This class defines an abstract Handler which all image handlers(loaders) should derive from. More...
#include <ossimBandSeparateHandler.h>
| ossimBandSeparateHandler () | |
| virtual | ~ossimBandSeparateHandler () |
| Destructor: More... | |
| virtual bool | open () |
| Opens multiple band-files based on info in metadata file. More... | |
| virtual void | close () |
| Closes all band-files and clears input handler list. More... | |
| virtual ossim_uint32 | getNumberOfLines (ossim_uint32 resLevel=0) const |
| virtual ossim_uint32 | getNumberOfSamples (ossim_uint32 resLevel=0) const |
| virtual ossimRefPtr< ossimImageData > | getTile (const ossimIrect &rect, ossim_uint32 resLevel) |
| Fills the requested tile by pulling pixels from multiple file tiles as needed. More... | |
| Returns scalar type of first band (should be the same for all bands) More... | |
| virtual bool | canConnectMyOutputTo (ossim_int32 index, const ossimConnectableObject *obj) |
| Overrides base connection method to connect output of merge source. More... | |
| Returns the geometry of the first band: More... | |
| These images are not tiled. More... | |
| ossimImageHandler () | |
| virtual ossimIrect | getImageRectangle (ossim_uint32 resLevel=0) const |
| template<class T > | |
| virtual | ~ossimSource () |
| ossimObject () | |
| ossimListenerManager () | |
| bool | hasError () const |
| virtual void | getBandFileNames (vector< ossimFilename > &file_names) |
| Fetches the list of band file names from the header file. More... | |
Definition at line 27 of file ossimBandSeparateHandler.h.
| ossimBandSeparateHandler::ossimBandSeparateHandler | ( | ) |
Destructor:
Definition at line 38 of file ossimBandSeparateHandler.cpp.
References close().
Definition at line 204 of file ossimBandSeparateHandler.cpp.
References ossimConnectableObject::canConnectMyOutputTo(), m_mergeSource, and ossimRefPtr< T >::valid().
Definition at line 87 of file ossimBandSeparateHandler.cpp.
References m_bandFiles, and m_mergeSource.
Referenced by open(), and ~ossimBandSeparateHandler().
protectedvirtual |
The header file name is contained in ossimImageHandler::theImageFile. NOTE TO PROGRAMMER: This class is presently tailored to the Ikonos metadata file specifying the individual band files. If other "metadata" formats are to be supported, then this class should be derived from. This method would therefore be pure virtual in this base-class and only this method would need to be implemented in the derived classes.
Definition at line 221 of file ossimBandSeparateHandler.cpp.
References ossimString::after(), ossimString::chars(), ossimString::contains(), ossimFilename::ext(), ossimNotify(), ossimNotifyLevel_WARN, ossimFilename::path(), ossimString::push_back(), ossimFilename::setPath(), ossimString::split(), and ossimImageHandler::theImageFile.
Referenced by open().
Returns the geometry of the first band.
Definition at line 277 of file ossimBandSeparateHandler.cpp.
References m_bandFiles.
inlinevirtual |
Implements ossimImageHandler.
Definition at line 80 of file ossimBandSeparateHandler.h.
inlinevirtual |
Definition at line 79 of file ossimBandSeparateHandler.h.
Returns the number of bands available from the input.
Implements ossimImageSource.
Definition at line 184 of file ossimBandSeparateHandler.cpp.
| resLevel | Reduced resolution level to return lines of. Default = 0 |
Definition at line 135 of file ossimBandSeparateHandler.cpp.
| resLevel | Reduced resolution level to return samples of. Default = 0 |
Definition at line 150 of file ossimBandSeparateHandler.cpp.
Returns scalar type of first tile (should be the same for all tiles)
Definition at line 192 of file ossimBandSeparateHandler.cpp.
References m_bandFiles, and OSSIM_SCALAR_UNKNOWN.
Definition at line 115 of file ossimBandSeparateHandler.cpp.
References ossimBandMergeSource::getTile(), ossimImageSource::getTile(), m_bandFiles, m_mergeSource, ossimImageHandler::theOverview, and ossimRefPtr< T >::valid().
Definition at line 104 of file ossimBandSeparateHandler.cpp.
Definition at line 173 of file ossimBandSeparateHandler.cpp.
References ossimImageHandler::loadState(), and open().
Definition at line 46 of file ossimBandSeparateHandler.cpp.
References close(), ossimImageHandler::completeOpen(), ossimConnectableObject::connectMyInputTo(), ossimRefPtr< T >::get(), getBandFileNames(), ossimImageHandlerRegistry::instance(), isOpen(), m_bandFiles, m_mergeSource, ossimImageHandlerRegistry::open(), ossimNotify(), ossimNotifyLevel_WARN, and ossimRefPtr< T >::valid().
Referenced by loadState().
Definition at line 164 of file ossimBandSeparateHandler.cpp.
References ossimImageHandler::saveState().
protected |
Definition at line 91 of file ossimBandSeparateHandler.h.
Referenced by close(), getImageGeometry(), getNumberOfInputBands(), getNumberOfLines(), getNumberOfSamples(), getOutputScalarType(), getTile(), isOpen(), and open().
protected |
Definition at line 92 of file ossimBandSeparateHandler.h.
Referenced by canConnectMyOutputTo(), close(), getTile(), and open().
