#include <ossimBandMergeSource.h>
| ossimBandMergeSource () | |
| ossimBandMergeSource (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| This will merge all the bands from the input source list into one contiguous ossimImageData object. More... | |
| virtual bool | getTile (ossimImageData *tile, ossim_uint32 resLevel=0) |
Public Member Functions inherited from ossimImageCombiner | |
| ossimImageCombiner () | |
| ossimImageCombiner (ossimObject *owner, int numberOfInputs, int numberOfOutputs, bool inputListIsFixedFlag, bool outputListIsFixedFlag) | |
| ossimImageCombiner (ossimConnectableObject::ConnectableObjectList &inputSources) | |
| virtual bool | loadState (const ossimKeywordlist &kwl, const char *prefix=NULL) |
| virtual bool | saveState (ossimKeywordlist &kwl, const char *prefix=NULL) const |
| virtual void | updateRects () |
| This will go through and precompute the bounding rects of each input image. More... | |
| Returns the number of bands available from the input. More... | |
| virtual ossim_uint32 | getNumberOfOverlappingImages (const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to retrieve the number of overlapping images withint the given rect. More... | |
| virtual void | getOverlappingImages (std::vector< ossim_uint32 > &result, const ossimIrect &rect, ossim_uint32 resLevel=0) const |
| Used to populate the result with the index of the overlapping images. More... | |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | getNextTile (ossim_uint32 &returnedIdx, const ossim_uint32 startIdx, ossimImageData *tile, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossim_uint32 index, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual ossimRefPtr< ossimImageData > | getNextNormTile (ossim_uint32 &returnedIdx, const ossimIrect &tileRect, ossim_uint32 resLevel=0) |
| virtual bool | canConnectMyInputTo (ossim_int32 inputIndex, const ossimConnectableObject *object) const |
| virtual bool | hasDifferentInputs () const |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| ProcessEvent. More... | |
| ossimListener () | |
| void | enableListener () |
| void | disableListener () |
| virtual | ~ossimBandMergeSource () |
| void | allocate () |
| Performs allocation of "theTile". More... | |
| ossim_uint32 | computeNumberOfInputBands () const |
Protected Member Functions inherited from ossimImageCombiner | |
| virtual | ~ossimImageCombiner () |
| void | precomputeBounds () const |
Definition at line 19 of file ossimBandMergeSource.h.
| ossimBandMergeSource::ossimBandMergeSource | ( | ) |
Definition at line 19 of file ossimBandMergeSource.cpp.
| ossimBandMergeSource::ossimBandMergeSource | ( | ossimConnectableObject::ConnectableObjectList & | inputSources | ) |
Definition at line 26 of file ossimBandMergeSource.cpp.
References initialize().
protectedvirtual |
Definition at line 34 of file ossimBandMergeSource.cpp.
References theNumberOfOutputBands.
protected |
Definition at line 246 of file ossimBandMergeSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theNumberOfOutputBands, and theTile.
Referenced by getTile().
protected |
Definition at line 256 of file ossimBandMergeSource.cpp.
References ossimConnectableObject::getInput(), ossimConnectableObject::getNumberOfInputs(), ossimImageSource::getNumberOfOutputBands(), PTR_CAST, and size.
Referenced by getNumberOfOutputBands(), and initialize().
Reimplemented from ossimImageCombiner.
Definition at line 206 of file ossimBandMergeSource.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getMaxPixelValue(), ossimConnectableObject::getNumberOfInputs(), getNumberOfOutputBands(), ossimImageSource::getNumberOfOutputBands(), ossim::nan(), and PTR_CAST.
Definition at line 178 of file ossimBandMergeSource.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getMinPixelValue(), ossimConnectableObject::getNumberOfInputs(), getNumberOfOutputBands(), ossimImageSource::getNumberOfOutputBands(), and PTR_CAST.
Definition at line 150 of file ossimBandMergeSource.cpp.
References ossimConnectableObject::getInput(), ossimImageSource::getNullPixelValue(), ossimConnectableObject::getNumberOfInputs(), getNumberOfOutputBands(), ossimImageSource::getNumberOfOutputBands(), ossim::nan(), and PTR_CAST.
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 278 of file ossimBandMergeSource.cpp.
References computeNumberOfInputBands(), and theNumberOfOutputBands.
Referenced by getMaxPixelValue(), getMinPixelValue(), and getNullPixelValue().
This is very useful when you want to split off an intesity channel in HSI and then run some algorithms on it and then merge it back. You can also try to do fusions by converting to an YCbCr and replace the Y or intensity channel with maybe a high-pass convolution on the pan.
Definition at line 39 of file ossimBandMergeSource.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimImageData::getHeight(), ossimImageCombiner::getNextTile(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::getWidth(), ossimIrect::height(), ossimImageData::initialize(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), ossimImageData::setHeight(), ossimImageData::setOrigin(), ossimImageData::setWidth(), theTile, ossimIrect::ul(), and ossimIrect::width().
Referenced by ossimBandSeparateHandler::getTile().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method. |
Definition at line 87 of file ossimBandMergeSource.cpp.
References ossimImageData::fill(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimConnectableObject::getInput(), ossimImageCombiner::getNextTile(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimConnectableObject::getNumberOfInputs(), ossimImageData::getSizePerBandInBytes(), ossimImageSource::getTile(), ossimSource::isSourceEnabled(), ossimImageData::makeBlank(), OSSIM_EMPTY, OSSIM_NULL, PTR_CAST, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 234 of file ossimBandMergeSource.cpp.
References computeNumberOfInputBands(), ossimRefPtr< T >::get(), ossimImageCombiner::initialize(), theNumberOfOutputBands, and theTile.
Referenced by ossimBandMergeSource().
protected |
Definition at line 55 of file ossimBandMergeSource.h.
Referenced by allocate(), getNumberOfOutputBands(), initialize(), and ~ossimBandMergeSource().
protected |
Definition at line 56 of file ossimBandMergeSource.h.
Referenced by allocate(), getTile(), and initialize().
