#include <ossimOpjJp2Reader.h>
Public Types | |
| enum | { SIGNATURE_BOX_SIZE = 12, GEOTIFF_UUID_SIZE = 16 } |
| Anonymous enumerations: More... | |
| enum | ossimOpjJp2ReadMode { ossimOpjJp2ReadUnknown = 0 } |
| ossimOpjJp2Reader () | |
| virtual | ~ossimOpjJp2Reader () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of decimation levels. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| virtual bool | open () |
| open method. More... | |
| virtual void | close () |
| close method More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| Gets an overview tile. More... | |
Private Member Functions | |
| virtual ossimRefPtr< ossimImageGeometry > | getInternalImageGeometry () |
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometryFromGeotiffBox () |
| virtual ossimRefPtr< ossimImageGeometry > | getImageGeometryFromGmlBox () |
| ossimRefPtr< ossimImageGeometry > | getMetadataImageGeometry () const |
| void | destroy () |
| bool | initSizRecord (std::istream *str, ossimJ2kSizRecord &sizRecord) const |
| bool | initCodRecord (std::istream *str, ossimJ2kCodRecord &sizRecord) const |
| void | allocate () |
| Initializes tiles. More... | |
Private Attributes | |
| ossimJ2kSizRecord | m_sizRecord |
| ossimRefPtr< ossimImageData > | m_tile |
| ossimRefPtr< ossimImageData > | m_cacheTile |
| std::ifstream * | m_str |
| ossim_uint32 | m_minDwtLevels |
| ossim_int32 | m_format |
Definition at line 25 of file ossimOpjJp2Reader.h.
| anonymous enum |
| Enumerator | |
| SIGNATURE_BOX_SIZE | |
| GEOTIFF_UUID_SIZE | |
Definition at line 30 of file ossimOpjJp2Reader.h.
| ossimOpjJp2Reader::ossimOpjJp2Reader | ( | ) |
default constructor
Definition at line 60 of file ossimOpjJp2Reader.cpp.
private |
Initializes tiles.
Called once on first getTile request.
Definition at line 998 of file ossimOpjJp2Reader.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_cacheTile, and m_tile.
Referenced by getTile().
close method
Definition at line 183 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::close(), and destroy().
private |
Definition at line 87 of file ossimOpjJp2Reader.cpp.
References m_cacheTile, m_str, and m_tile.
Referenced by close(), and ~ossimOpjJp2Reader().
Definition at line 469 of file ossimOpjJp2Reader.cpp.
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 599 of file ossimOpjJp2Reader.cpp.
References ossimImageGeometryRegistry::extendGeometry(), ossimRefPtr< T >::get(), ossimImageHandler::getExternalImageGeometry(), getInternalImageGeometry(), getMetadataImageGeometry(), ossimImageGeometry::getProjection(), ossimImageHandler::initImageParameters(), ossimImageGeometryRegistry::instance(), and ossimImageHandler::theGeometry.
privatevirtual |
| Method | to get geometry from the embedded JP2 GeoTIFF Box. |
Definition at line 688 of file ossimOpjJp2Reader.cpp.
privatevirtual |
| Method | to get geometry from the embedded JP2 GML Box. |
Definition at line 804 of file ossimOpjJp2Reader.cpp.
Note that rrds 0 is the highest resolution rrds.
Definition at line 342 of file ossimOpjJp2Reader.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Referenced by getOverviewTile().
Implements ossimImageHandler.
Definition at line 449 of file ossimOpjJp2Reader.cpp.
References getNumberOfLines(), m_sizRecord, ossimJ2kSizRecord::m_YTOsiz, and ossimJ2kSizRecord::m_YTsiz.
Definition at line 439 of file ossimOpjJp2Reader.cpp.
References getNumberOfSamples(), m_sizRecord, ossimJ2kSizRecord::m_XTOsiz, and ossimJ2kSizRecord::m_XTsiz.
privatevirtual |
| Method | to get geometry from the embedded JP2 Boxes. |
Definition at line 648 of file ossimOpjJp2Reader.cpp.
Referenced by getImageGeometry().
Definition at line 464 of file ossimOpjJp2Reader.cpp.
Definition at line 494 of file ossimOpjJp2Reader.cpp.
References ossimImageData::getMaxPix(), m_tile, and ossimRefPtr< T >::valid().
private |
| Method | to get geometry from the various external files like .prj, .j2w .xml and so on. |
Definition at line 889 of file ossimOpjJp2Reader.cpp.
This returns the total number of decimation levels. It is important to note that res level 0 or full resolution is included in the list and has decimation values 1.0, 1.0
Definition at line 367 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::getNumberOfDecimationLevels(), m_minDwtLevels, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 474 of file ossimOpjJp2Reader.cpp.
References ossimJ2kSizRecord::m_Csiz, and m_sizRecord.
Definition at line 390 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::getNumberOfLines(), ossimImageHandler::isValidRLevel(), m_minDwtLevels, m_sizRecord, ossimJ2kSizRecord::m_YOsiz, ossimJ2kSizRecord::m_Ysiz, ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), x, and y.
Referenced by getImageRectangle(), and getImageTileHeight().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 479 of file ossimOpjJp2Reader.cpp.
Definition at line 413 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::getNumberOfLines(), ossimImageHandler::isValidRLevel(), m_minDwtLevels, m_sizRecord, ossimJ2kSizRecord::m_XOsiz, ossimJ2kSizRecord::m_Xsiz, ossimImageHandler::theOverview, ossimRefPtr< T >::valid(), x, and y.
Referenced by getImageRectangle(), and getImageTileWidth().
Definition at line 484 of file ossimOpjJp2Reader.cpp.
References ossimJ2kSizRecord::getScalarType(), and m_sizRecord.
protectedvirtual |
Overrides ossimImageHandler::getOverviewTile
| resLevel | The resolution level to pull from with resLevel 0 being full res. |
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This method will subtract the subImageOffset if needed for external overview call since they do not know about the sub image offset. |
Definition at line 216 of file ossimOpjJp2Reader.cpp.
References ossimIrect::clipToRect(), getImageRectangle(), ossimImageData::getImageRectangle(), m_minDwtLevels, m_sizRecord, ossimJ2kSizRecord::m_XOsiz, ossimJ2kSizRecord::m_YOsiz, and status.
Definition at line 459 of file ossimOpjJp2Reader.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 189 of file ossimOpjJp2Reader.cpp.
References allocate(), ossimRefPtr< T >::get(), getOverviewTile(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), m_tile, ossimImageData::makeBlank(), ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
private |
private |
Definition at line 504 of file ossimOpjJp2Reader.cpp.
References ossimJ2kSizRecord::parseStream().
Definition at line 489 of file ossimOpjJp2Reader.cpp.
References m_str.
Definition at line 356 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::loadState(), and open().
open method.
Definition at line 100 of file ossimOpjJp2Reader.cpp.
Referenced by loadState().
Definition at line 350 of file ossimOpjJp2Reader.cpp.
References ossimImageHandler::saveState().
private |
Definition at line 224 of file ossimOpjJp2Reader.h.
Referenced by allocate(), and destroy().
private |
Definition at line 227 of file ossimOpjJp2Reader.h.
private |
Definition at line 226 of file ossimOpjJp2Reader.h.
Referenced by getNumberOfDecimationLevels(), getNumberOfLines(), getNumberOfSamples(), and getOverviewTile().
private |
Definition at line 221 of file ossimOpjJp2Reader.h.
Referenced by getImageTileHeight(), getImageTileWidth(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), getOutputScalarType(), and getOverviewTile().
private |
Definition at line 225 of file ossimOpjJp2Reader.h.
private |
Definition at line 223 of file ossimOpjJp2Reader.h.
Referenced by allocate(), destroy(), getMaxPixelValue(), and getTile().
