Class used for rendering range domes (a.k.a. More...
#include <ossimRangeDomeTileSource.h>
| ossimRangeDomeTileSource () | |
| virtual | ~ossimRangeDomeTileSource () |
| virtual bool | open () |
| Reads CSV file representing range domes. More... | |
| virtual void | close () |
| Deletes the overview and clears the valid image vertices. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Pure virtual, derived classes must implement. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| The reader properties are: – the GSD ("meters_per_pixel") More... | |
| virtual void | getGSD (ossimDpt &gsd, ossim_uint32 resLevel) const |
| virtual void | setGSD (const ossim_float64 &gsd) |
| ossim_uint32 | getNumRangeDomes () const |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
Static Protected Attributes | |
| static const ossimString | OSSIM_RANGE_DOME_SPEC_MAGIC_NUMBER |
"threat domes") as 2-D ortho-images.
This base class has the rudimentary capability of reading range dome specifications as a CSV file in the following format (one line per dome object):
id, lat, lon, hgt, R, C [,Az0, Az1] [, description]
where
id – integer ID of data object lat, lon, hgt – Location of center of dome (actually sphere) in WGS84 R – radius (in meters) of dome boundary C – classification id (unsigned 8-bit) corresponding to area inside r Az0, Az1 – [optional] starting and ending azimuth (clockwise from Az0 in degrees). If both Az0 and Az1 are equal, then 360 deg is implied. description – [optional] string
Definition at line 71 of file ossimRangeDomeTileSource.h.
| ossimRangeDomeTileSource::ossimRangeDomeTileSource | ( | ) |
Definition at line 73 of file ossimRangeDomeTileSource.cpp.
Definition at line 79 of file ossimRangeDomeTileSource.cpp.
References close().
Definition at line 172 of file ossimRangeDomeTileSource.cpp.
References m_rangeDomes, and ossimImageHandler::theGeometry.
Referenced by ~ossimRangeDomeTileSource().
Definition at line 379 of file ossimRangeDomeTileSource.cpp.
References m_gsd, ossimDpt::x, and ossimDpt::y.
inlinevirtual |
The geometry contains full-to-local image transform as well as projection (image-to-world).
Definition at line 97 of file ossimRangeDomeTileSource.h.
References ossimImageHandler::theGeometry.
inlinevirtual |
Implements ossimImageHandler.
Definition at line 93 of file ossimRangeDomeTileSource.h.
inlinevirtual |
Definition at line 92 of file ossimRangeDomeTileSource.h.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 270 of file ossimRangeDomeTileSource.cpp.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 276 of file ossimRangeDomeTileSource.cpp.
References ossimImageGeometry::getImageSize(), ossimImageHandler::theGeometry, ossimRefPtr< T >::valid(), and ossimIpt::y.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 284 of file ossimRangeDomeTileSource.cpp.
References ossimImageGeometry::getImageSize(), ossimImageHandler::theGeometry, ossimRefPtr< T >::valid(), and ossimIpt::x.
inline |
Definition at line 112 of file ossimRangeDomeTileSource.h.
inlinevirtual |
Definition at line 94 of file ossimRangeDomeTileSource.h.
References OSSIM_UINT8.
Definition at line 362 of file ossimRangeDomeTileSource.cpp.
References ossimImageHandler::getProperty(), m_gsd, ossimKeywordNames::METERS_PER_PIXEL_KW, ossimString::toString(), and ossimDpt::x.
Definition at line 179 of file ossimRangeDomeTileSource.cpp.
References ossimImageDataFactory::create(), ossimRefPtr< T >::get(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and ossimImageData::setImageRectangle().
Method to get a tile.
| result | The tile to stuff. Note The requested rectangle in full image space and bands should be set in the result tile prior to passing. This is the default implementation that is not thread-friendly as it uses the object's tile then simply copies its buffer to the provided tile. Eventually, all image sources should override this method. |
Definition at line 193 of file ossimRangeDomeTileSource.cpp.
References ossim::atan2d(), ossimImageData::fill(), ossimImageGeometry::getBoundingRect(), ossimImageData::getImageRectangle(), ossimImageHandler::getNullPixelValue(), ossimIrect::intersects(), m_rangeDomes, OSSIM_EMPTY, ossimDataObject::setDataObjectStatus(), ossimImageData::setValue(), ossimImageHandler::theGeometry, ossimRefPtr< T >::valid(), and ossimImageData::validate().
initialize Does nothing in this class.
Implemented to satisfy pure virtual.
Definition at line 127 of file ossimRangeDomeTileSource.cpp.
References ossimGrect::expandToInclude(), ossimRefPtr< T >::get(), ossimMapProjection::getDecimalDegreesPerPixel(), ossimGrect::height(), isOpen(), m_gsd, m_rangeDomes, ossimGrect::makeNan(), ossimGrect::midPoint(), ossimMapProjection::setElevationLookupFlag(), ossimImageGeometry::setImageSize(), ossimMapProjection::setMetersPerPixel(), ossimMapProjection::setOrigin(), ossimMapProjection::setUlTiePoints(), ossimImageHandler::theGeometry, ossimGrect::ul(), ossimGrect::width(), ossimImageGeometry::worldToLocal(), and ossimDpt::x.
Referenced by open(), and setGSD().
Definition at line 166 of file ossimRangeDomeTileSource.cpp.
References m_rangeDomes.
Referenced by initialize(), and open().
Definition at line 310 of file ossimRangeDomeTileSource.cpp.
References ossimString::empty(), ossimKeywordlist::find(), ossimErrorStatusInterface::getErrorStatus(), ossimImageHandler::loadState(), ossimKeywordNames::METERS_PER_PIXEL_KW, ossimKeywordNames::METERS_PER_PIXEL_Y_KW, open(), ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_WARN, setGSD(), ossimImageHandler::theDecimationFactors, ossimString::toDouble(), and ossimDpt::x.
Definition at line 85 of file ossimRangeDomeTileSource.cpp.
References ossimString::chars(), getline(), initialize(), isOpen(), ossimFilename::isReadable(), m_rangeDomes, OSSIM_RANGE_DOME_SPEC_MAGIC_NUMBER, ossimNotify(), ossimNotifyLevel_WARN, ossimString::size(), ossimString::split(), ossimImageHandler::theImageFile, and ossimRangeDome::valid.
Referenced by loadState().
Definition at line 292 of file ossimRangeDomeTileSource.cpp.
References ossimKeywordlist::add(), ossimErrorStatusInterface::getErrorStatus(), m_gsd, ossimKeywordNames::METERS_PER_PIXEL_KW, ossimErrorCodes::OSSIM_ERROR, ossimNotify(), ossimNotifyLevel_WARN, ossimImageHandler::saveState(), and ossimDpt::x.
Definition at line 386 of file ossimRangeDomeTileSource.cpp.
References initialize(), m_gsd, ossimDpt::x, and ossimDpt::y.
Referenced by loadState(), and setProperty().
Definition at line 338 of file ossimRangeDomeTileSource.cpp.
References ossimString::empty(), ossimProperty::getName(), ossim::isnan(), ossimKeywordNames::METERS_PER_PIXEL_KW, setGSD(), ossimImageHandler::setProperty(), ossimString::toFloat64(), and ossimRefPtr< T >::valid().
protected |
Definition at line 116 of file ossimRangeDomeTileSource.h.
Referenced by getGSD(), getProperty(), initialize(), saveState(), and setGSD().
protected |
Definition at line 115 of file ossimRangeDomeTileSource.h.
Referenced by close(), getTile(), initialize(), isOpen(), and open().
staticprotected |
Definition at line 118 of file ossimRangeDomeTileSource.h.
Referenced by open().
