#include <ossimNitfTileSource.h>
Public Types | |
| enum | ReadMode { READ_MODE_UNKNOWN = 0, READ_BIB_BLOCK = 1, READ_BIP_BLOCK = 2, READ_BIR_BLOCK = 3, READ_BSQ_BLOCK = 4, READ_BIB = 5, READ_BIP = 6, READ_BIR = 7, READ_JPEG_BLOCK = 8 } |
| ossimNitfTileSource () | |
| virtual bool | open () |
| Returns true if the image_file can be opened and is a valid nitf file. More... | |
| bool | open (std::shared_ptr< ossim::istream > &str, const std::string &connectionString) |
| This open takes a stream and stores/captures the shared pointer on success. More... | |
| virtual void | close () |
| Closes file and destroys all memory allocated. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| Returns the number of lines in the image. More... | |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| Returns the number of samples in the image. More... | |
| Returns the output pixel type of the tile source. More... | |
| Returns the width of the output tile. More... | |
| Returns the height of the output tile. More... | |
| ossim_uint32 | getNumberOfEntries () const |
| ossimString | getSecurityClassification () const |
| bool | getCacheEnabledFlag () const |
| void | setCacheEnabledFlag (bool flag) |
| const ossimNitfFileHeader * | getFileHeader () const |
| ossimNitfFileHeader * | getFileHeader () |
| const ossimNitfImageHeader * | getCurrentImageHeader () const |
| ossimNitfImageHeader * | getCurrentImageHeader () |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual | ~ossimNitfTileSource () |
| void | setBoundingRectangle (const ossimIrect &imageRect) |
| ossimNitfTileSource (const ossimNitfTileSource &obj) | |
| Copy constructor, disallow... More... | |
| ossimNitfTileSource & | operator= (const ossimNitfTileSource &rhs) |
| Operator=, disallow... More... | |
| bool | loadTile (const ossimIrect &clipRect) |
| Returns true on success, false on error. More... | |
| ossim_uint32 | getBlockNumber (const ossimIpt &block_origin) const |
| void | destroy () |
| Deletes all memory allocated by this object. More... | |
| virtual bool | parseFile () |
| Parses "theImageFile" and initializes all nitf headers. More... | |
| virtual bool | allocate () |
| Allocates everything for current entry. More... | |
| virtual bool | allocateBuffers () |
| Allocates buffers for current entry. More... | |
| virtual bool | canUncompress (const ossimNitfImageHeader *hdr) const |
| virtual void | initializeScalarType () |
| Initializes the data member "theScalarType" from the current entry. More... | |
| virtual void | initializeSwapBytesFlag () |
| Initializes the data member "theSwapBytesFlag" from the current entry. More... | |
| virtual void | initializeReadMode () |
| Initializes the data member "theReadMode" from the current entry. More... | |
| void | initializeBandCount () |
| Initializes the data member "theNumberOfBands" from the current entry. More... | |
| bool | initializeBlockSize () |
| Initializes the data member "theBlockSize" from the current entry. More... | |
| virtual bool | initializeImageRect () |
| Initializes the data members "theImageRect" and "theBlockRect" from the current entry. More... | |
| void | initializeCacheSize () |
| Initializes the data member "theCacheSize". More... | |
| virtual void | initializeCacheTileInterLeaveType () |
| Initializes the data member "theCacheTileInterLeaveType". More... | |
| void | initializeCacheTile () |
| Initializes the cache tile size(width and height). More... | |
| virtual void | initializeCompressedBuf () |
| Initializes the data member theCompressedBuf. More... | |
| virtual void | initializeOutputTile () |
| Initializes the output tile size(width and height). More... | |
| void | initializeLut () |
| Initializes "theLut" if applicable. More... | |
| bool | loadBlockFromCache (ossim_uint32 x, ossim_uint32 y, const ossimIrect &clipRect) |
| Loads a block of data to theCacheTile. More... | |
| virtual bool | loadBlock (ossim_uint32 x, ossim_uint32 y) |
| bool | getPosition (std::streamoff &position, ossim_uint32 x, ossim_uint32 y, ossim_uint32 band) const |
| ossim_uint32 | getNumberOfBlocks () const |
| std::streampos | getBandOffset () const |
| std::streampos | getBlockOffset () const |
| void | explodePackedBits (ossimRefPtr< ossimImageData > packedBuffer) const |
| void | convertTransparentToNull (ossimRefPtr< ossimImageData > tile) const |
| ossim_uint32 | getPartialReadSize (const ossimIpt &blockOrigin) const |
| bool | isVqCompressed (const ossimString &compressionCode) const |
| void | vqUncompressC4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization unmasked image data. More... | |
| void | vqUncompressM4 (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| Uncompresses Vector Quantization masked image data. More... | |
| void | lutUncompress (ossimRefPtr< ossimImageData > destination, ossim_uint8 *source) |
| virtual bool | scanForJpegBlockOffsets () |
| scans the file storing in offsets in "theNitfBlockOffset" and block sizes in "theNitfBlockSize". More... | |
| virtual bool | uncompressJpegBlock (ossim_uint32 x, ossim_uint32 y) |
| Uncompresses a jpeg block using the jpeg-6b library. More... | |
| bool | loadJpegQuantizationTables (jpeg_decompress_struct &cinfo) const |
| Loads one of the default tables based on COMRAT value. More... | |
| bool | loadJpegHuffmanTables (jpeg_decompress_struct &cinfo) const |
| Loads default huffman tables. More... | |
Definition at line 29 of file ossimNitfTileSource.h.
Definition at line 33 of file ossimNitfTileSource.h.
| ossimNitfTileSource::ossimNitfTileSource | ( | ) |
Definition at line 88 of file ossimNitfTileSource.cpp.
protectedvirtual |
Definition at line 129 of file ossimNitfTileSource.cpp.
References destroy().
protected |
Definition at line 3734 of file ossimNitfTileSource.cpp.
protectedvirtual |
This is called on an open() or a entry change to an already open nitf file.
This does not allocate buffers and tiles to keep open and setCurrentEntry times to a minimum. Buffers are allocated on first grab of pixel data by allocatBuffers method.
Reimplemented in ossimKakaduNitfReader.
Definition at line 587 of file ossimNitfTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), initializeBandCount(), initializeBlockSize(), initializeCacheSize(), initializeCacheTileInterLeaveType(), initializeImageRect(), initializeReadMode(), initializeScalarType(), initializeSwapBytesFlag(), ossimAppFixedTileCache::instance(), OSSIM_INTERLEAVE_UNKNOWN, OSSIM_SCALAR_UNKNOWN, READ_MODE_UNKNOWN, theCacheId, theCacheSize, theCacheTile, theCacheTileInterLeaveType, theCompressedBuf, theNumberOfInputBands, theReadMode, theScalarType, theTile, ossimIpt::x, and ossimIpt::y.
Referenced by setCurrentEntry().
protectedvirtual |
This is called on first getTile().
Definition at line 658 of file ossimNitfTileSource.cpp.
References initializeCacheTile(), initializeCompressedBuf(), initializeOutputTile(), ossimAppFixedTileCache::instance(), theBlockImageRect, theCacheEnabledFlag, theCacheId, theCacheSize, theCacheTile, and ossimRefPtr< T >::valid().
Referenced by ossimKakaduNitfReader::allocateBuffers(), and getTile().
protectedvirtual |
| hdr | Pointer to image header. |
Reimplemented in ossimKakaduNitfReader, ossimJpeg12NitfReader, and ossimOpjNitfReader.
Definition at line 690 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getBitsPerPixelPerBand(), and ossimNitfImageHeader::getCompressionCode().
Referenced by ossimJpeg12NitfReader::canUncompress(), and ossimKakaduNitfReader::canUncompress().
Definition at line 362 of file ossimNitfTileSource.cpp.
Referenced by open(), ossimKakaduNitfReader::~ossimKakaduNitfReader(), and ossimOpjNitfReader::~ossimOpjNitfReader().
protected |
Definition at line 1976 of file ossimNitfTileSource.cpp.
References getBlockNumber(), ossimImageData::getBuf(), getCurrentImageHeader(), ossimImageData::getHeight(), ossimImageData::getNullPix(), ossimImageData::getNumberOfBands(), ossimImageData::getOrigin(), ossimNitfImageHeader::getPadPixelMaskRecordOffset(), ossimRectilinearDataObject::getScalarType(), ossimNitfImageHeader::getTransparentCode(), ossimImageData::getWidth(), ossimNitfImageHeader::hasPadPixelMaskRecords(), ossimNitfImageHeader::hasTransparentCode(), OSSIM_SINT16, OSSIM_UINT16, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, and OSSIM_USHORT15.
protected |
Definition at line 134 of file ossimNitfTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theCacheId, theCacheTile, theFileStr, theNitfFile, theNitfImageHeader, ossimImageHandler::theOverview, and theTile.
Referenced by close(), and ~ossimNitfTileSource().
protectedvirtual |
Virtual method determines the decimation factors at each resolution level.
This method derives the decimations from the image metadata.
Definition at line 1178 of file ossimNitfTileSource.cpp.
References ossimImageHandler::establishDecimationFactors(), getCurrentImageHeader(), ossimNitfImageHeader::getDecimationFactor(), ossim::isnan(), and ossimImageHandler::theDecimationFactors.
protected |
Definition at line 1898 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getBitsPerPixelPerBand(), ossimImageData::getBuf(), getCurrentImageHeader(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getSizePerBandInBytes(), ossimPackedBits::getValueAsUint32(), ossimImageData::getWidth(), OSSIM_FLOAT, OSSIM_UINT16, OSSIM_UINT8, and theCacheTile.
protected |
Definition at line 2232 of file ossimNitfTileSource.cpp.
References getNumberOfBlocks(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, theBlockSizeInBytes, and theReadMode.
Referenced by getPosition().
protected |
Definition at line 2471 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfBlocksPerRow(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, theCacheSize, theReadMode, ossimIpt::x, and ossimIpt::y.
Referenced by convertTransparentToNull(), getPosition(), ossimJpeg12NitfReader::uncompressJpegBlock(), ossimOpjNitfReader::uncompressJpegBlock(), and uncompressJpegBlock().
protected |
Definition at line 2258 of file ossimNitfTileSource.cpp.
References getNumberOfBlocks(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, theBlockSizeInBytes, theNumberOfInputBands, theReadBlockSizeInBytes, and theReadMode.
| bool ossimNitfTileSource::getCacheEnabledFlag | ( | ) | const |
Definition at line 2681 of file ossimNitfTileSource.cpp.
References theCacheEnabledFlag.
Definition at line 2607 of file ossimNitfTileSource.cpp.
References theCurrentEntry.
| const ossimNitfImageHeader * ossimNitfTileSource::getCurrentImageHeader | ( | ) | const |
Definition at line 2731 of file ossimNitfTileSource.cpp.
References theCurrentEntry, and theNitfImageHeader.
Referenced by ossimNitf20Writer::addTags(), ossimKakaduNitfReader::checkJp2Signature(), convertTransparentToNull(), ossimNitfProjectionFactory::createProjection(), ossimImageGeometryFactory::createTransformFromNitf(), ossimKakaduNitfReader::dumpTiles(), establishDecimationFactors(), explodePackedBits(), getBlockNumber(), getImageTileHeight(), getImageTileWidth(), getMaxPixelValue(), getNumberOfBlocks(), getNumberOfLines(), getNumberOfSamples(), getPartialReadSize(), getPosition(), getProperty(), getPropertyNames(), getRgbBandList(), getSecurityClassification(), initializeBandCount(), initializeBlockSize(), initializeCacheSize(), initializeCacheTileInterLeaveType(), initializeCompressedBuf(), initializeImageRect(), initializeLut(), ossimOpjNitfReader::initializeReadMode(), ossimKakaduNitfReader::initializeReadMode(), initializeReadMode(), initializeScalarType(), ossimKakaduNitfReader::isEntryJ2k(), ossimJpeg12NitfReader::loadJpeg12QuantizationTables(), loadJpegQuantizationTables(), lutUncompress(), ossimOpjNitfReader::scanForJpegBlockOffsets(), ossimKakaduNitfReader::scanForJpegBlockOffsets(), scanForJpegBlockOffsets(), vqUncompressC4(), and vqUncompressM4().
Definition at line 2741 of file ossimNitfTileSource.cpp.
| entryList | This is the list to initialize with entry indexes. |
Definition at line 2617 of file ossimNitfTileSource.cpp.
References theEntryList.
| const ossimNitfFileHeader * ossimNitfTileSource::getFileHeader | ( | ) | const |
Definition at line 2711 of file ossimNitfTileSource.cpp.
References ossimNitfFile::getHeader(), theNitfFile, and ossimRefPtr< T >::valid().
Referenced by ossimNitf20Writer::addTags(), ossimNitfProjectionFactory::createProjection(), getProperty(), and getPropertyNames().
Definition at line 2721 of file ossimNitfTileSource.cpp.
Implements ossimImageHandler.
Definition at line 2584 of file ossimNitfTileSource.cpp.
References ossimImageHandler::getBoundingRect(), getCurrentImageHeader(), and ossimNitfImageHeader::getNumberOfPixelsPerBlockVert().
Definition at line 2570 of file ossimNitfTileSource.cpp.
References ossimImageHandler::getBoundingRect(), getCurrentImageHeader(), and ossimNitfImageHeader::getNumberOfPixelsPerBlockHoriz().
Definition at line 2602 of file ossimNitfTileSource.cpp.
Definition at line 2076 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getActualBitsPerPixelPerBand(), ossimNitfImageHeader::getBitsPerPixelPerBand(), getCurrentImageHeader(), ossimImageHandler::getMaxPixelValue(), and thePackedBitsFlag.
Referenced by getNullPixelValue().
Retuns the min pixel value.
If there was an external eta data file then use the meta data from that file. If not given then we will return the default min
Definition at line 2064 of file ossimNitfTileSource.cpp.
References ossimImageHandler::getMinPixelValue(), and thePackedBitsFlag.
Definition at line 2119 of file ossimNitfTileSource.cpp.
References getMaxPixelValue(), ossimImageHandler::getNullPixelValue(), and thePackedBitsFlag.
protected |
Definition at line 2298 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfBlocksPerCol(), and ossimNitfImageHeader::getNumberOfBlocksPerRow().
Referenced by getBandOffset(), getBlockOffset(), initializeCacheSize(), and initializeReadMode().
Definition at line 2612 of file ossimNitfTileSource.cpp.
Implements ossimImageSource.
Definition at line 2425 of file ossimNitfTileSource.cpp.
References theNumberOfInputBands.
Satisfies pure virtual from ImageHandler class.
Definition at line 2435 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), ossimImageHandler::getNumberOfLines(), ossimNitfImageHeader::getNumberOfRows(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by ossimKakaduNitfReader::getNumberOfLines().
Definition at line 2430 of file ossimNitfTileSource.cpp.
References theNumberOfOutputBands.
Referenced by ossimKakaduNitfReader::allocateBuffers(), ossimKakaduNitfReader::getOverviewTile(), and getRgbBandList().
Definition at line 2453 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfCols(), ossimImageHandler::getNumberOfSamples(), ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Referenced by ossimKakaduNitfReader::getNumberOfSamples().
Definition at line 2370 of file ossimNitfTileSource.cpp.
References theScalarType.
protected |
Definition at line 2518 of file ossimNitfTileSource.cpp.
References ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimNitfImageHeader::getBitsPerPixelPerBand(), getCurrentImageHeader(), ossimImageData::getImageRectangle(), ossimIrect::height(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, theBlockImageRect, theCacheSize, theCacheTile, theNumberOfInputBands, theReadBlockSizeInBytes, theReadMode, and ossimIpt::x.
protected |
| x | Horizontal upper left pixel position of the requested block. |
| y | Vertical upper left pixel position of the requested block. |
| band | Band of block. Only relative with IMODES that have bands in separate blocks. |
Definition at line 2137 of file ossimNitfTileSource.cpp.
References getBandOffset(), ossimNitfImageHeader::getBlockMaskRecordOffset(), getBlockNumber(), getBlockOffset(), getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), ossimNitfImageHeader::hasBlockMaskRecords(), READ_BIB, READ_BIB_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, theReadBlockSizeInBytes, theReadMode, x, and y.
Definition at line 2810 of file ossimNitfTileSource.cpp.
References ossimKeywordNames::ENABLE_CACHE_KW, getCurrentImageHeader(), getFileHeader(), ossimNitfFile::getHeader(), ossimNitfImageHeader::getProperty(), ossimNitfFileHeader::getProperty(), ossimImageHandler::getProperty(), ossimProperty::setReadOnlyFlag(), theCacheEnabledFlag, theNitfFile, and ossimRefPtr< T >::valid().
Definition at line 2867 of file ossimNitfTileSource.cpp.
References ossimKeywordNames::ENABLE_CACHE_KW, getCurrentImageHeader(), getFileHeader(), ossimNitfImageHeader::getPropertyNames(), ossimNitfFileHeader::getPropertyNames(), and ossimImageHandler::getPropertyNames().
Convenience method to get the zero based rgb output band list.
Attempts to derive RGB bands from nitf fields.
| bandList | Initialized by this. |
Definition at line 2751 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getBandInformation(), ossimNitfImageBand::getBandRepresentation(), getCurrentImageHeader(), getNumberOfOutputBands(), ossimString::trim(), ossimString::upcase(), and ossimRefPtr< T >::valid().
| ossimString ossimNitfTileSource::getSecurityClassification | ( | ) | const |
Definition at line 2882 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), and ossimNitfImageHeader::getSecurityClassification().
Definition at line 2597 of file ossimNitfTileSource.cpp.
| tileRect | Requested rectangle. |
| resLevel | Reduced resolution level to grab tileRect from. Default = 0 or the full resolution data set. |
Definition at line 1532 of file ossimNitfTileSource.cpp.
References allocateBuffers(), ossimIrect::clipToRect(), ossimIrect::completely_within(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimDataObject::getDataObjectStatus(), ossimImageData::getImageRectangle(), ossimImageHandler::getOverviewTile(), ossimIrect::intersects(), isOpen(), ossimSource::isSourceEnabled(), ossimImageHandler::isValidRLevel(), loadTile(), ossimImageData::loadTile(), ossimImageData::makeBlank(), OSSIM_EMPTY, ossimNotify(), ossimNotifyLevel_WARN, ossimImageData::setImageRectangle(), theBlockImageRect, theCacheTile, theCacheTileInterLeaveType, theImageRect, ossimImageHandler::theStartingResLevel, theTile, ossimRefPtr< T >::valid(), and ossimImageData::validate().
Definition at line 2400 of file ossimNitfTileSource.cpp.
References ossim::defaultTileSize(), ossimImageHandler::getBoundingRect(), ossimIpt::hasNans(), ossimIrect::height(), theCacheSize, and ossimIpt::y.
Definition at line 2375 of file ossimNitfTileSource.cpp.
References ossim::defaultTileSize(), ossimImageHandler::getBoundingRect(), ossimIpt::hasNans(), theCacheSize, ossimIrect::width(), and ossimIpt::x.
protected |
Definition at line 973 of file ossimNitfTileSource.cpp.
References ossimString::contains(), ossimNitfImageHeader::getBandInformation(), ossimNitfImageHeader::getCompressionCode(), getCurrentImageHeader(), ossimNitfImageHeader::getNumberOfBands(), ossimNitfImageBand::getNumberOfLuts(), ossimNitfImageHeader::getRepresentation(), isVqCompressed(), theNumberOfInputBands, theNumberOfOutputBands, theOutputBandList, and ossimRefPtr< T >::valid().
Referenced by allocate().
protected |
Definition at line 1027 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getCompressionCode(), getCurrentImageHeader(), isVqCompressed(), theBlockSizeInBytes, and theReadBlockSizeInBytes.
protected |
Definition at line 1373 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), getNumberOfBlocks(), ossimNitfImageHeader::getNumberOfPixelsPerBlockHoriz(), ossimNitfImageHeader::getNumberOfPixelsPerBlockVert(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, theCacheSize, theReadMode, ossimIpt::x, and ossimIpt::y.
protected |
For block images this will be the size of one block. For images that are a single block, this will be the image width by the height of one tile.
Definition at line 1480 of file ossimNitfTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), theCacheSize, theCacheTile, theNumberOfOutputBands, theScalarType, ossimIpt::x, and ossimIpt::y.
Referenced by allocateBuffers().
protectedvirtual |
Definition at line 1435 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), OSSIM_BIL, OSSIM_BIP, OSSIM_BSQ, OSSIM_INTERLEAVE_UNKNOWN, READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, theCacheTileInterLeaveType, and theReadMode.
Referenced by allocate(), and ossimKakaduNitfReader::initializeCacheTileInterLeaveType().
protectedvirtual |
Reimplemented in ossimOpjNitfReader.
Definition at line 1492 of file ossimNitfTileSource.cpp.
References ossimString::contains(), ossimNitfImageHeader::getCompressionCode(), getCurrentImageHeader(), ossimNitfImageHeader::getRepresentation(), isVqCompressed(), theCompressedBuf, theReadBlockSizeInBytes, and ossimString::upcase().
protectedvirtual |
Definition at line 1347 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getBlockImageRect(), getCurrentImageHeader(), ossimNitfImageHeader::getImageRect(), ossimIrect::makeNan(), theBlockImageRect, and theImageRect.
protected |
Definition at line 1517 of file ossimNitfTileSource.cpp.
References getCurrentImageHeader(), ossimNitfImageHeader::hasLut(), theCurrentEntry, ossimImageHandler::theLut, and theNitfImageHeader.
protectedvirtual |
Definition at line 1508 of file ossimNitfTileSource.cpp.
References ossimImageDataFactory::create(), ossimImageData::initialize(), ossimImageDataFactory::instance(), and theTile.
protectedvirtual |
Reimplemented in ossimKakaduNitfReader, and ossimOpjNitfReader.
Definition at line 730 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getCompressionCode(), getCurrentImageHeader(), ossimNitfImageHeader::getIMode(), getNumberOfBlocks(), READ_BIB, READ_BIB_BLOCK, READ_BIP, READ_BIP_BLOCK, READ_BIR, READ_BIR_BLOCK, READ_BSQ_BLOCK, READ_JPEG_BLOCK, READ_MODE_UNKNOWN, and theReadMode.
Referenced by allocate(), and ossimKakaduNitfReader::initializeReadMode().
protectedvirtual |
Definition at line 798 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getActualBitsPerPixelPerBand(), ossimNitfImageHeader::getBitsPerPixelPerBand(), getCurrentImageHeader(), ossimNitfImageHeader::getPixelValueType(), ossimNitfImageHeader::isCompressed(), OSSIM_FLOAT32, OSSIM_FLOAT64, OSSIM_SCALAR_UNKNOWN, OSSIM_SINT16, OSSIM_SINT32, OSSIM_UINT16, OSSIM_UINT8, OSSIM_USHORT11, OSSIM_USHORT12, OSSIM_USHORT13, OSSIM_USHORT14, OSSIM_USHORT15, thePackedBitsFlag, theScalarType, and ossimString::upcase().
protectedvirtual |
Definition at line 960 of file ossimNitfTileSource.cpp.
References ossim::byteOrder(), OSSIM_LITTLE_ENDIAN, OSSIM_UINT8, theScalarType, and theSwapBytesFlag.
Referenced by allocate(), and ossimKakaduNitfReader::initializeSwapBytesFlag().
Definition at line 161 of file ossimNitfTileSource.cpp.
References theNitfImageHeader.
Referenced by getTile(), open(), and setCurrentEntry().
protected |
Definition at line 2563 of file ossimNitfTileSource.cpp.
Referenced by initializeBandCount(), initializeBlockSize(), and initializeCompressedBuf().
protectedvirtual |
| x | Starting x position of block to load. |
| y | Starting y position of block to load. |
Definition at line 1741 of file ossimNitfTileSource.cpp.
Referenced by ossimKakaduNitfReader::loadBlock(), and loadTile().
protected |
Definition at line 1704 of file ossimNitfTileSource.cpp.
References ossimIrect::clipToRect(), ossimRefPtr< T >::get(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), ossimAppFixedTileCache::getTile(), ossimAppFixedTileCache::instance(), ossimImageData::loadTile(), theCacheEnabledFlag, theCacheId, theCacheTileInterLeaveType, theTile, ossimRefPtr< T >::valid(), x, and y.
Referenced by loadTile().
protected |
Definition at line 3689 of file ossimNitfTileSource.cpp.
protected |
Definition at line 3629 of file ossimNitfTileSource.cpp.
References ossimNitfImageHeader::getCompressionRateCode(), getCurrentImageHeader(), ossimNotify(), ossimNotifyLevel_WARN, ossimString::push_back(), ossimString::size(), and ossimString::toInt32().
Reimplemented in ossimQuickbirdNitfTileSource.
Definition at line 2310 of file ossimNitfTileSource.cpp.
References ossimImageHandler::loadState().
Referenced by ossimQuickbirdNitfTileSource::loadState().
protected |
Definition at line 1648 of file ossimNitfTileSource.cpp.
References ossimIrect::clipToRect(), ossimImageData::getBuf(), ossimImageData::getImageRectangle(), loadBlock(), loadBlockFromCache(), ossimImageData::loadTile(), ossimIrect::lr(), ossimIrect::stretchToTileBoundary(), theCacheSize, theCacheTile, theCacheTileInterLeaveType, theTile, ossimIrect::ul(), ossimIpt::x, x, ossimIpt::y, and y.
Referenced by getTile().
protected |
Definition at line 2892 of file ossimNitfTileSource.cpp.
References ossimImageData::getBuf(), getCurrentImageHeader(), ossimImageData::getHeight(), ossimImageData::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfBands(), ossimRectilinearDataObject::getScalarType(), ossimImageData::getWidth(), OSSIM_UINT8, ossimImageHandler::theLut, and ossimRefPtr< T >::valid().
Definition at line 167 of file ossimNitfTileSource.cpp.
References close(), ossim::StreamFactoryRegistry::createIstream(), ossimImageHandler::getFilename(), ossim::StreamFactoryRegistry::instance(), isOpen(), ossimErrorCodes::OSSIM_OK, and ossimErrorStatusInterface::theErrorStatus.
Referenced by ossimImageHandlerFactory::open(), ossimKakaduReaderFactory::open(), and ossimKakaduReaderFactory::openOverview().
| bool ossimNitfTileSource::open | ( | std::shared_ptr< ossim::istream > & | str, |
| const std::string & | connectionString | ||
| str | Open stream to image. |
| connectionString | Stored on success as the file name. |
Definition at line 193 of file ossimNitfTileSource.cpp.
protected |
Definition at line 3739 of file ossimNitfTileSource.cpp.
protectedvirtual |
Definition at line 367 of file ossimNitfTileSource.cpp.
References ossimImageHandler::getFilename().
Definition at line 2357 of file ossimNitfTileSource.cpp.
References ossimKeywordlist::add(), ossimKeywordNames::ENABLE_CACHE_KW, ossimImageHandler::saveState(), theCacheEnabledFlag, and theCurrentEntry.
Referenced by ossimQuickbirdNitfTileSource::saveState().
protectedvirtual |
Definition at line 3206 of file ossimNitfTileSource.cpp.
References ossim::byteOrder(), getCurrentImageHeader(), ossimNitfImageHeader::getDataLocation(), ossimNitfImageHeader::getNumberOfBlocksPerCol(), ossimNitfImageHeader::getNumberOfBlocksPerRow(), OSSIM_LITTLE_ENDIAN, ossimNotify(), ossimNotifyLevel_WARN, READ_JPEG_BLOCK, ossimEndian::swap(), theCurrentEntry, theFileStr, theNitfBlockOffset, theNitfBlockSize, and theReadMode.
protected |
| imageRect | The full resolution image rectangle. |
Definition at line 2803 of file ossimNitfTileSource.cpp.
References theBlockImageRect, theImageRect, and ossimIrect::ul().
| void ossimNitfTileSource::setCacheEnabledFlag | ( | bool | flag | ) |
| flag | Sets theCacheEnabledFlag and disables/enables caching accordingly. If cache is disabled it is also flushed at the same time. If cache is enabled, blocks read from the image will be cached. |
Definition at line 2686 of file ossimNitfTileSource.cpp.
References ossimAppFixedTileCache::deleteCache(), ossimAppFixedTileCache::instance(), theBlockImageRect, theCacheEnabledFlag, theCacheId, and theCacheSize.
Referenced by setProperty().
| entryIdx | Zero base entry number to select. Sets data member "theCurrentEntry". |
Definition at line 2627 of file ossimNitfTileSource.cpp.
References allocate(), ossimString::clear(), ossimImageHandler::completeOpen(), isOpen(), theCurrentEntry, ossimImageHandler::theGeometry, ossimImageHandler::theLut, theNitfImageHeader, theNumberOfImages, theOutputBandList, and ossimImageHandler::theOverviewFile.
Definition at line 2846 of file ossimNitfTileSource.cpp.
References ossimKeywordNames::ENABLE_CACHE_KW, ossimRefPtr< T >::get(), ossimBooleanProperty::getBoolean(), PTR_CAST, setCacheEnabledFlag(), and ossimImageHandler::setProperty().
protectedvirtual |
This method does eight bit jpeg compressed blocks. Note there is specialized jpeg12 plugin for 12 bit.
| x | sample location in image space. |
| y | line location in image space. |
Reimplemented in ossimOpjNitfReader, and ossimJpeg12NitfReader.
Definition at line 3397 of file ossimNitfTileSource.cpp.
References getBlockNumber(), x, and y.
protected |
IC field = C4
| destination | tile to stuff. |
| source | Pointer to compressed data. |
Definition at line 2937 of file ossimNitfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimNitfImageHeader::getBandInformation(), ossimImageData::getBuf(), ossimNitfImageHeader::getCompressionHeader(), getCurrentImageHeader(), ossimNitfVqCompressionHeader::getImageCodeBitLength(), ossimNitfImageBand::getLut(), ossimImageData::getNumberOfBands(), ossimNBandLutDataObject::getNumberOfBands(), ossimNitfVqCompressionHeader::getNumberOfImageCodesPerRow(), ossimNitfVqCompressionHeader::getNumberOfImageRows(), ossimRectilinearDataObject::getScalarType(), ossimNitfVqCompressionHeader::getTable(), ossimImageData::getWidth(), OSSIM_UINT8, PTR_CAST, ossimImageHandler::theLut, and ossimRefPtr< T >::valid().
protected |
IC field = M4
Definition at line 3051 of file ossimNitfTileSource.cpp.
References ossimRefPtr< T >::get(), ossimNitfImageHeader::getBandInformation(), ossimImageData::getBuf(), ossimNitfImageHeader::getCompressionHeader(), getCurrentImageHeader(), ossimNitfVqCompressionHeader::getImageCodeBitLength(), ossimNitfImageBand::getLut(), ossimImageData::getNumberOfBands(), ossimNitfVqCompressionHeader::getNumberOfImageCodesPerRow(), ossimNitfVqCompressionHeader::getNumberOfImageRows(), ossimRectilinearDataObject::getScalarType(), ossimNitfVqCompressionHeader::getTable(), ossimImageData::getWidth(), OSSIM_UINT8, PTR_CAST, and ossimRefPtr< T >::valid().
protected |
Definition at line 548 of file ossimNitfTileSource.h.
protected |
Definition at line 534 of file ossimNitfTileSource.h.
Referenced by allocateBuffers(), getPartialReadSize(), getTile(), initializeImageRect(), setBoundingRectangle(), and setCacheEnabledFlag().
protected |
Definition at line 520 of file ossimNitfTileSource.h.
Referenced by getBandOffset(), getBlockOffset(), and initializeBlockSize().
protected |
Definition at line 530 of file ossimNitfTileSource.h.
Referenced by allocateBuffers(), getCacheEnabledFlag(), getProperty(), loadBlockFromCache(), saveState(), and setCacheEnabledFlag().
protected |
Definition at line 532 of file ossimNitfTileSource.h.
Referenced by allocate(), allocateBuffers(), destroy(), ossimKakaduNitfReader::loadBlock(), loadBlockFromCache(), and setCacheEnabledFlag().
protected |
Definition at line 528 of file ossimNitfTileSource.h.
Referenced by allocate(), allocateBuffers(), getBlockNumber(), getPartialReadSize(), getTileHeight(), getTileWidth(), initializeCacheSize(), initializeCacheTile(), ossimKakaduNitfReader::loadBlock(), loadTile(), and setCacheEnabledFlag().
protected |
Definition at line 512 of file ossimNitfTileSource.h.
Referenced by allocate(), ossimKakaduNitfReader::allocateBuffers(), allocateBuffers(), destroy(), explodePackedBits(), getPartialReadSize(), getTile(), initializeCacheTile(), ossimKakaduNitfReader::loadBlock(), loadTile(), ossimKakaduNitfReader::setMaxPixelValue(), ossimKakaduNitfReader::setMinPixelValue(), and ossimKakaduNitfReader::setNullPixelValue().
protected |
Definition at line 529 of file ossimNitfTileSource.h.
Referenced by allocate(), getTile(), ossimKakaduNitfReader::initializeCacheTileInterLeaveType(), initializeCacheTileInterLeaveType(), loadBlockFromCache(), and loadTile().
protected |
Definition at line 535 of file ossimNitfTileSource.h.
Referenced by allocate(), ossimOpjNitfReader::initializeCompressedBuf(), and initializeCompressedBuf().
protected |
Definition at line 523 of file ossimNitfTileSource.h.
Referenced by getCurrentEntry(), getCurrentImageHeader(), initializeLut(), saveState(), scanForJpegBlockOffsets(), and setCurrentEntry().
protected |
Definition at line 531 of file ossimNitfTileSource.h.
Referenced by getEntryList(), and getNumberOfEntries().
protected |
Definition at line 525 of file ossimNitfTileSource.h.
Referenced by ossimKakaduNitfReader::checkJp2Signature(), destroy(), ossimKakaduNitfReader::dumpTiles(), ossimKakaduNitfReader::get_pos(), ossimKakaduNitfReader::read(), ossimOpjNitfReader::scanForJpegBlockOffsets(), ossimKakaduNitfReader::scanForJpegBlockOffsets(), scanForJpegBlockOffsets(), and ossimKakaduNitfReader::seek().
protected |
Definition at line 524 of file ossimNitfTileSource.h.
Referenced by getTile(), initializeImageRect(), and setBoundingRectangle().
protected |
Definition at line 541 of file ossimNitfTileSource.h.
Referenced by ossimOpjNitfReader::scanForJpegBlockOffsets(), and scanForJpegBlockOffsets().
protected |
Definition at line 542 of file ossimNitfTileSource.h.
Referenced by ossimOpjNitfReader::initializeCompressedBuf(), ossimOpjNitfReader::scanForJpegBlockOffsets(), and scanForJpegBlockOffsets().
protected |
Definition at line 513 of file ossimNitfTileSource.h.
Referenced by destroy(), getFileHeader(), and getProperty().
protected |
Definition at line 514 of file ossimNitfTileSource.h.
Referenced by destroy(), getCurrentImageHeader(), initializeLut(), isOpen(), and setCurrentEntry().
protected |
Definition at line 522 of file ossimNitfTileSource.h.
protected |
Definition at line 518 of file ossimNitfTileSource.h.
Referenced by allocate(), getBlockOffset(), getNumberOfInputBands(), getPartialReadSize(), and initializeBandCount().
protected |
Definition at line 519 of file ossimNitfTileSource.h.
Referenced by ossimKakaduNitfReader::configureChannelMapping(), getNumberOfOutputBands(), initializeBandCount(), and initializeCacheTile().
protected |
Definition at line 527 of file ossimNitfTileSource.h.
Referenced by initializeBandCount(), and setCurrentEntry().
protected |
Definition at line 533 of file ossimNitfTileSource.h.
Referenced by getMaxPixelValue(), getMinPixelValue(), getNullPixelValue(), and initializeScalarType().
protected |
Definition at line 521 of file ossimNitfTileSource.h.
Referenced by getBlockOffset(), getPartialReadSize(), getPosition(), initializeBlockSize(), and initializeCompressedBuf().
protected |
Definition at line 515 of file ossimNitfTileSource.h.
Referenced by allocate(), getBandOffset(), getBlockNumber(), getBlockOffset(), getPartialReadSize(), getPosition(), initializeCacheSize(), initializeCacheTileInterLeaveType(), ossimOpjNitfReader::initializeReadMode(), ossimKakaduNitfReader::initializeReadMode(), initializeReadMode(), ossimOpjNitfReader::scanForJpegBlockOffsets(), and scanForJpegBlockOffsets().
protected |
Definition at line 516 of file ossimNitfTileSource.h.
Referenced by allocate(), getOutputScalarType(), initializeCacheTile(), initializeScalarType(), and initializeSwapBytesFlag().
protected |
Definition at line 526 of file ossimNitfTileSource.h.
protected |
Definition at line 517 of file ossimNitfTileSource.h.
Referenced by ossimKakaduNitfReader::initializeSwapBytesFlag(), and initializeSwapBytesFlag().
protected |
Definition at line 511 of file ossimNitfTileSource.h.
Referenced by allocate(), ossimKakaduNitfReader::allocateBuffers(), destroy(), getTile(), initializeOutputTile(), loadBlockFromCache(), loadTile(), ossimKakaduNitfReader::setMaxPixelValue(), ossimKakaduNitfReader::setMinPixelValue(), and ossimKakaduNitfReader::setNullPixelValue().
