This is the base class for all imagery using HDF5 as the file format. More...
#include <ossimHdf5ImageHandler.h>
| ossimHdf5ImageHandler () | |
| virtual | ~ossimHdf5ImageHandler () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| virtual void | close () |
| Close method. More... | |
| ossimRefPtr< ossimHdf5ImageDataset > | getCurrentDataset () |
| Set propterty method. More... | |
| Get propterty method. More... | |
| Get propterty names. More... | |
| virtual bool | open () |
| The derived class needs to initialize the raster dataset names m_renderableNames in their constructor, for this method to work. More... | |
| const std::vector< ossimString > & | getRenderableSetNames () |
| void | addRenderable (const ossimString &datasetName) |
| Adds the dataset name, either the full HDF5 path or the simple object name, to the list of renderable datasets. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| void | allocate () |
| Allocates the tile. More... | |
Friends | |
| class | ossimHdf5ImageDataset |
HDF5 is unique in that it represents a variety of subformats for raster and projection information. The derived classes will need to specify the group and dataset names where the needed data lives.
Definition at line 26 of file ossimHdf5ImageHandler.h.
| ossimHdf5ImageHandler::ossimHdf5ImageHandler | ( | ) |
default constructor
Definition at line 50 of file ossimHdf5ImageHandler.cpp.
virtual destructor
Definition at line 59 of file ossimHdf5ImageHandler.cpp.
References close(), and isOpen().
inline |
Definition at line 212 of file ossimHdf5ImageHandler.h.
Referenced by ossimHdf5Tool::loadImageFiles().
protected |
Allocates the tile.
Definition at line 67 of file ossimHdf5ImageHandler.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), m_mutex, and m_tile.
Referenced by getTile().
Close method.
Definition at line 425 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::close(), m_entries, m_hdf5, m_tile, and ossimRefPtr< T >::valid().
Referenced by ~ossimHdf5ImageHandler().
Definition at line 387 of file ossimHdf5ImageHandler.cpp.
| ossimRefPtr< ossimHdf5ImageDataset > ossimHdf5ImageHandler::getCurrentDataset | ( | ) |
Definition at line 499 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, and m_entries.
Definition at line 494 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 454 of file ossimHdf5ImageHandler.cpp.
References m_entries.
Get the name of entry as a string.
Example given from HDF5 file:
entry_name: /All_Data/VIIRS-IMG-GTM-EDR-GEO_All/QF1_VIIRSGTMGEO
| entryIdx | Zero based entry index. If out of range name will be cleared. |
| name | Initialized by this. |
Definition at line 445 of file ossimHdf5ImageHandler.cpp.
Note that rrds 0 is the highest resolution rrds.
Definition at line 195 of file ossimHdf5ImageHandler.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Implements ossimImageHandler.
Definition at line 372 of file ossimHdf5ImageHandler.cpp.
Definition at line 367 of file ossimHdf5ImageHandler.cpp.
Definition at line 382 of file ossimHdf5ImageHandler.cpp.
Definition at line 512 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getMaxPixelValue(), m_currentEntry, and m_entries.
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 524 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getMinPixelValue(), m_currentEntry, and m_entries.
Reimplemented in ossimViirsHandler, and ossimViirsHandler.
Definition at line 507 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNullPixelValue().
Referenced by getTile(), ossimHdf5ImageDataset::getTileBuf(), and ossimHdf5ImageDataset::scanForMinMax().
Definition at line 440 of file ossimHdf5ImageHandler.cpp.
Satisfies pure virtual from ImageHandler class.
Implements ossimImageSource.
Definition at line 392 of file ossimHdf5ImageHandler.cpp.
Referenced by getNumberOfOutputBands(), and getTile().
Definition at line 335 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNumberOfLines(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageRectangle().
Note: we are supporting sources that can have multiple data objects. If you want to know the scalar type of an object you can pass in the
Definition at line 402 of file ossimHdf5ImageHandler.cpp.
References getNumberOfInputBands().
Definition at line 351 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getNumberOfSamples(), m_currentEntry, m_entries, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 408 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, m_entries, and OSSIM_SCALAR_UNKNOWN.
Overrides ossimImageHandler::getProperty.
| name | Property name to get. |
Definition at line 560 of file ossimHdf5ImageHandler.cpp.
References ossimString::string().
Overrides ossimImageHandler::getPropertyNames.
| propertyNames | Array to initialize. |
Definition at line 578 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::getPropertyNames().
inline |
Definition at line 208 of file ossimHdf5ImageHandler.h.
Referenced by ossimHdf5PluginHandlerFactory::getSupportedRenderableNames().
Definition at line 377 of file ossimHdf5ImageHandler.cpp.
Satisfies pure virtual from TileSource class.
Definition at line 75 of file ossimHdf5ImageHandler.cpp.
References allocate(), ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_mutex, m_tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 104 of file ossimHdf5ImageHandler.cpp.
References ossimIrect::area(), ossimIrect::clipToRect(), ossimIrect::completely_within(), getImageRectangle(), ossimImageData::getImageRectangle(), getNullPixelValue(), ossimImageData::getNumberOfBands(), getNumberOfInputBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossim_hdf5::getScalarType(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::loadBand(), m_currentEntry, m_entries, m_mutex, ossimImageData::makeBlank(), OSSIM_FLOAT32, ossimReferenced::ref(), ossim::scalarSizeInBytes(), status, ossimReferenced::unref(), and ossimImageData::validate().
Definition at line 420 of file ossimHdf5ImageHandler.cpp.
References m_currentEntry, m_entries, m_hdf5, and ossimRefPtr< T >::valid().
Referenced by ossimViirsHandler::getImageGeometry(), getTile(), setCurrentEntry(), and ~ossimHdf5ImageHandler().
There is an external file with an omd extension.
this file contains additional information about the image such as the null pixel, min and max values. For general raster it will contain much more than that.
Definition at line 220 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::loadMetaData(), and m_tile.
Definition at line 209 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::loadState(), and open().
This should be implemented by the derived HDF5-format readers defined in plugins.
Definition at line 226 of file ossimHdf5ImageHandler.cpp.
Referenced by ossimHdf5Tool::loadImageFiles(), and loadState().
Definition at line 203 of file ossimHdf5ImageHandler.cpp.
References ossimImageHandler::saveState().
| entryIdx | Entry number to select. |
Definition at line 464 of file ossimHdf5ImageHandler.cpp.
References ossimString::clear(), ossimImageHandler::completeOpen(), isOpen(), ossimIrect::ll(), ossimIrect::lr(), m_currentEntry, m_entries, m_tile, ossimImageHandler::theOverviewFile, ossimImageHandler::theValidImageVertices, ossimIrect::ul(), and ossimIrect::ur().
Overrides ossimImageHandler::setProperty.
Current property name handled: "scale" One double value representing the scale in meters per pixel. It is assumed the scale is same for x and y direction.
| property | to set. |
Definition at line 536 of file ossimHdf5ImageHandler.cpp.
References ossimProperty::getName(), ossimString::string(), and ossimRefPtr< T >::valid().
friend |
Definition at line 28 of file ossimHdf5ImageHandler.h.
protected |
Definition at line 221 of file ossimHdf5ImageHandler.h.
Referenced by getCurrentDataset(), getCurrentEntry(), getMaxPixelValue(), getMinPixelValue(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 220 of file ossimHdf5ImageHandler.h.
Referenced by close(), getCurrentDataset(), getEntryList(), getEntryNames(), getMaxPixelValue(), getMinPixelValue(), getNumberOfEntries(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and setCurrentEntry().
protected |
Definition at line 219 of file ossimHdf5ImageHandler.h.
Referenced by close(), ossimViirsHandler::getImageGeometry(), isOpen(), and ossimHdf5ImageDataset::ossimHdf5ImageDataset().
protected |
Definition at line 223 of file ossimHdf5ImageHandler.h.
Referenced by allocate(), and getTile().
protected |
Definition at line 218 of file ossimHdf5ImageHandler.h.
Referenced by ossimViirsHandler::ossimViirsHandler().
protected |
Definition at line 222 of file ossimHdf5ImageHandler.h.
Referenced by allocate(), close(), getTile(), loadMetaData(), and setCurrentEntry().
