#include <ossimAdrgTileSource.h>
Public Types | |
| enum | { ADRG_TILE_WIDTH = 128, ADRG_TILE_HEIGHT = 128, ADRG_TILE_SIZE = 16384, BAND_OFFSET = 16384, NUMBER_OF_BANDS = 3 } |
| enum | ADRG_COLOR { RED_BAND = 0, GREEN_BAND = 1, BLUE_BAND = 2 } |
| ossimAdrgTileSource () | |
| virtual bool | open () |
| Returns a pointer to a tile given an origin representing the upper left corner of the tile to grab from the image. More... | |
| Returns the number of bands in the image. More... | |
| Returns the number of lines in the image. More... | |
| Returns the number of samples in the image. More... | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 reduced_res_level=0) const |
| Returns the zero based image rectangle for the reduced resolution data set (rrds) passed in. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| Returns the height of the output tile. More... | |
| Gets a property for matching name. More... | |
| Gets a list of property names available. More... | |
| ossimImageHandler () | |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimAdrgTileSource () |
| void | adjustToStartOfTile (ossimIpt &pt) const |
| Adjust point to even 128 boundary. More... | |
| bool | fillBuffer (const ossimIrect &tile_rect, const ossimIrect &clip_rect, ossimImageData *tile) |
| Returns true on success, false on error. More... | |
Definition at line 25 of file ossimAdrgTileSource.h.
| anonymous enum |
| Enumerator | |
| ADRG_TILE_WIDTH | |
| ADRG_TILE_HEIGHT | |
| ADRG_TILE_SIZE | |
| BAND_OFFSET | |
| NUMBER_OF_BANDS | |
Definition at line 29 of file ossimAdrgTileSource.h.
| ossimAdrgTileSource::ossimAdrgTileSource | ( | ) |
Definition at line 53 of file ossimAdrgTileSource.cpp.
protectedvirtual |
Definition at line 64 of file ossimAdrgTileSource.cpp.
References close(), m_AdrgHeader, and m_TileBuffer.
protected |
Assumes 0,0 origin.
Definition at line 678 of file ossimAdrgTileSource.cpp.
References ossimIpt::x, and ossimIpt::y.
Referenced by fillBuffer().
Definition at line 269 of file ossimAdrgTileSource.cpp.
References m_AdrgHeader, m_FileStr, and m_Tile.
Referenced by ~ossimAdrgTileSource().
protected |
Definition at line 158 of file ossimAdrgTileSource.cpp.
References adjustToStartOfTile(), ADRG_TILE_HEIGHT, ADRG_TILE_SIZE, ADRG_TILE_WIDTH, ossimIrect::clipToRect(), ossimIrect::intersects(), ossimImageData::loadBand(), ossimIrect::lr(), m_AdrgHeader, m_FileStr, m_TileBuffer, ossimErrorCodes::OSSIM_ERROR, ossimErrorStatusInterface::theErrorStatus, ossimAdrgHeader::tim(), ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by getTile().
Definition at line 398 of file ossimAdrgTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::CENTRAL_MERIDIAN_KW, ossimKeywordNames::DATUM_KW, ossimImageHandler::getExternalImageGeometry(), ossimImageHandler::getNumberOfDecimationLevels(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfOutputBands(), getNumberOfSamples(), ossimUnitTypeLut::instance(), ossimAdrgHeader::lines(), m_AdrgHeader, ossimAdrgHeader::maxLatitude(), ossimAdrgHeader::maxLongitude(), ossimAdrgHeader::minLatitude(), ossimAdrgHeader::minLongitude(), ossimKeywordNames::NUMBER_INPUT_BANDS_KW, ossimKeywordNames::NUMBER_LINES_KW, ossimKeywordNames::NUMBER_OUTPUT_BANDS_KW, ossimKeywordNames::NUMBER_REDUCED_RES_SETS_KW, ossimKeywordNames::NUMBER_SAMPLES_KW, ossimKeywordNames::ORIGIN_LATITUDE_KW, OSSIM_DEGREES, ossimKeywordNames::PIXEL_SCALE_UNITS_KW, ossimKeywordNames::PIXEL_SCALE_XY_KW, ossimAdrgHeader::samples(), ossimAdrgHeader::startCol(), ossimAdrgHeader::startRow(), ossimImageHandler::theGeometry, ossimKeywordNames::TIE_POINT_LAT_KW, ossimKeywordNames::TIE_POINT_LON_KW, ossimKeywordNames::TIE_POINT_UNITS_KW, ossimKeywordNames::TIE_POINT_XY_KW, and ossimKeywordNames::TYPE_KW.
Note that rrds 0 is the highest resolution rrds.
Definition at line 261 of file ossimAdrgTileSource.cpp.
References getNumberOfLines(), and getNumberOfSamples().
Note: this is not the same as the ossimImageSource::getTileHeight which returns the output tile width which can be different than the internal image tile width on disk.
Implements ossimImageHandler.
Definition at line 632 of file ossimAdrgTileSource.cpp.
References ADRG_TILE_HEIGHT.
Note: this is not the same as the ossimImageSource::getTileWidth which returns the output tile width, which can be different than the internal image tile width on disk.
Definition at line 627 of file ossimAdrgTileSource.cpp.
References ADRG_TILE_WIDTH.
Definition at line 658 of file ossimAdrgTileSource.cpp.
Satisfies pure virtual requirement from ImageHandler class.
Implements ossimImageSource.
Definition at line 663 of file ossimAdrgTileSource.cpp.
References m_AdrgHeader, and ossimAdrgHeader::numberOfBands().
Referenced by getImageGeometry(), and getNumberOfOutputBands().
Definition at line 596 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::getNumberOfLines(), m_AdrgHeader, ossimAdrgHeader::startRow(), ossimAdrgHeader::stopRow(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by getImageGeometry(), and getImageRectangle().
Definition at line 252 of file ossimAdrgTileSource.cpp.
References getNumberOfInputBands().
Referenced by getImageGeometry(), and getTile().
Definition at line 613 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::getNumberOfSamples(), m_AdrgHeader, ossimAdrgHeader::startCol(), ossimAdrgHeader::stopCol(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 572 of file ossimAdrgTileSource.cpp.
References OSSIM_UCHAR.
| name | The name of the property to get. |
Definition at line 637 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::getProperty().
| propertyNames | The list to push back names to. |
Definition at line 647 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::getPropertyNames().
Definition at line 653 of file ossimAdrgTileSource.cpp.
Satisfies pure virtual requirement from TileSource class.
Definition at line 80 of file ossimAdrgTileSource.cpp.
References ossimRefPtr< T >::get(), ossimDataObject::getDataObjectStatus(), m_Tile, ossimImageData::makeBlank(), OSSIM_NULL, ossimImageData::setImageRectangle(), and ossimRefPtr< T >::valid().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. It will be an error if: result.getNumberOfBands() != this->getNumberOfOutputBands() |
Definition at line 101 of file ossimAdrgTileSource.cpp.
References ossimIrect::clipToRect(), fillBuffer(), getImageRectangle(), ossimImageData::getImageRectangle(), ossimImageData::getNumberOfBands(), getNumberOfOutputBands(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), ossimImageData::makeBlank(), ossimReferenced::ref(), status, ossimReferenced::unref(), and ossimImageData::validate().
Definition at line 588 of file ossimAdrgTileSource.cpp.
References ossimImageData::getHeight(), m_Tile, and ossimRefPtr< T >::valid().
Definition at line 580 of file ossimAdrgTileSource.cpp.
References ossimImageData::getWidth(), m_Tile, and ossimRefPtr< T >::valid().
Definition at line 673 of file ossimAdrgTileSource.cpp.
References m_AdrgHeader.
Definition at line 381 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::loadState(), and open().
Definition at line 286 of file ossimAdrgTileSource.cpp.
Referenced by loadState().
Definition at line 371 of file ossimAdrgTileSource.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 191 of file ossimAdrgTileSource.h.
Referenced by close(), fillBuffer(), getImageGeometry(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), isOpen(), and ~ossimAdrgTileSource().
protected |
Definition at line 190 of file ossimAdrgTileSource.h.
Referenced by close(), and fillBuffer().
protected |
Definition at line 188 of file ossimAdrgTileSource.h.
Referenced by close(), getTile(), getTileHeight(), and getTileWidth().
protected |
Definition at line 189 of file ossimAdrgTileSource.h.
Referenced by fillBuffer(), and ~ossimAdrgTileSource().
