ossimKakaduNitfReader class for reading NITF images with JPEG2000 (J2K) compressed blocks using kakadu library for decompression. More...
#include <ossimKakaduNitfReader.h>
Public Types | |
| enum | { SIGNATURE_BOX_SIZE = 12 } |
| Anonymous enumerations: More... | |
Public Types inherited from ossimNitfTileSource | |
| enum | ReadMode { READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3, READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7, READ_JPEG_BLOCK = 8 } |
| ossimKakaduNitfReader () | |
| default construtor More... | |
| virtual | ~ossimKakaduNitfReader () |
| virtural destructor More... | |
| Returns short name. More... | |
| Returns long name. More... | |
| Returns the number of decimation levels. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Gets number of lines for res level. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Gets the number of samples for res level. More... | |
| virtual ossim_float64 | getMinPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getMaxPixelValue (ossim_uint32 band=0) const |
| virtual ossim_float64 | getNullPixelValue (ossim_uint32 band=0) const |
Public Member Functions inherited from ossimNitfTileSource | |
| ossimNitfTileSource () | |
| virtual bool | open () |
| Returns true if the image_file can be opened and is a valid nitf file. More... | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| virtual void | close () |
| Closes file and destroys all memory allocated. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| ossim_uint32 | getNumberOfEntries () const |
| ossimString | getSecurityClassification () const |
| bool | getCacheEnabledFlag () const |
| void | setCacheEnabledFlag (bool flag) |
| const ossimNitfFileHeader * | getFileHeader () const |
| ossimNitfFileHeader * | getFileHeader () |
| const ossimNitfImageHeader * | getCurrentImageHeader () const |
| ossimNitfImageHeader * | getCurrentImageHeader () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Gets an overview tile. More... | |
| virtual bool | loadBlock (ossim_uint32 x, ossim_uint32 y) |
| Loads a block of data to theCacheTile. More... | |
| virtual bool | parseFile () |
| Parses "theImageFile" and initializes all nitf headers. More... | |
| virtual bool | allocate () |
| Allocates everything for current entry. More... | |
| virtual bool | allocateBuffers () |
| Allocates buffers for current entry. More... | |
| virtual bool | canUncompress (const ossimNitfImageHeader *hdr) const |
| Checks header to see is we can decompress entry. More... | |
| virtual void | initializeReadMode () |
| Initializes the data member "theReadMode" from the current entry. More... | |
| virtual bool | scanForJpegBlockOffsets () |
| This method simply checks for Start of Codestream (SOC) marker as the Kakadu library handles finding tiles for us. More... | |
| virtual void | initializeSwapBytesFlag () |
| Sets the "theSwapBytesFlag" from the current entry. More... | |
| virtual void | initializeCacheTileInterLeaveType () |
| Initializes the data member "theCacheTileInterLeaveType". More... | |
| virtual ossim_int32 | get_capabilities () |
| Gets kdu source capability. More... | |
| virtual ossim_int32 | read (kdu_core::kdu_byte *buf, ossim_int32 num_bytes) |
| Read method. More... | |
| virtual bool | seek (kdu_core::kdu_long offset) |
| Seek method. More... | |
| virtual kdu_core::kdu_long | get_pos () |
| Get file position relative to the start of code stream offset. More... | |
Protected Member Functions inherited from ossimNitfTileSource | |
| virtual | ~ossimNitfTileSource () |
| void | setBoundingRectangle (const ossimIrect &imageRect) |
| ossimNitfTileSource (const ossimNitfTileSource &obj) | |
| Copy constructor, disallow... More... | |
| ossimNitfTileSource & | operator= (const ossimNitfTileSource &rhs) |
| Operator=, disallow... More... | |
| bool | loadTile (const ossimIrect &clipRect) |
| Returns true on success, false on error. More... | |
| ossim_uint32 | getBlockNumber (const ossimIpt &block_origin) const |
| void | destroy () |
| Deletes all memory allocated by this object. More... | |
| virtual void | initializeScalarType () |
| Initializes the data member "theScalarType" from the current entry. More... | |
| void | initializeBandCount () |
| Initializes the data member "theNumberOfBands" from the current entry. More... | |
| bool | initializeBlockSize () |
| Initializes the data member "theBlockSize" from the current entry. More... | |
| virtual bool | initializeImageRect () |
| Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More... | |
| void | initializeCacheSize () |
| Initializes the data member "theCacheSize". More... | |
| void | initializeCacheTile () |
| Initializes the cache tile size(width and height). More... | |
| virtual void | initializeCompressedBuf () |
| Initializes the data member theCompressedBuf. More... | |
| virtual void | initializeOutputTile () |
| Initializes the output tile size(width and height). More... | |
| void | initializeLut () |
| Initializes "theLut" if applicable. More... | |
| bool | loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect) |
| bool | getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const |
| ossim_uint32 | getNumberOfBlocks () const |
| std::streampos | getBandOffset () const |
| std::streampos | getBlockOffset () const |
| void | explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const |
| void | convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const |
| ossim_uint32 | getPartialReadSize (const ossimIpt &blockOrigin) const |
| bool | isVqCompressed (const ossimString &compressionCode) const |
| void | vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization unmasked image data. More... | |
| void | vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization masked image data. More... | |
| void | lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| virtual bool | uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y) |
| Uncompresses a jpeg block using the jpeg-6b library. More... | |
| bool | loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const |
| Loads one of the default tables based on COMRAT value. More... | |
| bool | loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const |
| Loads default huffman tables. More... | |
Private Member Functions | |
| bool | isEntryJ2k () const |
| Checks current entry image header to see if it is j2k. More... | |
| bool | checkJp2Signature () |
| Checks for jp2 signature block. More... | |
| void | configureChannelMapping () |
| Initializes m_channels to be used with copyRegionToTile if it makes sense. More... | |
| std::ostream & | dumpTiles (std::ostream &out) |
| Method to print out tile info. More... | |
Private Attributes | |
| std::streamoff | m_startOfCodestreamOffset |
| kdu_supp::jp2_family_src * | m_jp2FamilySrc |
| kdu_supp::jp2_source * | m_jp2Source |
| kdu_supp::kdu_channel_mapping * | m_channels |
| kdu_core::kdu_codestream | m_codestream |
| kdu_core::kdu_thread_env * | m_threadEnv |
| kdu_core::kdu_thread_queue * | m_openTileThreadQueue |
| ossim_uint32 | m_sourcePrecisionBits |
| ossim_uint32 | m_minDwtLevels |
| std::vector< ossimIrect > | m_imageDims |
| Image dimensions for each level. More... | |
| ossim_float64 | m_minSampleValue |
| min/max/null These are class attributes so that when behaving as an overview the owner or base image handler can pass its min/max/null to us. More... | |
| ossim_float64 | m_maxSampleValue |
| ossim_float64 | m_nullSampleValue |
Definition at line 44 of file ossimKakaduNitfReader.h.
| anonymous enum |
| Enumerator | |
| SIGNATURE_BOX_SIZE | |
Definition at line 50 of file ossimKakaduNitfReader.h.
| ossimKakaduNitfReader::ossimKakaduNitfReader | ( | ) |
default construtor
virtural destructor
Definition at line 76 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::close(), m_channels, m_codestream, m_jp2FamilySrc, m_jp2Source, m_openTileThreadQueue, m_threadEnv, ossimNotify(), and ossimNotifyLevel_WARN.
protectedvirtual |
This is called on an open() or a entry change to an already open nitf file.
This does not allocate buffers and tiles to keep open and setCurrentEntry times to a minimum. Buffers are allocated on first grab of pixel data by allocatBuffers method.
Overrides ossimNitfTileSource::allocate
Reimplemented from ossimNitfTileSource.
Definition at line 528 of file ossimKakaduNitfReader.cpp.
protectedvirtual |
This is called on first getTile().
Overrides ossimNitfTileSource::allocateBuffers
Definition at line 763 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::allocateBuffers(), ossimNitfTileSource::getNumberOfOutputBands(), ossim::isnan(), m_maxSampleValue, m_minSampleValue, m_nullSampleValue, ossimImageData::setMaxPix(), ossimImageData::setMinPix(), ossimImageData::setNullPix(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
protectedvirtual |
If compression code is not "C8" calls base canUncompress as you could have a J2k entry and a jpeg entry.
Overrides ossimNitfTileSource::canUncompress
| hdr | Pointer to image header. |
Definition at line 815 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::canUncompress(), and ossimNitfImageHeader::getCompressionCode().
private |
Note the stream is repositioned to start of data after the check so that the jp2 open code does not have to reposition.
Definition at line 973 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), SIGNATURE_BOX_SIZE, and ossimNitfTileSource::theFileStr.
Referenced by scanForJpegBlockOffsets().
private |
Definition at line 1010 of file ossimKakaduNitfReader.cpp.
References m_channels, m_codestream, m_jp2Source, and ossimNitfTileSource::theNumberOfOutputBands.
private |
For debug only.
Definition at line 1050 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfBlocksPerCol(), ossimNitfImageHeader::getNumberOfBlocksPerRow(), m_startOfCodestreamOffset, ossimJ2kSizRecord::parseStream(), ossimJ2kSotRecord::parseStream(), ossimJ2kTlmRecord::parseStream(), ossimJ2kCodRecord::parseStream(), ossimJ2kCodRecord::print(), ossimJ2kSotRecord::print(), ossimJ2kSizRecord::print(), ossimJ2kTlmRecord::print(), ossimNitfTileSource::theFileStr, and ossimJ2kSotRecord::thePsot.
inlineprotectedvirtual |
Overrides kdu_compressed_source::get_capabilities
Definition at line 369 of file ossimKakaduNitfReader.h.
Overrides kdu_compressed_source::get_pos
Definition at line 395 of file ossimKakaduNitfReader.h.
References m_startOfCodestreamOffset, and ossimNitfTileSource::theFileStr.
Returns long name.
Definition at line 157 of file ossimKakaduNitfReader.cpp.
Definition at line 351 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getMaxPixelValue(), ossim::isnan(), and m_maxSampleValue.
Definition at line 342 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getMinPixelValue(), ossim::isnan(), and m_minSampleValue.
Definition at line 360 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getNullPixelValue(), ossim::isnan(), and m_nullSampleValue.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 162 of file ossimKakaduNitfReader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), isEntryJ2k(), m_minDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Overrides ossimNitfTileSource::getNumberOfLines
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 187 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getNumberOfLines(), ossimImageHandler::getNumberOfLines(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_imageDims, m_minDwtLevels, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
Overrides ossimNitfTileSource::getNumberOfSamples
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 224 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::getNumberOfSamples(), ossimImageHandler::getNumberOfSamples(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_imageDims, m_minDwtLevels, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, and ossimRefPtr< T >::valid().
protectedvirtual |
Overrides ossimImageHandler::getOverviewTile
| resLevel | The resolution level to pull from with resLevel 0 being full res. |
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset. |
Definition at line 369 of file ossimKakaduNitfReader.cpp.
References ossim::copyRegionToTile(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), ossimNitfTileSource::getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimImageSource::getTile(), isEntryJ2k(), ossimImageHandler::isValidRLevel(), m_channels, m_codestream, m_minDwtLevels, m_openTileThreadQueue, m_threadEnv, ossimNotify(), ossimNotifyLevel_WARN, status, ossimImageHandler::theOverview, ossimImageHandler::theStartingResLevel, ossimRefPtr< T >::valid(), and ossimException::what().
Referenced by loadBlock().
Returns short name.
Definition at line 152 of file ossimKakaduNitfReader.cpp.
protectedvirtual |
Overrides ossimNitfTileSource::initializeCacheTileInterLeaveType
Definition at line 946 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::initializeCacheTileInterLeaveType(), isEntryJ2k(), OSSIM_BSQ, and ossimNitfTileSource::theCacheTileInterLeaveType.
protectedvirtual |
Overrides ossimNitfTileSource::initializeReadMode
Definition at line 832 of file ossimKakaduNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getIMode(), ossimNitfTileSource::initializeReadMode(), ossimNitfTileSource::READ_JPEG_BLOCK, ossimNitfTileSource::READ_MODE_UNKNOWN, and ossimNitfTileSource::theReadMode.
protectedvirtual |
Overrides ossimNitfTileSource::initializeSwapBytesFlag
Definition at line 933 of file ossimKakaduNitfReader.cpp.
References ossimNitfTileSource::initializeSwapBytesFlag(), isEntryJ2k(), and ossimNitfTileSource::theSwapBytesFlag.
private |
Definition at line 959 of file ossimKakaduNitfReader.cpp.
References ossimNitfImageHeader::getCompressionCode(), and ossimNitfTileSource::getCurrentImageHeader().
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), getOverviewTile(), initializeCacheTileInterLeaveType(), initializeSwapBytesFlag(), and loadBlock().
protectedvirtual |
| x | Starting x position of block to load. |
| y | Starting y position of block to load. |
Definition at line 450 of file ossimKakaduNitfReader.cpp.
References ossimAppFixedTileCache::addTile(), ossimRefPtr< T >::get(), getOverviewTile(), ossimAppFixedTileCache::instance(), isEntryJ2k(), ossimNitfTileSource::loadBlock(), ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), ossimNitfTileSource::theCacheId, ossimNitfTileSource::theCacheSize, ossimNitfTileSource::theCacheTile, ossimIpt::x, x, ossimIpt::y, and y.
protectedvirtual |
Overrides ossimNitfTileSource::parseFile
Definition at line 488 of file ossimKakaduNitfReader.cpp.
Read method.
Implements pure virtual kdu_compressed_source::read
| buf | Buffer to fill. |
| num_bytes | Bytes to read. |
Definition at line 374 of file ossimKakaduNitfReader.h.
References ossimNitfTileSource::theFileStr.
protectedvirtual |
Overrides ossimNitfTileSource::scanForJpegBlockOffsets
Definition at line 852 of file ossimKakaduNitfReader.cpp.
References checkJp2Signature(), ossimNitfTileSource::getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), m_startOfCodestreamOffset, and ossimNitfTileSource::theFileStr.
Seek method.
Overrides kdu_compressed_source::seek
| offset | Seek position relative to the start of code stream offset. |
Definition at line 380 of file ossimKakaduNitfReader.h.
convenience method to set max pixel value.
Added for overview readers so that the image handler that owns the overview reader can pass on it's max value.
| band | Zero based band to set. |
| pix | Max pixel value. |
Definition at line 280 of file ossimKakaduNitfReader.cpp.
References m_maxSampleValue, ossimImageData::setMaxPix(), ossimImageHandler::setMaxPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
convenience method to set min pixel value.
Added for overview readers so that the image handler that owns the overview reader can pass on it's min value.
| pix | Min pixel value. |
Definition at line 261 of file ossimKakaduNitfReader.cpp.
References m_minSampleValue, ossimImageData::setMinPix(), ossimImageHandler::setMinPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
convenience method to set null pixel value.
| pix | Null pixel value. |
Definition at line 299 of file ossimKakaduNitfReader.cpp.
References ossimImageData::getNullPix(), m_nullSampleValue, ossimImageData::makeBlank(), OSSIM_STATUS_UNKNOWN, ossimDataObject::setDataObjectStatus(), ossimImageData::setNullPix(), ossimImageHandler::setNullPixelValue(), ossimNitfTileSource::theCacheTile, ossimNitfTileSource::theTile, and ossimRefPtr< T >::valid().
private |
Definition at line 345 of file ossimKakaduNitfReader.h.
Referenced by configureChannelMapping(), getOverviewTile(), and ~ossimKakaduNitfReader().
private |
Definition at line 346 of file ossimKakaduNitfReader.h.
private |
Definition at line 354 of file ossimKakaduNitfReader.h.
Referenced by getNumberOfLines(), and getNumberOfSamples().
private |
Definition at line 343 of file ossimKakaduNitfReader.h.
Referenced by ~ossimKakaduNitfReader().
private |
Definition at line 344 of file ossimKakaduNitfReader.h.
Referenced by configureChannelMapping(), and ~ossimKakaduNitfReader().
private |
Definition at line 363 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getMaxPixelValue(), and setMaxPixelValue().
private |
Definition at line 351 of file ossimKakaduNitfReader.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
private |
For non eight bit data this is critical so that the data gets stretched exactly as the base handler. Did NOT make these a vector the size of bands as it was not needed at time of coding.
Definition at line 362 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getMinPixelValue(), and setMinPixelValue().
private |
Definition at line 364 of file ossimKakaduNitfReader.h.
Referenced by allocateBuffers(), getNullPixelValue(), and setNullPixelValue().
private |
Definition at line 348 of file ossimKakaduNitfReader.h.
Referenced by getOverviewTile(), and ~ossimKakaduNitfReader().
private |
Definition at line 350 of file ossimKakaduNitfReader.h.
private |
Definition at line 341 of file ossimKakaduNitfReader.h.
Referenced by dumpTiles(), get_pos(), scanForJpegBlockOffsets(), and seek().
private |
Definition at line 347 of file ossimKakaduNitfReader.h.
