMPTY, OSSIM_NULL, processNBandTile(), processRgbTile(), ossimDataObject::setDataObjectStatus(), ossimImageData::setImageRectangle(), theBrightness, theContrast, ossimImageSourceFilter::theInputConnection, theNormTile, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Referenced by ossimBrightnessMatch::getTile().
Definition at line 169 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::initialize(), theNormTile, and theTile.
brightness: 0.0
contrast: 1.0
Definition at line 255 of file ossimBrightnessContrastSource.cpp.
References ossimKeywordlist::find(), ossimImageSourceFilter::loadState(), theBrightness, theContrast, and ossimString::toDouble().
protected |
This method simply applies brightness contrast to all bands. Called if input does not have three bands.
Definition at line 148 of file ossimBrightnessContrastSource.cpp.
References ossimImageData::getFloatBuf(), ossimImageData::getMinNormalizedPix(), ossimImageData::getNumberOfBands(), ossimImageData::getSizePerBand(), theBrightness, theContrast, and theNormTile.
protected |
This method works in hsi space on the intensity channel; thus, preserving hue and saturation of an rgb pixel. Called if input has three bands.
Definition at line 97 of file ossimBrightnessContrastSource.cpp.
References ossimNormRgbVector::getB(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimNormRgbVector::getG(), ossimImageData::getHeight(), ossimHsiVector::getI(), ossimNormRgbVector::getR(), ossimImageData::getWidth(), OSSIM_DEFAULT_MIN_PIX_NORM_FLOAT, OSSIM_FULL, ossimHsiVector::setI(), theBrightness, theContrast, and theNormTile.
brightness: 0.0
contrast: 1.0
Definition at line 273 of file ossimBrightnessContrastSource.cpp.
References ossimKeywordlist::add(), ossimImageSourceFilter::saveState(), theBrightness, and theContrast.
| brightness | Value between -1.0 and +1.0 with zero being no brightness offset. |
Definition at line 296 of file ossimBrightnessContrastSource.cpp.
References getContrast(), and setBrightnessContrast().
Referenced by ossimBrightnessMatch::computeInputBrightness(), and ossimBrightnessMatch::setProperty().
| contrast | Value between 0.0 and 2.0 with 1.0 being no contrast adjustment. |
Definition at line 289 of file ossimBrightnessContrastSource.cpp.
References theBrightness, and theContrast.
Referenced by setBrightness(), and setContrast().
Definition at line 301 of file ossimBrightnessContrastSource.cpp.
References getBrightness(), and setBrightnessContrast().
Definition at line 201 of file ossimBrightnessContrastSource.cpp.
References ossimImageSourceFilter::setProperty(), theBrightness, and theContrast.
protected |
Definition at line 124 of file ossimBrightnessContrastSource.h.
Referenced by getBrightness(), getTile(), loadState(), processNBandTile(), processRgbTile(), saveState(), setBrightnessContrast(), and setProperty().
protected |
Definition at line 125 of file ossimBrightnessContrastSource.h.
Referenced by getContrast(), getTile(), loadState(), processNBandTile(), processRgbTile(), saveState(), setBrightnessContrast(), and setProperty().
protected |
Definition at line 127 of file ossimBrightnessContrastSource.h.
Referenced by allocate(), getTile(), initialize(), processNBandTile(), and processRgbTile().
protected |
Definition at line 126 of file ossimBrightnessContrastSource.h.
Referenced by allocate(), getTile(), and initialize().
